Other Parts Discussed in Thread: TDA2
Tool/software: Linux
I build PROCESSOR_SDK_VISION_03_07_00_00, and run on TDA2.
I got error, like this
root@dra7xx-evm:/opt/vision_sdk# ./load_ocl_kos.sh
Opened log file: lad.txt
numProcessors = 5 id = 0 baseId = 0
Spawned daemon: /usr/bin/lad_dra7xx
[ 49.855607] CMEMK module: reference Linux version 4.4.84
[ 49.861705] CMEMK Error: Failed to request_mem_region(0xa9000000, 0x4000000)
insmod: ERROR: could not insert module /opt/vision_sdk/cmemk.ko: Bad address
root@dra7xx-evm:/opt/vision_sdk# source vision_sdk_load.sh
[ 2201.875991] DMA: Module install successful, device major num = 241
[ 2201.882434] DRV: Module install successful
insmod: ERROR: could not load module ./bin/cmemk.ko: No such file or directory
./disableDssInterruptsOnA15.sh: line 11: COMMANDS: command not found
./disableDssInterruptsOnA15.sh: line 12: COMMANDS: command not found
./disableDssInterruptsOnA15.sh: line 13: COMMANDS: command not found
./disableDssInterruptsOnA15.sh: line 14: COMMANDS: command not found
./disableDssInterruptsOnA15.sh: line 15: COMMANDS: command not found
./disableDssInterruptsOnA15.sh: line 16: COMMANDS: command not found
./disableDssInterruptsOnA15.sh: line 17: COMMANDS: command not found
./disableDssInterruptsOnA15.sh: line 18: COMMANDS: command not found
./disableDssInterruptsOnA15.sh: line 19: COMMANDS: command not found
updated value is
COMMANDS
### WARNING ###: use the following [read | write | set bit | clear bit | dump] commands at your own risk!
No address check done, may generate:
- bus error (invalid or not accessible <physical address>,
- platform crash/hang (bad <value>).
Read any OMAP memory address (register), given its <physical address> or <name> as listed in TRM.
Write <value> at any OMAP memory address (register), given its <physical address> or <name> as listed in TRM.
Set bit at <position> into any OMAP memory address (register), given its <physical address> or <name> as listed in TRM.
Clear bit at <position> into any OMAP memory address (register), given its <physical address> or <name> as listed in TRM.
Dump a range of OMAP memory addresses, from <start address> to <end address>.
Note all addresses within given range must be valid and accessible.
### WARNING ###: use the following I2C [read | write] commands at your own risk!
- I2C bus error (invalid or not accessible <physical address>,
Read I2C register at address <addr> from I2C chip at <chip-addr> on I2C <bus>.
Write <value> in I2C register at address <addr> from I2C chip at <chip-addr> on I2C <bus>.
root@dra7xx-evm:/opt/vision_sdk# ./apps.out
[HOST] OSA: MEM: 0: Mapped 0xa0100000 to 0xb6941000 of size 0x00100000
[HOST] OSA: MEM: 1: Mapped 0x84203000 to 0xa3d41000 of size 0x12c00000
[HOST] OSA: MEM: 2: Mapped 0xa0200000 to 0xa3c81000 of size 0x00040000
[HOST] OSA: MEM: 3: Mapped 0xa02c0000 to 0xa3cc1000 of size 0x00080000
[HOST] OSA: MEM: 4: Mapped 0xa04c0000 to 0xa3a81000 of size 0x00200000
[HOST] OSA: HOST Remote Log Shared Memory @ 0xa024f140
[HOST] OSA: DSP1 Remote Log Shared Memory @ 0xa02769e0
[HOST] OSA: DSP2 Remote Log Shared Memory @ 0xa029e280
[HOST] OSA: EVE1 Remote Log Shared Memory @ 0xa02c5b20
[HOST] OSA: EVE2 Remote Log Shared Memory @ 0xa02ed3c0
[HOST] OSA: EVE3 Remote Log Shared Memory @ 0xa0314c60
[HOST] OSA: EVE4 Remote Log Shared Memory @ 0xa033c500
[HOST] OSA: IPU2 Remote Log Shared Memory @ 0xa0363da0
[HOST] [HOST ] 285.887001 s: SYSTEM: System A15 Init in progress !!!
[HOST] [HOST ] 285.887093 s: SYSTEM: IPC: Init in progress !!!
[HOST] [HOST ] 285.887093 s: SYSTEM: IPC: Notify init in progress !!!
[HOST] [HOST ] 285.888892 s: SYSTEM: IPC: [IPU2] socket bind success !!! (dst vproc = 1, endpt = 81)
[HOST] [HOST ] 285.888923 s: SYSTEM: IPC: [IPU2] socket info (family = 41, dst proc id = -1, endpt = 81) !!!
[HOST] [HOST ] 285.888984 s: SYSTEM: IPC: [IPU2] socket connect success !!! (dst vproc = 1, endpt = 80)
[HOST] [HOST ] 285.888984 s: SYSTEM: IPC: [IPU2] socket info (family = 41, dst proc id = -1, endpt = 1024) !!!
[HOST] [HOST ] 285.890051 s: SYSTEM: IPC: [DSP1] socket bind success !!! (dst vproc = 2, endpt = 81)
[HOST] [HOST ] 285.890082 s: SYSTEM: IPC: [DSP1] socket info (family = 41, dst proc id = -1, endpt = 81) !!!
[HOST] [HOST ] 285.890112 s: SYSTEM: IPC: [DSP1] socket connect success !!! (dst vproc = 2, endpt = 80)
[HOST] [HOST ] 285.890112 s: SYSTEM: IPC: [DSP1] socket info (family = 41, dst proc id = -1, endpt = 1024) !!!
[HOST] [HOST ] 285.891271 s: SYSTEM: IPC: [DSP2] socket bind success !!! (dst vproc = 3, endpt = 81)
[HOST] [HOST ] 285.891271 s: SYSTEM: IPC: [DSP2] socket info (family = 41, dst proc id = -1, endpt = 81) !!!
