CODECOMPOSER: Building Stack_Wrapper doesn't find build_config.opt
Part Number: CODECOMPOSER
I've changed setup and I've tried building previous projects from the company (they are on SDK 5.20) but I couldn't build them. So I decided to get the latest versions and I want to build the StackWrapper project that I got from Resource Explorer but I am having problems with /build_config.opt as It doesn't find the file.
Things to consider:
- Software versions: Code Composer Studio 12.3.0.00005 (installed using web version, deactivated Antivirus and every check was OK during installation), TI Arm Clang 1.3.0 LTS Compiler, SimpleLink CC13xx CC26xx SDK 7.10.00.98, XDCtools 3.62.0.08_core
- Projects I got right now are from Wireless connectivity > Embedded Software > SimpleLink CC13xx CC26xx SDK - 7.10.00.98 > Examples > Development Tools > CC26x2R LaunchPad > BL5-Stack
- I was able to succesfully build project_zero_CC26X2R1_LAUNCHXL_tirtos7_ticlang and host_test_CC26X2R1_LAUNCHXL_tirtos7_ticlang, but it fails with Stack_Wrapper and Stack_Wrapper_ticlang
Problems seem to be related to not finding '@/build_confogi.opt', I've checked a few other threads and tried solutions (Adding flag NVOCMP_MIGRATE_ENABLED to compiler, installing SimpleLink Academy v1.11) but they didn't work (or I failed to do it properly).
The warnings for both Stack_Wrapper and Stack_Wrapper_ticlang I get are:
Build-variable 'OPT_LOC' cannot be resolved. This project may not build as expected.	Stack_Wrapper		properties	Problem
Invalid project path: Include path not found (C:\ti\simplelink_cc13xx_cc26xx_sdk_7_10_00_98\source\ti\ble5stack\services\src\nv).	Stack_Wrapper		pathentry	Path Entry Problem
Invalid project path: Include path not found (C:\ti\simplelink_cc13xx_cc26xx_sdk_7_10_00_98\source\ti\ble5stack\services\src\nv\cc26xx).	Stack_Wrapper		pathentry	Path Entry Problem
The output trying to rebuild project Stack_Wrapper:
**** Clean-only build of configuration Stack_Wrapper for project Stack_Wrapper ****
"C:\\ti\\ccs1230\\ccs\\utils\\bin\\gmake" -k -j 8 clean -O
DEL /F  "Stack_Wrapper.lib"
DEL /F "HAL\Common\hal_assert.obj" "HAL\Target\CC2650\Drivers\hal_flash_wrapper.obj" "HAL\Target\CC2650\Drivers\hal_trng_wrapper.obj" "Host\gap.obj" "Host\gapbondmgr.obj" "Host\gatt_uuid.obj" "Host\gattservapp_util.obj" "Host\rtls_srv.obj" "Host\sm_ecc.obj" "ICallBLE\ble_dispatch_JT.obj" "ICallBLE\ble_dispatch_lite.obj" "ICallBLE\icall_lite_translation.obj" "NPI\npi.obj" "OSAL\osal.obj" "OSAL\osal_bufmgr.obj" "OSAL\osal_cbtimer.obj" "OSAL\osal_clock.obj" "OSAL\osal_list.obj" "OSAL\osal_memory_icall.obj" "OSAL\osal_pwrmgr.obj" "OSAL\osal_snv_wrapper.obj" "OSAL\osal_timers.obj" "ROM\common_rom_init.obj" "Startup\icall_startup.obj" "TOOLS\onboard.obj"
DEL /F "HAL\Common\hal_assert.d" "HAL\Target\CC2650\Drivers\hal_flash_wrapper.d" "HAL\Target\CC2650\Drivers\hal_trng_wrapper.d" "Host\gap.d" "Host\gapbondmgr.d" "Host\gatt_uuid.d" "Host\gattservapp_util.d" "Host\rtls_srv.d" "Host\sm_ecc.d" "ICallBLE\ble_dispatch_JT.d" "ICallBLE\ble_dispatch_lite.d" "ICallBLE\icall_lite_translation.d" "NPI\npi.d" "OSAL\osal.d" "OSAL\osal_bufmgr.d" "OSAL\osal_cbtimer.d" "OSAL\osal_clock.d" "OSAL\osal_list.d" "OSAL\osal_memory_icall.d" "OSAL\osal_pwrmgr.d" "OSAL\osal_snv_wrapper.d" "OSAL\osal_timers.d" "ROM\common_rom_init.d" "Startup\icall_startup.d" "TOOLS\onboard.d"
No se pudo encontrar C:\Users\user1234\TI_workspace\Stack_Wrapper\Stack_Wrapper\Stack_Wrapper.lib
No se pudo encontrar C:\Users\user1234\TI_workspace\Stack_Wrapper\Stack_Wrapper\NPI\npi.obj
No se pudo encontrar C:\Users\user1234\TI_workspace\Stack_Wrapper\Stack_Wrapper\TOOLS\onboard.obj
