On-Chip flash programmer for CCS v4.x
Other Parts Discussed in Thread: CCSTUDIO
Hi
I want to program flash without to use debug active project. Is it possible like CCS v3.x On-Chip flash programmer?
I have CCS Version: 4.2.3.00004
  • Jeremy,
    If you launch the debugger vs debug active project, when you do a program load it will flash the .out.
    You can start a non-project debug session a couple of different ways.
    1) click the down arrow beside the bug icon and select launch TI debugger.  That will start a debug session for your default target configuration.
    2) Open the Target Configuration view.  Right click on a specific target configuration file and select "Launch selected configuration"
    John
  • Hi
    I want to flash another .out like the programmer on CCS v3.x. I want to take an external .out CCS project to program flash. For example with CCS 3.x I can take only the .out of my CCS v4.x project and program flash with the On-chip program flash plug in but I can't take my CCS v3.x .out project and program my flash with CCS v4.x.
    How I can pass to CCS v4.x without to import CCS 3.3 project, but only use .out.
    Jeremy
  • Jeremy,
    You have lost me.  Why can't you launch the debugger and load your .out from CCSv3.3.  The Load Program function will flash the program.
    John
  • Hi
    We want to change from CCS 3 to CCS 4. So if I can't program flash independently with CCS 4, we have problems... But we  probably  don't  update to CCS 4.
    Jeremy
  • Jeremy,
    You can program the flash independently in v4 just like in 3.3.
    CCSv3.3:
    • Start CCS
    • Click on Connect to target.
    • Open the flash programmer, specify your .out
    CCSv4:
    • Start CCS
    • Launch a debug session, click on the down arrow beside the bug button and select Launch TI debugger.
      • This is different from v3 as in v3 the debugger is started as soon as you start CCS.
    • Click on connect to target
    • Select Load program. specify your .out.  This will flash the device.
    You can also script flashing in v4 which you could not do in v3.3.
    I uploaded a little video here that shows what I am talking about.  The link won't be good for another hour.
    http://software-dl.ti.com/dsps/dsps_public_sw/sdo_ccstudio/CCSv4/Demos/Flashing28x.html
    John
  • Thanks for the video!
    Jeremy