[HOST] [HOST ] 285.891302 s: SYSTEM: IPC: [DSP2] socket connect success !!! (dst vproc = 3, endpt = 80)
[HOST] [HOST ] 285.891332 s: SYSTEM: IPC: [DSP2] socket info (family = 41, dst proc id = -1, endpt = 1024) !!!
[HOST] [HOST ] 285.891485 s: SYSTEM: IPC: Notify init DONE !!!
[HOST] [HOST ] 285.891485 s: SYSTEM: MSGQ: MsgQ init in progress !!!
[HOST] [HOST ] 285.891607 s: SYSTEM: MSGQ: MsgQ init DONE !!!
[HOST] [HOST ] 285.891607 s: SYSTEM: IPC: Init DONE !!!
[HOST] [HOST ] 285.891637 s: SYSTEM: Initializing A15 Links !!!
[HOST] [HOST ] 285.891759 s: IPC_OUT_0 : Init done - linkid-0x2000000
[HOST] [HOST ] 285.891881 s: IPC_OUT_1 : Init done - linkid-0x2000001
[HOST] [HOST ] 285.891973 s: IPC_OUT_2 : Init done - linkid-0x2000002
[HOST] [HOST ] 285.892095 s: IPC_OUT_3 : Init done - linkid-0x2000003
[HOST] [HOST ] 285.892217 s: IPC_OUT_4 : Init done - linkid-0x2000004
[HOST] [HOST ] 285.892339 s: IPC_IN_0 : Init done - linkid-0x200000a
[HOST] [HOST ] 285.892461 s: IPC_IN_1 : Init done - linkid-0x200000b
[HOST] [HOST ] 285.892583 s: IPC_IN_2 : Init done - linkid-0x200000c
[HOST] [HOST ] 285.892674 s: IPC_IN_3 : Init done - linkid-0x200000d
[HOST] [HOST ] 285.892857 s: IPC_IN_4 : Init done - linkid-0x200000e
[HOST] [HOST ] 285.893040 s: IPC_IN_5 : Init done - linkid-0x200000f
[HOST] [HOST ] 285.893193 s: IPC_IN_6 : Init done - linkid-0x2000010
[HOST] [HOST ] 285.893528 s: NULL_0 : Init done - linkid-0x2000014
[HOST] [HOST ] 285.893681 s: NULL_1 : Init done - linkid-0x2000015
[HOST] [HOST ] 285.893833 s: NULL_SRC_0 : Init done - linkid-0x2000039
[HOST] [HOST ] 285.894047 s: DISP_DIST_SRC_0 : Init done - linkid-0x2000062
[HOST] [HOST ] 285.894169 s: DISP_DIST_SRC_1 : Init done - linkid-0x2000063
[HOST] [HOST ] 285.894291 s: DISP_DIST_SRC_2 : Init done - linkid-0x2000064
[HOST] [HOST ] 285.894413 s: DISP_DIST_SRC_3 : Init done - linkid-0x2000065
[HOST] [HOST ] 285.894565 s: SGX3DSRV_0 : Init done - linkid-0x200004b
[HOST] [HOST ] 285.894748 s: ALGORITHM_0 : Init done - linkid-0x2000031
[HOST] [HOST ] 285.894901 s: ALGORITHM_1 : Init done - linkid-0x2000032
[HOST] [HOST ] 285.895053 s: ALGORITHM_2 : Init done - linkid-0x2000033
[HOST] [HOST ] 285.895206 s: ALGORITHM_3 : Init done - linkid-0x2000034
[HOST] [HOST ] 285.895358 s: ALGORITHM_4 : Init done - linkid-0x2000035
[HOST] [HOST ] 285.895511 s: ALGORITHM_5 : Init done - linkid-0x2000036
[HOST] [HOST ] 285.895694 s: ALGORITHM_6 : Init done - linkid-0x2000037
[HOST] [HOST ] 285.895846 s: ALGORITHM_7 : Init done - linkid-0x2000038
[HOST] [HOST ] 285.896121 s: DUP0 : Init done - linkid-0x0
[HOST] [HOST ] 285.896334 s: DUP1 : Init done - linkid-0x0
[HOST] [HOST ] 285.896578 s: DUP2 : Init done - linkid-0x0
[HOST] [HOST ] 285.896822 s: DUP3 : Init done - linkid-0x0
[HOST] [HOST ] 285.897036 s: DUP4 : Init done - linkid-0x0
[HOST] [HOST ] 285.897219 s: SYNC_0 : Init done - linkid-0x0
[HOST] [HOST ] 285.897371 s: SYNC_1 : Init done - linkid-0x0
[HOST] [HOST ] 285.897524 s: SYNC_2 : Init done - linkid-0x0
[HOST] [HOST ] 285.897676 s: SYNC_3 : Init done - linkid-0x0
[HOST] [HOST ] 285.897829 s: MERGE_0 : Init done - linkid-0x0
[HOST] [HOST ] 285.897981 s: MERGE_1 : Init done - linkid-0x0
[HOST] [HOST ] 285.898164 s: MERGE_2 : Init done - linkid-0x0
[HOST] [HOST ] 285.898317 s: MERGE_3 : Init done - linkid-0x0
[HOST] [HOST ] 285.902404 s: MERGE_4 : Init done - linkid-0x0
[HOST] [HOST ] 285.902617 s: SELECT_0 : Init done - linkid-0x0
[HOST] [HOST ] 285.902922 s: SELECT_1 : Init done - linkid-0x0
[HOST] [HOST ] 285.903044 s: GATE_0 : Init done - linkid-0x0
[HOST] [HOST ] 285.903197 s: GATE_1 : Init done - linkid-0x0
[HOST] [HOST ] 285.903319 s: GATE_2 : Init done - linkid-0x0
[HOST] [HOST ] 285.903441 s: GATE_3 : Init done - linkid-0x0
[HOST] [HOST ] 285.903563 s: SGXFRMCPY_0 : Init done - linkid-0x200004a
[HOST] [HOST ] 285.903716 s: SGX3DSFM_0 : Init done - linkid-0x200004c
[HOST] [HOST ] 285.903716 s: SYSTEM: Initializing A15 Links ... DONE !!!
[HOST] [HOST ] 285.904143 s: OSA: Adjusting global time, timeH by 0 units!!!
