Part Number: TCI6630K2L
Below, the code of a loop .
for(ii = 0; ii < len_words; ii++)
src1 = _amemd8(pdSrc++);
src2 = _amemd8(pdSrc2++);
_amemd8(pdDst++) = src1;
_amemd8(pdDst2++) = src2;
The software pipeline information for this loop is,
;* SOFTWARE PIPELINE INFORMATION
;* Loop found in file : C:/Users/Lekha/workspac_Tarana_Optimiz/Source/memcopy.c
;* Loop source line : 43
;* Loop opening brace source line : 44
;* Loop closing brace source line : 49
;* Known Minimum Trip Count : 1
;* Known Max Trip Count Factor : 1
;* Loop Carried Dependency Bound(^) : 0
;* Unpartitioned Resource Bound : 2
;* Partitioned Resource Bound(*) : 2
;* Resource Partition:
;* A-side B-side
;* .L units 0 0
;* .S units 0 0
;* .D units 2* 2*
;* .M units 0 0
;* .X cross paths 0 0
;* .T address paths 2* 2*
;* Long read paths 0 0
;* Long write paths 0 0
;* Logical ops (.LS) 0 0 (.L or .S unit)
;* Addition ops (.LSD) 0 0 (.L or .S or .D unit)
;* Bound(.L .S .LS) 0 0
;* Bound(.L .S .D .LS .LSD) 1 1
;* Searching for software pipeline schedule at ...
;* ii = 2 Schedule found with 3 iterations in parallel
;* Done
;* Loop will be splooped
;* Collapsed epilog stages : 0
;* Collapsed prolog stages : 0
;* Minimum required memory pad : 0 bytes
;* Minimum safe trip count : 1
$C$L1: ; PIPED LOOP PROLOG
SPLOOP 2 ;6 ; (P)
|| MV .L2X A4,B6
$C$L2: ; PIPED LOOP KERNEL
$C$DW$L$t_memcpy$3$B:
LDDW .D2T2 *B6++,B5:B4 ; |47| (P) <0,0>
|| LDDW .D1T1 *A3++,A5:A4 ; |48| (P) <0,0>
NOP 2
SPMASK L1
|| MV .L1 A7,A6
NOP 1
SPKERNEL 2,0
|| STDW .D2T2 B5:B4,*B7++ ; |47| <0,5>
|| STDW .D1T1 A5:A4,*A6++ ; |48| <0,5>
$C$DW$L$t_memcpy$3$E:
$C$L3: ; PIPED LOOP EPILOG
in software pipeline information showing as 2 cycles, but its taking 21 cycles for one iteration.I am not understanding here what is problem?
Thanks & regards,
Raj Bhavani.
