Part Number: CC2640R2F
with firefox while ti cloudagent bridge is enabled. + export TI_DS_ENABLE_LOGGING=3
+ TI_DS_ENABLE_LOGGING=3
+ export TI_DS_LOGGING_OUTPUT=/tmp/my.log
+ TI_DS_LOGGING_OUTPUT=/tmp/my.log
+ echo '---./ticloudagent.sh ARGS--- not_chrome '
++ dirname ./ticloudagent.sh
+ pushd .
++ pwd
+ SCRIPTPATH=/opt/ti/ccs901/ccs/ccs_base/cloudagent
+ popd
+ CA_TEMPDIR=/tmp/ticloudagent/
+ CA_UDEV_LINK=/tmp/ticloudagent//libudev.so.0
++ /sbin/ldconfig -p
++ grep 'libudev.so.0 .*64'
+ [[ ! -n libudev.so.0 (libc6,x86-64) => /usr/lib64/libudev.so.0 ]]
+ '[' -z /root ']'
+ '[' -z '' ']'
+ export TMPDIR=/root/.ti/TICloudAgent/tmp
+ TMPDIR=/root/.ti/TICloudAgent/tmp
+ mkdir -p /root/.ti/TICloudAgent/tmp
+ export PATH=/opt/ti/ccsv8/utils/bin:/opt/android-sdk-update-manager/tools:/opt/android-sdk-update-manager/platform-tools:/usr/lib/llvm/8/bin:/usr/lib/llvm/7/bin:/usr/lib/llvm/6/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/opt/bin:/opt/android-sdk-update-manager/tools:/opt/android-sdk-update-manager/platform-tools:.:/root/.fzf/bin:/usr/sbin:/opt/ti/ccs901/ccs/ccs_base/cloudagent/util
+ PATH=/opt/ti/ccsv8/utils/bin:/opt/android-sdk-update-manager/tools:/opt/android-sdk-update-manager/platform-tools:/usr/lib/llvm/8/bin:/usr/lib/llvm/7/bin:/usr/lib/llvm/6/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/opt/bin:/opt/android-sdk-update-manager/tools:/opt/android-sdk-update-manager/platform-tools:.:/root/.fzf/bin:/usr/sbin:/opt/ti/ccs901/ccs/ccs_base/cloudagent/util
+ '[' not_chrome = not_chrome ']'
+ /opt/ti/ccs901/ccs/ccs_base/cloudagent/node /opt/ti/ccs901/ccs/ccs_base/cloudagent/src/main.js
{"port":37683,"version":"4.7"}
root@gentoo:/opt/ti/ccs901/ccs/ccs_base/cloudagent#
2019-05-26T10:56:34.101Z: main: Staring directory = /opt/ti/ccs901/ccs/ccs_base/cloudagent/src
2019-05-26T10:56:34.103Z: Starting Agent!
2019-05-26T10:56:34.171Z: Module( Agent )->Web socket server started!
2019-05-26T10:56:35.961Z: Overridden Proxy =
2019-05-26T10:56:35.982Z: Discovered Module : DeviceDetector
2019-05-26T10:56:35.984Z: Discovered Module : DS
2019-05-26T10:56:35.986Z: Discovered Module : EventBroker
2019-05-26T10:56:36.007Z: Discovered Module : File
2019-05-26T10:56:36.009Z: Discovered Module : Flash
2019-05-26T10:56:36.012Z: rov_server_redirect: looking in: /opt/ti/ccs901/ccs/eclipse/dropins
2019-05-26T10:56:36.012Z: rov_server_redirect: looking in: /opt/ti/ccs901/ccs/eclipse/plugins
2019-05-26T10:56:36.015Z: rov_server_redirect: found: /opt/ti/ccs901/ccs/eclipse/plugins/com.ti.rov_1.0.0.201902251325
2019-05-26T10:56:36.015Z: rov_server_redirect: looking in: /opt/ti/ccs901/ccs/eclipse/Eclipse.app/Contents/Eclipse/dropins
2019-05-26T10:56:36.015Z: rov_server_redirect: looking in: /opt/ti/ccs901/ccs/eclipse/Eclipse.app/Contents/Eclipse/plugins
2019-05-26T10:56:36.016Z: rov_server_redirect: setting XDCTOOLS_JAVA_HOME to /opt/ti/ccs901/ccs/eclipse/jre
2019-05-26T10:56:36.016Z: rov_server_redirect: requiring /opt/ti/ccs901/ccs/eclipse/plugins/com.ti.rov_1.0.0.201902251325/rov_server.js
2019-05-26T10:56:36.029Z: Discovered Module : ROVServer
2019-05-26T10:56:36.145Z: Discovered Module : Serial
2019-05-26T10:56:36.155Z: Discovered Module : TargetSupport
2019-05-26T10:56:36.174Z: Discovered Module : USB-HID
2019-05-26T10:56:36.174Z: Agent main module running on port 37683
root@gentoo:~#
Step 1:
and install the TI Cloud Agent Application
- Help. I already did this