Finished clean
**** Build Finished ****
**** Build of configuration Stack_Wrapper for project Stack_Wrapper ****
"C:\\ti\\ccs1230\\ccs\\utils\\bin\\gmake" -k -j 8 all -O
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/host/gap.c"
Invoking: Arm Compiler
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/bin/armcl" --cmd_file="C:/Users/user1234/TI_workspace/Stack_Wrapper/TOOLS/Defines/Stack_Wrapper.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" --cmd_file="/build_config.opt"  -mv7M4 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/user1234/TI_workspace/Stack_Wrapper" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" --include_path="C:/ti/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/include" -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Host/gap.d_raw" --obj_directory="Host"  "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/host/gap.c"
>> Compilation failure
Host/subdir_rules.mk:9: recipe for target 'Host/gap.obj' failed
>> ERROR: Cannot open command file '/build_config.opt': No such file or directory
"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc/bcomdef.h", line 124: fatal error #35: #error directive: "Build Configuration Error: At least one Controller build component required!"
1 catastrophic error detected in the compilation of "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/host/gap.c".
Compilation terminated.
gmake: *** [Host/gap.obj] Error 1
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/host/gatt_uuid.c"
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/bin/armcl" --cmd_file="C:/Users/user1234/TI_workspace/Stack_Wrapper/TOOLS/Defines/Stack_Wrapper.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" --cmd_file="/build_config.opt"  -mv7M4 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/user1234/TI_workspace/Stack_Wrapper" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" --include_path="C:/ti/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/include" -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Host/gatt_uuid.d_raw" --obj_directory="Host"  "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/host/gatt_uuid.c"
>> Compilation failure
Host/subdir_rules.mk:23: recipe for target 'Host/gatt_uuid.obj' failed
"C:\ti\simplelink_cc13xx_cc26xx_sdk_7_10_00_98\source\ti\ble5stack\inc\bcomdef.h", line 124: fatal error #35: #error directive: "Build Configuration Error: At least one Controller build component required!"
1 catastrophic error detected in the compilation of "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/host/gatt_uuid.c".
gmake: *** [Host/gatt_uuid.obj] Error 1
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/host/rtls_srv.c"
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/bin/armcl" --cmd_file="C:/Users/user1234/TI_workspace/Stack_Wrapper/TOOLS/Defines/Stack_Wrapper.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" --cmd_file="/build_config.opt"  -mv7M4 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/user1234/TI_workspace/Stack_Wrapper" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" --include_path="C:/ti/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/include" -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Host/rtls_srv.d_raw" --obj_directory="Host"  "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/host/rtls_srv.c"
>> Compilation failure
Host/subdir_rules.mk:37: recipe for target 'Host/rtls_srv.obj' failed
1 catastrophic error detected in the compilation of "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/host/rtls_srv.c".
