CCS/LAUNCHXL-CC26X2R1: CCS crashes every second debug session
Part Number: LAUNCHXL-CC26X2R1
Hi
I have been using CCS with the cc26x2 Launch pad and the BLE5 SDK v1.3. It has been working fine so far but since a few days CCS keeps crashing whenever I start the second debug session. The first one runs without a problem.
There might have been a probe update before it started happening but I am uncertain about this.
Best regards
# A fatal error has been detected by the Java Runtime Environment:
#  EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x6e80a604, pid=6540, tid=0x00001b40
# JRE version: Java(TM) SE Runtime Environment (8.0_112-b15) (build 1.8.0_112-b15)
# Java VM: Java HotSpot(TM) Client VM (25.112-b15 mixed mode windows-x86 )
# Problematic frame:
# C  0x6e80a604
# Failed to write core dump. Minidumps are not enabled by default on client versions of Windows
# If you would like to submit a bug report, please visit:
#   http://bugreport.java.com/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
---------------  T H R E A D  ---------------
Current thread (0x39a89c00):  JavaThread "polling thread" daemon [_thread_in_native, id=6976, stack(0x41c60000,0x41d60000)]
siginfo: ExceptionCode=0xc0000005, ExceptionInformation=0x00000008 0x6e80a604
Registers:
EAX=0x41d5e044, EBX=0xe000edfc, ECX=0x4b0f68c0, EDX=0x6e806540
ESP=0x41d5e024, EBP=0x41d5e05c, ESI=0x4d3388d0, EDI=0x4b13f88c
EIP=0x6e80a604, EFLAGS=0x00010293
Top of Stack: (sp=0x41d5e024)
0x41d5e024:   5f457d5a 41d5e044 e000edfc 00000004
0x41d5e034:   00000000 4ceb77a8 4d3388d0 41d5e470
0x41d5e044:   00000000 41d5e0b0 41d5e058 5f3f607f
0x41d5e054:   41d5e0b0 41d5e064 41d5e084 5f48eae3
0x41d5e064:   e000edfc 00000000 41d5e0a0 5f4c8978
0x41d5e074:   41d5e0e4 5f4c8978 00000000 4245e780
0x41d5e084:   41d5e0a8 5f485dd2 0000edfc 41d5e0a0
0x41d5e094:   5f4c8978 4245e780 00000000 00000000
Instructions: (pc=0x6e80a604)
0x6e80a5e4:   00 00 00 00 40 00 00 00 30 a8 80 6e 00 00 00 00
0x6e80a5f4:   20 00 00 00 00 00 00 00 54 f9 81 6e 8c a7 80 6e
0x6e80a604:   00 00 00 00 34 00 00 00 00 00 00 00 54 f9 81 6e
0x6e80a614:   8c a7 80 6e 00 00 00 00 00 00 00 00 02 00 00 00
Register to memory mapping:
EAX=0x41d5e044 is pointing into the stack for thread: 0x39a89c00
EBX=0xe000edfc is an unknown value
ECX=0x4b0f68c0 is an unknown value
EDX=0x6e806540 is an unknown value
ESP=0x41d5e024 is pointing into the stack for thread: 0x39a89c00
EBP=0x41d5e05c is pointing into the stack for thread: 0x39a89c00
ESI=0x4d3388d0 is an unknown value
EDI=0x4b13f88c is an unknown value
Stack: [0x41c60000,0x41d60000],  sp=0x41d5e024,  free space=1016k
Native frames: (J=compiled Java code, j=interpreted, Vv=VM code, C=native code)
C  0x6e80a604
C  0x5f48eae3
C  0x5f485dd2
C  0x5f4643ad
C  0x5f45a1fe
C  0x5f41dd12
C  0x5f434bfb
C  0x5f434123
C  0x5f42d1f6
C  0x6e839c3c
C  0x67eb2907
C  0x67d9a304
C  0x67d82c3b
C  0x67d988b2
C  0x67d757fe
C  0x67d734ce
C  0x67d650f2
C  0x67d65a87
C  0x67d6589c
C  0x67d74c79
C  0x67d75cba
C  0x67c3dc81
C  0x67bb0e4d
C  0x67bafb7a
C  0x67baf94e
C  0x67ba6d8b
C  0x67bdeda8
C  0x67bdc987
C  0x67bcc29f
C  0x67ca08ff
C  0x67c9c9d2
C  0x67c9c24f
C  0x67c9cda8
C  0x67b7e70a
C  0x67b7933d
C  [ti_xpcom.dll+0xe751]
C  0x00000001
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j  com.ti.xpcom.internal.XPCOMJavaProxy.callXPCOMMethod(JLjava/lang/String;[Ljava/lang/Object;)Ljava/lang/Object;+0
j  com.ti.xpcom.internal.XPCOMJavaProxy.invoke(Ljava/lang/Object;Ljava/lang/reflect/Method;[Ljava/lang/Object;)Ljava/lang/Object;+107
j  com.sun.proxy.$Proxy21.pollThreadMain()V+9
j  com.ti.debug.engine.cce.CCEDebugEngine$1.run()V+10
j  java.lang.Thread.run()V+11
v  ~StubRoutines::call_stub
---------------  P R O C E S S  ---------------
Java Threads: ( => current thread )
  0x40ec0800 JavaThread "AWT-Shutdown" [_thread_blocked, id=2504, stack(0x4df90000,0x4e090000)]
  0x38e63800 JavaThread "pool-10-thread-1" [_thread_blocked, id=4272, stack(0x4c660000,0x4c760000)]
  0x40ec4000 JavaThread "Thread-58" daemon [_thread_in_native, id=2628, stack(0x4b890000,0x4b990000)]
  0x40ec3400 JavaThread "JSON response handler: DeviceDetector" daemon [_thread_blocked, id=6204, stack(0x4c1c0000,0x4c2c0000)]
