Compiler/C6000-CGT: 8.3.3 compiler caused functional incorrectness for DSPLIB
Part Number: C6000-CGT
Previous releases of DSPLIB on ti.com were compiled using C6000 7.4.2 code gen tools. From Proc-SDK 5.2, DSPLIB was included in Processor-SDK and was compiled with C6000 8.x  code gen tool.
However, with C6000_8.3.3 code gen tool, following kernels of DSPLIB for C66x were incorrect functionally (failed unit tests) when compiled with -o3 optimization:
DSPF_sp_fftSPxSP, DSPF_sp_ifftSPxSP, DSPF_sp_svd_cmplx.
Attached are CCS projects for these kernels and readme on howDSPF_sp_ifftSPxSP.zipDSPF_sp_svd_cmplx.zip
Here are the steps to reproduce the failures of 3 DSPLIB kernels:
   - DSPF_sp_fftSPxSP,
   - DSPF_sp_ifftSPxSP,
   - DSPF_sp_svd_cmplx
DSPF_sp_fftSPxSP:
1. Import project at: DSPF_sp_fftSPxSP\c66\DSPF_sp_fftSPxSP_66_LE_ELF
2. Set project configuration to Debug, and build project
3. Load DSPF_sp_fftSPxSP\c66\DSPF_sp_fftSPxSP_66_LE_ELF\Debug\DSPF_sp_fftSPxSP_66_LE_ELF.OUT to C66x DSP and run.
CCS console should print the following (cycle numbers may not be exactly the same):
DSPF_sp_fftSPxSP	Iter#: 1	Intrinsic Successful SA Successful 	N = 8	radix = 2	natC: 4292	optC: 1166	SA: 433
DSPF_sp_fftSPxSP	Iter#: 2	Intrinsic Successful SA Successful 	N = 16	radix = 4	natC: 7115	optC: 2246	SA: 835
DSPF_sp_fftSPxSP	Iter#: 3	Intrinsic Successful SA Successful 	N = 32	radix = 2	natC: 17506	optC: 6327	SA: 2320
DSPF_sp_fftSPxSP	Iter#: 4	Intrinsic Successful SA Successful 	N = 64	radix = 4	natC: 32839	optC: 13265	SA: 4902
DSPF_sp_fftSPxSP	Iter#: 5	Intrinsic Successful SA Successful 	N = 128	radix = 2	natC: 81841	optC: 34259	SA: 12639
DSPF_sp_fftSPxSP	Iter#: 6	Intrinsic Successful SA Successful 	N = 256	radix = 4	natC: 158393	optC: 71552	SA: 26428
DSPF_sp_fftSPxSP	Iter#: 7	Intrinsic Successful SA Successful 	N = 512	radix = 2	natC: 384393	optC: 174389	SA: 64253
DSPF_sp_fftSPxSP	Iter#: 8	Intrinsic Successful SA Successful 	N = 1024	radix = 4	natC: 750925	optC: 361993	SA: 133625
Memory:  1216 bytes
Cycles:  12639 (N=128) 26428 (N=256)
