I would like to suppress one particular instance of a warning/remark. How can I do this? The usual method is with some #pragma, but I don't see it. SPRU514C says on p. 39:
--diag_error=num Categorizes the diagnostic identified by num as an error. To determine the
numeric identifier of a diagnostic message, use the --display_error_number
option first in a separate compile. Then use --diag_error=num to recategorize
the diagnostic as an error. You can only alter the severity of discretionary
diagnostics.
--diag_remark=num Categorizes the diagnostic identified by num as a remark. To determine the
option first in a separate compile. Then use --diag_remark=num to
recategorize the diagnostic as a remark. You can only alter the severity of
discretionary diagnostics.
--diag_suppress=num Suppresses the diagnostic identified by num. To determine the numeric
identifier of a diagnostic message, use the --display_error_number option first
in a separate compile. Then use --diag_suppress=num to suppress the
diagnostic. You can only suppress discretionary diagnostics.
--diag_warning=num Categorizes the diagnostic identified by num as a warning. To determine the
option first in a separate compile. Then use --diag_warning=num to
recategorize the diagnostic as a warning. You can only alter the severity of
but these options apply for the whole file.
