CCS/TMS320F28069M: Issue Connecting to Target
Part Number: TMS320F28069M
Other Parts Discussed in Thread: BOOSTXL-3PHGANINV, CONTROLSUITE, C2000WARE, MOTORWARE, DRV8301
I'm having an issue starting a debug session because it will not connect to target. This is the first time building and debugging, so the device has never connected. The errors are shown in image.
I did a connectivity test and it failed.
Any help would be appreciated!
    You are getting build errors, hence your project did not build successfully.
    I see several errors. The main one is a common linker error:
    https://software-dl.ti.com/ccs/esd/documents/dmed/HTML/10099.html
    Are you working with an existing example? Or is this your own custom project?
    ki
  • I'm using Instaspin Lab 2a (suggested for using BOOSTXL-3PhGaNInv in the manual)
  • Which version of C2000Ware or ControlSUITE are you using?
  • controlSUITE3.4.9 and motorware_1_01_00_18
  • Thanks. I can't seem to find the example for BOOSTXL-3PhGaNInv in my motorware installation. Where did you find it?
  • I found it in the manual starting on page 8 "4 InstaSPIN-FOC Example Project for Teknic Servo Motor M-2310P-LN-04K"sluubp1a.pdf
  • Thanks. I was able to follow the steps and the project built successfully. Can you post all the build messages in your build console? You can copy and paste to a text file and post the file to this thread.
    ki
  • Hi Ki,
    The main issue is the debug session would not work because it would not connect to target, the target configuration verification failed.
    Here is my build message:
    **** Build of configuration Release for project proj_lab02a ****
    "C:\\ti\\ccs1011\\ccs\\utils\\bin\\gmake" -k all
    Building target: "proj_lab02a.out"
    Invoking: C2000 Linker
    "C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-c2000_20.2.1.LTS/bin/cl2000" -v28 -ml -mt --cla_support=cla0 --float_support=fpu32 --vcu_support=vcu0 -O2 --define=FAST_ROM_V1p6 -g --diag_warning=225 --display_error_number --abi=coffabi -z -m"proj_lab02a.map" --stack_size=0x3B0 --warn_sections -i"C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-c2000_20.2.1.LTS/lib" -i"C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-c2000_20.2.1.LTS/include" --priority --reread_libs --disable_auto_rts --diag_suppress=16002 --xml_link_info="proj_lab02a_linkInfo.xml" --rom_model -o "proj_lab02a.out" "C:/ti/motorware/motorware_1_01_00_18/sw/modules/fast/lib/32b/f28x/f2806x/2806xRevB_FastSpinROMSymbols.lib" "C:/ti/motorware/motorware_1_01_00_18/sw/modules/iqmath/lib/f28x/32b/IQmath.lib" "./CodeStartBranch.obj" "./adc.obj" "./clk.obj" "./cpu.obj" "./drv8301.obj" "./flash.obj" "./gpio.obj" "./hal.obj" "./osc.obj" "./pie.obj" "./pll.obj" "./proj_lab02a-BOOSTXL-3PhGaNInv.obj" "./pwm.obj" "./pwr.obj" "./spi.obj" "./timer.obj" "./usDelay.obj" "./user.obj" "./wdog.obj" "../28069_RAM_lnk.cmd" -llibc.a
    <Linking>
    error #16008-D: file
    06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out_FD$$MPY_tmp.ob
    j>" specifies ISA revision "C2800", which is not compatible with ISA
    revision "C28FPU32" specified in a previous file or on the command line
    06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out_FD$$TOL_tmp.ob
    revision "C2700" specified in a previous file or on the command line
    06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out_FS$$DIV_tmp.ob
    06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out_FS$$TOFD_tmp.o
    bj>" specifies ISA revision "C2800", which is not compatible with ISA
    06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__CTRL_getVersi
    on_tmp.obj>" specifies ISA revision "C2800", which is not compatible with
    ISA revision "C2700" specified in a previous file or on the command line
    06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__CTRL_initCtrl
    _tmp.obj>" specifies ISA revision "C2800", which is not compatible with ISA
    06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__CTRL_run_tmp.
