Hello everyone,
I am trying to generate binary files for my project in CCS,
I use the following command as a post build step
${CCS_INSTALL_ROOT}/utils/tiobj2bin/tiobj2bin ${BuildArtifactFileName} ${BuildArtifactFileBaseName}.bin ${CG_TOOL_ROOT}/bin/ofd2000 ${CG_TOOL_ROOT}/bin/hex2000 ${CCS_INSTALL_ROOT}/utils/tiobj2bin/mkhex4bin
the problem is that some sections which are placed in PAGE1 such as .cinit and .econst are not included in the binary file. in fact, i get the following error
warning: section project.out(.econst) at 013a000h falls in unconfigured memory (skipped) warning: section project.out(.cinit) at 013b1e8h falls in unconfigured memory (skipped) warning: section project.out(.binit) at 013c380h falls in unconfigured memory (skipped)
I have also tried to use the hex utility but it creates two separate files, one for each page. Then I need to merge them and translate them to binary but this also has caveats as most intel-hex manipulation utilities assume one-byte at every address and thus don't work.
Is there a way I can create a binary which includes both pages in a unified address space and fill the empty locations?
