CCS/SW-EK-TM4C129EXL: EK-TM4C129EXL : UDP TO PC
Expert 1660 points
Part Number: SW-EK-TM4C129EXL
Other Parts Discussed in Thread: EK-TM4C129EXL, EK-TM4C1294XL
Hello I am using EK-TM4C129EXL  .  I want to send ADC values from tiva to PC using udp (i am using udp test tool)  . i successfully run udp echo example.
and successfully read the ADC values via UART0.
But i got stuck in how to send these values to pc via UDP.
This is my adc .c file
// single_ended.c - Example demonstrating how to configure the ADC for
//                  single ended operation.
// Copyright (c) 2010-2017 Texas Instruments Incorporated.  All rights reserved.
// Software License Agreement
//   Redistribution and use in source and binary forms, with or without
//   modification, are permitted provided that the following conditions
//   are met:
//   Redistributions of source code must retain the above copyright
//   notice, this list of conditions and the following disclaimer.
//   Redistributions in binary form must reproduce the above copyright
//   notice, this list of conditions and the following disclaimer in the
//   documentation and/or other materials provided with the
//   distribution.
//   Neither the name of Texas Instruments Incorporated nor the names of
//   its contributors may be used to endorse or promote products derived
//   from this software without specific prior written permission.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
// "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
// LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
// OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
// SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
// LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
// DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
// THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
// (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
// OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
// This is part of revision 2.1.4.178 of the Tiva Firmware Development Package.
#include <stdbool.h>
#include <stdint.h>
#include "inc/hw_memmap.h"
#include "driverlib/adc.h"
#include "driverlib/gpio.h"
#include "driverlib/pin_map.h"
#include "driverlib/sysctl.h"
#include "driverlib/uart.h"
#include "utils/uartstdio.h"
//! \addtogroup adc_examples_list
//! <h1>Single Ended ADC (single_ended)</h1>
//! This example shows how to setup ADC0 as a single ended input and take a
//! single sample on AIN0/PE3.
//! This example uses the following peripherals and I/O signals.  You must
//! review these and change as needed for your own board:
//! - ADC0 peripheral
//! - GPIO Port E peripheral (for AIN0 pin)
//! - AIN0 - PE3
//! The following UART signals are configured only for displaying console
//! messages for this example.  These are not required for operation of the
//! ADC.
//! - UART0 peripheral
//! - GPIO Port A peripheral (for UART0 pins)
//! - UART0RX - PA0
//! - UART0TX - PA1
//! This example uses the following interrupt handlers.  To use this example
//! in your own application you must add these interrupt handlers to your
//! vector table.
//! - None.
// This function sets up UART0 to be used for a console to display information
// as the example is running.
void
InitConsole(void)
    // Enable GPIO port A which is used for UART0 pins.
    // TODO: change this to whichever GPIO port you are using.
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOA);
    // Configure the pin muxing for UART0 functions on port A0 and A1.
    // This step is not necessary if your part does not support pin muxing.
    // TODO: change this to select the port/pin you are using.
    GPIOPinConfigure(GPIO_PA0_U0RX);
    GPIOPinConfigure(GPIO_PA1_U0TX);
    // Enable UART0 so that we can configure the clock.
    SysCtlPeripheralEnable(SYSCTL_PERIPH_UART0);
    // Use the internal 16MHz oscillator as the UART clock source.
    UARTClockSourceSet(UART0_BASE, UART_CLOCK_PIOSC);
    // Select the alternate (UART) function for these pins.
    GPIOPinTypeUART(GPIO_PORTA_BASE, GPIO_PIN_0 | GPIO_PIN_1);
    // Initialize the UART for console I/O.
    UARTStdioConfig(0, 115200, 16000000);
// Configure ADC0 for a single-ended input and a single sample.  Once the
// sample is ready, an interrupt flag will be set.  Using a polling method,
// the data will be read then displayed on the console via UART0.
int
main(void)
    uint32_t ui32SysClock;
    // This array is used for storing the data read from the ADC FIFO. It
    // must be as large as the FIFO for the sequencer in use.  This example
    // uses sequence 3 which has a FIFO depth of 1.  If another sequence
    // was used with a deeper FIFO, then the array size must be changed.
    uint32_t pui32ADC0Value[1];
    // Set the clocking to run at 20 MHz (200 MHz / 10) using the PLL.  When
    // using the ADC, you must either use the PLL or supply a 16 MHz clock
    // source.
    // TODO: The SYSCTL_XTAL_ value must be changed to match the value of the
    // crystal on your board.
    ui32SysClock = SysCtlClockFreqSet((SYSCTL_XTAL_25MHZ |
                                       SYSCTL_OSC_MAIN |
                                       SYSCTL_USE_PLL |
                                       SYSCTL_CFG_VCO_480), 20000000);
    // Set up the serial console to use for displaying messages.  This is
    // just for this example program and is not needed for ADC operation.