    06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__CTRL_setGains
    06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__CTRL_setParam
    s_tmp.obj>" specifies ISA revision "C2800", which is not compatible with ISA
    06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__CTRL_setSpd_r
    ef_krpm_tmp.obj>" specifies ISA revision "C2800", which is not compatible
    with ISA revision "C2700" specified in a previous file or on the command
    line
    06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__CTRL_setup_tm
    06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__CTRL_updateSt
    ate_tmp.obj>" specifies ISA revision "C2800", which is not compatible with
    06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_computeDi
    rection_qFmt_tmp.obj>" specifies ISA revision "C2800", which is not
    compatible with ISA revision "C2700" specified in a previous file or on the
    command line
    06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_getFlux_V
    pHz_tmp.obj>" specifies ISA revision "C2800", which is not compatible with
    06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_getFlux_p
    u_tmp.obj>" specifies ISA revision "C2800", which is not compatible with ISA
    06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_getIdRate
    d_tmp.obj>" specifies ISA revision "C2800", which is not compatible with ISA
    06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_getLs_coa
    rse_max_pu_tmp.obj>" specifies ISA revision "C2800", which is not compatible
    line
    06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_getLs_d_H
    06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_getLs_d_p
    06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_getLs_q_H
    06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_getLs_q_p
    06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_getMaxCur
    rentSlope_pu_tmp.obj>" specifies ISA revision "C2800", which is not
    command line
    06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_getRr_Ohm
    06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_getRs_Ohm
    06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_getSpeed_
    krpm_tmp.obj>" specifies ISA revision "C2800", which is not compatible with
    06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_getState_
    06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_get_pu_to
    _krpm_sf_tmp.obj>" specifies ISA revision "C2800", which is not compatible
    line
    06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_isMotorId
    entified_tmp.obj>" specifies ISA revision "C2800", which is not compatible
    line
    06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_setDir_qF
    mt_tmp.obj>" specifies ISA revision "C2800", which is not compatible with
    06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_setFe_neg
    line
    06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_setFe_pos
    _min_pu_tmp.obj>" specifies ISA revision "C2800", which is not compatible
    line
    06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_setFlag_e
    nableForceAngle_tmp.obj>" specifies ISA revision "C2800", which is not
    command line
    06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_setLs_d_p
    06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_setLs_qFm
    t_tmp.obj>" specifies ISA revision "C2800", which is not compatible with ISA
    06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_setLs_q_p
    06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__EST_setMaxCur
    command line
    06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__OFFSET_init_t
    06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__OFFSET_setBet
    a_tmp.obj>" specifies ISA revision "C2800", which is not compatible with ISA
    06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__OFFSET_setIni
    tCond_tmp.obj>" specifies ISA revision "C2800", which is not compatible with
    06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__OFFSET_setOff
    set_tmp.obj>" specifies ISA revision "C2800", which is not compatible with
    lib<IQ30toF.obj>" specifies ISA revision "C2800", which is not compatible
    line
    error #16008-D: file "boot28.asm.obj in
    C:\ti\ccs1011\ccs\tools\compiler\ti-cgt-c2000_20.2.1.LTS\lib\rts2800_fpu32.l
    ib" specifies ISA revision "C28FPU32", which is not compatible with ISA
    06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__log_tmp.obj>"
    specifies ISA revision "C2800", which is not compatible with ISA revision
    06xRevB_FastSpinROMSymbols.lib<TMS320x2806x_REVB_boot_rom_out__pow_tmp.obj>"
    warning #10247-D: creating output section "ramfuncs" without a SECTIONS
    specification
    "../28069_RAM_lnk.cmd", line 121: error #10099-D: program will not fit into
    available memory, or the section contains a call site that requires a
    trampoline that can't be generated for this section. placement with
    alignment/blocking fails for section ".text" size 0x20f1page 0. Available
    memory ranges:
    RAML0_L3 size: 0x2000 unused: 0x1fec max hole: 0x1fec
    error #10010: errors encountered during linking; "proj_lab02a.out" not built
    >> Compilation failure
    makefile:160: recipe for target 'proj_lab02a.out' failed
    gmake: *** [proj_lab02a.out] Error 1
    gmake: Target 'all' not remade because of errors.