  0x40ec1400 JavaThread "WebSocket response handler: DeviceDetector" daemon [_thread_in_native, id=6880, stack(0x4bf90000,0x4c090000)]
  0x38e64000 JavaThread "com.ti.ccstudio.debug.debugModel - 1" [_thread_in_native, id=1512, stack(0x4bd60000,0x4be60000)]
  0x34ec9800 JavaThread "Thread-49" [_thread_in_native, id=2080, stack(0x4cab0000,0x4cbb0000)]
  0x39979000 JavaThread "org.eclipse.cdt.internal.ui.text.CReconciler" daemon [_thread_blocked, id=524, stack(0x4c9b0000,0x4cab0000)]
  0x40933400 JavaThread "SystemAnalyzer.stringQueue" [_thread_blocked, id=6960, stack(0x4dd50000,0x4de50000)]
  0x38e63400 JavaThread "arm properties event broadcaster" daemon [_thread_blocked, id=3900, stack(0x4c830000,0x4c930000)]
  0x34ec7c00 JavaThread "JSON response handler: DeviceDetector" daemon [_thread_blocked, id=6720, stack(0x4a7d0000,0x4a8d0000)]
  0x34ec8400 JavaThread "WebSocket response handler: DeviceDetector" daemon [_thread_in_native, id=6684, stack(0x4af90000,0x4b090000)]
  0x40d85000 JavaThread "Provisioning Event Dispatcher" daemon [_thread_blocked, id=6604, stack(0x45890000,0x45990000)]
  0x34eca400 JavaThread "JxBrowser Executor - 6" [_thread_blocked, id=2896, stack(0x45da0000,0x45ea0000)]
  0x34ecb000 JavaThread "pool-1-thread-2" [_thread_blocked, id=4080, stack(0x44bc0000,0x44cc0000)]
  0x40d46c00 JavaThread "JxBrowser Executor - 5" [_thread_blocked, id=4472, stack(0x45190000,0x45290000)]
  0x40d47400 JavaThread "pool-1-thread-1" [_thread_blocked, id=4852, stack(0x44f70000,0x45070000)]
  0x40932000 JavaThread "websocket thread" daemon [_thread_in_native, id=6032, stack(0x4ad30000,0x4ae30000)]
  0x40d86800 JavaThread "JSON response handler: Agent" [_thread_blocked, id=6052, stack(0x4ae40000,0x4af40000)]
  0x40d86400 JavaThread "WebSocket response handler: Agent" [_thread_in_native, id=6048, stack(0x4abe0000,0x4ace0000)]
  0x40d85c00 JavaThread "JxBrowser Executor - 4" [_thread_blocked, id=6264, stack(0x4aa20000,0x4ab20000)]
  0x40d85800 JavaThread "JxBrowser Executor - 3" [_thread_blocked, id=6220, stack(0x4a8e0000,0x4a9e0000)]
  0x40d4a400 JavaThread "JxBrowser Executor - 1" [_thread_blocked, id=2920, stack(0x4a4e0000,0x4a5e0000)]
  0x40d4a000 JavaThread "qtp2972830-111" [_thread_blocked, id=7140, stack(0x49ec0000,0x49fc0000)]
  0x40d49400 JavaThread "qtp2972830-109" [_thread_blocked, id=3016, stack(0x4a140000,0x4a240000)]
  0x40d48c00 JavaThread "qtp2972830-108" [_thread_blocked, id=2688, stack(0x49fe0000,0x4a0e0000)]
  0x40d48400 JavaThread "Scheduler-24281435" [_thread_blocked, id=5328, stack(0x49960000,0x49a60000)]
  0x40d48000 JavaThread "D3D Screen Updater" daemon [_thread_blocked, id=6324, stack(0x49750000,0x49850000)]
  0x34ecb800 JavaThread "TimerQueue" daemon [_thread_blocked, id=6020, stack(0x48d90000,0x48e90000)]
  0x34eca800 JavaThread "AWT-Windows" daemon [_thread_in_native, id=5060, stack(0x45f50000,0x46050000)]
  0x34ec9c00 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=3308, stack(0x45ba0000,0x45ca0000)]
  0x38e62c00 JavaThread "IPC Async Events Thread" [_thread_blocked, id=6472, stack(0x44a60000,0x44b60000)]
  0x38e62400 JavaThread "Memory Writer SocketInfo{cid=0, bid=-1, channelType=Main}" [_thread_blocked, id=5544, stack(0x44910000,0x44a10000)]
  0x39a8a000 JavaThread "Socket Connection Checker SocketInfo{cid=0, bid=-1, channelType=Main}" [_thread_in_native, id=4620, stack(0x43da0000,0x43ea0000)]
  0x38e62000 JavaThread "IPC Memory Reader Thread" [_thread_in_native, id=4228, stack(0x44720000,0x44820000)]
  0x38e61800 JavaThread "Chromium Process Logger" daemon [_thread_in_native, id=7128, stack(0x44450000,0x44550000)]
  0x38e61400 JavaThread "IPC Process Thread" daemon [_thread_in_native, id=4792, stack(0x44340000,0x44440000)]
  0x375a4800 JavaThread "IPC Server Thread" daemon [_thread_in_native, id=4020, stack(0x44070000,0x44170000)]
  0x39a8d400 JavaThread "Worker-21" [_thread_blocked, id=2816, stack(0x43580000,0x43680000)]
  0x39a8cc00 JavaThread "Worker-20" [_thread_blocked, id=6572, stack(0x43470000,0x43570000)]
  0x39a8c800 JavaThread "Worker-19" [_thread_blocked, id=7040, stack(0x42ef0000,0x42ff0000)]