    InitConsole();
    // The ADC0 peripheral must be enabled for use.
    SysCtlPeripheralEnable(SYSCTL_PERIPH_ADC0);
    // For this example ADC0 is used with AIN0 on port E7.
    // The actual port and pins used may be different on your part, consult
    // the data sheet for more information.  GPIO port E needs to be enabled
    // so these pins can be used.
    SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOE);
    // Select the analog ADC function for these pins.
    // Consult the data sheet to see which functions are allocated per pin.
    GPIOPinTypeADC(GPIO_PORTE_BASE, GPIO_PIN_3);
    // Enable sample sequence 3 with a processor signal trigger.  Sequence 3
    // will do a single sample when the processor sends a signal to start the
    // conversion.  Each ADC module has 4 programmable sequences, sequence 0
    // to sequence 3.  This example is arbitrarily using sequence 3.
    ADCSequenceConfigure(ADC0_BASE, 3, ADC_TRIGGER_PROCESSOR, 0);
    // Configure step 0 on sequence 3.  Sample channel 0 (ADC_CTL_CH0) in
    // single-ended mode (default) and configure the interrupt flag
    // (ADC_CTL_IE) to be set when the sample is done.  Tell the ADC logic
    // that this is the last conversion on sequence 3 (ADC_CTL_END).  Sequence
    // 3 has only one programmable step.  Sequence 1 and 2 have 4 steps, and
    // sequence 0 has 8 programmable steps.  Since we are only doing a single
    // conversion using sequence 3 we will only configure step 0.  For more
    // information on the ADC sequences and steps, reference the datasheet.
    ADCSequenceStepConfigure(ADC0_BASE, 3, 0, ADC_CTL_CH0 | ADC_CTL_IE |
                             ADC_CTL_END);
    // Since sample sequence 3 is now configured, it must be enabled.
    ADCSequenceEnable(ADC0_BASE, 3);
    // Clear the interrupt status flag.  This is done to make sure the
    // interrupt flag is cleared before we sample.
    ADCIntClear(ADC0_BASE, 3);
    // Sample AIN0 forever.  Display the value on the console.
    while(1)
        // Trigger the ADC conversion.
        ADCProcessorTrigger(ADC0_BASE, 3);
        // Wait for conversion to be completed.
        while(!ADCIntStatus(ADC0_BASE, 3, false))
        // Clear the ADC interrupt flag.
        // Read ADC Value.
        ADCSequenceDataGet(ADC0_BASE, 3, pui32ADC0Value);
        // Display the AIN0 (PE3) digital value on the console.
        UARTprintf("AIN0 = %4d\r", pui32ADC0Value[0]);
        // This function provides a means of generating a constant length
        // delay.  The function delay (in cycles) = 3 * parameter.  Delay
        // 250ms arbitrarily.
        SysCtlDelay(ui32SysClock / 12);
S
this is the udp.c file
#include <stdint.h>
#include "inc/hw_ints.h"
#include "driverlib/flash.h"
#include "driverlib/interrupt.h"
#include "driverlib/rom_map.h"
#include "driverlib/systick.h"
#include "utils/lwiplib.h"
#include "utils/ustdlib.h"
#include "drivers/pinout.h"
#include "lwip/udp.h"
//! \addtogroup example_list
//! <h1>Ethernet with lwIP (enet_lwip)</h1>
//! This example application demonstrates the operation of the Tiva
//! Ethernet controller using the lwIP TCP/IP Stack.  DHCP is used to obtain
//! an Ethernet address.  If DHCP times out without obtaining an address,
//! AutoIP will be used to obtain a link-local address.  The address that is
//! selected will be shown on the UART.
//! UART0, connected to the ICDI virtual COM port and running at 115,200,
//! 8-N-1, is used to display messages from this application. Use the
//! following command to re-build the any file system files that change.
//!     ../../../../tools/bin/makefsfile -i fs -o enet_fsdata.h -r -h -q
//! For additional details on lwIP, refer to the lwIP web page at:
//! <a href="http://savannah.nongnu.org/projects/lwip/">savannah.nongnu.org/.../</a>
// Defines for setting up the system clock.
#define SYSTICKHZ               100
#define SYSTICKMS               (1000 / SYSTICKHZ)
// Interrupt priority definitions.  The top 3 bits of these values are
// significant with lower values indicating higher priority interrupts.
#define SYSTICK_INT_PRIORITY    0x80
#define ETHERNET_INT_PRIORITY   0xC0
// The current IP address.
uint32_t g_ui32IPAddress;
// The system clock frequency.
uint32_t g_ui32SysClock;
// Volatile global flag to manage LED blinking, since it is used in interrupt
// and main application.  The LED blinks at the rate of SYSTICKHZ.
volatile bool g_bLED;
// The error routine that is called if the driver library encounters an error.