    **** Build Finished ****
  • Interesting. Your linker build options are different than mine:
    "C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-c2000_20.2.1.LTS/bin/cl2000" -v28 -ml -mt -O2 --define=FAST_ROM_V1p6 -g --diag_warning=225 --display_error_number --abi=coffabi -z -m"proj_lab02a.map" --stack_size=0x3B0 --warn_sections -i"C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-c2000_20.2.1.LTS/lib" -i"C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-c2000_20.2.1.LTS/include" --priority --reread_libs --disable_auto_rts --diag_suppress=16002 --xml_link_info="proj_lab02a_linkInfo.xml" --rom_model -o "proj_lab02a.out" -lrts2800_ml.lib "C:/ti/motorware/motorware_1_01_00_18/sw/modules/fast/lib/32b/f28x/f2806x/2806xRevB_FastSpinROMSymbols.lib" "C:/ti/motorware/motorware_1_01_00_18/sw/modules/iqmath/lib/f28x/32b/IQmath.lib" "./CodeStartBranch.obj" "./adc.obj" "./clk.obj" "./cpu.obj" "./drv8301.obj" "./flash.obj" "./gpio.obj" "./hal.obj" "./osc.obj" "./pie.obj" "./pll.obj" "./proj_lab02a-BOOSTXL-3PhGaNInv.obj" "./pwm.obj" "./pwr.obj" "./spi.obj" "./timer.obj" "./usDelay.obj" "./user.obj" "./wdog.obj" "C:/ti/motorware/motorware_1_01_00_18/sw/ide/ccs/cmd/f2806x/f28069F_ram_lnk.cmd"
    <Linking>
    Finished building target: "proj_lab02a.out"
    Did you change any of the options? The options should be based on the "boostxldrv8301_revB" that you copied and renamed as per the instructions. I am using the same motorware version as you.
    ki
  • I have not edited my linker options. They are as follows:
    -m"${ProjName}.map" --stack_size=0x3B0 --warn_sections -i"${CG_TOOL_ROOT}/lib" -i"${CG_TOOL_ROOT}/include" --priority --reread_libs --disable_auto_rts --diag_suppress=16002 --xml_link_info="${ProjName}_linkInfo.xml" --rom_model
  • I followed the procedure for linking as shown here:
  • Can you try importing my project (into a new workspace) and see if it builds for you?
    /cfs-file/__key/communityserver-discussions-components-files/81/proj_5F00_lab02a.zip
    I built your project and it eliminated the linking error. The current errors are shown in the image. Here is my console report:
    **** Clean-only build of configuration Release for project proj_lab02a ****
    "C:\\ti\\ccs1011\\ccs\\utils\\bin\\gmake" -k clean
    DEL /F "proj_lab02a.hex" "proj_lab02a.out"
    DEL /F "CodeStartBranch.obj" "adc.obj" "clk.obj" "cpu.obj" "drv8301.obj" "flash.obj" "gpio.obj" "hal.obj" "osc.obj" "pie.obj" "pll.obj" "proj_lab02a-BOOSTXL-3PhGaNInv.obj" "pwm.obj" "pwr.obj" "spi.obj" "timer.obj" "usDelay.obj" "user.obj" "wdog.obj"
    DEL /F "adc.d" "clk.d" "cpu.d" "drv8301.d" "flash.d" "gpio.d" "hal.d" "osc.d" "pie.d" "pll.d" "proj_lab02a-BOOSTXL-3PhGaNInv.d" "pwm.d" "pwr.d" "spi.d" "timer.d" "user.d" "wdog.d"
    DEL /F "CodeStartBranch.d" "usDelay.d"
    Could Not Find C:\ti\motorware\motorware_1_01_00_18\sw\solutions\instaspin_foc\boards\boostxl-3PhGanInv\f28x\f2806xF\projects\ccs\tisupportproj_lab02a\proj_lab02a\Release\CodeStartBranch.d
    Finished clean
    Building file: "C:/ti/motorware/motorware_1_01_00_18/sw/drivers/cpu/src/32b/f28x/f2806x/CodeStartBranch.asm"
    Invoking: C2000 Compiler
    "C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-c2000_20.2.1.LTS/bin/cl2000" -v28 -ml -mt -O2 --include_path="C:/ti/motorware/motorware_1_01_00_18/sw/modules/hal/boards/boostxl-3PhGanInv/f28x/f2806x/src/" --include_path="C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-c2000_20.2.1.LTS/include" --include_path="C:/ti/motorware/motorware_1_01_00_18/sw/solutions/instaspin_foc/boards/boostxl-3PhGanInv/f28x/f2806xF/src" --include_path="C:/ti/motorware/motorware_1_01_00_18" --define=FAST_ROM_V1p6 -g --diag_warning=225 --display_error_number --abi=coffabi --preproc_with_compile --preproc_dependency="CodeStartBranch.d_raw" "C:/ti/motorware/motorware_1_01_00_18/sw/drivers/cpu/src/32b/f28x/f2806x/CodeStartBranch.asm"