  0x39a8c000 JavaThread "Worker-18" [_thread_blocked, id=6632, stack(0x43180000,0x43280000)]
  0x39a8bc00 JavaThread "Worker-17" [_thread_blocked, id=6788, stack(0x43050000,0x43150000)]
  0x39a8b400 JavaThread "Worker-16" [_thread_blocked, id=7052, stack(0x42db0000,0x42eb0000)]
  0x39a8ac00 JavaThread "Worker-15" [_thread_blocked, id=6152, stack(0x42b50000,0x42c50000)]
  0x39a8a800 JavaThread "DVT Disk Space Monitor" [_thread_blocked, id=2456, stack(0x41f60000,0x42060000)]
=>0x39a89c00 JavaThread "polling thread" daemon [_thread_in_native, id=6976, stack(0x41c60000,0x41d60000)]
  0x3997a800 JavaThread "qtp2972830-52-acceptor-0@1bb0b59-ServerConnector@17cee9e{HTTP/1.1,[http/1.1]}{127.0.0.1:50842}" [_thread_in_native, id=4712, stack(0x407d0000,0x408d0000)]
  0x39979c00 JavaThread "qtp2972830-50" [_thread_blocked, id=7104, stack(0x404e0000,0x405e0000)]
  0x39979800 JavaThread "qtp2972830-49" [_thread_in_native, id=5548, stack(0x402a0000,0x403a0000)]
  0x39978800 JavaThread "qtp2972830-47" [_thread_blocked, id=2720, stack(0x400e0000,0x401e0000)]
  0x39977c00 JavaThread "qtp2972830-45" [_thread_in_native, id=5684, stack(0x3fc30000,0x3fd30000)]
  0x39977800 JavaThread "Scripting Console - Rhino" [_thread_blocked, id=6924, stack(0x3f5a0000,0x3f6a0000)]
  0x39977000 JavaThread "Timer-0" [_thread_blocked, id=4208, stack(0x3f3b0000,0x3f4b0000)]
  0x375aac00 JavaThread "Worker-14" [_thread_blocked, id=6600, stack(0x3e8f0000,0x3e9f0000)]
  0x375aa800 JavaThread "Worker-13" [_thread_blocked, id=6640, stack(0x3e630000,0x3e730000)]
  0x375aa000 JavaThread "Worker-12" [_thread_blocked, id=1388, stack(0x3e000000,0x3e100000)]
  0x375a9c00 JavaThread "Worker-11" [_thread_blocked, id=1996, stack(0x3e510000,0x3e610000)]
  0x375a9400 JavaThread "Worker-10" [_thread_blocked, id=5324, stack(0x3e2e0000,0x3e3e0000)]
  0x375a8c00 JavaThread "Worker-9" [_thread_blocked, id=6592, stack(0x3e180000,0x3e280000)]
  0x375a8800 JavaThread "Worker-8" [_thread_blocked, id=4024, stack(0x3d8e0000,0x3d9e0000)]
  0x375a8000 JavaThread "Worker-7" [_thread_blocked, id=3180, stack(0x3dc10000,0x3dd10000)]
  0x375a7c00 JavaThread "Worker-6" [_thread_blocked, id=3584, stack(0x3da20000,0x3db20000)]
  0x375a7400 JavaThread "Worker-5" [_thread_blocked, id=6780, stack(0x3d6a0000,0x3d7a0000)]
  0x375a7000 JavaThread "Worker-4" [_thread_blocked, id=5844, stack(0x3d5a0000,0x3d6a0000)]
  0x375a6800 JavaThread "Worker-3" [_thread_blocked, id=268, stack(0x3d350000,0x3d450000)]
  0x375a6000 JavaThread "Worker-2" [_thread_blocked, id=1096, stack(0x3d240000,0x3d340000)]
  0x375a5c00 JavaThread "Worker-1" [_thread_blocked, id=6824, stack(0x3d140000,0x3d240000)]
  0x375a5400 JavaThread "EventAdmin Async Event Dispatcher Thread" daemon [_thread_blocked, id=3028, stack(0x3ce90000,0x3cf90000)]
  0x375a5000 JavaThread "org.eclipse.cdt.internal.ui.text.CReconciler" daemon [_thread_blocked, id=6996, stack(0x3cb10000,0x3cc10000)]
  0x375a4400 JavaThread "xpcom dispose thread" daemon [_thread_blocked, id=6308, stack(0x3c1c0000,0x3c2c0000)]
  0x375a3c00 JavaThread "Bundle File Closer" daemon [_thread_blocked, id=2332, stack(0x39e30000,0x39f30000)]
  0x3732e400 JavaThread "EMF Reference Cleaner" daemon [_thread_blocked, id=5832, stack(0x38700000,0x38800000)]
  0x37284000 JavaThread "Worker-0" [_thread_blocked, id=6488, stack(0x38590000,0x38690000)]
  0x36ea5400 JavaThread "Worker-JM" [_thread_blocked, id=5820, stack(0x379d0000,0x37ad0000)]
  0x3639dc00 JavaThread "SCR Component Actor" daemon [_thread_blocked, id=4304, stack(0x36cc0000,0x36dc0000)]
  0x36360000 JavaThread "Framework Event Dispatcher: org.eclipse.osgi.internal.framework.EquinoxEventPublisher@c7a078" daemon [_thread_blocked, id=2888, stack(0x36ae0000,0x36be0000)]
  0x36334000 JavaThread "Start Level: Equinox Container: 8d8dd9b8-4db7-4153-93c3-2b0a3bafe86c" daemon [_thread_blocked, id=4856, stack(0x36900000,0x36a00000)]
  0x362f7800 JavaThread "Active Thread: Equinox Container: 8d8dd9b8-4db7-4153-93c3-2b0a3bafe86c" [_thread_blocked, id=2648, stack(0x366d0000,0x367d0000)]
