Compiler: Compiler crash
Other Parts Discussed in Thread: TM4C129ENCPDT, CODECOMPOSER
Not sure, if I am on the right forum, but I got the following message:
Invoking: ARM Compiler
"C:/TI/ccsv8/tools/compiler/ti-cgt-arm_18.12.0.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="D:/SVN-repository_CodeComposer/workspace/Cortex-M4/brennenstuhl/matrixSSL_core" --include_path="C:/TI/ccsv8/tools/compiler/ti-cgt-arm_18.12.0.LTS/include" --include_path="D:/SVN-repository_CodeComposer/workspace/Cortex-M4/brennenstuhl/matrixSSL_core/matrixssl-4-0-1/core/config" --include_path="D:/SVN-repository_CodeComposer/workspace/Cortex-M4/brennenstuhl/matrixSSL_core/matrixssl-4-0-1/core/include" --include_path="D:/SVN-repository_CodeComposer/workspace/Cortex-M4/brennenstuhl/matrixSSL_core/matrixssl-4-0-1/core/include/sfzcl" --include_path="D:/SVN-repository_CodeComposer/workspace/Cortex-M4/brennenstuhl/matrixSSL_core/matrixssl-4-0-1/core/osdep/include" --define=ccs="ccs" --define=PART_TM4C129ENCPDT --define=TARGET_IS_TM4C129_RA2 --define=PS_UNSUPPORTED_OS --define=NO_MULTITHREADING --define=__CC_ARM -g --c99 --diag_warning=225 -k --asm_listing --c_src_interlist --preproc_with_compile --preproc_dependency="matrixssl-4-0-1/core/src/sfzcltimemeasure.d_raw" --obj_directory="matrixssl-4-0-1/core/src"  "../matrixssl-4-0-1/core/src/sfzcltimemeasure.c"
>> Compilation failure
matrixssl-4-0-1/core/src/subdir_rules.mk:9: recipe for target 'matrixssl-4-0-1/core/src/sfzcltimemeasure.obj' failed
>> ../matrixssl-4-0-1/core/src/sfzcltimemeasure.c, line 245:
               INTERNAL ERROR: no match for PLUS
This may be a serious problem.  Please contact customer support with a
description of this problem and a sample of the source files that caused this
INTERNAL ERROR message to appear.
Cannot continue compilation - ABORTING!
I am trying to compile the matrixSSL stack 4.0.1
    You are.
    For the source file sfzcltimemeasure.c, please follow the directions in the article How to Submit a Compiler Test Case.  That test case will allow me to reproduce the problem, and then submit a bug report to the compiler development team.
    Thanks and regards,
    -George
  • Hi George,
    something is wrong with your interface. If I try to attach a text file as shown in the video, this text entry window changes into some "media view" and I cannot enter any text anymore. So I just copy it into this window. I hope this works.
    I have reduced the original file to an absolute minimum...
    These are the compiler options plus the compiler output:
    ---------------------------------------------------8<--------------------------------------------------
    "C:/TI/ccsv8/tools/compiler/ti-cgt-arm_18.12.0.LTS/bin/armcl" -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me --include_path="D:/SVN-repository_CodeComposer/workspace/Cortex-M4/brennenstuhl" --include_path="C:/TI/ccsv8/tools/compiler/ti-cgt-arm_18.12.0.LTS/include" --include_path="C:/TI/TivaWare_C_Series-2.1.4.178" --include_path="D:/SVN-repository_CodeComposer/workspace/Cortex-M4/brennenstuhl/matrixssl-4-0-1/core/config" --include_path="D:/SVN-repository_CodeComposer/workspace/Cortex-M4/brennenstuhl/matrixssl-4-0-1/core/include" --include_path="D:/SVN-repository_CodeComposer/workspace/Cortex-M4/brennenstuhl/matrixssl-4-0-1/core/include/sfzcl" --include_path="D:/SVN-repository_CodeComposer/workspace/Cortex-M4/brennenstuhl/matrixssl-4-0-1/core/osdep/include" --define=ccs="ccs" --define=__CC_ARM --define=PART_TM4C129ENCPDT --define=TARGET_IS_TM4C129_RA2 --define=PS_UNSUPPORTED_OS --define=NO_MULTITHREADING -g --c99 --preproc_with_comment --preproc_with_compile --diag_warning=225 -k --asm_listing --c_src_interlist --obj_directory="core/src"  "D:/SVN-repository_CodeComposer/workspace/Cortex-M4/brennenstuhl/matrixssl-4-0-1/core/src/sfzcltimemeasure.c"
    >> Compilation failure
    core/src/subdir_rules.mk:205: recipe for target 'core/src/sfzcltimemeasure.obj' failed
    >> D:/SVN-repository_CodeComposer/workspace/Cortex-M4/brennenstuhl/matrixssl-4-0-1/core/src/sfzcltimemeasure.c, line 16:
    gmake: *** [core/src/sfzcltimemeasure.obj] Error 1
    This is the generated pp-file, which I could not attach:
    /* STDINT.H        */
    /* Copyright (c) 2002 Texas Instruments Incorporated                         */
    /* www.ti.com/                                                        */
    /*  Redistribution and  use in source  and binary forms, with  or without    */