#ifdef DEBUG
void
__error__(char *pcFilename, uint32_t ui32Line)
#endif
void ADC_init( void );
void udp_echo_init( void );
// Display an lwIP type IP Address.
void
DisplayIPAddress(uint32_t ui32Addr)
    char pcBuf[16];
    // Convert the IP Address into a string.
    usprintf(pcBuf, "%d.%d.%d.%d", ui32Addr & 0xff, (ui32Addr >> 8) & 0xff,
            (ui32Addr >> 16) & 0xff, (ui32Addr >> 24) & 0xff);
    // Display the string.
    UARTprintf(pcBuf);
// Required by lwIP library to support any host-related timer functions.
void
lwIPHostTimerHandler(void)
    uint32_t ui32NewIPAddress;
    // Get the current IP address.
    ui32NewIPAddress = lwIPLocalIPAddrGet();
    // See if the IP address has changed.
    if(ui32NewIPAddress != g_ui32IPAddress)
        // See if there is an IP address assigned.
        if(ui32NewIPAddress == 0xffffffff)
            // Indicate that there is no link.
            UARTprintf("Waiting for link.\n");
        else if(ui32NewIPAddress == 0)
            // There is no IP address, so indicate that the DHCP process is
            // running.
            UARTprintf("Waiting for IP address.\n");
        else
            // Display the new IP address.
            UARTprintf("IP Address: ");
            DisplayIPAddress(ui32NewIPAddress);
            UARTprintf("\nEcho Server is ready.\n");
        // Save the new IP address.
        g_ui32IPAddress = ui32NewIPAddress;
    // If there is not an IP address.
    if((ui32NewIPAddress == 0) || (ui32NewIPAddress == 0xffffffff))
        // Do nothing and keep waiting.
// The interrupt handler for the SysTick interrupt.
void
SysTickIntHandler(void)
    // Call the lwIP timer handler.
    lwIPTimer(SYSTICKMS);
    // Tell the application to change the state of the LED (in other words
    // blink).
    g_bLED = true;
// This example demonstrates the use of the Ethernet Controller.
int
main(void)
    uint32_t ui32User0, ui32User1;
    uint8_t pui8MACArray[8];
//    uint32_t pui32ADC0Value[1];
    // Make sure the main oscillator is enabled because this is required by
    // the PHY.  The system must have a 25MHz crystal attached to the OSC
    // pins. The SYSCTL_MOSC_HIGHFREQ parameter is used when the crystal
    // frequency is 10MHz or higher.
    SysCtlMOSCConfigSet(SYSCTL_MOSC_HIGHFREQ);
    // Run from the PLL at 120 MHz.
    g_ui32SysClock = MAP_SysCtlClockFreqSet((SYSCTL_XTAL_25MHZ |
                                             SYSCTL_OSC_MAIN |
                                             SYSCTL_USE_PLL |
                                             SYSCTL_CFG_VCO_480), 120000000);
    PinoutSet(true, false);
    // Configure UART.
    UARTStdioConfig(0, 115200, g_ui32SysClock);
    // Clear the terminal and print banner.
    UARTprintf("\033[2J\033[H");
    UARTprintf("Ethernet lwIP udp echo example\n\n");
    // Configure Port N1 for as an output for the animation LED.
    MAP_GPIOPinTypeGPIOOutput(GPIO_PORTN_BASE, GPIO_PIN_1);
    // Initialize LED to OFF (0)
    MAP_GPIOPinWrite(GPIO_PORTN_BASE, GPIO_PIN_1, ~GPIO_PIN_1);
    // Configure SysTick for a periodic interrupt.
    MAP_SysTickPeriodSet(g_ui32SysClock / SYSTICKHZ);
    MAP_SysTickEnable();
    MAP_SysTickIntEnable();
    // Configure the hardware MAC address for Ethernet Controller filtering of
    // incoming packets.  The MAC address will be stored in the non-volatile
    // USER0 and USER1 registers.
    MAP_FlashUserGet(&ui32User0, &ui32User1);
    if((ui32User0 == 0xffffffff) || (ui32User1 == 0xffffffff))
        // We should never get here.  This is an error if the MAC address has
        // not been programmed into the device.  Exit the program.
        // Let the user know there is no MAC address
        UARTprintf("No MAC programmed!\n");
        while(1)
    // Tell the user what we are doing just now.