VX_ZONE_INIT:Enabled
VX_ZONE_ERROR:Enabled
VX_ZONE_WARNING:Enabled
[HOST] [DSP1 ] 2278.945739 s: ***** DSP1 Firmware build time 05:05:41 Jul 4 2019
[HOST] [DSP1 ] 2278.945800 s: *** SYSTEM: CPU Frequency <ORG = 600000000 Hz>, <NEW = 750000000 Hz>
[HOST] [DSP1 ] 2278.946074 s: SYSTEM: System Common Init in progress !!!
[HOST] [DSP1 ] 2278.946288 s: UTILS: CIO: Init Done !!!
[HOST] [DSP1 ] 2278.946318 s: SYSTEM: IPC init in progress !!!
[HOST] [DSP1 ] 2278.946349 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP1 ] 2278.999328 s: SYSTEM: Attaching to [IPU2] ... SUCCESS !!!
[HOST] [DSP1 ] 2279.004178 s: SYSTEM: Attaching to [DSP2] ... SUCCESS !!!
[HOST] [DSP1 ] 2279.026596 s: SYSTEM: Attaching to [EVE1] ... SUCCESS !!!
[HOST] [DSP1 ] 2279.046574 s: SYSTEM: Attaching to [EVE2] ... SUCCESS !!!
[HOST] [DSP1 ] 2279.066888 s: SYSTEM: Attaching to [EVE3] ... SUCCESS !!!
[HOST] [DSP1 ] 2279.086561 s: SYSTEM: Attaching to [EVE4] ... SUCCESS !!!
[HOST] [DSP1 ] 2279.086622 s: SYSTEM: Notify register to [IPU2] line 0, event 15...
[HOST] [DSP1 ] 2279.086652 s: SYSTEM: Notify register to [DSP2] line 0, event 15...
[HOST] [DSP1 ] 2279.086713 s: SYSTEM: Notify register to [EVE1] line 0, event 15...
[HOST] [DSP1 ] 2279.086744 s: SYSTEM: Notify register to [EVE2] line 0, event 15...
[HOST] [DSP1 ] 2279.086774 s: SYSTEM: Notify register to [EVE3] line 0, event 15...
[HOST] [DSP1 ] 2279.086805 s: SYSTEM: Notify register to [EVE4] line 0, event 15...
[HOST] [DSP1 ] 2279.086835 s: SYSTEM: Notify init done !!!
[HOST] [DSP1 ] 2279.087018 s: SYSTEM: MsgQ init done !!!
[HOST] [DSP1 ] 2279.087140 s: RpmsgInit in progress...
[HOST] [DSP1 ] 2279.087171 s: Connection established with HLOS, calling rpmsgInit
[HOST] [DSP1 ] 2279.087354 s: SYSTEM: IPC init DONE !!!
[HOST] [DSP1 ] 2279.087964 s: SYSTEM: Initializing TIOVX ...
[HOST] [DSP1 ] 2279.088025 s: VX_ZONE_INIT:Enabled
[HOST] [DSP1 ] 2279.088055 s: VX_ZONE_ERROR:Enabled
[HOST] [DSP1 ] 2279.088116 s: VX_ZONE_WARNING:Enabled
[HOST] [DSP1 ] 2279.088848 s: VX_ZONE_INIT:[tivxReserveC66xL2MEM:366] BAM memory config: IBUF 180224 bytes @ 0x00800000, WBUF 45056 bytes @ 0x0082c000 !!!
[HOST] [DSP1 ] 2279.089245 s: VX_ZONE_INIT:[tivxInit:72] Initialization Done !!!
[HOST] [DSP1 ] 2279.089275 s: SYSTEM: Initializing TIOVX ... Done !!!
[HOST] [DSP1 ] 2279.089275 s: Register DMS on vision sdk system_common.c !!!
[HOST] [DSP1 ] 2279.089336 s: SYSTEM: System Common Init Done !!!
[HOST] [DSP1 ] 2279.089336 s: SYSTEM: System DSP Init in progress !!!
[HOST] [DSP1 ] 2279.089580 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[HOST] [DSP1 ] 2279.089611 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB)
[HOST] [DSP1 ] 2279.089672 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 524288 B (512 KB), Free size = 516176 B (504 KB)
[HOST] [DSP1 ] 2279.089702 s: SYSTEM: Initializing Links !!!
[HOST] [DSP1 ] 2279.098792 s: SYSTEM: Initializing Links ... DONE !!!
[HOST] [DSP1 ] 2279.098853 s: lz4CompDecomp Init
[HOST] [DSP1 ] 2279.098853 s: SYSTEM: System DSP Init Done !!!
[HOST] [DSP1 ] 2279.431068 s: SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after boot !!!
[HOST] [DSP1 ] 2279.431098 s: SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after update by APP !!!
[HOST] [DSP2 ] 2278.647288 s: ***** DSP2 Firmware build time 05:08:29 Jul 4 2019
[HOST] [DSP2 ] 2278.647349 s: *** SYSTEM: CPU Frequency <ORG = 600000000 Hz>, <NEW = 750000000 Hz>
[HOST] [DSP2 ] 2278.647623 s: SYSTEM: System Common Init in progress !!!
[HOST] [DSP2 ] 2278.647837 s: UTILS: CIO: Init Done !!!
[HOST] [DSP2 ] 2278.647867 s: SYSTEM: IPC init in progress !!!
[HOST] [DSP2 ] 2278.647898 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [DSP2 ] 2279.002257 s: SYSTEM: Attaching to [IPU2] ... SUCCESS !!!
[HOST] [DSP2 ] 2279.004178 s: SYSTEM: Attaching to [DSP1] ... SUCCESS !!!
[HOST] [DSP2 ] 2279.036478 s: SYSTEM: Attaching to [EVE1] ... SUCCESS !!!
[HOST] [DSP2 ] 2279.056518 s: SYSTEM: Attaching to [EVE2] ... SUCCESS !!!
[HOST] [DSP2 ] 2279.076526 s: SYSTEM: Attaching to [EVE3] ... SUCCESS !!!
[HOST] [DSP2 ] 2279.096504 s: SYSTEM: Attaching to [EVE4] ... SUCCESS !!!