  0x34e53800 JavaThread "Service Thread" daemon [_thread_blocked, id=3012, stack(0x35c50000,0x35d50000)]
  0x34e4e400 JavaThread "C1 CompilerThread0" daemon [_thread_blocked, id=6228, stack(0x35a60000,0x35b60000)]
  0x34e4d000 JavaThread "Attach Listener" daemon [_thread_blocked, id=6252, stack(0x354a0000,0x355a0000)]
  0x34e4a800 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=6384, stack(0x357d0000,0x358d0000)]
  0x34e37400 JavaThread "Finalizer" daemon [_thread_blocked, id=5760, stack(0x355f0000,0x356f0000)]
  0x34e11400 JavaThread "Reference Handler" daemon [_thread_blocked, id=5508, stack(0x35390000,0x35490000)]
  0x027bd000 JavaThread "main" [_thread_in_native, id=2948, stack(0x002b0000,0x003b0000)]
Other Threads:
  0x34e0a800 VMThread [stack: 0x35010000,0x35110000] [id=7048]
  0x34e5c400 WatcherThread [stack: 0x35900000,0x35a00000] [id=1348]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap:
 def new generation   total 153408K, used 35003K [0x04800000, 0x0ee70000, 0x14800000)
  eden space 136384K,  24% used [0x04800000, 0x06810790, 0x0cd30000)
  from space 17024K,  12% used [0x0ddd0000, 0x0dfee578, 0x0ee70000)
  to   space 17024K,   0% used [0x0cd30000, 0x0cd30000, 0x0ddd0000)
 tenured generation   total 340308K, used 236620K [0x14800000, 0x29455000, 0x34800000)
   the space 340308K,  69% used [0x14800000, 0x22f130c0, 0x22f13200, 0x29455000)
 Metaspace       used 76367K, capacity 81729K, committed 81920K, reserved 82304K
Card table byte_map: [0x34800000,0x34990000] byte_map_base: 0x347dc000
Polling page: 0x001d0000
CodeCache: size=32768Kb used=11935Kb max_used=13417Kb free=20832Kb
 bounds [0x027c0000, 0x03508000, 0x047c0000]
 total_blobs=5856 nmethods=5537 adapters=243
 compilation: enabled
Compilation events (10 events):
Event: 276.002 Thread 0x34e4e400 30199             org.eclipse.ui.internal.CoolBarToTrimManager::getOverridenVisibility (23 bytes)
Event: 276.002 Thread 0x34e4e400 nmethod 30199 0x029cc908 code [0x029cca20, 0x029ccaf8]
Event: 276.006 Thread 0x34e4e400 30200             org.eclipse.jface.action.MenuManager::update (595 bytes)
Event: 276.008 Thread 0x34e4e400 nmethod 30200 0x02c76308 code [0x02c76720, 0x02c77864]
Event: 276.010 Thread 0x34e4e400 30201             org.eclipse.swt.widgets.Scrollable::callWindowProc (18 bytes)
Event: 276.010 Thread 0x34e4e400 nmethod 30201 0x029cc6c8 code [0x029cc7d0, 0x029cc88c]
Event: 276.011 Thread 0x34e4e400 30202             org.eclipse.swt.widgets.EventTable::hook (141 bytes)
Event: 276.011 Thread 0x34e4e400 nmethod 30202 0x032807c8 code [0x03280900, 0x03280de8]
Event: 276.013 Thread 0x34e4e400 30203             org.eclipse.swt.internal.win32.OS::GetWindowLong (18 bytes)
Event: 276.013 Thread 0x34e4e400 nmethod 30203 0x029cc4c8 code [0x029cc5c0, 0x029cc63c]
GC Heap History (10 events):
Event: 273.710 GC heap before
{Heap before GC invocations=296 (full 10):
 def new generation   total 153408K, used 139343K [0x04800000, 0x0ee70000, 0x14800000)
  eden space 136384K, 100% used [0x04800000, 0x0cd30000, 0x0cd30000)
  from space 17024K,  17% used [0x0cd30000, 0x0d013fa0, 0x0ddd0000)
  to   space 17024K,   0% used [0x0ddd0000, 0x0ddd0000, 0x0ee70000)
 tenured generation   total 340308K, used 235120K [0x14800000, 0x29455000, 0x34800000)
   the space 340308K,  69% used [0x14800000, 0x22d9c130, 0x22d9c200, 0x29455000)
 Metaspace       used 76363K, capacity 81724K, committed 81920K, reserved 82304K
Event: 273.721 GC heap after
Heap after GC invocations=297 (full 10):
 def new generation   total 153408K, used 2951K [0x04800000, 0x0ee70000, 0x14800000)
  eden space 136384K,   0% used [0x04800000, 0x04800000, 0x0cd30000)
  from space 17024K,  17% used [0x0ddd0000, 0x0e0b1df8, 0x0ee70000)
 tenured generation   total 340308K, used 235554K [0x14800000, 0x29455000, 0x34800000)
   the space 340308K,  69% used [0x14800000, 0x22e08888, 0x22e08a00, 0x29455000)
Event: 274.046 GC heap before
{Heap before GC invocations=297 (full 10):
 def new generation   total 153408K, used 139335K [0x04800000, 0x0ee70000, 0x14800000)
Event: 274.055 GC heap after
Heap after GC invocations=298 (full 10):
 def new generation   total 153408K, used 2573K [0x04800000, 0x0ee70000, 0x14800000)
