Part Number: MSP432P401R
Is there a configuration option in the PinMux tool that allows changing the generic "board" to a custom string? Making the change manually takes additional time and may result in errors.
Hi Keith,
I want to make sure I understand what you're looking at. Are you using the PinMux tool for MSP432P401R to generate board.c and board.h files that you later use with TI Drivers? You want to change the generated file names to something else, correct?
If so, there is no way to do this in the PinMux tool. The "board.c" and "board.h" names are kind of baked into a lot of areas.
I would also suguest you have a look at the Sysconfig Preview examples in the more recent SDKs. The SysConfig tool makes it easier to configure TI Drivers. The "board" file names are still not configurable here though.
Ki,
To answer your question; yes, board.c and board.h are very generic so I was looking for an easy way to rename them to <board_name>.c and .h. It's not critical as the project itself will be named for the target board.
Your suggestion to use the SysConfig tool looks promising and I've been reading the available documentation for the tool (http://processors.wiki.ti.com/index.php/Category:SysConfig). Also, in the SimpleLink Academy -> SysConfig Tool Basics tutorial, there's mention of a future lab to integrate custom boards.
SysConfig supports all the SimpleLink LaunchPads and many BoosterPacks. Documentation (and a SimpleLink Academy Lab) will be provided in the future to show how to integrate in your custom board(s).
Has this tutorial been written yet? If not, can you provide pointers to any other documentation that might assist in generating a custom board project?
Thanks!
Keith
Hi Keith,
To answer your other documentation questions...
I think the "SDK User Guide's SysConfig" referred to can be found here.
You also appear to have the most recent SimpleLink academy version (v2.40.00.17).