[HOST] [DSP2 ] 2279.096535 s: SYSTEM: Notify register to [IPU2] line 0, event 15...
[HOST] [DSP2 ] 2279.096596 s: SYSTEM: Notify register to [DSP1] line 0, event 15...
[HOST] [DSP2 ] 2279.096626 s: SYSTEM: Notify register to [EVE1] line 0, event 15...
[HOST] [DSP2 ] 2279.096657 s: SYSTEM: Notify register to [EVE2] line 0, event 15...
[HOST] [DSP2 ] 2279.096718 s: SYSTEM: Notify register to [EVE3] line 0, event 15...
[HOST] [DSP2 ] 2279.096748 s: SYSTEM: Notify register to [EVE4] line 0, event 15...
[HOST] [DSP2 ] 2279.096779 s: SYSTEM: Notify init done !!!
[HOST] [DSP2 ] 2279.096962 s: SYSTEM: MsgQ init done !!!
[HOST] [DSP2 ] 2279.097053 s: RpmsgInit in progress...
[HOST] [DSP2 ] 2279.097084 s: Connection established with HLOS, calling rpmsgInit
[HOST] [DSP2 ] 2279.097297 s: SYSTEM: IPC init DONE !!!
[HOST] [DSP2 ] 2279.097907 s: SYSTEM: Initializing TIOVX ...
[HOST] [DSP2 ] 2279.097968 s: VX_ZONE_INIT:Enabled
[HOST] [DSP2 ] 2279.097999 s: VX_ZONE_ERROR:Enabled
[HOST] [DSP2 ] 2279.098029 s: VX_ZONE_WARNING:Enabled
[HOST] [DSP2 ] 2279.098792 s: VX_ZONE_INIT:[tivxReserveC66xL2MEM:366] BAM memory config: IBUF 180224 bytes @ 0x00800000, WBUF 45056 bytes @ 0x0082c000 !!!
[HOST] [DSP2 ] 2279.099188 s: VX_ZONE_INIT:[tivxInit:72] Initialization Done !!!
[HOST] [DSP2 ] 2279.099188 s: SYSTEM: Initializing TIOVX ... Done !!!
[HOST] [DSP2 ] 2279.099219 s: Register DMS on vision sdk system_common.c !!!
[HOST] [DSP2 ] 2279.099249 s: SYSTEM: System Common Init Done !!!
[HOST] [DSP2 ] 2279.099280 s: SYSTEM: System DSP Init in progress !!!
[HOST] [DSP2 ] 2279.099524 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[HOST] [DSP2 ] 2279.099554 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB)
[HOST] [DSP2 ] 2279.099585 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 524288 B (512 KB), Free size = 516176 B (504 KB)
[HOST] [DSP2 ] 2279.099615 s: SYSTEM: Initializing Links !!!
[HOST] [DSP2 ] 2279.108796 s: SYSTEM: Initializing Links ... DONE !!!
[HOST] [DSP2 ] 2279.108857 s: lz4CompDecomp Init
[HOST] [DSP2 ] 2279.108857 s: SYSTEM: System DSP Init Done !!!
[HOST] [DSP2 ] 2279.433081 s: SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after boot !!!
[HOST] [DSP2 ] 2279.433111 s: SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after update by APP !!!
[HOST] [EVE1 ] 2278.999847 s: ***** EVE Firmware build time 04:59:39 Jul 4 2019
[HOST] [EVE1 ] 2279.001799 s: *** SYSTEM: CPU Frequency <ORG = 267500000 Hz>, <NEW = 267500000 Hz>
[HOST] [EVE1 ] 2279.005154 s: SYSTEM: System Common Init in progress !!!
[HOST] [EVE1 ] 2279.007472 s: UTILS: CIO: Init Done !!!
[HOST] [EVE1 ] 2279.008540 s: SYSTEM: IPC init in progress !!!
[HOST] [EVE1 ] 2279.009638 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [EVE1 ] 2279.016927 s: SYSTEM: Attaching to [IPU2] ... SUCCESS !!!
[HOST] [EVE1 ] 2279.026596 s: SYSTEM: Attaching to [DSP1] ... SUCCESS !!!
[HOST] [EVE1 ] 2279.036478 s: SYSTEM: Attaching to [DSP2] ... SUCCESS !!!
[HOST] [EVE1 ] 2279.076679 s: SYSTEM: Attaching to [EVE2] ... SUCCESS !!!
[HOST] [EVE1 ] 2279.106661 s: SYSTEM: Attaching to [EVE3] ... SUCCESS !!!
[HOST] [EVE1 ] 2279.126700 s: SYSTEM: Attaching to [EVE4] ... SUCCESS !!!
[HOST] [EVE1 ] 2279.128011 s: SYSTEM: Notify register to [IPU2] line 0, event 15...
[HOST] [EVE1 ] 2279.129445 s: SYSTEM: Notify register to [DSP1] line 0, event 15...
[HOST] [EVE1 ] 2279.130879 s: SYSTEM: Notify register to [DSP2] line 0, event 15...
[HOST] [EVE1 ] 2279.132282 s: SYSTEM: Notify register to [EVE2] line 0, event 15...
[HOST] [EVE1 ] 2279.133685 s: SYSTEM: Notify register to [EVE3] line 0, event 15...
[HOST] [EVE1 ] 2279.135118 s: SYSTEM: Notify register to [EVE4] line 0, event 15...
[HOST] [EVE1 ] 2279.136674 s: SYSTEM: Notify init done !!!
[HOST] [EVE1 ] 2279.138473 s: SYSTEM: MsgQ init done !!!
[HOST] [EVE1 ] 2279.139541 s: SYSTEM: IPC init DONE !!!
[HOST] [EVE1 ] 2279.152321 s: SYSTEM: Initializing TIOVX ...
[HOST] [EVE1 ] 2279.153998 s: VX_ZONE_INIT:Enabled
[HOST] [EVE1 ] 2279.155676 s: VX_ZONE_ERROR:Enabled
[HOST] [EVE1 ] 2279.157384 s: VX_ZONE_WARNING:Enabled
[HOST] [EVE1 ] 2279.161257 s: VX_ZONE_INIT:[tivxInit:72] Initialization Done !!!