    /*  modification,  are permitted provided  that the  following conditions    */
    /*  are met:        */
    /*     Redistributions  of source  code must  retain the  above copyright    */
    /*     notice, this list of conditions and the following disclaimer.         */
    /*     Redistributions in binary form  must reproduce the above copyright    */
    /*     notice, this  list of conditions  and the following  disclaimer in    */
    /*     the  documentation  and/or   other  materials  provided  with  the    */
    /*     distribution.                                                         */
    /*     Neither the  name of Texas Instruments Incorporated  nor the names    */
    /*     of its  contributors may  be used to  endorse or  promote products    */
    /*     derived  from   this  software  without   specific  prior  written    */
    /*     permission.                                                           */
    /*  THIS SOFTWARE  IS PROVIDED BY THE COPYRIGHT  HOLDERS AND CONTRIBUTORS    */
    /*  "AS IS"  AND ANY  EXPRESS OR IMPLIED  WARRANTIES, INCLUDING,  BUT NOT    */
    /*  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR    */
    /*  A PARTICULAR PURPOSE ARE DISCLAIMED.  IN NO EVENT SHALL THE COPYRIGHT    */
    /*  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,    */
    /*  SPECIAL,  EXEMPLARY,  OR CONSEQUENTIAL  DAMAGES  (INCLUDING, BUT  NOT    */
    /*  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,    */
    /*  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY    */
    /*  THEORY OF  LIABILITY, WHETHER IN CONTRACT, STRICT  LIABILITY, OR TORT    */
    /*  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE    */
    /*  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.     */
    /* _STDINT40.H                                                               */
    /* Copyright (c) 2018 Texas Instruments Incorporated                         */
    /* www.ti.com/                                                        */
    /*  are met:        */
    /*     distribution.                                                         */
    /*     permission.                                                           */
       According to footnotes in the 1999 C standard, "C++ implementations
       should define these macros only when __STDC_LIMIT_MACROS is defined
       before <stdint.h> is included."
     * SPDX-License-Identifier: BSD-2-Clause-FreeBSD
     * Copyright (c) 2001 Mike Barcroft <mike@FreeBSD.org>
     * All rights reserved.
     * are met:
     * 1. Redistributions of source code must retain the above copyright
     * 2. Redistributions in binary form must reproduce the above copyright
     *    notice, this list of conditions and the following disclaimer in the
     *    documentation and/or other materials provided with the distribution.
     * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
     * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
     * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
     * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
     * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
     * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
     * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
     * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
     * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
     * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
     * SUCH DAMAGE.
     * $FreeBSD$
     * SPDX-License-Identifier: BSD-3-Clause
     * Copyright (c) 1991, 1993
     *    The Regents of the University of California.  All rights reserved.
     * This code is derived from software contributed to Berkeley by
     * Berkeley Software Design, Inc.
     * are met:
     * 3. Neither the name of the University nor the names of its contributors
     *    may be used to endorse or promote products derived from this software
     *    without specific prior written permission.
     * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
     * ARE DISCLAIMED.  IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
     * SUCH DAMAGE.
     *    @(#)cdefs.h    8.8 (Berkeley) 1/9/95
     * $FreeBSD$
    #pragma diag_push
    #pragma CHECK_MISRA("none")
     * Testing against Clang-specific extensions.
     * This code has been put in place to help reduce the addition of
     * compiler specific defines in FreeBSD code.  It helps to aid in
     * having a compiler-agnostic source tree.