4. Change project configuration to Release, and rebuild the project
5. Load DSPF_sp_fftSPxSP\c66\DSPF_sp_fftSPxSP_66_LE_ELF\Release\DSPF_sp_fftSPxSP_66_LE_ELF.OUT to C66x DSP and run.
CCS console should print the following (notice the failure at the second line):
DSPF_sp_fftSPxSP	Iter#: 1	Intrinsic Successful SA Successful 	N = 8	radix = 2	natC: 411	optC: 179	SA: 256
DSPF_sp_fftSPxSP	Iter#: 2	Intrinsic Successful SA Failure  max_pct_diff = 5007338130857002139.091492	N = 16	radix = 4	natC: 576	optC: 207	SA: 213
DSPF_sp_fftSPxSP	Iter#: 3	Intrinsic Successful SA Successful 	N = 32	radix = 2	natC: 1256	optC: 354	SA: 258
DSPF_sp_fftSPxSP	Iter#: 4	Intrinsic Successful SA Successful 	N = 64	radix = 4	natC: 2355	optC: 531	SA: 457
DSPF_sp_fftSPxSP	Iter#: 5	Intrinsic Successful SA Successful 	N = 128	radix = 2	natC: 5530	optC: 1414	SA: 986
DSPF_sp_fftSPxSP	Iter#: 6	Intrinsic Successful SA Successful 	N = 256	radix = 4	natC: 10930	optC: 2731	SA: 1915
DSPF_sp_fftSPxSP	Iter#: 7	Intrinsic Successful SA Successful 	N = 512	radix = 2	natC: 25586	optC: 6250	SA: 4308
DSPF_sp_fftSPxSP	Iter#: 8	Intrinsic Successful SA Successful 	N = 1024	radix = 4	natC: 51038	optC: 12336	SA: 8408
Memory:  2496 bytes
Cycles:  986 (N=128) 1915 (N=256)
DSPF_sp_ifftSPxSP:
Import and build the project with Debug and Release configurations respectively, similarly to DSPF_sp_fftSPxSP.
1. With Debug configuration, program execution generates console output below:
DSPF_sp_ifftSPxSP	Iter#: 1	Intrinsic Successful SA Successful 	N = 8	radix = 2	natC: 4413	optC: 1205	SA: 471
DSPF_sp_ifftSPxSP	Iter#: 2	Intrinsic Successful SA Successful 	N = 16	radix = 4	natC: 7307	optC: 2311	SA: 907
DSPF_sp_ifftSPxSP	Iter#: 3	Intrinsic Successful SA Successful 	N = 32	radix = 2	natC: 17664	optC: 6440	SA: 2454
DSPF_sp_ifftSPxSP	Iter#: 4	Intrinsic Successful SA Successful 	N = 64	radix = 4	natC: 33405	optC: 13488	SA: 5171
DSPF_sp_ifftSPxSP	Iter#: 5	Intrinsic Successful SA Successful 	N = 128	radix = 2	natC: 82393	optC: 34662	SA: 13128
DSPF_sp_ifftSPxSP	Iter#: 6	Intrinsic Successful SA Successful 	N = 256	radix = 4	natC: 160801	optC: 72431	SA: 27451
DSPF_sp_ifftSPxSP	Iter#: 7	Intrinsic Successful SA Successful 	N = 512	radix = 2	natC: 387183	optC: 176077	SA: 66293
DSPF_sp_ifftSPxSP	Iter#: 8	Intrinsic Successful SA Successful 	N = 1024	radix = 4	natC: 762014	optC: 365599	SA: 137716
Memory:  1344 bytes
Cycles:  13128 (N=128) 27451 (N=256)
2. With Release configuration, program execution generates console output below:
DSPF_sp_ifftSPxSP	Iter#: 1	Intrinsic Successful SA Successful 	N = 8	radix = 2	natC: 534	optC: 177	SA: 262
DSPF_sp_ifftSPxSP	Iter#: 2	Intrinsic Successful SA Failure  max_pct_diff = 5007338130857002139.091492	N = 16	radix = 4	natC: 690	optC: 189	SA: 272
DSPF_sp_ifftSPxSP	Iter#: 3	Intrinsic Successful SA Successful 	N = 32	radix = 2	natC: 1398	optC: 306	SA: 296
DSPF_sp_ifftSPxSP	Iter#: 4	Intrinsic Successful SA Successful 	N = 64	radix = 4	natC: 2537	optC: 535	SA: 561
DSPF_sp_ifftSPxSP	Iter#: 5	Intrinsic Successful SA Successful 	N = 128	radix = 2	natC: 5856	optC: 1465	SA: 1066
DSPF_sp_ifftSPxSP	Iter#: 6	Intrinsic Successful SA Successful 	N = 256	radix = 4	natC: 11480	optC: 2888	SA: 2441
DSPF_sp_ifftSPxSP	Iter#: 7	Intrinsic Successful SA Successful 	N = 512	radix = 2	natC: 26840	optC: 6534	SA: 4410
DSPF_sp_ifftSPxSP	Iter#: 8	Intrinsic Successful SA Successful 	N = 1024	radix = 4	natC: 53444	optC: 13142	SA: 10485
Memory:  2688 bytes
Cycles:  1066 (N=128) 2441 (N=256)
DSPF_sp_svd_cmplx:
1. Import project at: DSPF_sp_svd_cmplx\c66\DSPF_sp_svd_cmplx_66_LE_ELF
2. Download MATHLIB 3.1.2.1 from http://software-dl.ti.com/sdoemb/sdoemb_public_sw/mathlib/latest/index_FDS.html and install it
3. Open project DSPF_sp_svd_cmplx_66_LE_ELF, go to Build Settings -> Build -> Variables, and set MATHLIB_INSTALL_DIR to
   MATHLIB 3.1.2.1 installation root folder.