  from space 17024K,  15% used [0x0cd30000, 0x0cfb3430, 0x0ddd0000)
 tenured generation   total 340308K, used 235862K [0x14800000, 0x29455000, 0x34800000)
   the space 340308K,  69% used [0x14800000, 0x22e55a50, 0x22e55c00, 0x29455000)
Event: 274.372 GC heap before
{Heap before GC invocations=298 (full 10):
 def new generation   total 153408K, used 138957K [0x04800000, 0x0ee70000, 0x14800000)
Event: 274.382 GC heap after
Heap after GC invocations=299 (full 10):
 def new generation   total 153408K, used 2347K [0x04800000, 0x0ee70000, 0x14800000)
  from space 17024K,  13% used [0x0ddd0000, 0x0e01ace8, 0x0ee70000)
 tenured generation   total 340308K, used 236129K [0x14800000, 0x29455000, 0x34800000)
   the space 340308K,  69% used [0x14800000, 0x22e98428, 0x22e98600, 0x29455000)
Event: 274.717 GC heap before
{Heap before GC invocations=299 (full 10):
 def new generation   total 153408K, used 138731K [0x04800000, 0x0ee70000, 0x14800000)
Event: 274.726 GC heap after
Heap after GC invocations=300 (full 10):
 def new generation   total 153408K, used 2588K [0x04800000, 0x0ee70000, 0x14800000)
  from space 17024K,  15% used [0x0cd30000, 0x0cfb7000, 0x0ddd0000)
 tenured generation   total 340308K, used 236156K [0x14800000, 0x29455000, 0x34800000)
   the space 340308K,  69% used [0x14800000, 0x22e9f278, 0x22e9f400, 0x29455000)
Event: 275.054 GC heap before
{Heap before GC invocations=300 (full 10):
 def new generation   total 153408K, used 138972K [0x04800000, 0x0ee70000, 0x14800000)
Event: 275.064 GC heap after
Heap after GC invocations=301 (full 10):
 def new generation   total 153408K, used 2169K [0x04800000, 0x0ee70000, 0x14800000)
Deoptimization events (0 events):
No events
Internal exceptions (10 events):
Event: 274.633 Thread 0x375a7c00 Exception <a 'java/lang/ArrayIndexOutOfBoundsException': 1> (0x0a6f27a0) thrown at [C:\re\workspace\8-2-build-windows-i586-cygwin\jdk8u112\7884\hotspot\src\share\vm\interpreter\interpreterRuntime.cpp, line 366]
Event: 274.633 Thread 0x375a7c00 Exception <a 'java/lang/ArrayIndexOutOfBoundsException': 6> (0x0a6f4c20) thrown at [C:\re\workspace\8-2-build-windows-i586-cygwin\jdk8u112\7884\hotspot\src\share\vm\interpreter\interpreterRuntime.cpp, line 366]
Event: 274.634 Thread 0x375a7c00 Exception <a 'java/lang/ArrayIndexOutOfBoundsException': 1> (0x0a6f8490) thrown at [C:\re\workspace\8-2-build-windows-i586-cygwin\jdk8u112\7884\hotspot\src\share\vm\interpreter\interpreterRuntime.cpp, line 366]
Event: 274.634 Thread 0x375a7c00 Exception <a 'java/lang/ArrayIndexOutOfBoundsException': 3> (0x0a6fa1b8) thrown at [C:\re\workspace\8-2-build-windows-i586-cygwin\jdk8u112\7884\hotspot\src\share\vm\interpreter\interpreterRuntime.cpp, line 366]
Event: 274.634 Thread 0x375a7c00 Exception <a 'java/lang/ArrayIndexOutOfBoundsException': 1> (0x0a6fb400) thrown at [C:\re\workspace\8-2-build-windows-i586-cygwin\jdk8u112\7884\hotspot\src\share\vm\interpreter\interpreterRuntime.cpp, line 366]
Event: 274.634 Thread 0x375a7c00 Exception <a 'java/lang/ArrayIndexOutOfBoundsException': 6> (0x0a6ffb28) thrown at [C:\re\workspace\8-2-build-windows-i586-cygwin\jdk8u112\7884\hotspot\src\share\vm\interpreter\interpreterRuntime.cpp, line 366]
Event: 274.868 Thread 0x375a7c00 Exception <a 'java/lang/ArrayIndexOutOfBoundsException': 1> (0x084da3e8) thrown at [C:\re\workspace\8-2-build-windows-i586-cygwin\jdk8u112\7884\hotspot\src\share\vm\interpreter\interpreterRuntime.cpp, line 366]
Event: 274.868 Thread 0x375a7c00 Exception <a 'java/lang/ArrayIndexOutOfBoundsException': 1> (0x084dc110) thrown at [C:\re\workspace\8-2-build-windows-i586-cygwin\jdk8u112\7884\hotspot\src\share\vm\interpreter\interpreterRuntime.cpp, line 366]
Event: 274.868 Thread 0x375a7c00 Exception <a 'java/lang/ArrayIndexOutOfBoundsException': 1> (0x084dca20) thrown at [C:\re\workspace\8-2-build-windows-i586-cygwin\jdk8u112\7884\hotspot\src\share\vm\interpreter\interpreterRuntime.cpp, line 366]
Event: 274.868 Thread 0x375a7c00 Exception <a 'java/lang/ArrayIndexOutOfBoundsException': 1> (0x084debd0) thrown at [C:\re\workspace\8-2-build-windows-i586-cygwin\jdk8u112\7884\hotspot\src\share\vm\interpreter\interpreterRuntime.cpp, line 366]