     * Macro to test if we're using a specific version of gcc or later.
     * The __CONCAT macro is used to concatenate parts of symbol names, e.g.
     * with "#define OLD(foo) __CONCAT(old,foo)", OLD(foo) produces oldfoo.
     * The __CONCAT macro is a bit tricky to use if it must work in non-ANSI
     * mode -- there must be no spaces between its arguments, and for nested
     * __CONCAT's, all the __CONCAT's must be at the left.  __CONCAT can also
     * concatenate double-quoted strings produced by the __STRING macro, but
     * this only works with ANSI C.
     * __XSTRING is like __STRING, but it expands any macros in its argument
     * first.  It is only available with ANSI C.
     * Compiler-dependent macros to help declare dead (non-returning) and
     * pure (no side effects) functions, and unused variables.  They are
     * null except for versions of gcc that are known to support the features
     * properly (old versions of gcc-2 supported the dead and pure features
     * in a different (wrong) way).  If we do not provide an implementation
     * for a given compiler, let the compile fail if it is told to use
     * a feature that we cannot live without.
     * TI ADD - check that __GNUC__ is defined before referencing it to avoid
     *          generating an error when __GNUC__ treated as zero warning is
     *          promoted to an error via -pdse195 option.
     * Keywords added in C11.
     * XXX: Some compilers (Clang 3.3, GCC 4.7) falsely announce C++11 mode
     * without actually supporting the thread_local keyword. Don't check for
     * the presence of C++11 when defining _Thread_local.
     * Emulation of C11 _Generic().  Unlike the previously defined C11
     * keywords, it is not possible to implement this using exactly the same
     * syntax.  Therefore implement something similar under the name
     * __generic().  Unlike _Generic(), this macro can only distinguish
     * between a single type, so it requires nested invocations to
     * distinguish multiple cases.
     * C99 Static array indices in function parameter declarations.  Syntax such as:
     * void bar(int myArray[static 10]);
     * is allowed in C99 but not in C++.  Define __min_size appropriately so
     * headers using it can be compiled in either language.  Use like this:
     * void bar(int myArray[__min_size(10)]);
    /* XXX: should use `#if __STDC_VERSION__ < 199901'. */
    /* C++11 exposes a load of C99 stuff */
     * GCC 2.95 provides `__restrict' as an extension to C90 to support the
     * C99-specific `restrict' type qualifier.  We happen to use `__restrict' as
     * a way to define the `restrict' type qualifier without disturbing older
     * software that is unaware of C99 keywords.
     * The TI compiler supports __restrict in all compilation modes.
     * GNU C version 2.96 adds explicit branch prediction so that
     * the CPU back-end can hint the processor and also so that
     * code blocks can be reordered such that the predicted path
     * sees a more linear flow, thus improving cache behavior, etc.
     * The following two macros provide us with a way to utilize this
     * compiler feature.  Use __predict_true() if you expect the expression
     * to evaluate to true, and __predict_false() if you expect the
     * expression to evaluate to false.
     * A few notes about usage:
     *    * Generally, __predict_false() error condition checks (unless
     *      you have some _strong_ reason to do otherwise, in which case
     *      document it), and/or __predict_true() `no-error' condition
     *      checks, assuming you want to optimize for the no-error case.
     *    * Other than that, if you don't know the likelihood of a test
     *      succeeding from empirical or other `hard' evidence, don't
     *      make predictions.
     *    * These are meant to be used in places that are run `a lot'.
     *      It is wasteful to make predictions in code that is run
     *      seldomly (e.g. at subsystem initialization time) as the
     *      basic block reordering that this affects can often generate
     *      larger code.
     * We define this here since <stddef.h>, <sys/queue.h>, and <sys/types.h>
     * require it.
     * Given the pointer x to the member m of the struct s, return
     * a pointer to the containing structure.  When using GCC, we first
     * assign pointer x to a local variable, to check that its type is
     * compatible with member m.
     * Compiler-dependent macros to declare that functions take printf-like
     * or scanf-like arguments.  They are null except for versions of gcc
     * that are known to support the features properly (old versions of gcc-2
     * didn't permit keeping the keywords out of the application namespace).