[HOST] [EVE1 ] 2279.162538 s: SYSTEM: Initializing TIOVX ... Done !!!
[HOST] [EVE1 ] 2279.163667 s: SYSTEM: System Common Init Done !!!
[HOST] [EVE1 ] 2279.164795 s: SYSTEM: System EVE Init in progress !!!
[HOST] [EVE1 ] 2279.166473 s: UTILS: DMA: HWI Create for INT8 !!!
[HOST] [EVE1 ] 2279.167846 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[HOST] [EVE1 ] 2279.169310 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB)
[HOST] [EVE1 ] 2279.171750 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254280 B (248 KB)
[HOST] [EVE1 ] 2279.174098 s: SYSTEM: Initializing Links !!!
[HOST] [EVE1 ] 2279.260538 s: SYSTEM: Initializing Links ... DONE !!!
[HOST] [EVE1 ] 2279.261788 s: SYSTEM: System EVE Init Done !!!
[HOST] [EVE2 ] 2278.999938 s: ***** EVE Firmware build time 05:00:57 Jul 4 2019
[HOST] [EVE2 ] 2279.001952 s: *** SYSTEM: CPU Frequency <ORG = 267500000 Hz>, <NEW = 267500000 Hz>
[HOST] [EVE2 ] 2279.005337 s: SYSTEM: System Common Init in progress !!!
[HOST] [EVE2 ] 2279.007655 s: UTILS: CIO: Init Done !!!
[HOST] [EVE2 ] 2279.008784 s: SYSTEM: IPC init in progress !!!
[HOST] [EVE2 ] 2279.009912 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [EVE2 ] 2279.036936 s: SYSTEM: Attaching to [IPU2] ... SUCCESS !!!
[HOST] [EVE2 ] 2279.046574 s: SYSTEM: Attaching to [DSP1] ... SUCCESS !!!
[HOST] [EVE2 ] 2279.056518 s: SYSTEM: Attaching to [DSP2] ... SUCCESS !!!
[HOST] [EVE2 ] 2279.076679 s: SYSTEM: Attaching to [EVE1] ... SUCCESS !!!
[HOST] [EVE2 ] 2279.126547 s: SYSTEM: Attaching to [EVE3] ... SUCCESS !!!
[HOST] [EVE2 ] 2279.146495 s: SYSTEM: Attaching to [EVE4] ... SUCCESS !!!
[HOST] [EVE2 ] 2279.147745 s: SYSTEM: Notify register to [IPU2] line 0, event 15...
[HOST] [EVE2 ] 2279.149240 s: SYSTEM: Notify register to [DSP1] line 0, event 15...
[HOST] [EVE2 ] 2279.150735 s: SYSTEM: Notify register to [DSP2] line 0, event 15...
[HOST] [EVE2 ] 2279.152260 s: SYSTEM: Notify register to [EVE1] line 0, event 15...
[HOST] [EVE2 ] 2279.153754 s: SYSTEM: Notify register to [EVE3] line 0, event 15...
[HOST] [EVE2 ] 2279.155249 s: SYSTEM: Notify register to [EVE4] line 0, event 15...
[HOST] [EVE2 ] 2279.156865 s: SYSTEM: Notify init done !!!
[HOST] [EVE2 ] 2279.158726 s: SYSTEM: MsgQ init done !!!
[HOST] [EVE2 ] 2279.159793 s: SYSTEM: IPC init DONE !!!
[HOST] [EVE2 ] 2279.172878 s: SYSTEM: Initializing TIOVX ...
[HOST] [EVE2 ] 2279.174556 s: VX_ZONE_INIT:Enabled
[HOST] [EVE2 ] 2279.176325 s: VX_ZONE_ERROR:Enabled
[HOST] [EVE2 ] 2279.178033 s: VX_ZONE_WARNING:Enabled
[HOST] [EVE2 ] 2279.182242 s: VX_ZONE_INIT:[tivxInit:72] Initialization Done !!!
[HOST] [EVE2 ] 2279.183523 s: SYSTEM: Initializing TIOVX ... Done !!!
[HOST] [EVE2 ] 2279.184712 s: SYSTEM: System Common Init Done !!!
[HOST] [EVE2 ] 2279.185963 s: SYSTEM: System EVE Init in progress !!!
[HOST] [EVE2 ] 2279.187549 s: UTILS: DMA: HWI Create for INT8 !!!
[HOST] [EVE2 ] 2279.188922 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[HOST] [EVE2 ] 2279.190355 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB)
[HOST] [EVE2 ] 2279.192765 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254280 B (248 KB)
[HOST] [EVE2 ] 2279.195113 s: SYSTEM: Initializing Links !!!
[HOST] [EVE2 ] 2279.281644 s: SYSTEM: Initializing Links ... DONE !!!
[HOST] [EVE2 ] 2279.282834 s: SYSTEM: System EVE Init Done !!!
[HOST] [EVE3 ] 2278.999969 s: ***** EVE Firmware build time 05:02:08 Jul 4 2019
[HOST] [EVE3 ] 2279.001982 s: *** SYSTEM: CPU Frequency <ORG = 267500000 Hz>, <NEW = 267500000 Hz>
[HOST] [EVE3 ] 2279.005368 s: SYSTEM: System Common Init in progress !!!
[HOST] [EVE3 ] 2279.007655 s: UTILS: CIO: Init Done !!!
[HOST] [EVE3 ] 2279.008784 s: SYSTEM: IPC init in progress !!!
[HOST] [EVE3 ] 2279.009912 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [EVE3 ] 2279.056945 s: SYSTEM: Attaching to [IPU2] ... SUCCESS !!!
[HOST] [EVE3 ] 2279.066888 s: SYSTEM: Attaching to [DSP1] ... SUCCESS !!!
[HOST] [EVE3 ] 2279.076526 s: SYSTEM: Attaching to [DSP2] ... SUCCESS !!!
[HOST] [EVE3 ] 2279.106630 s: SYSTEM: Attaching to [EVE1] ... SUCCESS !!!
[HOST] [EVE3 ] 2279.126547 s: SYSTEM: Attaching to [EVE2] ... SUCCESS !!!