    Finished building: "C:/ti/motorware/motorware_1_01_00_18/sw/drivers/cpu/src/32b/f28x/f2806x/CodeStartBranch.asm"
    Building file: "C:/ti/motorware/motorware_1_01_00_18/sw/drivers/adc/src/32b/f28x/f2806x/adc.c"
    "C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-c2000_20.2.1.LTS/bin/cl2000" -v28 -ml -mt -O2 --include_path="C:/ti/motorware/motorware_1_01_00_18/sw/modules/hal/boards/boostxl-3PhGanInv/f28x/f2806x/src/" --include_path="C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-c2000_20.2.1.LTS/include" --include_path="C:/ti/motorware/motorware_1_01_00_18/sw/solutions/instaspin_foc/boards/boostxl-3PhGanInv/f28x/f2806xF/src" --include_path="C:/ti/motorware/motorware_1_01_00_18" --define=FAST_ROM_V1p6 -g --diag_warning=225 --display_error_number --abi=coffabi --preproc_with_compile --preproc_dependency="adc.d_raw" "C:/ti/motorware/motorware_1_01_00_18/sw/drivers/adc/src/32b/f28x/f2806x/adc.c"
    Finished building: "C:/ti/motorware/motorware_1_01_00_18/sw/drivers/adc/src/32b/f28x/f2806x/adc.c"
    Building file: "C:/ti/motorware/motorware_1_01_00_18/sw/drivers/clk/src/32b/f28x/f2806x/clk.c"
    "C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-c2000_20.2.1.LTS/bin/cl2000" -v28 -ml -mt -O2 --include_path="C:/ti/motorware/motorware_1_01_00_18/sw/modules/hal/boards/boostxl-3PhGanInv/f28x/f2806x/src/" --include_path="C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-c2000_20.2.1.LTS/include" --include_path="C:/ti/motorware/motorware_1_01_00_18/sw/solutions/instaspin_foc/boards/boostxl-3PhGanInv/f28x/f2806xF/src" --include_path="C:/ti/motorware/motorware_1_01_00_18" --define=FAST_ROM_V1p6 -g --diag_warning=225 --display_error_number --abi=coffabi --preproc_with_compile --preproc_dependency="clk.d_raw" "C:/ti/motorware/motorware_1_01_00_18/sw/drivers/clk/src/32b/f28x/f2806x/clk.c"
    Finished building: "C:/ti/motorware/motorware_1_01_00_18/sw/drivers/clk/src/32b/f28x/f2806x/clk.c"
    Building file: "C:/ti/motorware/motorware_1_01_00_18/sw/drivers/cpu/src/32b/f28x/f2806x/cpu.c"
    "C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-c2000_20.2.1.LTS/bin/cl2000" -v28 -ml -mt -O2 --include_path="C:/ti/motorware/motorware_1_01_00_18/sw/modules/hal/boards/boostxl-3PhGanInv/f28x/f2806x/src/" --include_path="C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-c2000_20.2.1.LTS/include" --include_path="C:/ti/motorware/motorware_1_01_00_18/sw/solutions/instaspin_foc/boards/boostxl-3PhGanInv/f28x/f2806xF/src" --include_path="C:/ti/motorware/motorware_1_01_00_18" --define=FAST_ROM_V1p6 -g --diag_warning=225 --display_error_number --abi=coffabi --preproc_with_compile --preproc_dependency="cpu.d_raw" "C:/ti/motorware/motorware_1_01_00_18/sw/drivers/cpu/src/32b/f28x/f2806x/cpu.c"
    Finished building: "C:/ti/motorware/motorware_1_01_00_18/sw/drivers/cpu/src/32b/f28x/f2806x/cpu.c"
    Building file: "C:/ti/motorware/motorware_1_01_00_18/sw/drivers/drvic/drv8301/src/32b/f28x/f2806x/drv8301.c"
    "C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-c2000_20.2.1.LTS/bin/cl2000" -v28 -ml -mt -O2 --include_path="C:/ti/motorware/motorware_1_01_00_18/sw/modules/hal/boards/boostxl-3PhGanInv/f28x/f2806x/src/" --include_path="C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-c2000_20.2.1.LTS/include" --include_path="C:/ti/motorware/motorware_1_01_00_18/sw/solutions/instaspin_foc/boards/boostxl-3PhGanInv/f28x/f2806xF/src" --include_path="C:/ti/motorware/motorware_1_01_00_18" --define=FAST_ROM_V1p6 -g --diag_warning=225 --display_error_number --abi=coffabi --preproc_with_compile --preproc_dependency="drv8301.d_raw" "C:/ti/motorware/motorware_1_01_00_18/sw/drivers/drvic/drv8301/src/32b/f28x/f2806x/drv8301.c"