Events (10 events):
Event: 275.976 Thread 0x34e4e400 flushing nmethod 0x02948008
Event: 275.977 Thread 0x34e4e400 flushing nmethod 0x02ac1248
Event: 275.978 Thread 0x34e4e400 flushing nmethod 0x02be5948
Event: 275.978 Thread 0x34e4e400 flushing nmethod 0x02c42a08
Event: 275.978 Thread 0x34e4e400 flushing nmethod 0x02c74a48
Event: 275.978 Thread 0x34e4e400 flushing nmethod 0x02c9bd88
Event: 275.978 Thread 0x34e4e400 flushing nmethod 0x02d22cc8
Event: 275.978 Thread 0x34e4e400 flushing nmethod 0x02db0f48
Event: 275.979 Thread 0x34e4e400 flushing nmethod 0x02e4e008
Event: 275.980 Thread 0x34e4e400 flushing nmethod 0x02f25fc8
Dynamic libraries:
0x00ed0000 - 0x00ede000 	C:\ti\ccsv8\eclipse\ccstudio.exe
0x77bf0000 - 0x77d70000 	C:\Windows\SysWOW64\ntdll.dll
0x75e10000 - 0x75f20000 	C:\Windows\syswow64\kernel32.dll
0x75730000 - 0x75777000 	C:\Windows\syswow64\KERNELBASE.dll
0x75c30000 - 0x75d30000 	C:\Windows\syswow64\USER32.dll
0x76800000 - 0x76890000 	C:\Windows\syswow64\GDI32.dll
0x77780000 - 0x7778a000 	C:\Windows\syswow64\LPK.dll
0x75d70000 - 0x75e0d000 	C:\Windows\syswow64\USP10.dll
0x776d0000 - 0x7777c000 	C:\Windows\syswow64\msvcrt.dll
0x764a0000 - 0x76541000 	C:\Windows\syswow64\ADVAPI32.dll
0x76780000 - 0x76799000 	C:\Windows\SysWOW64\sechost.dll
0x775d0000 - 0x776c0000 	C:\Windows\syswow64\RPCRT4.dll
0x75310000 - 0x75370000 	C:\Windows\syswow64\SspiCli.dll
0x75300000 - 0x7530c000 	C:\Windows\syswow64\CRYPTBASE.dll
0x71f30000 - 0x720ce000 	C:\Windows\WinSxS\x86_microsoft.windows.common-controls_6595b64144ccf1df_6.0.7601.24380_none_2b2053e245779417\COMCTL32.dll
0x767a0000 - 0x767f7000 	C:\Windows\syswow64\SHLWAPI.dll
0x74740000 - 0x74816000 	C:\Windows\system32\MSVCR110.dll
0x76550000 - 0x765b0000 	C:\Windows\system32\IMM32.DLL
0x75b60000 - 0x75c2d000 	C:\Windows\syswow64\MSCTF.dll
0x000f0000 - 0x000fd000 	C:\ti\ccsv8\eclipse\plugins\org.eclipse.equinox.launcher.win32.win32.x86_1.1.551.v20171108-1834\eclipse_1630.dll
0x72160000 - 0x72169000 	C:\Windows\system32\VERSION.dll
0x71360000 - 0x713e0000 	C:\Windows\system32\UxTheme.dll
0x765d0000 - 0x7672f000 	C:\Windows\system32\ole32.dll
0x74370000 - 0x7473e000 	C:\ti\ccsv8\eclipse\jre\bin\client\jvm.dll
0x71de0000 - 0x71de7000 	C:\Windows\system32\WSOCK32.dll
0x75d30000 - 0x75d65000 	C:\Windows\syswow64\WS2_32.dll
0x768e0000 - 0x768e6000 	C:\Windows\syswow64\NSI.dll
0x75060000 - 0x75092000 	C:\Windows\system32\WINMM.dll
0x76730000 - 0x76735000 	C:\Windows\syswow64\PSAPI.DLL
0x74840000 - 0x748ff000 	C:\Windows\system32\MSVCR100.dll
0x75270000 - 0x7527c000 	C:\ti\ccsv8\eclipse\jre\bin\verify.dll
0x75230000 - 0x75251000 	C:\ti\ccsv8\eclipse\jre\bin\java.dll
0x74aa0000 - 0x74ab3000 	C:\ti\ccsv8\eclipse\jre\bin\zip.dll
0x76980000 - 0x775cc000 	C:\Windows\syswow64\SHELL32.dll
0x765c0000 - 0x765cb000 	C:\Windows\syswow64\profapi.dll
0x71490000 - 0x714a7000 	C:\Windows\system32\CRYPTSP.dll
0x71450000 - 0x7148b000 	C:\Windows\system32\rsaenh.dll
0x759a0000 - 0x759b7000 	C:\Windows\syswow64\USERENV.dll
0x74a80000 - 0x74a96000 	C:\ti\ccsv8\eclipse\jre\bin\net.dll
0x71da0000 - 0x71ddc000 	C:\Windows\system32\mswsock.dll
0x74a70000 - 0x74a76000 	C:\Windows\System32\wship6.dll
0x71cc0000 - 0x71cdc000 	C:\Windows\system32\IPHLPAPI.DLL
0x71cb0000 - 0x71cb7000 	C:\Windows\system32\WINNSI.DLL
0x71c40000 - 0x71c4d000 	C:\Windows\system32\dhcpcsvc6.DLL
0x71c20000 - 0x71c32000 	C:\Windows\system32\dhcpcsvc.DLL
0x74a60000 - 0x74a6f000 	C:\ti\ccsv8\eclipse\jre\bin\nio.dll
0x35fc0000 - 0x3602e000 	C:\ti\ccsv8\eclipse\configuration\org.eclipse.osgi\289\0\.cp\swt-win32-4763.dll
0x76400000 - 0x76492000 	C:\Windows\syswow64\OLEAUT32.dll
0x77790000 - 0x7780b000 	C:\Windows\syswow64\comdlg32.dll
0x75120000 - 0x75171000 	C:\Windows\system32\WINSPOOL.DRV
0x75f30000 - 0x76366000 	C:\Windows\syswow64\WININET.dll
0x75780000 - 0x75784000 	C:\Windows\syswow64\api-ms-win-downlevel-user32-l1-1-0.dll
0x76740000 - 0x76744000 	C:\Windows\syswow64\api-ms-win-downlevel-shlwapi-l1-1-0.dll
0x75f20000 - 0x75f24000 	C:\Windows\syswow64\api-ms-win-downlevel-version-l1-1-0.dll