[HOST] [EVE3 ] 2279.166534 s: SYSTEM: Attaching to [EVE4] ... SUCCESS !!!
[HOST] [EVE3 ] 2279.167815 s: SYSTEM: Notify register to [IPU2] line 0, event 15...
[HOST] [EVE3 ] 2279.169340 s: SYSTEM: Notify register to [DSP1] line 0, event 15...
[HOST] [EVE3 ] 2279.170896 s: SYSTEM: Notify register to [DSP2] line 0, event 15...
[HOST] [EVE3 ] 2279.172451 s: SYSTEM: Notify register to [EVE1] line 0, event 15...
[HOST] [EVE3 ] 2279.174068 s: SYSTEM: Notify register to [EVE2] line 0, event 15...
[HOST] [EVE3 ] 2279.175745 s: SYSTEM: Notify register to [EVE4] line 0, event 15...
[HOST] [EVE3 ] 2279.177331 s: SYSTEM: Notify init done !!!
[HOST] [EVE3 ] 2279.179436 s: SYSTEM: MsgQ init done !!!
[HOST] [EVE3 ] 2279.180564 s: SYSTEM: IPC init DONE !!!
[HOST] [EVE3 ] 2279.193863 s: SYSTEM: Initializing TIOVX ...
[HOST] [EVE3 ] 2279.195601 s: VX_ZONE_INIT:Enabled
[HOST] [EVE3 ] 2279.197279 s: VX_ZONE_ERROR:Enabled
[HOST] [EVE3 ] 2279.199017 s: VX_ZONE_WARNING:Enabled
[HOST] [EVE3 ] 2279.202952 s: VX_ZONE_INIT:[tivxInit:72] Initialization Done !!!
[HOST] [EVE3 ] 2279.204233 s: SYSTEM: Initializing TIOVX ... Done !!!
[HOST] [EVE3 ] 2279.205514 s: SYSTEM: System Common Init Done !!!
[HOST] [EVE3 ] 2279.206673 s: SYSTEM: System EVE Init in progress !!!
[HOST] [EVE3 ] 2279.208320 s: UTILS: DMA: HWI Create for INT8 !!!
[HOST] [EVE3 ] 2279.209693 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[HOST] [EVE3 ] 2279.211157 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB)
[HOST] [EVE3 ] 2279.213536 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254280 B (248 KB)
[HOST] [EVE3 ] 2279.215884 s: SYSTEM: Initializing Links !!!
[HOST] [EVE3 ] 2279.300768 s: SYSTEM: Initializing Links ... DONE !!!
[HOST] [EVE3 ] 2279.301958 s: SYSTEM: System EVE Init Done !!!
[HOST] [EVE4 ] 2279.000122 s: ***** EVE Firmware build time 05:03:20 Jul 4 2019
[HOST] [EVE4 ] 2279.002013 s: *** SYSTEM: CPU Frequency <ORG = 267500000 Hz>, <NEW = 267500000 Hz>
[HOST] [EVE4 ] 2279.005368 s: SYSTEM: System Common Init in progress !!!
[HOST] [EVE4 ] 2279.007686 s: UTILS: CIO: Init Done !!!
[HOST] [EVE4 ] 2279.008784 s: SYSTEM: IPC init in progress !!!
[HOST] [EVE4 ] 2279.009912 s: SYSTEM: Attaching to [IPU2] ...
[HOST] [EVE4 ] 2279.076953 s: SYSTEM: Attaching to [IPU2] ... SUCCESS !!!
[HOST] [EVE4 ] 2279.086561 s: SYSTEM: Attaching to [DSP1] ... SUCCESS !!!
[HOST] [EVE4 ] 2279.096504 s: SYSTEM: Attaching to [DSP2] ... SUCCESS !!!
[HOST] [EVE4 ] 2279.126700 s: SYSTEM: Attaching to [EVE1] ... SUCCESS !!!
[HOST] [EVE4 ] 2279.146495 s: SYSTEM: Attaching to [EVE2] ... SUCCESS !!!
[HOST] [EVE4 ] 2279.166534 s: SYSTEM: Attaching to [EVE3] ... SUCCESS !!!
[HOST] [EVE4 ] 2279.167815 s: SYSTEM: Notify register to [IPU2] line 0, event 15...
[HOST] [EVE4 ] 2279.169340 s: SYSTEM: Notify register to [DSP1] line 0, event 15...
[HOST] [EVE4 ] 2279.170896 s: SYSTEM: Notify register to [DSP2] line 0, event 15...
[HOST] [EVE4 ] 2279.172482 s: SYSTEM: Notify register to [EVE1] line 0, event 15...
[HOST] [EVE4 ] 2279.174068 s: SYSTEM: Notify register to [EVE2] line 0, event 15...
[HOST] [EVE4 ] 2279.175715 s: SYSTEM: Notify register to [EVE3] line 0, event 15...
[HOST] [EVE4 ] 2279.177301 s: SYSTEM: Notify init done !!!
[HOST] [EVE4 ] 2279.179375 s: SYSTEM: MsgQ init done !!!
[HOST] [EVE4 ] 2279.180503 s: SYSTEM: IPC init DONE !!!
[HOST] [EVE4 ] 2279.193741 s: SYSTEM: Initializing TIOVX ...
[HOST] [EVE4 ] 2279.195510 s: VX_ZONE_INIT:Enabled
[HOST] [EVE4 ] 2279.197187 s: VX_ZONE_ERROR:Enabled
[HOST] [EVE4 ] 2279.198926 s: VX_ZONE_WARNING:Enabled
[HOST] [EVE4 ] 2279.202891 s: VX_ZONE_INIT:[tivxInit:72] Initialization Done !!!
[HOST] [EVE4 ] 2279.204172 s: SYSTEM: Initializing TIOVX ... Done !!!
[HOST] [EVE4 ] 2279.205453 s: SYSTEM: System Common Init Done !!!
[HOST] [EVE4 ] 2279.206612 s: SYSTEM: System EVE Init in progress !!!
[HOST] [EVE4 ] 2279.208259 s: UTILS: DMA: HWI Create for INT8 !!!
