Part Number: MSP-EXP432P401R
Hi, I want to test out empty_MSP_EXP432P401R_tirtos_ccs project mentioned in http://dev.ti.com/tirex/#/?link=Software%2FSimpleLink%20MSP432P4%20SDK%2FSimpleLink%20Academy%2FTI%20Drivers%2FConfiguring%20TI%20Drivers with newly installed CCS 8.3 version. But after the hammer button was clicked just after the project was imported, the console will output:
Buildfile generation error occurred.. Cannot build project. Referenced RTSC Configuration project 'tirtos_builds_MSP_EXP432P401R_release_ccs' contains build-errors. Build stopped..
And when I do this at second and third time, there will be more output.
**** Clean-only build of configuration Debug for project empty_MSP_EXP432P401R_tirtos_ccs **** "D:\\Program Files\\ti\\ccsv8\\utils\\bin\\gmake" -k -j 8 clean -O DEL /F "empty_MSP_EXP432P401R_tirtos_ccs.hex" "empty_MSP_EXP432P401R_tirtos_ccs.out" DEL /F "MSP_EXP432P401R.obj" "empty.obj" "main_tirtos.obj" DEL /F "MSP_EXP432P401R.d" "empty.d" "main_tirtos.d" Cannot find D:\test\empty_MSP_EXP432P401R_tirtos_ccs\Debug\empty_MSP_EXP432P401R_tirtos_ccs.hex Cannot find D:\test\empty_MSP_EXP432P401R_tirtos_ccs\Debug\MSP_EXP432P401R.obj Cannot find D:\test\empty_MSP_EXP432P401R_tirtos_ccs\Debug\MSP_EXP432P401R.d Finished clean **** Build Finished **** Buildfile generation error occurred.. Cannot build project. Referenced RTSC Configuration project 'tirtos_builds_MSP_EXP432P401R_release_ccs' contains build-errors. Build stopped..
I have tried this process several times and with different workspaces, but things have never worked. Also I noticed IDE seems call DEL command to remove these later not found files. I failed to find similar issues on the web so I am here to ask for suggestion. Thanks.