gmake: *** [Host/rtls_srv.obj] Error 1
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/host/gattservapp_util.c"
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/bin/armcl" --cmd_file="C:/Users/user1234/TI_workspace/Stack_Wrapper/TOOLS/Defines/Stack_Wrapper.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" --cmd_file="/build_config.opt"  -mv7M4 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/user1234/TI_workspace/Stack_Wrapper" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" --include_path="C:/ti/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/include" -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Host/gattservapp_util.d_raw" --obj_directory="Host"  "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/host/gattservapp_util.c"
>> Compilation failure
Host/subdir_rules.mk:30: recipe for target 'Host/gattservapp_util.obj' failed
1 catastrophic error detected in the compilation of "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/host/gattservapp_util.c".
gmake: *** [Host/gattservapp_util.obj] Error 1
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/host/sm_ecc.c"
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/bin/armcl" --cmd_file="C:/Users/user1234/TI_workspace/Stack_Wrapper/TOOLS/Defines/Stack_Wrapper.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" --cmd_file="/build_config.opt"  -mv7M4 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/user1234/TI_workspace/Stack_Wrapper" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" --include_path="C:/ti/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/include" -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Host/sm_ecc.d_raw" --obj_directory="Host"  "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/host/sm_ecc.c"
>> Compilation failure
Host/subdir_rules.mk:44: recipe for target 'Host/sm_ecc.obj' failed
1 catastrophic error detected in the compilation of "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/host/sm_ecc.c".
gmake: *** [Host/sm_ecc.obj] Error 1
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/host/gapbondmgr.c"
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/bin/armcl" --cmd_file="C:/Users/user1234/TI_workspace/Stack_Wrapper/TOOLS/Defines/Stack_Wrapper.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" --cmd_file="/build_config.opt"  -mv7M4 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/user1234/TI_workspace/Stack_Wrapper" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" --include_path="C:/ti/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/include" -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Host/gapbondmgr.d_raw" --obj_directory="Host"  "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/host/gapbondmgr.c"
Finished building: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/host/gapbondmgr.c"
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common/hal_trng_wrapper.c"
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/bin/armcl" --cmd_file="C:/Users/user1234/TI_workspace/Stack_Wrapper/TOOLS/Defines/Stack_Wrapper.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" --cmd_file="/build_config.opt"  -mv7M4 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/user1234/TI_workspace/Stack_Wrapper" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" --include_path="C:/ti/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/include" -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="HAL/Target/CC2650/Drivers/hal_trng_wrapper.d_raw" --obj_directory="HAL/Target/CC2650/Drivers"  "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common/hal_trng_wrapper.c"
Finished building: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common/hal_trng_wrapper.c"
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common/hal_flash_wrapper.c"
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/bin/armcl" --cmd_file="C:/Users/user1234/TI_workspace/Stack_Wrapper/TOOLS/Defines/Stack_Wrapper.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" --cmd_file="/build_config.opt"  -mv7M4 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/user1234/TI_workspace/Stack_Wrapper" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" --include_path="C:/ti/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/include" -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="HAL/Target/CC2650/Drivers/hal_flash_wrapper.d_raw" --obj_directory="HAL/Target/CC2650/Drivers"  "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common/hal_flash_wrapper.c"
Finished building: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common/hal_flash_wrapper.c"
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/common/hal_assert.c"
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/bin/armcl" --cmd_file="C:/Users/user1234/TI_workspace/Stack_Wrapper/TOOLS/Defines/Stack_Wrapper.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" --cmd_file="/build_config.opt"  -mv7M4 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/user1234/TI_workspace/Stack_Wrapper" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" --include_path="C:/ti/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/include" -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="HAL/Common/hal_assert.d_raw" --obj_directory="HAL/Common"  "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/common/hal_assert.c"
Finished building: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/common/hal_assert.c"
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/stack/ble_dispatch_JT.c"
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/bin/armcl" --cmd_file="C:/Users/user1234/TI_workspace/Stack_Wrapper/TOOLS/Defines/Stack_Wrapper.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" --cmd_file="/build_config.opt"  -mv7M4 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/user1234/TI_workspace/Stack_Wrapper" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" --include_path="C:/ti/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/include" -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="ICallBLE/ble_dispatch_JT.d_raw" --obj_directory="ICallBLE"  "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/stack/ble_dispatch_JT.c"
>> Compilation failure
ICallBLE/subdir_rules.mk:9: recipe for target 'ICallBLE/ble_dispatch_JT.obj' failed
1 catastrophic error detected in the compilation of "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/stack/ble_dispatch_JT.c".
