Other Parts Discussed in Thread: OMAPL138
k2gUser@poppy:~/ti/ipcdev-3.50.04.08B$ make -f ipc-linux.mak config
Configuring Linux Ipc ...
./configure --host=arm-none-eabi \
--prefix=/home/k2gUser/ti/ipcdev-3.50.04.08B/IPC_install \
CC=/home/k2gUser/ti/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc \
PLATFORM=66AK2G \
CMEM_INSTALL_DIR= \
KERNEL_INSTALL_DIR= \
DRM_PREFIX= \
AF_RPMSG=45
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for arm-none-eabi-strip... no
checking for strip... strip
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether make supports nested variables... yes
checking whether to enable maintainer-specific portions of Makefiles... no
checking build system type... x86_64-pc-linux-gnu
checking host system type... arm-none-eabi
checking how to print strings... printf
checking for style of include used by make... GNU
checking for arm-none-eabi-gcc... /home/k2gUser/ti/gcc-arm-none-eabi-7-2018-q2-update/bin/arm-none-eabi-gcc
checking whether the C compiler works... no
configure: error: in `/home/k2gUser/ti/ipcdev-3.50.04.08B':
configure: error: C compiler cannot create executables
See `config.log' for more details
ipc-linux.mak:56: recipe for target 'config' failed
make: *** [config] Error 77
k2gUser@poppy:~/ti/ipcdev-3.50.04.08B$ cat products.mak
# Copyright (c) 2012-2018 Texas Instruments Incorporated - http://www.ti.com
# Redistribution and use in source and binary forms, with or without
# modification, are permitted provided that the following conditions
# are met:
# * Redistributions of source code must retain the above copyright
# notice, this list of conditions and the following disclaimer.
# * Redistributions in binary form must reproduce the above copyright
# notice, this list of conditions and the following disclaimer in the
# documentation and/or other materials provided with the distribution.
# * Neither the name of Texas Instruments Incorporated nor the names of
# its contributors may be used to endorse or promote products derived
# from this software without specific prior written permission.
# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
# THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
# PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
# CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
# EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
# PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
# OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
# WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
# OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
# EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
# ======== products.mak ========
# Note that these variables can be explicitly set here or on the command line.
# If you want to use variables in the environment, see the GNU make manual's
# -e option: www.gnu.org/.../make.html
# Optional: recommended to install all dependent components in one folder.
DEPOT = /home/k2gUser/ti
# Platform to build for
# Supported platforms (choose one):
# OMAPL138, OMAP54XX, DRA7XX, 66AK2G, 66AK2E, TCI6630, TCI6636, TCI6638,
# TDA3XX, AM65XX
# Note, this is used for Linux, QNX and BIOS builds
PLATFORM = 66AK2G
# Destination when installing the built binaries
# Note, this is used for Linux (if you use ipc-linux.mak to run the
# configure command), QNX and BIOS.
DESTDIR = /home/k2gUser/ti/ipcdev-3.50.04.08B/IPC_install
#################### IPC Linux ####################
# Set up required cross compiler path for IPC Linux configuration and build
#TOOLCHAIN_LONGNAME = arm-none-linux-gnueabi
TOOLCHAIN_LONGNAME = arm-none-eabi
TOOLCHAIN_INSTALL_DIR = $(DEPOT)/gcc-arm-none-eabi-7-2018-q2-update
TOOLCHAIN_PREFIX = $(TOOLCHAIN_INSTALL_DIR)/bin/$(TOOLCHAIN_LONGNAME)-
# Path to Linux Kernel - needed to build the IPC user libraries
KERNEL_INSTALL_DIR =
# Optional: Specify the Address Family for RPMSG. This value is specified
# either from the Linux kernel specified by KERNEL_INSTALL_DIR above, or
# the make variable AF_RPMSG below. Do not use both.
AF_RPMSG = 45
# Optional: Path to DRM Library
DRM_PREFIX =
# Optional: Path to TI Linux Utils product
CMEM_INSTALL_DIR =
#################### IPC QNX ####################
# Path to QNX tools installation
QNX_INSTALL_DIR =
# Optional: Any additional compile options
QNX_CFLAGS =
#################### IPC Bios ####################
# Path to required dependencies for IPC BIOS builds
XDC_INSTALL_DIR = $(DEPOT)/xdctools_3_55_02_22_core
BIOS_INSTALL_DIR = $(DEPOT)/bios_6_76_02_02
PDK_INSTALL_DIR = $(DEPOT)/pdk_k2g_1_0_15
# Do you want to build SMP-enabled libraries (if supported for your target)?
# Set to either 0 (disabled) or 1 (enabled)
BIOS_SMPENABLED=1
# Path to various cgtools
ti.targets.elf.C64P =
ti.targets.elf.C64T =
ti.targets.elf.C66 = /home/k2gUser/ti/ccs1000/ccs/tools/compiler/ti-cgt-c6000_8.3.6
ti.targets.elf.C674 =
ti.targets.arm.elf.Arm9 =
ti.targets.arm.elf.A8F =
ti.targets.arm.elf.A8Fnv =
ti.targets.arm.elf.M3 =
ti.targets.arm.elf.M4 =
ti.targets.arm.elf.M4F =
ti.targets.arm.elf.R5F =
ti.targets.arp32.elf.ARP32 =
ti.targets.arp32.elf.ARP32_far =
gnu.targets.arm.A8F =
gnu.targets.arm.A15F = /home/k2gUser/ti/gcc-arm-none-eabi-9-2019-q4-major-x86_64-linux
gnu.targets.arm.A53F =
Build machine:
Ubuntu 18.04 SMP x86_64
Note using the tools provided with CCS-10 produced the same message. Version ipc_3_50_04_07 also failed.