    UARTprintf("Waiting for IP.\n");
    // Convert the 24/24 split MAC address from NV ram into a 32/16 split MAC
    // address needed to program the hardware registers, then program the MAC
    // address into the Ethernet Controller registers.
    pui8MACArray[0] = ((ui32User0 >>  0) & 0xff);
    pui8MACArray[1] = ((ui32User0 >>  8) & 0xff);
    pui8MACArray[2] = ((ui32User0 >> 16) & 0xff);
    pui8MACArray[3] = ((ui32User1 >>  0) & 0xff);
    pui8MACArray[4] = ((ui32User1 >>  8) & 0xff);
    pui8MACArray[5] = ((ui32User1 >> 16) & 0xff);
    // Initialize the lwIP library, using DHCP.
    lwIPInit(g_ui32SysClock, pui8MACArray, 0, 0, 0, IPADDR_USE_DHCP);
    // Initialize the echo server.
    //Run the udpSendReceive Linux or Windows executable that is shipped with TI-RTOS.
    //The executable is found in:
      //<tirtos_install_dir>\packages\examples\tools\udpSendReceive
      //Usage: ./udpSendReceive <IP-addr> <port> <id> -l[length] -s[sleep in uS]
      //<IP-addr> is the IP address
      //<port>    is the UDP port being listened to (23)
      //<id>      is a unique id for the executable. Printed out when 1000 packets are
      //          transmitted. It allows the user to run multiple instances
      //          of udpSendReceive.
      //Optional:
      //  -l[length]      size of the packet in bytes. Default is 1024 bytes.
      //  -s[sleep in uS] usleep time to between sends. Default is 1000 uSecs.
      //Example:
      //      udpSendReceive 192.168.1.5 23 1 -s100
    //Messages such as the following will begin to appear on the terminal window when
    //a UDP packet has been echoed back:
    //        Starting test with a 1000 uSec delay between transmits
    //        [id 1] count = 1000, time = 12
    //        [id 1] count = 2000, time = 24
    //        [id 1] count = 3000, time = 36
   udp_echo_init();
    // Set the interrupt priorities.  We set the SysTick interrupt to a higher
    // priority than the Ethernet interrupt to ensure that the file system
    // tick is processed if SysTick occurs while the Ethernet handler is being
    // processed.  This is very likely since all the TCP/IP and HTTP work is
    // done in the context of the Ethernet interrupt.
    MAP_IntPrioritySet(INT_EMAC0, ETHERNET_INT_PRIORITY);
    MAP_IntPrioritySet(FAULT_SYSTICK, SYSTICK_INT_PRIORITY);
    // Loop forever, processing the LED blinking.  All the work is done in
    // interrupt handlers.
    while(1)
        // Wait till the SysTick Interrupt indicates to change the state of the
        // LED.
        while(g_bLED == false)
        // Clear the flag.
        g_bLED = false;
        // Toggle the LED.
                         (MAP_GPIOPinRead(GPIO_PORTN_BASE, GPIO_PIN_1) ^
                          GPIO_PIN_1));
      //   UARTprintf("AIN0 = %4d\r", pui32ADC0Value[0]);
//         SysCtlDelay(g_ui32SysClock / 12);
void ADC_init(void)
                              ADC_CTL_END);
// Read ADC Value.
void udp_echo_recv(void *arg, struct udp_pcb *pcb, struct pbuf *p, struct
ip_addr *addr, u16_t port)
    ADC_init();
    if (p != NULL) {
        p=pbuf_alloc(PBUF_TRANSPORT, 1, PBUF_RAM);
        memcpy(p->payload, pui32ADC0Value[0], 1);
        /* send received packet back to sender */
        udp_sendto(pcb, p, addr, 12345);
        /* free the pbuf */
        pbuf_free(p);
void udp_echo_init(void)
    struct udp_pcb * pcb;
    /* get new pcb */
    pcb = udp_new();
    if (pcb == NULL) {
        LWIP_DEBUGF(UDP_DEBUG, ("udp_new failed!\n"));
        return;
    /* bind to any IP address on port 23 */
    if (udp_bind(pcb, IP_ADDR_ANY, 23) != ERR_OK) {
        LWIP_DEBUGF(UDP_DEBUG, ("udp_bind failed!\n"));
        return;
    /* set udp_echo_recv() as callback function
       for received packets */
    udp_recv(pcb, udp_echo_recv, NULL);
  • I am not really sure what you are asking. You have examples on how to use the ADC and UDP on LWIP. LWIP is not a TI product. You can find more information on LWIP from https://www.nongnu.org/lwip/2_1_x/index.html. Are you asking about software to run on the PC? That is beyond how I can help. Are you asking for me to debug your software? I can answer specific questions, but it is beyond my charter to debug customer code.
  • my question is i want to transmit continuous stream of data over the udp to pc (the data changes in range 0-2000).
  • OK, but that does not tell me what you have tried and where you are stuck. Are you able to successfully take periodic ADC readings? Are you stuck on the UDP transmit? Maybe a different example will help you. Look at the TivaWare example in:
    C:\ti\TivaWare_C_Series-2.2.0.274\examples\boards\ek-tm4c1294xl\enet_uip
    This example uses the SysTick timer to check for received packets and send transmit packets.