gmake: *** [ICallBLE/ble_dispatch_JT.obj] Error 1
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/stack/ble_dispatch_lite.c"
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/bin/armcl" --cmd_file="C:/Users/user1234/TI_workspace/Stack_Wrapper/TOOLS/Defines/Stack_Wrapper.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" --cmd_file="/build_config.opt"  -mv7M4 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/user1234/TI_workspace/Stack_Wrapper" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" --include_path="C:/ti/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/include" -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="ICallBLE/ble_dispatch_lite.d_raw" --obj_directory="ICallBLE"  "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/stack/ble_dispatch_lite.c"
>> Compilation failure
ICallBLE/subdir_rules.mk:16: recipe for target 'ICallBLE/ble_dispatch_lite.obj' failed
1 catastrophic error detected in the compilation of "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/stack/ble_dispatch_lite.c".
gmake: *** [ICallBLE/ble_dispatch_lite.obj] Error 1
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack/npi.c"
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/bin/armcl" --cmd_file="C:/Users/user1234/TI_workspace/Stack_Wrapper/TOOLS/Defines/Stack_Wrapper.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" --cmd_file="/build_config.opt"  -mv7M4 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/user1234/TI_workspace/Stack_Wrapper" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" --include_path="C:/ti/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/include" -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="NPI/npi.d_raw" --obj_directory="NPI"  "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack/npi.c"
>> Compilation failure
NPI/subdir_rules.mk:9: recipe for target 'NPI/npi.obj' failed
1 catastrophic error detected in the compilation of "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack/npi.c".
gmake: *** [NPI/npi.obj] Error 1
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/icall_lite_translation.c"
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/bin/armcl" --cmd_file="C:/Users/user1234/TI_workspace/Stack_Wrapper/TOOLS/Defines/Stack_Wrapper.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" --cmd_file="/build_config.opt"  -mv7M4 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/user1234/TI_workspace/Stack_Wrapper" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" --include_path="C:/ti/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/include" -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="ICallBLE/icall_lite_translation.d_raw" --obj_directory="ICallBLE"  "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/icall_lite_translation.c"
Finished building: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/icall_lite_translation.c"
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/common/osal_cbtimer.c"
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/bin/armcl" --cmd_file="C:/Users/user1234/TI_workspace/Stack_Wrapper/TOOLS/Defines/Stack_Wrapper.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" --cmd_file="/build_config.opt"  -mv7M4 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/user1234/TI_workspace/Stack_Wrapper" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" --include_path="C:/ti/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/include" -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="OSAL/osal_cbtimer.d_raw" --obj_directory="OSAL"  "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/common/osal_cbtimer.c"
>> Compilation failure
OSAL/subdir_rules.mk:23: recipe for target 'OSAL/osal_cbtimer.obj' failed
1 catastrophic error detected in the compilation of "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/common/osal_cbtimer.c".
