Hi there,
I am using Code Composer 3.3 and somehow the project tab is now disabled and wont let me load any projects. The project folder is also missing from the Files view. I have looked online but didn't see a way to reset the view.
Rob
Hi there,
Rob
I suspect the project server dll somehow got unregistered. What windows version are you using?
Can you try explicitly registering the project manager component from a DOS command window:
regsvr32 <CCSv3 Install Dir>\cc\bin\projsvr.dll
Note that you will need admin rights to your PC. I assume you do since you are running CCSv3.3 on XP.
