Part Number: CCSTUDIO
Hello all,
I was trying to install CCS 10.1 and 10.0 on openSUSE 15.1 but both installers fails on ti_cgt_tms470 package installation because of segmentation fault in this installer. I tried to run this installer from console and found segfault appearing on exit from this installer:
user@host:~/tmp/tms470> /tmp/ccs_308bab8b-971f-41d7-4157-4d0454d53800/CGT_DEFAULTLIBS_TMS470/ti_cgt_tms470_20.2.0.LTS_linux_installer_x86.bin --prefix "/home/user/ti/ccs1000/ccs" --eclipseprefix "/home/user/ti/ccs1000/ccs/eclipse" --ccs true
Welcome to the TMS470 Code Generation Tools Setup Wizard.
Select Installation Directory
Please specify the directory where TMS470 Code Generation Tools will be
installed. The installation requires 445254 KB.
Destination Directory [/home/realmer/ti/ccs1000/ccs/tools/compiler/ti-cgt-arm_20.2.0.LTS]:
Setup is now ready to begin installing TMS470 Code Generation Tools on your
computer.
Do you want to continue? [Y/n]:
Please wait while Setup installs TMS470 Code Generation Tools on your computer.
Installing
0% ______________ 50% ______________ 100%
Setup has finished installing TMS470 Code Generation Tools on your computer.
Segmentation fault (core dumped)
Installation was started with following parameters: ./ccs_setup_10.0.0.00010.run --enable-components PF_MSP432,PF_CC2X,PF_CC3X,PF_TM4C
Both full and web install of 10 and 10.1 shows same behavior. 9.3 installs without any problems. Logs were uploaded during installation.
Is there a way to bypass this error somehow or make manual installation to use CCS 10.1? Or is there a way to troubleshoot it more?
