  • TI Thinks Resolved
CCS/AM5718: CortexA15_0: AutoRun: Target not run as the symbol "main" is not defined
Guru 15930 points
Anonymous
Anonymous
Part Number: AM5718
When I am trying to load my code on AM5718 evm. i don't get any error. but there is  a message on my console like
what is the reason for this?
  • Guru 310715 points
    Does you program have a 'main' in it? If not, that would explain the message. After loading the code, the debugger will try to auto-run to 'main'. If there is no 'main' to be reached, that error will occur and the target will be left running. You can disable the auto-run in the debugger options (or specify a new label to run to):
    software-dl.ti.com/.../ccs_debug-main.html
    ki
    Did you read the CCS Forum Guidelines & FAQ? If not, PLEASE read it. If you haven't read it in awhile, please read it again to see if any updates were made.
    Having CCS problems? Check out the CCS Troubleshooting Guide
    Looking for CCS Training/Documentation? Check out the CCS Resources page
    Curious about the status of a bug and know the tracking ID? Track it via the public bug tracking portal
    NOTE: When a bug is filed and a tracking ID is provided, the thread may then be suggested as "TI Thinks Resolved". Why? Please read the first FAQ of the CCS Forum Guidelines & FAQ