    Finished building: "C:/ti/motorware/motorware_1_01_00_18/sw/drivers/drvic/drv8301/src/32b/f28x/f2806x/drv8301.c"
    Building file: "C:/ti/motorware/motorware_1_01_00_18/sw/drivers/flash/src/32b/f28x/f2806x/flash.c"
    "C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-c2000_20.2.1.LTS/bin/cl2000" -v28 -ml -mt -O2 --include_path="C:/ti/motorware/motorware_1_01_00_18/sw/modules/hal/boards/boostxl-3PhGanInv/f28x/f2806x/src/" --include_path="C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-c2000_20.2.1.LTS/include" --include_path="C:/ti/motorware/motorware_1_01_00_18/sw/solutions/instaspin_foc/boards/boostxl-3PhGanInv/f28x/f2806xF/src" --include_path="C:/ti/motorware/motorware_1_01_00_18" --define=FAST_ROM_V1p6 -g --diag_warning=225 --display_error_number --abi=coffabi --preproc_with_compile --preproc_dependency="flash.d_raw" "C:/ti/motorware/motorware_1_01_00_18/sw/drivers/flash/src/32b/f28x/f2806x/flash.c"
    Finished building: "C:/ti/motorware/motorware_1_01_00_18/sw/drivers/flash/src/32b/f28x/f2806x/flash.c"
    Building file: "C:/ti/motorware/motorware_1_01_00_18/sw/drivers/gpio/src/32b/f28x/f2806x/gpio.c"
    "C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-c2000_20.2.1.LTS/bin/cl2000" -v28 -ml -mt -O2 --include_path="C:/ti/motorware/motorware_1_01_00_18/sw/modules/hal/boards/boostxl-3PhGanInv/f28x/f2806x/src/" --include_path="C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-c2000_20.2.1.LTS/include" --include_path="C:/ti/motorware/motorware_1_01_00_18/sw/solutions/instaspin_foc/boards/boostxl-3PhGanInv/f28x/f2806xF/src" --include_path="C:/ti/motorware/motorware_1_01_00_18" --define=FAST_ROM_V1p6 -g --diag_warning=225 --display_error_number --abi=coffabi --preproc_with_compile --preproc_dependency="gpio.d_raw" "C:/ti/motorware/motorware_1_01_00_18/sw/drivers/gpio/src/32b/f28x/f2806x/gpio.c"
    Finished building: "C:/ti/motorware/motorware_1_01_00_18/sw/drivers/gpio/src/32b/f28x/f2806x/gpio.c"
    Building file: "C:/ti/motorware/motorware_1_01_00_18/sw/modules/hal/boards/boostxl-3PhGanInv/f28x/f2806x/src/hal.c"
    "C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-c2000_20.2.1.LTS/bin/cl2000" -v28 -ml -mt -O2 --include_path="C:/ti/motorware/motorware_1_01_00_18/sw/modules/hal/boards/boostxl-3PhGanInv/f28x/f2806x/src/" --include_path="C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-c2000_20.2.1.LTS/include" --include_path="C:/ti/motorware/motorware_1_01_00_18/sw/solutions/instaspin_foc/boards/boostxl-3PhGanInv/f28x/f2806xF/src" --include_path="C:/ti/motorware/motorware_1_01_00_18" --define=FAST_ROM_V1p6 -g --diag_warning=225 --display_error_number --abi=coffabi --preproc_with_compile --preproc_dependency="hal.d_raw" "C:/ti/motorware/motorware_1_01_00_18/sw/modules/hal/boards/boostxl-3PhGanInv/f28x/f2806x/src/hal.c"
    Finished building: "C:/ti/motorware/motorware_1_01_00_18/sw/modules/hal/boards/boostxl-3PhGanInv/f28x/f2806x/src/hal.c"
    Building file: "C:/ti/motorware/motorware_1_01_00_18/sw/drivers/osc/src/32b/f28x/f2806x/osc.c"
