CCS/MSP430F5528: MSP-FET
Part Number: MSP430F5528
Other Parts Discussed in Thread: MSP-FET, MSP-FLASHER
I'm using the MSP-TS430RGC64USB with MSP-FET.
When I connect my MSP-FET to CCS 10.0, it starts configuring Debugger, it says (Error initializing emulator. A firmware update is required). Upon clicking update, it starts the update process but then it shows me an error that says "Error initlziating emulator, could not set device Vcc". I looked up solutions, and it said try to use the MSP-Flasher. When I run the MSP-Flasher, this is the error that pops up.
C:\ti\MSPFlasher_1.3.19>MSP430Flasher.exe -w "Firmware.txt" -v -g -z [VCC]
*     / |__        *
*    /_   /   MSP Flasher v1.3.19                                             *
* Evaluating triggers...done
* Checking for available FET debuggers:
* Found USB FET @ COM6 <- Selected
* Initializing interface @ COM6...done
* Checking firmware compatibility:
* FET firmware is up to date.
* Reading FW version...done
* Setting VCC to 3000 mV...done
* Accessing device...
# Exit: 16
# ERROR: Unknown device
* Starting target code execution...done
* Disconnecting from device...done
* Driver      : closed (Internal error)
As you can see, there's conflicting information from CCS and MSPFlasher, CCS says I need an update, Flasher says I do not but then fails.
How can I go about fixing this?
Thanks.
  • Hi Raghav,
    I would suggest trying Uniflash and see what information it reports.  Let me know what you find.
  • Hello Raghav,
    I haven’t heard from you for a couple of days now, so I’m assuming you were able to resolve your issue.
    If this isn’t the case, please click the "This did NOT resolve my issue" button and reply to this thread with more information.
    If this thread locks, please click the "Ask a related question" button and in the new thread describe the current status of your issue and any additional details you may have to assist us in helping to solve your issues.
