I have problem to lunch code composer studio v8.3.1.
I run ccs_setup_8.3.1.00004.exe and got the following error:
I tried to run it on command windows but got nothing.
Please help me to solve that problem
Itzhak
Itzhak
Hello Itzhak,
It looks like your account does not have permissions to write to the system temp folders that is needed by the installer.
Did you pass in a folder path that you have write permissions to?
ki
I change installation to version ccs11 and during installation I got the following error
my path is c:\ti\ccs1100 and so the setup
Thanks'
Itzhak Kroin
Looks like you have some unicode characters in the temp path. This can cause issues. Please see the below like for more details:
ki
What it means temp path, where can I found it. the only path I'm using is the c:\ti\ccs1100 where the ccs_setup_11.0.0.00012.exe is find
Itzhak Kroin
Please see:
As shown in your first screenshot, you can use the --temp parameter to specify a custom temp directory
In your case, it is likely that the issue is with the temp directory in your user folder. Does you user name have unicode characters?