    "C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-c2000_20.2.1.LTS/bin/cl2000" -v28 -ml -mt -O2 --include_path="C:/ti/motorware/motorware_1_01_00_18/sw/modules/hal/boards/boostxl-3PhGanInv/f28x/f2806x/src/" --include_path="C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-c2000_20.2.1.LTS/include" --include_path="C:/ti/motorware/motorware_1_01_00_18/sw/solutions/instaspin_foc/boards/boostxl-3PhGanInv/f28x/f2806xF/src" --include_path="C:/ti/motorware/motorware_1_01_00_18" --define=FAST_ROM_V1p6 -g --diag_warning=225 --display_error_number --abi=coffabi --preproc_with_compile --preproc_dependency="osc.d_raw" "C:/ti/motorware/motorware_1_01_00_18/sw/drivers/osc/src/32b/f28x/f2806x/osc.c"
    Finished building: "C:/ti/motorware/motorware_1_01_00_18/sw/drivers/osc/src/32b/f28x/f2806x/osc.c"
    Building file: "C:/ti/motorware/motorware_1_01_00_18/sw/drivers/pie/src/32b/f28x/f2806x/pie.c"
    "C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-c2000_20.2.1.LTS/bin/cl2000" -v28 -ml -mt -O2 --include_path="C:/ti/motorware/motorware_1_01_00_18/sw/modules/hal/boards/boostxl-3PhGanInv/f28x/f2806x/src/" --include_path="C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-c2000_20.2.1.LTS/include" --include_path="C:/ti/motorware/motorware_1_01_00_18/sw/solutions/instaspin_foc/boards/boostxl-3PhGanInv/f28x/f2806xF/src" --include_path="C:/ti/motorware/motorware_1_01_00_18" --define=FAST_ROM_V1p6 -g --diag_warning=225 --display_error_number --abi=coffabi --preproc_with_compile --preproc_dependency="pie.d_raw" "C:/ti/motorware/motorware_1_01_00_18/sw/drivers/pie/src/32b/f28x/f2806x/pie.c"
    Finished building: "C:/ti/motorware/motorware_1_01_00_18/sw/drivers/pie/src/32b/f28x/f2806x/pie.c"
    Building file: "C:/ti/motorware/motorware_1_01_00_18/sw/drivers/pll/src/32b/f28x/f2806x/pll.c"
    "C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-c2000_20.2.1.LTS/bin/cl2000" -v28 -ml -mt -O2 --include_path="C:/ti/motorware/motorware_1_01_00_18/sw/modules/hal/boards/boostxl-3PhGanInv/f28x/f2806x/src/" --include_path="C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-c2000_20.2.1.LTS/include" --include_path="C:/ti/motorware/motorware_1_01_00_18/sw/solutions/instaspin_foc/boards/boostxl-3PhGanInv/f28x/f2806xF/src" --include_path="C:/ti/motorware/motorware_1_01_00_18" --define=FAST_ROM_V1p6 -g --diag_warning=225 --display_error_number --abi=coffabi --preproc_with_compile --preproc_dependency="pll.d_raw" "C:/ti/motorware/motorware_1_01_00_18/sw/drivers/pll/src/32b/f28x/f2806x/pll.c"
    Finished building: "C:/ti/motorware/motorware_1_01_00_18/sw/drivers/pll/src/32b/f28x/f2806x/pll.c"
    Building file: "C:/ti/motorware/motorware_1_01_00_18/sw/drivers/pwm/src/32b/f28x/f2806x/pwm.c"
    "C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-c2000_20.2.1.LTS/bin/cl2000" -v28 -ml -mt -O2 --include_path="C:/ti/motorware/motorware_1_01_00_18/sw/modules/hal/boards/boostxl-3PhGanInv/f28x/f2806x/src/" --include_path="C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-c2000_20.2.1.LTS/include" --include_path="C:/ti/motorware/motorware_1_01_00_18/sw/solutions/instaspin_foc/boards/boostxl-3PhGanInv/f28x/f2806xF/src" --include_path="C:/ti/motorware/motorware_1_01_00_18" --define=FAST_ROM_V1p6 -g --diag_warning=225 --display_error_number --abi=coffabi --preproc_with_compile --preproc_dependency="pwm.d_raw" "C:/ti/motorware/motorware_1_01_00_18/sw/drivers/pwm/src/32b/f28x/f2806x/pwm.c"
    Finished building: "C:/ti/motorware/motorware_1_01_00_18/sw/drivers/pwm/src/32b/f28x/f2806x/pwm.c"
    gmake: *** No rule to make target 'C:/ti/motorware/motorware_1_01_00_18/sw/solutions/instaspin_foc/boards/boostxl-3PhGanInv/f28x/f2806xF/projects/motorware/motorware_1_01_00_18/sw/solutions/instaspin_foc/src/proj_lab02a-BOOSTXL-3PhGaNInv.c', needed by 'proj_lab02a-BOOSTXL-3PhGaNInv.obj'.
