CCS/AWR1642: Loading a project in Eclipse
Part Number: AWR1642
Hi all,
I am trying to run the mmw demo using Eclipse. I can successfully launch the target configuration and then connect it but cannot load the files generated after building the projects. i cannot find the "load" option which we usually find in the CCS. What is the right approach to load the files using Eclipse ?
 I have attached the following screenshot for reference
Thanks .
    It looks like you are missing the top main toolbar. If you hover your mouse all the way to the top, the CCS menus should appear. Then follow the screenshot below to enable the main toolbar:
    This will bring back the main toolbar with all buttons that were missing before.
    ki