gmake: *** [OSAL/osal_cbtimer.obj] Error 1
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/common/osal_memory_icall.c"
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/bin/armcl" --cmd_file="C:/Users/user1234/TI_workspace/Stack_Wrapper/TOOLS/Defines/Stack_Wrapper.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" --cmd_file="/build_config.opt"  -mv7M4 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/user1234/TI_workspace/Stack_Wrapper" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" --include_path="C:/ti/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/include" -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="OSAL/osal_memory_icall.d_raw" --obj_directory="OSAL"  "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/common/osal_memory_icall.c"
Finished building: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/common/osal_memory_icall.c"
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/common/osal_list.c"
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/bin/armcl" --cmd_file="C:/Users/user1234/TI_workspace/Stack_Wrapper/TOOLS/Defines/Stack_Wrapper.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" --cmd_file="/build_config.opt"  -mv7M4 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/user1234/TI_workspace/Stack_Wrapper" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" --include_path="C:/ti/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/include" -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="OSAL/osal_list.d_raw" --obj_directory="OSAL"  "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/common/osal_list.c"
Finished building: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/common/osal_list.c"
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/common/osal_bufmgr.c"
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/bin/armcl" --cmd_file="C:/Users/user1234/TI_workspace/Stack_Wrapper/TOOLS/Defines/Stack_Wrapper.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" --cmd_file="/build_config.opt"  -mv7M4 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/user1234/TI_workspace/Stack_Wrapper" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" --include_path="C:/ti/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/include" -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="OSAL/osal_bufmgr.d_raw" --obj_directory="OSAL"  "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/common/osal_bufmgr.c"
Finished building: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/common/osal_bufmgr.c"
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/common/osal_pwrmgr.c"
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/bin/armcl" --cmd_file="C:/Users/user1234/TI_workspace/Stack_Wrapper/TOOLS/Defines/Stack_Wrapper.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" --cmd_file="/build_config.opt"  -mv7M4 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/user1234/TI_workspace/Stack_Wrapper" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" --include_path="C:/ti/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/include" -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="OSAL/osal_pwrmgr.d_raw" --obj_directory="OSAL"  "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/common/osal_pwrmgr.c"
Finished building: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/common/osal_pwrmgr.c"
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/common/osal_clock.c"
Invoking: Arm Compiler
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/bin/armcl" --cmd_file="C:/Users/user1234/TI_workspace/Stack_Wrapper/TOOLS/Defines/Stack_Wrapper.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" --cmd_file="/build_config.opt"  -mv7M4 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/user1234/TI_workspace/Stack_Wrapper" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" --include_path="C:/ti/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/include" -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="OSAL/osal_clock.d_raw" --obj_directory="OSAL"  "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/common/osal_clock.c"
>> ERROR: Cannot open command file '/build_config.opt': No such file or directory
Finished building: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/common/osal_clock.c"
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/onboard.c"
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/bin/armcl" --cmd_file="C:/Users/user1234/TI_workspace/Stack_Wrapper/TOOLS/Defines/Stack_Wrapper.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" --cmd_file="/build_config.opt"  -mv7M4 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/user1234/TI_workspace/Stack_Wrapper" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" --include_path="C:/ti/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/include" -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="TOOLS/onboard.d_raw" --obj_directory="TOOLS"  "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/onboard.c"
>> Compilation failure
TOOLS/subdir_rules.mk:9: recipe for target 'TOOLS/onboard.obj' failed
"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc/bcomdef.h", line 124: fatal error #35: #error directive: "Build Configuration Error: At least one Controller build component required!"
1 catastrophic error detected in the compilation of "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/onboard.c".
Compilation terminated.
gmake: *** [TOOLS/onboard.obj] Error 1
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/mcu/cc26xx/osal_snv_wrapper.c"