    Building file: "C:/ti/motorware/motorware_1_01_00_18/sw/drivers/pwr/src/32b/f28x/f2806x/pwr.c"
    "C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-c2000_20.2.1.LTS/bin/cl2000" -v28 -ml -mt -O2 --include_path="C:/ti/motorware/motorware_1_01_00_18/sw/modules/hal/boards/boostxl-3PhGanInv/f28x/f2806x/src/" --include_path="C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-c2000_20.2.1.LTS/include" --include_path="C:/ti/motorware/motorware_1_01_00_18/sw/solutions/instaspin_foc/boards/boostxl-3PhGanInv/f28x/f2806xF/src" --include_path="C:/ti/motorware/motorware_1_01_00_18" --define=FAST_ROM_V1p6 -g --diag_warning=225 --display_error_number --abi=coffabi --preproc_with_compile --preproc_dependency="pwr.d_raw" "C:/ti/motorware/motorware_1_01_00_18/sw/drivers/pwr/src/32b/f28x/f2806x/pwr.c"
    Finished building: "C:/ti/motorware/motorware_1_01_00_18/sw/drivers/pwr/src/32b/f28x/f2806x/pwr.c"
    Building file: "C:/ti/motorware/motorware_1_01_00_18/sw/drivers/spi/src/32b/f28x/f2806x/spi.c"
    "C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-c2000_20.2.1.LTS/bin/cl2000" -v28 -ml -mt -O2 --include_path="C:/ti/motorware/motorware_1_01_00_18/sw/modules/hal/boards/boostxl-3PhGanInv/f28x/f2806x/src/" --include_path="C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-c2000_20.2.1.LTS/include" --include_path="C:/ti/motorware/motorware_1_01_00_18/sw/solutions/instaspin_foc/boards/boostxl-3PhGanInv/f28x/f2806xF/src" --include_path="C:/ti/motorware/motorware_1_01_00_18" --define=FAST_ROM_V1p6 -g --diag_warning=225 --display_error_number --abi=coffabi --preproc_with_compile --preproc_dependency="spi.d_raw" "C:/ti/motorware/motorware_1_01_00_18/sw/drivers/spi/src/32b/f28x/f2806x/spi.c"
    Finished building: "C:/ti/motorware/motorware_1_01_00_18/sw/drivers/spi/src/32b/f28x/f2806x/spi.c"
    Building file: "C:/ti/motorware/motorware_1_01_00_18/sw/drivers/timer/src/32b/f28x/f2806x/timer.c"
    "C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-c2000_20.2.1.LTS/bin/cl2000" -v28 -ml -mt -O2 --include_path="C:/ti/motorware/motorware_1_01_00_18/sw/modules/hal/boards/boostxl-3PhGanInv/f28x/f2806x/src/" --include_path="C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-c2000_20.2.1.LTS/include" --include_path="C:/ti/motorware/motorware_1_01_00_18/sw/solutions/instaspin_foc/boards/boostxl-3PhGanInv/f28x/f2806xF/src" --include_path="C:/ti/motorware/motorware_1_01_00_18" --define=FAST_ROM_V1p6 -g --diag_warning=225 --display_error_number --abi=coffabi --preproc_with_compile --preproc_dependency="timer.d_raw" "C:/ti/motorware/motorware_1_01_00_18/sw/drivers/timer/src/32b/f28x/f2806x/timer.c"
    Finished building: "C:/ti/motorware/motorware_1_01_00_18/sw/drivers/timer/src/32b/f28x/f2806x/timer.c"
    Building file: "C:/ti/motorware/motorware_1_01_00_18/sw/modules/usDelay/src/32b/f28x/usDelay.asm"
    "C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-c2000_20.2.1.LTS/bin/cl2000" -v28 -ml -mt -O2 --include_path="C:/ti/motorware/motorware_1_01_00_18/sw/modules/hal/boards/boostxl-3PhGanInv/f28x/f2806x/src/" --include_path="C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-c2000_20.2.1.LTS/include" --include_path="C:/ti/motorware/motorware_1_01_00_18/sw/solutions/instaspin_foc/boards/boostxl-3PhGanInv/f28x/f2806xF/src" --include_path="C:/ti/motorware/motorware_1_01_00_18" --define=FAST_ROM_V1p6 -g --diag_warning=225 --display_error_number --abi=coffabi --preproc_with_compile --preproc_dependency="usDelay.d_raw" "C:/ti/motorware/motorware_1_01_00_18/sw/modules/usDelay/src/32b/f28x/usDelay.asm"