    /* Compiler-dependent macros that rely on FreeBSD-specific extensions. */
     * The following definition might not work well if used in header files,
     * but it should be better than nothing.  If you want a "do nothing"
     * version, then it should generate some harmless declaration, such as:
     *    #define    __IDSTRING(name,string)    struct __hack
     * Embed the rcs id of a source file in the resulting library.  Note that in
     * more recent ELF binutils, we use .ident allowing the ID to be stripped.
     * Usage:
     *    __FBSDID("$FreeBSD$");
     * The following definitions are an extension of the behavior originally
     * implemented in <sys/_posix.h>, but with a different level of granularity.
     * POSIX.1 requires that the macros we test be defined before any standard
     * header file is included.
     * Here's a quick run-down of the versions:
     *  defined(_POSIX_SOURCE)        1003.1-1988
     *  _POSIX_C_SOURCE == 1        1003.1-1990
     *  _POSIX_C_SOURCE == 2        1003.2-1992 C Language Binding Option
     *  _POSIX_C_SOURCE == 199309        1003.1b-1993
     *  _POSIX_C_SOURCE == 199506        1003.1c-1995, 1003.1i-1995,
     *                    and the omnibus ISO/IEC 9945-1: 1996
     *  _POSIX_C_SOURCE == 200112        1003.1-2001
     *  _POSIX_C_SOURCE == 200809        1003.1-2008
     * In addition, the X/Open Portability Guide, which is now the Single UNIX
     * Specification, defines a feature-test macro which indicates the version of
     * that specification, and which subsumes _POSIX_C_SOURCE.
     * Our macros begin with two underscores to avoid namespace screwage.
    /* Deal with IEEE Std. 1003.1-1990, in which _POSIX_C_SOURCE == 1. */
    /* Deal with IEEE Std. 1003.2-1992, in which _POSIX_C_SOURCE == 2. */
    /* Deal with various X/Open Portability Guides and Single UNIX Spec. */
     * Deal with all versions of POSIX.  The ordering relative to the tests above is
     * important.
     * Deal with _ANSI_SOURCE:
     * If it is defined, and no other compilation environment is explicitly
     * requested, then define our internal feature-test macros to zero.  This
     * makes no difference to the preprocessor (undefined symbols in preprocessing
     * expressions are defined to have value zero), but makes it more convenient for
     * a test program to print out the values.
     * If a program mistakenly defines _ANSI_SOURCE and some other macro such as
     * _POSIX_C_SOURCE, we will assume that it wants the broader compilation
     * environment (and in fact we will never get here).
    /* User override __EXT1_VISIBLE */
     * Old versions of GCC use non-standard ARM arch symbols; acle-compat.h
     * translates them to __ARM_ARCH and the modern feature symbols defined by ARM.
     * Nullability qualifiers: currently only supported by Clang.
     * Type Safety Checking
     * Clang provides additional attributes to enable checking type safety
     * properties that cannot be enforced by the C type system.
     * Lock annotations.
     * Clang provides support for doing basic thread-safety tests at
     * compile-time, by marking which locks will/should be held when
     * entering/leaving a functions.
     * Furthermore, it is also possible to annotate variables and structure
     * members to enforce that they are only accessed when certain locks are
     * held.
    /* Structure implements a lock. */
    /* Function acquires an exclusive or shared lock. */
    /* Function attempts to acquire an exclusive or shared lock. */
    /* Function releases a lock. */
    /* Function asserts that an exclusive or shared lock is held. */
    /* Function requires that an exclusive or shared lock is or is not held. */
    /* Function should not be analyzed. */
    /* Guard variables and structure members by lock. */
    #pragma diag_pop
     * Copyright (c) 2002 Mike Barcroft <mike@FreeBSD.org>
     * are met:
     * SUCH DAMAGE.
     * $FreeBSD$
     * SPDX-License-Identifier: BSD-4-Clause
     * Copyright (c) 1990, 1993
     * are met:
     * 3. All advertising materials mentioning features or use of this software
     *    must display the following acknowledgement:
     *    This product includes software developed by the University of
     *    California, Berkeley and its contributors.
     * 4. Neither the name of the University nor the names of its contributors
     * SUCH DAMAGE.