0x75790000 - 0x75793000 	C:\Windows\syswow64\api-ms-win-downlevel-normaliz-l1-1-0.dll
0x765b0000 - 0x765b3000 	C:\Windows\syswow64\normaliz.DLL
0x754c0000 - 0x756f6000 	C:\Windows\syswow64\iertutil.dll
0x75700000 - 0x75705000 	C:\Windows\syswow64\api-ms-win-downlevel-advapi32-l1-1-0.dll
0x75a30000 - 0x75b52000 	C:\Windows\syswow64\CRYPT32.dll
0x75a20000 - 0x75a2c000 	C:\Windows\syswow64\MSASN1.dll
0x71e30000 - 0x71f25000 	C:\Windows\system32\propsys.dll
0x76370000 - 0x763f3000 	C:\Windows\syswow64\CLBCatQ.DLL
0x00290000 - 0x002ad000 	C:\ti\ccsv8\eclipse\configuration\org.eclipse.osgi\289\0\.cp\swt-gdip-win32-4763.dll
0x741d0000 - 0x74362000 	C:\Windows\WinSxS\x86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.7601.24385_none_5c0ad4dfa00a8e0a\gdiplus.dll
0x74090000 - 0x741c1000 	C:\Windows\system32\WindowsCodecs.dll
0x007c0000 - 0x007cc000 	C:\ti\ccsv8\eclipse\configuration\org.eclipse.osgi\106\0\.cp\os\win32\x86\localfile_1_0_0.dll
0x749e0000 - 0x749f7000 	C:\ti\ccsv8\eclipse\configuration\org.eclipse.osgi\111\0\.cp\os\win32\x86\win32refresh.dll
0x74a50000 - 0x74a53000 	C:\Windows\system32\api-ms-win-core-synch-l1-2-0.DLL
0x74a10000 - 0x74a1f000 	C:\ti\ccsv8\eclipse\configuration\org.eclipse.osgi\109\0\.cp\jWinHttp-1.0.0.dll
0x71670000 - 0x716c8000 	C:\Windows\system32\WINHTTP.dll
0x715f0000 - 0x71640000 	C:\Windows\system32\webio.dll
0x74a00000 - 0x74a08000 	C:\Windows\system32\credssp.dll
0x757a0000 - 0x757c7000 	C:\Windows\syswow64\CFGMGR32.dll
0x71400000 - 0x71405000 	C:\Windows\system32\msimg32.dll
0x74ff0000 - 0x7502c000 	C:\Windows\system32\oleacc.dll
0x749b0000 - 0x749de000 	C:\Windows\system32\mlang.dll
0x6ece0000 - 0x6ecee000 	C:\Windows\system32\RpcRtRemote.dll
0x749a0000 - 0x749aa000 	C:\ti\ccsv8\ccs_base\DebugServer\bin\LibraryLoader.dll
0x74010000 - 0x74081000 	C:\Windows\system32\MSVCP140.dll
0x74980000 - 0x74995000 	C:\Windows\system32\VCRUNTIME140.dll
0x74830000 - 0x74834000 	C:\Windows\system32\api-ms-win-crt-runtime-l1-1-0.dll
0x73e50000 - 0x73f30000 	C:\Windows\system32\ucrtbase.DLL
0x74820000 - 0x74823000 	C:\Windows\system32\api-ms-win-core-timezone-l1-1-0.dll
0x74000000 - 0x74003000 	C:\Windows\system32\api-ms-win-core-file-l2-1-0.dll
0x73ff0000 - 0x73ff3000 	C:\Windows\system32\api-ms-win-core-localization-l1-2-0.dll
0x73fe0000 - 0x73fe3000 	C:\Windows\system32\api-ms-win-core-processthreads-l1-1-1.dll
0x73fd0000 - 0x73fd3000 	C:\Windows\system32\api-ms-win-core-file-l1-2-0.dll
0x73fc0000 - 0x73fc4000 	C:\Windows\system32\api-ms-win-crt-string-l1-1-0.dll
0x73fb0000 - 0x73fb3000 	C:\Windows\system32\api-ms-win-crt-heap-l1-1-0.dll
0x73fa0000 - 0x73fa4000 	C:\Windows\system32\api-ms-win-crt-stdio-l1-1-0.dll
0x73f90000 - 0x73f94000 	C:\Windows\system32\api-ms-win-crt-convert-l1-1-0.dll
0x73f80000 - 0x73f83000 	C:\Windows\system32\api-ms-win-crt-locale-l1-1-0.dll
0x73f70000 - 0x73f75000 	C:\Windows\system32\api-ms-win-crt-math-l1-1-0.dll
0x73f60000 - 0x73f65000 	C:\Windows\system32\api-ms-win-crt-multibyte-l1-1-0.dll
0x73f50000 - 0x73f53000 	C:\Windows\system32\api-ms-win-crt-time-l1-1-0.dll
0x73f40000 - 0x73f43000 	C:\Windows\system32\api-ms-win-crt-filesystem-l1-1-0.dll
0x73f30000 - 0x73f33000 	C:\Windows\system32\api-ms-win-crt-environment-l1-1-0.dll
0x73e40000 - 0x73e43000 	C:\Windows\system32\api-ms-win-crt-utility-l1-1-0.dll
0x73df0000 - 0x73e31000 	C:\ti\ccsv8\ccs_base\common\bin\ti_logger.dll
0x73dd0000 - 0x73de6000 	C:\ti\ccsv8\ccs_base\common\bin\CCReg.dll
0x73d20000 - 0x73dcb000 	C:\ti\ccsv8\ccs_base\common\bin\fsutil.dll
0x73ca0000 - 0x73d17000 	C:\ti\ccsv8\ccs_base\common\bin\libusb-1.0.dll
0x70c40000 - 0x70c75000 	C:\ti\ccsv8\ccs_base\common\bin\MiniDump.dll
0x70bf0000 - 0x70c3c000 	C:\Windows\system32\apphelp.dll
0x70a50000 - 0x70be5000 	C:\ti\ccsv8\ccs_base\common\bin\setup_parser.dll
0x6c750000 - 0x6c9e7000 	C:\ti\ccsv8\ccs_base\common\bin\xerces-c_2_8.dll
0x38560000 - 0x38572000 	C:\ti\ccsv8\ccs_base\common\bin\ti_targetdb_parser.dll
0x709f0000 - 0x70a47000 	C:\ti\ccsv8\ccs_base\DebugServer\bin\ti_xpcom.dll
0x70ca0000 - 0x70cb6000 	C:\ti\ccsv8\ccs_base\DebugServer\bin\DirectoryService.dll
0x709b0000 - 0x709ec000 	C:\ti\ccsv8\ccs_base\DebugServer\bin\XPCOMUtility.dll