[HOST] [EVE4 ] 2279.209632 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[HOST] [EVE4 ] 2279.211096 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB)
[HOST] [EVE4 ] 2279.213505 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254280 B (248 KB)
[HOST] [EVE4 ] 2279.215854 s: SYSTEM: Initializing Links !!!
[HOST] [EVE4 ] 2279.300799 s: SYSTEM: Initializing Links ... DONE !!!
[HOST] [EVE4 ] 2279.302019 s: SYSTEM: System EVE Init Done !!!
[HOST] [IPU2 ] 2278.831482 s:
[HOST] [IPU2 ] EVE1 Image Load Completed
[HOST] [IPU2 ] 2278.880863 s:
[HOST] [IPU2 ] EVE2 Image Load Completed
[HOST] [IPU2 ] 2278.931800 s:
[HOST] [IPU2 ] EVE3 Image Load Completed
[HOST] [IPU2 ] 2278.981272 s:
[HOST] [IPU2 ] EVE4 Image Load Completed
[HOST] [IPU2 ] 2278.981394 s:
[HOST] [IPU2 ] EVE MMU configuration completed
[HOST] [IPU2 ] 2278.981486 s:
[HOST] [IPU2 ] 2278.981547 s:
[HOST] [IPU2 ] 2278.981638 s:
[HOST] [IPU2 ] 2278.981699 s: ***** IPU2 Firmware build time 05:10:22 Jul 4 2019
[HOST] [IPU2 ] 2278.981882 s: *** SYSTEM: CPU Frequency <ORG = 212800000 Hz>, <NEW = 212800000 Hz>
[HOST] [IPU2 ] 2278.985298 s: SYSTEM: System Common Init in progress !!!
[HOST] [IPU2 ] 2278.996461 s: UTILS: CIO: Init Done !!!
[HOST] [IPU2 ] 2278.996583 s: SYSTEM: IPC init in progress !!!
[HOST] [IPU2 ] 2278.996675 s: SYSTEM: Attaching to [DSP1] ...
[HOST] [IPU2 ] 2278.999328 s: SYSTEM: Attaching to [DSP1] ... SUCCESS !!!
[HOST] [IPU2 ] 2279.002257 s: SYSTEM: Attaching to [DSP2] ... SUCCESS !!!
[HOST] [IPU2 ] 2279.016927 s: SYSTEM: Attaching to [EVE1] ... SUCCESS !!!
[HOST] [IPU2 ] 2279.036936 s: SYSTEM: Attaching to [EVE2] ... SUCCESS !!!
[HOST] [IPU2 ] 2279.056945 s: SYSTEM: Attaching to [EVE3] ... SUCCESS !!!
[HOST] [IPU2 ] 2279.076953 s: SYSTEM: Attaching to [EVE4] ... SUCCESS !!!
[HOST] [IPU2 ] 2279.077075 s: SYSTEM: Notify register to [DSP1] line 0, event 15...
[HOST] [IPU2 ] 2279.077228 s: SYSTEM: Notify register to [DSP2] line 0, event 15...
[HOST] [IPU2 ] 2279.077350 s: SYSTEM: Notify register to [EVE1] line 0, event 15...
[HOST] [IPU2 ] 2279.077441 s: SYSTEM: Notify register to [EVE2] line 0, event 15...
[HOST] [IPU2 ] 2279.077563 s: SYSTEM: Notify register to [EVE3] line 0, event 15...
[HOST] [IPU2 ] 2279.077716 s: SYSTEM: Notify register to [EVE4] line 0, event 15...
[HOST] [IPU2 ] 2279.077838 s: SYSTEM: Notify init done !!!
[HOST] [IPU2 ] 2279.079546 s: SYSTEM: MsgQ init done !!!
[HOST] [IPU2 ] 2279.080491 s: RpmsgInit in progress...
[HOST] [IPU2 ] 2279.080583 s: Connection established with HLOS, calling rpmsgInit
[HOST] [IPU2 ] 2279.081193 s: SYSTEM: IPC init DONE !!!
[HOST] [IPU2 ] 2279.086378 s: SYSTEM: Initializing TIOVX ...
[HOST] [IPU2 ] 2279.086561 s: VX_ZONE_INIT:Enabled
[HOST] [IPU2 ] 2279.086744 s: VX_ZONE_ERROR:Enabled
[HOST] [IPU2 ] 2279.086866 s: VX_ZONE_WARNING:Enabled
[HOST] [IPU2 ] 2279.090800 s: VX_ZONE_INIT:[tivxInit:72] Initialization Done !!!
[HOST] [IPU2 ] 2279.090892 s: SYSTEM: Initializing TIOVX ... Done !!!
[HOST] [IPU2 ] 2279.090983 s: SYSTEM: System Common Init Done !!!
[HOST] [IPU2 ] 2279.091044 s: SYSTEM: System Init in progress !!!
[HOST] [IPU2 ] 2279.091105 s: SYSTEM: BSP Common Init in progress !!!
[HOST] [IPU2 ] 2279.091197 s: SYSTEM: BSP Common Init Done !!!
[HOST] [IPU2 ] 2279.091258 s: SYSTEM: BSP Platform Init in progress !!!
[HOST] [IPU2 ] 2279.092173 s: SYSTEM: BSP Platform Init Done !!!
[HOST] [IPU2 ] 2279.092234 s: SYSTEM: FVID2 Init in progress !!!
[HOST] [IPU2 ] 2279.092386 s: SYSTEM: FVID2 Init Done !!!
[HOST] [IPU2 ] 2279.092447 s: SYSTEM: VPS Init in progress !!!