     * $FreeBSD$
    #pragma diag_push
    /* This file is required to use base types */
    #pragma CHECK_MISRA("-6.3")
     * Basic types upon which most other types are built.
    typedef    signed char        __int8_t;
    typedef    unsigned char        __uint8_t;
    typedef    short            __int16_t;
    typedef    unsigned short        __uint16_t;
    typedef    int            __int32_t;
    typedef    unsigned int        __uint32_t;
    /* LONGLONG */
    typedef    long long        __int64_t;
    /* LONGLONG */
    typedef    unsigned long long    __uint64_t;
     * Standard type definitions.
    typedef    __uint32_t    __clock_t;        /* clock()... */
    typedef    __int32_t    __critical_t;
    typedef    double        __double_t;
    typedef    float        __float_t;
    typedef    __int32_t    __intfptr_t;
    typedef    __int64_t    __intmax_t;
    typedef    __int32_t    __intptr_t;
    typedef    __int32_t    __int_fast8_t;
    typedef    __int32_t    __int_fast16_t;
    typedef    __int32_t    __int_fast32_t;
    typedef    __int64_t    __int_fast64_t;
    typedef    __int8_t    __int_least8_t;
    typedef    __int16_t    __int_least16_t;
    typedef    __int32_t    __int_least32_t;
    typedef    __int64_t    __int_least64_t;
    typedef    __int32_t    __ptrdiff_t;        /* ptr1 - ptr2 */
    typedef    __int32_t    __register_t;
    typedef    __int32_t    __segsz_t;        /* segment size (in pages) */
    typedef    __uint32_t    __size_t;        /* sizeof() */
    typedef    __int32_t    __ssize_t;        /* byte count or error */
    typedef __uint32_t      __time_t;
    typedef    __uint32_t    __uintfptr_t;
    typedef    __uint64_t    __uintmax_t;
    typedef    __uint32_t    __uintptr_t;
    typedef    __uint32_t    __uint_fast8_t;
    typedef    __uint32_t    __uint_fast16_t;
    typedef    __uint32_t    __uint_fast32_t;
    typedef    __uint64_t    __uint_fast64_t;
    typedef    __uint8_t    __uint_least8_t;
    typedef    __uint16_t    __uint_least16_t;
    typedef    __uint32_t    __uint_least32_t;
    typedef    __uint64_t    __uint_least64_t;
    typedef    __uint32_t    __u_register_t;
    typedef    __uint32_t    __vm_offset_t;
    typedef    __uint32_t    __vm_paddr_t;
    typedef    __uint32_t    __vm_size_t;
    typedef    unsigned short ___wchar_t;
     * Unusual type definitions.
    typedef struct __va_list_t {
        void * __ap;
    } __va_list;
    #pragma diag_pop
    #pragma diag_push
    /* This file is required to use types without size and signedness */
    typedef    __int32_t    __blksize_t;    /* file block size */
    typedef    __int64_t    __blkcnt_t;    /* file block count */
    typedef    __int32_t    __clockid_t;    /* clock_gettime()... */
    typedef    __uint32_t    __fflags_t;    /* file flags */
    typedef    __uint64_t    __fsblkcnt_t;
    typedef    __uint64_t    __fsfilcnt_t;
    typedef    __uint32_t    __gid_t;
    typedef    __int64_t    __id_t;        /* can hold a gid_t, pid_t, or uid_t */
    typedef    __uint64_t    __ino_t;    /* inode number */
    typedef    long        __key_t;    /* IPC key (for Sys V IPC) */
    typedef    __int32_t    __lwpid_t;    /* Thread ID (a.k.a. LWP) */
    typedef    __uint16_t    __mode_t;    /* permissions */
    typedef    int        __accmode_t;    /* access permissions */
    typedef    int        __nl_item;
    typedef    __uint64_t    __nlink_t;    /* link count */
    typedef    __int64_t    __off_t;    /* file offset */
    typedef    __int64_t    __off64_t;    /* file offset (alias) */
    typedef    __int32_t    __pid_t;    /* process [group] */
    typedef    __int64_t    __rlim_t;    /* resource limit - intentionally */
                        /* signed, because of legacy code */
                        /* that uses -1 for RLIM_INFINITY */
    typedef    __uint8_t    __sa_family_t;
    typedef    __uint32_t    __socklen_t;
    typedef    long        __suseconds_t;    /* microseconds (signed) */
    typedef    struct __timer    *__timer_t;    /* timer_gettime()... */
    typedef    struct __mq    *__mqd_t;    /* mq_open()... */
    typedef    __uint32_t    __uid_t;
    typedef    unsigned int    __useconds_t;    /* microseconds (unsigned) */
    typedef    int        __cpuwhich_t;    /* which parameter for cpuset. */
    typedef    int        __cpulevel_t;    /* level parameter for cpuset. */
    typedef int        __cpusetid_t;    /* cpuset identifier. */
     * rune_t is declared to be an ``int'' instead of the more natural
     * ``unsigned long'' or ``long''.  Two things are happening here.  It is not
     * unsigned so that EOF (-1) can be naturally assigned to it and used.  Also,
     * it looks like 10646 will be a 31 bit standard.  This means that if your
     * ints cannot hold 32 bits, you will be in trouble.  The reason an int was
     * chosen over a long is that the is*() and to*() routines take ints (says
     * ANSI C), but they use __ct_rune_t instead of int.
