Part Number: LAUNCHXL2-570LC43
Section J.3.10 Qualifiers of ARM Optimizing C/C++ Compiler v18.1.0.LTS User's Guide states:
The TMS570LC4357_emac_status.zip CCS project attached to https://e2e.ti.com/support/microcontrollers/hercules/f/312/p/858377/3179628#3179628 contains the following function designed to sample two volatile registers in a specific order:The TI compiler will not reorder two volatile accesses, but it may reorder a volatile and a non-volatile access, so volatile cannot be used to create a critical section.
static inline void sampleEmacStatus (const bool sample_a_first,
const volatile uint32_t *const in_a, const volatile uint32_t *const in_b,
uint32_t *const out_a, uint32_t *const out_b)
if (sample_a_first)
*out_a = *in_a;
*out_b = *in_b;
else
*out_b = *in_b;
*out_a = *in_a;
Where the function is alternatively called with the sample_a_first parameter as either false or true.
With the debug configuration for the sample project where the Optimization Level is Off then the generated assembler shown in the debugger does allow the order or the volatile accesses to be controlled on each pass:
0000d618: E34F0C52 movt r0, #0xfc52
0000d61c: E34FCCF7 movt r12, #0xfcf7
112 if (sample_a_first)
0000d620: E3510001 cmp r1, #1
0000d624: 0A000002 beq $C$L3
119 *out_b = *in_b;
0000d628: E59CC000 ldr r12, [r12]
120 *out_a = *in_a;
0000d62c: E5901000 ldr r1, [r0]
0000d630: EA000001 b $C$L4
114 *out_a = *in_a;
$C$L3:
0000d634: E5901000 ldr r1, [r0]
115 *out_b = *in_b;
0000d638: E59CC000 ldr r12, [r12]
138 hdp_null = hdp == 0;
$C$L4:
Whereas the Release configuration for the sample project where the Optimization Level is 4 in the generated assembler the sampleEmacStatus function appears to be been optimized such that only the first part of the condition is ever taken:
$C$L39:
000092d8: E3570001 cmp r7, #1
000092dc: E1A0C005 mov r12, r5
114 *out_a = *in_a;
000092e0: E5141004 ldr r1, [r4, #-4]
115 *out_b = *in_b;
000092e4: E59604C0 ldr r0, [r6, #0x4c0]
I think r7 is the register which holds the sample_a_first boolean. There is a test on the value of r7, but there is no branch instructions based upon the comparison result.
I.e. optimization level 4 appears to removed the code which attempts to alternate the order of access to volatile registers through each pass. Is this a bug in the compiler, or a limitation of trying to use C code to control the order of access to two volatile registers?
