Other Parts Discussed in Thread: CCSTUDIO
I am installing code composer 8.0 on a linux server to be used by our development team. I followed the eclipse installation notes about making sure everything under /opt/ti does not have group/other write permissions. The installation works fine for the first user to run code composer. However when a 2nd user goes to run it code composer starts with a pop-up window "Getting Started Initializer" has encountered a problem. An internal error has occurred. java.lang.ExceptionInitializerError.
I have diagnosed the problem starting code composer from the command line with:
bash-4.2$ /opt/ti/ccsv8/eclipse/ccstudio -clean
09:17:47 SEVERE: Failed to extract Chromium binaries into /tmp/jxbrowser-chromium-60.0.3112.113.6.15
java.lang.RuntimeException: java.io.IOException: Permission denied
at com.teamdev.jxbrowser.chromium.internal.XZExtractor.extract(SourceFile:45)
at com.teamdev.jxbrowser.chromium.internal.b.run(SourceFile:1066)
at java.security.AccessController.doPrivileged(Native Method)
at com.teamdev.jxbrowser.chromium.internal.ChromiumExtractor.extractChromiumBinariesIfNecessary(SourceFile:60)
at com.teamdev.jxbrowser.chromium.internal.ipc.IPC.<init>(SourceFile:66)
at com.teamdev.jxbrowser.chromium.internal.ipc.IPC.create(SourceFile:96)
at com.teamdev.jxbrowser.chromium.internal.ipc.IPC$a.<clinit>(SourceFile:467)
at com.teamdev.jxbrowser.chromium.internal.ipc.IPC.getDefault(SourceFile:90)
at com.teamdev.jxbrowser.chromium.BrowserCore.isInitialized(SourceFile:71)
at com.ti.chromium.browser.JxBrowser.init(JxBrowser.java:228)
at com.ti.chromium.browser.ChromiumBrowserContributor.init(ChromiumBrowserContributor.java:40)
at com.ti.browser.internal.TIBrowserPlugin.getPreferredBrowserContributor(TIBrowserPlugin.java:224)
The problem is the JxBrowser is always trying to extract into /tmp/jxbrowser-chromium-60.0.3112.113.6.15 which is owned by the first user that runs code composer it on the machine.
I can't find anywhere in the documentation about how to over ride the directory where it the jxbrowser-chromium.jar file extracts to.
