CCS/66AK2H12: TI/RTOS NDK - Initializing FD environment: fdOpenSession vs autoOpenCloseFD = true
Part Number: 66AK2H12
PDK 4.0.7, NDK 2.25.1.11, SYS/BIOS 6.45.5.55, IPC 3.46.2.04, EDMA3 2.12.4, CTools 2.2.0
I've got a task that needs to use the file descriptor environment (require using pipe()). This task is not created by main().
The flow is:
main() {Task_create(myFunc())};
myFunc() { Task_create( funcWithProblem()) }
In funcWithProblem() is where I need the fd environment and is where I call pipe(). I had fdOpenSession() in funcWithProblem() and it works. I commented that out and placed in my CFG file the following per the NDK API user manual:
var Ndk = xdc.useModule('ti.ndk.config.Global');
Ndk.autoOpenCloseFD = true;
Now the call to pipe() fails returning -1.  ffdError() returns -1, a sure indication that the fd environment is not initialized.
What am I doing wrong?
Mike
