I raised this issue previously on another thread
Upon installing the latest CCS v8.x to a new laptop and rebuilding my application from CCS v7.x I started to get Flash ECC errors whenever I wrote to a RAM variable through the debug server interface. This only occurs when I build with the latest compiler that ships with v8.x; install and specify the earlier CCS v7.x packaged compilers and my application runs OK. We are at production release so I will continue to just use the earlier compiler. But in parallel I need to identify the root cause.
Previous version was TI 16.9.0 LTS, I installed 16.9.10 and it works well. Version 18.1.4 throws the Flash ECC errors.
Thanks in advance for paths to identifying root cause. Any known differences in the compiler would be of interest.
