Hi All,
I want to transfer data from host to DDR memory using ethernet cable. I would like to know where I can find sample code and documents related to it.
Hi All,
Are you using the vision SDK or some other SDK?
Linux is running on A15 core?
Gaviraju
I am using Vision SDK , but we need to develop independent code to communicate between host and target.
We are planning to use sysbios on A15.
Refer the below document
vision_sdk/docs/FeatureSpecificUserGuides/VisionSDK_UserGuide_NetworkTools.pdf
Network RX link: vision_sdk\links_fw\src\rtos\links_common\network_rx
Network TX link: vision_sdk\links_fw\src\rtos\links_common\network_tx
Demo example use-case: vision_sdk\apps\src\rtos\usecases\network_rx_tx
Gaviraju