[HOST] [IPU2 ] 2279.092539 s: SYSTEM: VPDMA Descriptor Memory Address translation ENABLED [0x80000000 -> 0x80000000]
[HOST] [IPU2 ] 2279.095589 s: *** VPDMA Firmware Loading... ***
[HOST] [IPU2 ] 2279.095742 s: VPDMA Firmware Address = 0xa03dc4c0
[HOST] [IPU2 ] 2279.095833 s: VPDMA Load Address = 0x4897d004
[HOST] [IPU2 ] 2279.095955 s: VPDMA Firmware Version = 0x4d0001b8
[HOST] [IPU2 ] 2279.096047 s: VPDMA List Busy Status = 0x00000000
[HOST] [IPU2 ] 2279.096108 s: *** VPDMA Firmware Load Success ***
[HOST] [IPU2 ] 2279.096443 s: *** VPDMA Firmware Loading... ***
[HOST] [IPU2 ] 2279.096535 s: VPDMA Firmware Address = 0xa03dc4c0
[HOST] [IPU2 ] 2279.096657 s: VPDMA Load Address = 0x4899d004
[HOST] [IPU2 ] 2279.096748 s: VPDMA Firmware Version = 0x4d0001b8
[HOST] [IPU2 ] 2279.096840 s: VPDMA List Busy Status = 0x00000000
[HOST] [IPU2 ] 2279.096931 s: *** VPDMA Firmware Load Success ***
[HOST] [IPU2 ] 2279.097267 s: *** VPDMA Firmware Loading... ***
[HOST] [IPU2 ] 2279.097358 s: VPDMA Firmware Address = 0xa03dc4c0
[HOST] [IPU2 ] 2279.097450 s: VPDMA Load Address = 0x489bd004
[HOST] [IPU2 ] 2279.097541 s: VPDMA Firmware Version = 0x4d0001b8
[HOST] [IPU2 ] 2279.097663 s: VPDMA List Busy Status = 0x00000000
[HOST] [IPU2 ] 2279.097724 s: *** VPDMA Firmware Load Success ***
[HOST] [IPU2 ] 2279.098090 s: *** VPDMA Firmware Loading... ***
[HOST] [IPU2 ] 2279.098182 s: VPDMA Firmware Address = 0xa03dc4c0
[HOST] [IPU2 ] 2279.098273 s: VPDMA Load Address = 0x489dd004
[HOST] [IPU2 ] 2279.098365 s: VPDMA Firmware Version = 0x4d0001b8
[HOST] [IPU2 ] 2279.098456 s: VPDMA List Busy Status = 0x00000000
[HOST] [IPU2 ] 2279.098548 s: *** VPDMA Firmware Load Success ***
[HOST] [IPU2 ] 2279.156164 s: SYSTEM: VPS Init Done !!!
[HOST] [IPU2 ] 2279.157079 s: UTILS: DMA: HWI Create for INT25 !!!
[HOST] [IPU2 ] 2279.157353 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[HOST] [IPU2 ] 2279.157445 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 253744 B (247 KB)
[HOST] [IPU2 ] 2279.157658 s: SYSTEM: Heap = SR_OCMC @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB)
[HOST] [IPU2 ] 2279.157811 s: SYSTEM: Heap = SR_DDR_CACHED @ 0x84203000, Total size = 314572800 B (300 MB), Free size = 314572800 B (300 MB)
[HOST] [IPU2 ] 2279.158024 s: SYSTEM: Heap = SR_DDR_NON_CACHED @ 0xa0100000, Total size = 1045376 B (0 MB), Free size = 851840 B (0 MB)
[HOST] [IPU2 ] 2279.158177 s: SYSTEM: Initializing Links !!!
[HOST] [IPU2 ] 2279.423351 s: SYSTEM: Initializing Links ... DONE !!!
[HOST] [IPU2 ] 2279.505459 s: CHAINS: Application Started !!!
[HOST] [IPU2 ] 2279.516043 s: BOARD: Board Init in progress !!!
[HOST] [IPU2 ] 2279.516500 s: BOARD: Board Init Done !!!
[HOST] [IPU2 ] 2279.524766 s:
[HOST] [HOST ] 286.250388 s: SYSTEM: System A15 Init Done !!!
[HOST] [HOST ] 286.250540 s: NETWORK_CTRL: Starting Server (port=5000) !!!
[HOST] [HOST ] 286.250601 s: NETWORK_CTRL: Starting Server ... DONE (port=5000) !!!
[HOST] [HOST ] 286.752767 s:
[HOST] [HOST ]
[HOST] [HOST ] ====================
[HOST] [HOST ] Vision SDK Usecases
[HOST] [HOST ] 1: Single Camera Usecases
[HOST] [HOST ] 2: Multi-Camera LVDS Usecases
[HOST] [HOST ] 3: Open-Compute Usecases
[HOST] [HOST ] 6: Radar Usecases
[HOST] [HOST ]
[HOST] [HOST ] 7: PCIe SSD card Write Test
[HOST] [HOST ] p: CPU Status
[HOST] [HOST ] i: Show IP Addr (IPU + NDK + AVB)
[HOST] [HOST ]
[HOST] [HOST ] s: System Settings
[HOST] [HOST ]
[HOST] [HOST ] x: Exit
[HOST] [HOST ] z: Exit - AND SHUTDOWN Remote CPUs
[HOST] [HOST ]
[HOST] [HOST ] Enter Choice:
3
[HOST] [HOST ] 421.726597 s:
[HOST] [HOST ]
[HOST] [HOST ] OpenCompute Usecases
[HOST] [HOST ] ----------------------------
[HOST] [HOST ] 1: OpenVX USecases
[HOST] [HOST ]
[HOST] [HOST ]
[HOST] [HOST ]
[HOST] [HOST ] 421.726628 s:
[HOST] [HOST ] 421.726628 s: Unsupported option '
[HOST] [HOST ] '. Please try again
[HOST] [HOST ] 421.726658 s:
[HOST] [HOST ]
[HOST] [HOST ]
[HOST] [HOST ]
[HOST] [HOST ]
1
[HOST] [HOST ] 425.534747 s:
[HOST] [HOST ]
[HOST] [HOST ] OPENVX Usecases
[HOST] [HOST ] 1: OpenVX v1.1 Conformance Test
[HOST] [HOST ] 2: OpenVX Tutorials
[HOST] [HOST ] 3: OpenVX TIDL Object Classification
[HOST] [HOST ] 4: OpenVX TIDL Object Detection
[HOST] [HOST ]
[HOST] [HOST ]
[HOST] [HOST ]
4
ASSERT (nullSrcLink_tsk.c|NullSrcLink_create|1164)
[HOST] [HOST ] 428.302819 s:
How could I run OpenVX TIDL Object Detection ?
Ting
