Part Number: TMDSEMU110-U
Other Parts Discussed in Thread: F28M36P63C2
Hello
OS: Ubuntu 19.10
Probe: XDS110 Debug Probe
CCS Version: 9.3.0.00012
Chip: F28M36P63C2
In CCS, Project>>Properties>>General>>Connection>>Texas Instruments XDS110 Debug Probe, Click Verify
Error parsing file: Fatal Error at (0, 0): An exception occurred! Type:RuntimeException, Message:The primary document entity could not be opened. Id=/opt/ti/ccs930/ccs/ccs_base/common/Modules/C2000/C2000_ADC_Type3_M3_Result_Registers.xml while parsing file: /opt/ti/ccs930/ccs/ccs_base/common/Modules/C2000/C2000_ADC_Type3_M3_Result_Registers.xml
While searching for this file, the actual location is:
/opt/ti/ccs930/ccs/ccs_base/common/targetdb/Modules/C2000
We were originally developing on windows, and switched to Ubuntu, and most likely went from ccs9 something to the current 9.3.0.00012 version we have. Note the probe is not connected to the board, only the computer over USB.
Is this a windows vs linux file path?
How do I correct this search path? To work on both platforms
Does something need to be updated?
Thank you,