    Finished building: "C:/ti/motorware/motorware_1_01_00_18/sw/modules/usDelay/src/32b/f28x/usDelay.asm"
    Building file: "C:/ti/motorware/motorware_1_01_00_18/sw/modules/user/src/32b/user.c"
    "C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-c2000_20.2.1.LTS/bin/cl2000" -v28 -ml -mt -O2 --include_path="C:/ti/motorware/motorware_1_01_00_18/sw/modules/hal/boards/boostxl-3PhGanInv/f28x/f2806x/src/" --include_path="C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-c2000_20.2.1.LTS/include" --include_path="C:/ti/motorware/motorware_1_01_00_18/sw/solutions/instaspin_foc/boards/boostxl-3PhGanInv/f28x/f2806xF/src" --include_path="C:/ti/motorware/motorware_1_01_00_18" --define=FAST_ROM_V1p6 -g --diag_warning=225 --display_error_number --abi=coffabi --preproc_with_compile --preproc_dependency="user.d_raw" "C:/ti/motorware/motorware_1_01_00_18/sw/modules/user/src/32b/user.c"
    Finished building: "C:/ti/motorware/motorware_1_01_00_18/sw/modules/user/src/32b/user.c"
    Building file: "C:/ti/motorware/motorware_1_01_00_18/sw/drivers/wdog/src/32b/f28x/f2806x/wdog.c"
    "C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-c2000_20.2.1.LTS/bin/cl2000" -v28 -ml -mt -O2 --include_path="C:/ti/motorware/motorware_1_01_00_18/sw/modules/hal/boards/boostxl-3PhGanInv/f28x/f2806x/src/" --include_path="C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-c2000_20.2.1.LTS/include" --include_path="C:/ti/motorware/motorware_1_01_00_18/sw/solutions/instaspin_foc/boards/boostxl-3PhGanInv/f28x/f2806xF/src" --include_path="C:/ti/motorware/motorware_1_01_00_18" --define=FAST_ROM_V1p6 -g --diag_warning=225 --display_error_number --abi=coffabi --preproc_with_compile --preproc_dependency="wdog.d_raw" "C:/ti/motorware/motorware_1_01_00_18/sw/drivers/wdog/src/32b/f28x/f2806x/wdog.c"
    Finished building: "C:/ti/motorware/motorware_1_01_00_18/sw/drivers/wdog/src/32b/f28x/f2806x/wdog.c"
  • Does the following file exist in your directory?
  • So my directory does not look exactly the same....
    C:\ti\motorware\motorware_1_01_00_18\sw\solutions\instaspin_foc\boards\boostxl-3PhGanInv\f28x\f2806xF\projects\ccs\proj_lab02a\Release
    I don't have another motorware folder within boostxl-3PhGanInv, but if I go into the projects folder, the only option is ccs and that leads to all the labs and I have the proj_lab02a folder with all the files for that in the Release folder shown in the image
    Oops, you are right. The path I mentioned is a weird path. The correct path to the file is.
    C:\ti\motorware\motorware_1_01_00_18\sw\solutions\instaspin_foc\src\proj_lab02a-BOOSTXL-3PhGaNInv.c
    If that file is there, please go to the project in CCS and replace the bad link for proj_lab02a-BOOSTXL-3PhGaNInv.c with the correct one. You can simply delete the link in Project Explorer and then add the file back tp the project