0x70840000 - 0x709b0000 	C:\Windows\system32\explorerframe.dll
0x6eeb0000 - 0x6eedf000 	C:\Windows\system32\DUser.dll
0x6eb50000 - 0x6ec02000 	C:\Windows\system32\DUI70.dll
0x71430000 - 0x71450000 	C:\ti\ccsv8\eclipse\jre\bin\sunec.dll
0x70820000 - 0x70830000 	C:\Windows\system32\NLAapi.dll
0x70810000 - 0x70820000 	C:\Windows\system32\napinsp.dll
0x6ee00000 - 0x6ee12000 	C:\Windows\system32\pnrpnsp.dll
0x71c60000 - 0x71ca4000 	C:\Windows\system32\DNSAPI.dll
0x70800000 - 0x70808000 	C:\Windows\System32\winrnr.dll
0x6edd0000 - 0x6edf4000 	C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live\WLIDNSP.DLL
0x6eda0000 - 0x6edc1000 	C:\Program Files (x86)\Bonjour\mdnsNSP.dll
0x71d90000 - 0x71d95000 	C:\Windows\System32\wshtcpip.dll
0x6ed90000 - 0x6ed96000 	C:\Windows\system32\rasadhlp.dll
0x6ed50000 - 0x6ed88000 	C:\Windows\System32\fwpuclnt.dll
0x73c90000 - 0x73c9e000 	C:\Users\Malte\AppData\Local\Temp\proxy_vole1617311108646921648.dll
0x70c90000 - 0x70c9a000 	C:\ti\ccsv8\eclipse\jre\bin\management.dll
0x6ee90000 - 0x6eeaa000 	C:\ti\ccsv8\ccs_base\emulation\analysis\bin\cToolsIF.dll
0x6eab0000 - 0x6eb45000 	C:\ti\ccsv8\ccs_base\emulation\analysis\bin\ctools.dll
VM Arguments:
jvm_args: -Dosgi.instance.area.default=@user.home/workspace_v8 -Djxbrowser.ipc.external=true -Dorg.eclipse.equinox.http.jetty.customizer.class=com.ti.ccstudio.gui.composer.http.jetty.MaqettaJettyCustomizer -Dccs.minXDCVersion=3.25.5.1 -Dorg.eclipse.ecf.provider.filetransfer.retrieve.readTimeout=30000 -Dorg.eclipse.ecf.provider.filetransfer.retrieve.closeTimeout=10000 -Dsun.net.client.defaultReadTimeout=30000 -Dsun.net.client.defaultConnectTimeout=10000 -Xms128m -Xmx768m -XX:ErrorFile=C:\Users\Malte\AppData\Local\TEXASI~1\CCS\ti\0\dmp\\hs_err_%p.log
java_command: <unknown>
java_class_path (initial): C:\ti\ccsv8\eclipse\\plugins/org.eclipse.equinox.launcher_1.4.0.v20161219-1356.jar
Launcher Type: generic
Environment Variables:
JAVA_HOME=C:\Program Files\Java\jdk1.7.0_04
PATH=C:\ti\ccsv8\ccs_base\emulation\analysis\bin\..\..\..\common\bin;C:\ti\ccsv8\ccs_base\emulation\analysis\bin\..\..\..\DebugServer\bin;C:\ti\ccsv8\ccs_base\emulation\analysis\bin\ofs;C:\ti\ccsv8\ccs_base\common\bin;C:\ti\ccsv8\ccs_base\common\uscif;C:/ti/ccsv8/eclipse/jre/bin/client;C:/ti/ccsv8/eclipse/jre/bin;C:/ti/ccsv8/eclipse/jre/lib/i386;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Program Files (x86)\Common Files\Microsoft Shared\Windows Live;C:\Program Files (x86)\AMD APP\bin\x86_64;C:\Program Files\Java\jdk1.7.0_04\bin;C:\Program Files (x86)\AMD APP\bin\x86;C:\Program Files (x86)\MiKTeX 2.9\miktex\bin;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static;C:\Program Files (x86)\Intel\OpenCL SDK\2.0\bin\x86;C:\Program Files (x86)\Intel\OpenCL SDK\2.0\bin\x64;C:\Program Files (x86)\AMD\ATI.ACE\Core-Static;C:\Program Files (x86)\PuTTY\;C:\Program Files\Common Files\Microsoft Shared\Windows Live;C:\ti\ccsv8\eclipse;;C:\ti\ccsv8\ccs_base\emulation\analysis\bin\.;C:\ti\ccsv8\ccs_base\emulation\analysis\bin\../xmldb/aet_config;C:\ti\ccsv8\ccs_base\emulation\analysis\bin\../xmldb/trace_config/setup;C:\ti\ccsv8\ccs_base\emulation\analysis\bin\../xmldb/trace_config/devices;C:\ti\ccsv8\ccs_base\emulation\analysis\bin\../../../common/bin;C:\ti\ccsv8\ccs_base\emulation\analysis\bin\../../../common/uscif;C:\ti\ccsv8\ccs_base\emulation\analysis\bin\../../tpi;C:\ti\ccsv8\ccs_base\emulation\drivers
USERNAME=Malte
OS=Windows_NT
PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 42 Stepping 7, GenuineIntel
---------------  S Y S T E M  ---------------
OS: Windows 7 , 64 bit Build 7601 (6.1.7601.24387)
CPU:total 4 (4 cores per cpu, 1 threads per core) family 6 model 42 stepping 7, cmov, cx8, fxsr, mmx, sse, sse2, sse3, ssse3, sse4.1, sse4.2, popcnt, avx, aes, clmul, tsc, tscinvbit
Memory: 4k page, physical 8365492k(3752056k free), swap 16729084k(10966724k free)
vm_info: Java HotSpot(TM) Client VM (25.112-b15) for windows-x86 JRE (1.8.0_112-b15), built on Sep 22 2016 21:03:20 by "java_re" with MS VC++ 10.0 (VS2010)
time: Tue Mar 26 09:21:49 2019
elapsed time: 276 seconds (0d 0h 4m 36s)