4. Build the project with Debug and Release configurations respectively, similarly to DSPF_sp_fftSPxSP.
5. With Debug configuration, program execution generates console output below:
DSPF_sp_svd_cmplx	Iter#: 0	Result Successful	order= 3x 3	natC: 143512	optC: 45931
DSPF_sp_svd_cmplx	Iter#: 1	Result Successful	order= 4x 2	natC: 79790	optC: 28271
DSPF_sp_svd_cmplx	Iter#: 2	Result Successful	order= 3x 3	natC: 142265	optC: 45497
DSPF_sp_svd_cmplx	Iter#: 3	Result Successful	order= 3x 3	natC: 142769	optC: 45871
DSPF_sp_svd_cmplx	Iter#: 4	Result Successful	order= 3x 3	natC: 140245	optC: 45198
DSPF_sp_svd_cmplx	Iter#: 5	Result Successful	order= 5x 4	natC: 73164	optC: 26094
DSPF_sp_svd_cmplx	Iter#: 6	Result Successful	order= 8x 5	natC: 414471	optC: 147010
DSPF_sp_svd_cmplx	Iter#: 7	Result Successful	order= 5x 5	natC: 71462	optC: 29171
DSPF_sp_svd_cmplx	Iter#: 8	Result Successful	order= 4x 5	natC: 121316	optC: 27559
DSPF_sp_svd_cmplx	Iter#: 9	Result Successful	order= 2x 4	natC: 79745	optC: 23870
DSPF_sp_svd_cmplx	Iter#: 10	Result Successful	order=16x16	natC: 5632326	optC: 1916451
DSPF_sp_svd_cmplx	Iter#: 11	Result Successful	order=32x32	natC: 31444014	optC: 12341916
DSPF_sp_svd_cmplx	Iter#: 12	Result Successful	order=64x64	natC: 208170164	optC: 91753342
Memory:  0 bytes
Cycles:  12341916 (order=32)  91753342 (order=64)
6. With Release configuration, program execution generates console output below:
DSPF_sp_svd_cmplx	Iter#: 0	opt decomp:  orig=4.000000e+00 3.000000e+00  calc=2.901682e+00 4.097286e+00 error=9.831762e-02 9.728622e-02
opt decomp:  orig=6.000000e+00 5.000000e+00  calc=5.133464e+00 5.860123e+00 error=1.334643e-01 1.398768e-01
opt decomp:  orig=1.000000e+01 9.000000e+00  calc=8.964866e+00 1.002669e+01 error=3.513432e-02 2.669334e-02
opt decomp:  orig=1.200000e+01 1.100000e+01  calc=1.097500e+01 1.203735e+01 error=2.500439e-02 3.734875e-02
opt decomp:  orig=1.600000e+01 1.500000e+01  calc=1.502695e+01 1.597042e+01 error=2.695179e-02 2.958012e-02
opt decomp:  orig=0.000000e+00 0.000000e+00  calc=2.897382e-03 -1.086049e-03 error=2.897382e-03 1.086049e-03
Result Failure	order= 3
DSPF_sp_svd_cmplx	Iter#: 1	opt decomp:  orig=3.000000e+00 4.000000e+00  calc=4.038859e+00 2.964571e+00 error=3.885889e-02 3.542852e-02
opt decomp:  orig=7.000000e+00 8.000000e+00  calc=8.020570e+00 6.980567e+00 error=2.056980e-02 1.943254e-02
opt decomp:  orig=1.100000e+01 1.200000e+01  calc=1.200228e+01 1.099657e+01 error=2.282143e-03 3.433228e-03
opt decomp:  orig=1.500000e+01 1.600000e+01  calc=1.598400e+01 1.501256e+01 error=1.600456e-02 1.256084e-02