     * NOTE: rune_t is not covered by ANSI nor other standards, and should not
     * be instantiated outside of lib/libc/locale.  Use wchar_t.  wint_t and
     * rune_t must be the same type.  Also, wint_t should be able to hold all
     * members of the largest character set plus one extra value (WEOF), and
     * must be at least 16 bits.
    typedef    int        __ct_rune_t;    /* arg type for ctype funcs */
    typedef    __ct_rune_t    __rune_t;    /* rune_t (see above) */
    typedef    __ct_rune_t    __wint_t;    /* wint_t (see above) */
    /* Clang already provides these types as built-ins, but only in C++ mode. */
    typedef    __uint_least16_t __char16_t;
    typedef    __uint_least32_t __char32_t;
    /* In C++11, char16_t and char32_t are built-in types. */
    typedef struct {
        long long __max_align1 __attribute__((aligned(__alignof__(long long))));
        long double __max_align2 __attribute__((aligned(__alignof__(long double))));
    } __max_align_t;
    typedef    __uint64_t    __dev_t;    /* device number */
    typedef    __uint32_t    __fixpt_t;    /* fixed point number */
     * mbstate_t is an opaque object to keep conversion state during multibyte
     * stream conversions.
    typedef int _Mbstatet;
    typedef _Mbstatet __mbstate_t;
    typedef __uintmax_t     __rman_res_t;
     * When the following macro is defined, the system uses 64-bit inode numbers.
     * Programs can use this to avoid including <sys/param.h>, with its associated
     * namespace pollution.
    #pragma diag_pop
     * SPDX-License-Identifier: BSD-2-Clause-NetBSD
     * Copyright (c) 2001, 2002 Mike Barcroft <mike@FreeBSD.org>
     * Copyright (c) 2001 The NetBSD Foundation, Inc.
     * This code is derived from software contributed to The NetBSD Foundation
     * by Klaus Klein.
     * are met:
     * THIS SOFTWARE IS PROVIDED BY THE NETBSD FOUNDATION, INC. AND CONTRIBUTORS
     * ``AS IS'' AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
     * TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
     * PURPOSE ARE DISCLAIMED.  IN NO EVENT SHALL THE FOUNDATION OR CONTRIBUTORS
     * BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
     * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
     * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
     * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
     * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
     * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
     * POSSIBILITY OF SUCH DAMAGE.
     * $FreeBSD$
    #pragma diag_push
    /* 19.4 is issued for macros that are defined in terms of other macros. */
    #pragma CHECK_MISRA("-19.4")
     * ISO/IEC 9899:1999
     * 7.18.2.1 Limits of exact-width integer types
    /* Minimum values of exact-width signed integer types. */
    /* Maximum values of exact-width signed integer types. */
    /* Maximum values of exact-width unsigned integer types. */
     * ISO/IEC 9899:1999
     * 7.18.2.2  Limits of minimum-width integer types
    /* Minimum values of minimum-width signed integer types. */
    /* Maximum values of minimum-width signed integer types. */
    /* Maximum values of minimum-width unsigned integer types. */
     * ISO/IEC 9899:1999
     * 7.18.2.3  Limits of fastest minimum-width integer types
    /* Minimum values of fastest minimum-width signed integer types. */
    /* Maximum values of fastest minimum-width signed integer types. */
    /* Maximum values of fastest minimum-width unsigned integer types. */
     * ISO/IEC 9899:1999
     * 7.18.2.4  Limits of integer types capable of holding object pointers
     * ISO/IEC 9899:1999
     * 7.18.2.5  Limits of greatest-width integer types
     * ISO/IEC 9899:1999
     * 7.18.3  Limits of other integer types
    /* Limits of ptrdiff_t. */
    /* Limits of sig_atomic_t. */
    /* Limit of size_t. */
    /* Limits of wint_t. */
    #pragma diag_pop
     * Copyright (c) 2011 David E. O'Brien <obrien@FreeBSD.org>
     * are met:
     * SUCH DAMAGE.