Result Failure	order= 4
DSPF_sp_svd_cmplx	Iter#: 2	Result Successful	order= 3x 3	natC: 114729	optC: 24938
DSPF_sp_svd_cmplx	Iter#: 3	Result Successful	order= 3x 3	natC: 114739	optC: 24998
DSPF_sp_svd_cmplx	Iter#: 4	Result Successful	order= 3x 3	natC: 112961	optC: 24774
DSPF_sp_svd_cmplx	Iter#: 5	opt decomp:  orig=0.000000e+00 0.000000e+00  calc=-5.656855e+00 -5.656852e+00 error=5.656855e+00 5.656852e+00
Result Failure	order= 5
DSPF_sp_svd_cmplx	Iter#: 6	Result Successful	order= 8x 5	natC: 341907	optC: 63431
DSPF_sp_svd_cmplx	Iter#: 7	Result Successful	order= 5x 5	natC: 43460	optC: 11813
DSPF_sp_svd_cmplx	Iter#: 8	opt decomp:  orig=0.000000e+00 0.000000e+00  calc=-5.656855e+00 -5.656852e+00 error=5.656855e+00 5.656852e+00
DSPF_sp_svd_cmplx	Iter#: 9	Result Successful	order= 2x 4	natC: 63173	optC: 11494
DSPF_sp_svd_cmplx	Iter#: 10	opt decomp:  orig=5.345317e-01 3.086337e-01  calc=6.736217e-01 -9.613143e-02 error=3.649880e-01 6.306632e-01
opt decomp:  orig=1.717277e-01 9.476302e-01  calc=-1.710862e-02 9.526858e-01 error=9.647388e-01 7.809581e-01
opt decomp:  orig=2.264168e-01 7.022309e-01  calc=9.213583e-01 1.006981e+00 error=2.191274e-01 7.805644e-01
opt decomp:  orig=1.246986e-01 4.947661e-01  calc=7.281303e-01 7.588238e-02 error=2.333643e-01 4.881626e-02
opt decomp:  orig=3.896298e-01 8.389539e-02  calc=9.840196e-01 6.467397e-01 error=9.001242e-01 2.571099e-01
opt decomp:  orig=3.680532e-01 2.772301e-01  calc=3.895895e-01 -1.534027e-01 error=1.123593e-01 5.214559e-01
opt decomp:  orig=5.353862e-01 9.834590e-01  calc=1.091957e+00 1.232446e+00 error=1.084980e-01 6.970596e-01
opt decomp:  orig=6.464736e-01 7.656789e-01  calc=9.002686e-03 4.127785e-01 error=7.566762e-01 2.336951e-01
opt decomp:  orig=7.802362e-01 7.671438e-01  calc=6.346341e-01 -1.226493e-01 error=1.325097e-01 9.028854e-01
opt decomp:  orig=1.519211e-01 8.229621e-01  calc=6.530185e-01 3.441887e-01 error=1.699436e-01 1.922676e-01
opt decomp:  orig=3.146763e-01 6.254768e-01  calc=-1.995233e-01 5.356525e-01 error=8.250001e-01 2.209761e-01
opt decomp:  orig=9.172033e-01 3.469039e-01  calc=5.908008e-01 6.356075e-01 error=2.438969e-01 2.815958e-01
opt decomp:  orig=4.011658e-01 5.197607e-01  calc=1.008279e+00 3.441169e-01 error=4.885182e-01 5.704895e-02
opt decomp:  orig=7.854244e-01 6.067690e-01  calc=7.777394e-01 7.605299e-01 error=1.709704e-01 2.489448e-02
opt decomp:  orig=8.699301e-01 9.315470e-01  calc=9.965378e-01 5.573298e-01 error=6.499082e-02 3.126003e-01