     * $FreeBSD$
    typedef    __int8_t        int8_t;
    typedef    __int16_t        int16_t;
    typedef    __int32_t        int32_t;
    typedef    __int64_t        int64_t;
    typedef    __uint8_t        uint8_t;
    typedef    __uint16_t        uint16_t;
    typedef    __uint32_t        uint32_t;
    typedef    __uint64_t        uint64_t;
    typedef    __intptr_t        intptr_t;
    typedef    __uintptr_t        uintptr_t;
    typedef    __intmax_t        intmax_t;
    typedef    __uintmax_t        uintmax_t;
    typedef    __int_least8_t        int_least8_t;
    typedef    __int_least16_t        int_least16_t;
    typedef    __int_least32_t        int_least32_t;
    typedef    __int_least64_t        int_least64_t;
    typedef    __uint_least8_t        uint_least8_t;
    typedef    __uint_least16_t    uint_least16_t;
    typedef    __uint_least32_t    uint_least32_t;
    typedef    __uint_least64_t    uint_least64_t;
    typedef    __int_fast8_t        int_fast8_t;
    typedef    __int_fast16_t        int_fast16_t;
    typedef    __int_fast32_t        int_fast32_t;
    typedef    __int_fast64_t        int_fast64_t;
    typedef    __uint_fast8_t        uint_fast8_t;
    typedef    __uint_fast16_t        uint_fast16_t;
    typedef    __uint_fast32_t        uint_fast32_t;
    typedef    __uint_fast64_t        uint_fast64_t;
    /* GNU and Darwin define this and people seem to think it's portable */
    #pragma diag_push
    /* Limits of wchar_t. */
    #pragma diag_pop
    /* ISO/IEC 9899:2011 K.3.4.4 */
     * Copyright (c) 2000 Jeroen Ruigrok van der Werven <asmodai@FreeBSD.org>
     * Copyright (c) 2014-2014 Texas Instruments Incorporated
     * are met:
     * SUCH DAMAGE.
     * $FreeBSD: release/10.0.0/include/stdbool.h 228878 2011-12-25 20:15:41Z ed $
    typedef int64_t SfzclTimeT;
    SfzclTimeT sfzcl_time_measure_get(int32_t granularity)
        uint64_t seconds = 0;
        uint32_t nanoseconds = 0;
        switch (granularity)
        case 0: //SFZCL_TIME_GRANULARITY_MICROSECOND:
            return ((((SfzclTimeT) (seconds))) *
                    (SfzclTimeT) 1000000) + (((SfzclTimeT) nanoseconds) /
                                             (SfzclTimeT) 1000);
        default:
            return (SfzclTimeT) 0;
    Klaus
  • Thank you for submitting a test case.  I am able to reproduce the same behavior.  I filed CODEGEN-5775 in the SDOWP system to have this investigated.  You are welcome to follow it with the SDOWP link below in my signature.
    I'm sorry about that.  I've never seen that before.  So, the file you tried to attach, it has the extension .txt?  Which browser do you use?
    Thanks and regards,
    -George
  • Hi, I am using FireFox 64.0.2 (64Bit)
    Klaus
  • When you attached the file, exactly how did you do it?  Did you click-and-drag the file over from some file browser view?
    Thanks and regards,
    -George
  • Hi Klaus,
    I have a workaround for you until the bug is resolved.  If you save the result of the division in a temporary variable and use that as the second input to the addition in the below code snippet, the program should compile.  Please let me know if this works for you.
    Anna Youssefi, Codegen Group
        SfzclTimeT tmp;
           tmp = ((SfzclTimeT) nanoseconds) /  ((SfzclTimeT) 1000);
            return (((SfzclTimeT) seconds) * ((SfzclTimeT) 1000000)) +  tmp;
        default:
  • Hi Anna,
    thanks a lot, that's the solution I also used. I opened this posting just to notify this bug...
    About he previous quesition about how I tried to add the source code to the posting, I am sorry. I really don't remember how I did it.
    Klaus