opt decomp:  orig=5.818964e-01 7.584155e-01  calc=6.268492e-01 1.052595e+00 error=1.315663e-01 4.706985e-01
opt decomp:  orig=3.556322e-01 3.892331e-01  calc=8.805515e-01 1.533649e+00 error=4.913184e-01 1.178017e+00
opt decomp:  orig=8.269295e-01 2.002319e-01  calc=5.081270e-01 5.852357e-01 error=3.078950e-01 2.416938e-01
opt decomp:  orig=4.635151e-01 4.159063e-01  calc=3.925760e-01 -2.755134e-01 error=2.333024e-02 7.390285e-01
opt decomp:  orig=1.264382e-01 9.791864e-01  calc=5.740923e-01 -4.270523e-01 error=4.050940e-01 5.534905e-01
opt decomp:  orig=9.584643e-01 2.126224e-01  calc=7.625121e-01 7.130163e-01 error=5.498896e-01 2.454481e-01
opt decomp:  orig=4.090396e-01 7.374798e-01  calc=9.346265e-02 5.518734e-03 error=6.440172e-01 4.035209e-01
opt decomp:  orig=7.578967e-01 7.801141e-01  calc=5.286452e-01 6.019846e-01 error=2.514690e-01 1.559120e-01
opt decomp:  orig=2.807703e-02 9.568468e-01  calc=6.185585e-01 -1.667596e-01 error=3.382883e-01 1.948366e-01
opt decomp:  orig=7.569506e-01 3.187353e-01  calc=1.322550e-01 5.682697e-01 error=1.864803e-01 1.886809e-01
opt decomp:  orig=5.895566e-01 2.429884e-01  calc=4.547104e-01 8.814226e-01 error=2.117220e-01 2.918661e-01
opt decomp:  orig=9.560533e-01 4.339732e-02  calc=5.732488e-01 1.535505e+00 error=5.298515e-01 5.794517e-01
opt decomp:  orig=5.935850e-02 3.191321e-01  calc=4.168135e-02 -2.175532e-01 error=2.774507e-01 2.769117e-01
opt decomp:  orig=9.150364e-01 4.418775e-01  calc=3.879997e-01 8.951935e-01 error=5.387777e-02 1.984298e-02
opt decomp:  orig=1.188391e-01 5.722526e-01  calc=5.535980e-01 2.873653e-01 error=1.865453e-02 1.685263e-01
opt decomp:  orig=2.367321e-01 4.958647e-01  calc=3.929330e-01 2.839139e-02 error=1.029318e-01 2.083407e-01
opt decomp:  orig=4.060793e-01 4.769738e-01  calc=5.255923e-01 7.101768e-01 error=4.861856e-02 3.040975e-01
opt decomp:  orig=4.269539e-01 8.730125e-01  calc=8.175417e-01 8.140490e-01 error=5.547076e-02 3.870951e-01
opt decomp:  orig=3.819697e-01 3.582263e-01  calc=2.343700e-01 3.702796e-01 error=1.238563e-01 1.169002e-02
Result Failure	order=64
Memory:  0 bytes
Cycles:  3709381 (order=32)  27881787 (order=64)
to reproduce the problems.
Thanks for your help.
JianzhongDSPF_sp_fftSPxSP.zip
  • Thank you for notifying us of this problem.  I have reproduced the failures you show in the readme.txt.  Through other channels, I have started a conversation about the best way forward.  Once that is settled, I will post a summary here.  For now, I will mark this thread resolved.
    Thanks and regards,
    -George