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/bin/armcl" --cmd_file="C:/Users/user1234/TI_workspace/Stack_Wrapper/TOOLS/Defines/Stack_Wrapper.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" --cmd_file="/build_config.opt"  -mv7M4 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/user1234/TI_workspace/Stack_Wrapper" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" --include_path="C:/ti/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/include" -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="OSAL/osal_snv_wrapper.d_raw" --obj_directory="OSAL"  "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/mcu/cc26xx/osal_snv_wrapper.c"
Finished building: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/mcu/cc26xx/osal_snv_wrapper.c"
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom/agama_r1/common_rom_init.c"
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/bin/armcl" --cmd_file="C:/Users/user1234/TI_workspace/Stack_Wrapper/TOOLS/Defines/Stack_Wrapper.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" --cmd_file="/build_config.opt"  -mv7M4 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/user1234/TI_workspace/Stack_Wrapper" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" --include_path="C:/ti/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/include" -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="ROM/common_rom_init.d_raw" --obj_directory="ROM"  "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom/agama_r1/common_rom_init.c"
Finished building: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom/agama_r1/common_rom_init.c"
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/common/osal_timers.c"
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/bin/armcl" --cmd_file="C:/Users/user1234/TI_workspace/Stack_Wrapper/TOOLS/Defines/Stack_Wrapper.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" --cmd_file="/build_config.opt"  -mv7M4 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/user1234/TI_workspace/Stack_Wrapper" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" --include_path="C:/ti/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/include" -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="OSAL/osal_timers.d_raw" --obj_directory="OSAL"  "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/common/osal_timers.c"
Finished building: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/common/osal_timers.c"
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/icall_startup.c"
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/bin/armcl" --cmd_file="C:/Users/user1234/TI_workspace/Stack_Wrapper/TOOLS/Defines/Stack_Wrapper.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" --cmd_file="/build_config.opt"  -mv7M4 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/user1234/TI_workspace/Stack_Wrapper" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" --include_path="C:/ti/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/include" -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="Startup/icall_startup.d_raw" --obj_directory="Startup"  "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/icall_startup.c"
Finished building: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/icall_startup.c"
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/common/osal.c"
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/bin/armcl" --cmd_file="C:/Users/user1234/TI_workspace/Stack_Wrapper/TOOLS/Defines/Stack_Wrapper.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" --cmd_file="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" --cmd_file="/build_config.opt"  -mv7M4 --code_state=16 -me -O4 --opt_for_speed=0 --include_path="C:/Users/user1234/TI_workspace/Stack_Wrapper" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" --include_path="C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" --include_path="C:/ti/xdctools_3_62_00_08_core/packages" --include_path="C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS/include" -g --c99 --gcc --diag_warning=225 --diag_wrap=off --display_error_number --gen_func_subsections=on --abi=eabi --preproc_with_compile --preproc_dependency="OSAL/osal.d_raw" --obj_directory="OSAL"  "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/common/osal.c"
Finished building: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/common/osal.c"
gmake: Target 'all' not remade because of errors.
**** Build Finished ****
The output trying to rebuild project Stack_Wrapper_ticlang:
**** Clean-only build of configuration Stack_Wrapper for project Stack_Wrapper_ticlang ****
"C:\\ti\\ccs1230\\ccs\\utils\\bin\\gmake" -k -j 8 clean -O
DEL /F  "Stack_Wrapper_ticlang.lib"
DEL /F "HAL\Common\hal_assert.o" "HAL\Target\CC2650\Drivers\hal_flash_wrapper.o" "HAL\Target\CC2650\Drivers\hal_trng_wrapper.o" "Host\gap.o" "Host\gapbondmgr.o" "Host\gatt_uuid.o" "Host\gattservapp_util.o" "Host\rtls_srv.o" "Host\sm_ecc.o" "ICallBLE\ble_dispatch_JT.o" "ICallBLE\ble_dispatch_lite.o" "ICallBLE\icall_lite_translation.o" "NPI\npi.o" "OSAL\osal.o" "OSAL\osal_bufmgr.o" "OSAL\osal_cbtimer.o" "OSAL\osal_clock.o" "OSAL\osal_list.o" "OSAL\osal_memory_icall.o" "OSAL\osal_pwrmgr.o" "OSAL\osal_snv_wrapper.o" "OSAL\osal_timers.o" "ROM\common_rom_init.o" "Startup\icall_startup.o" "TOOLS\onboard.o"
DEL /F "HAL\Common\hal_assert.d" "HAL\Target\CC2650\Drivers\hal_flash_wrapper.d" "HAL\Target\CC2650\Drivers\hal_trng_wrapper.d" "Host\gap.d" "Host\gapbondmgr.d" "Host\gatt_uuid.d" "Host\gattservapp_util.d" "Host\rtls_srv.d" "Host\sm_ecc.d" "ICallBLE\ble_dispatch_JT.d" "ICallBLE\ble_dispatch_lite.d" "ICallBLE\icall_lite_translation.d" "NPI\npi.d" "OSAL\osal.d" "OSAL\osal_bufmgr.d" "OSAL\osal_cbtimer.d" "OSAL\osal_clock.d" "OSAL\osal_list.d" "OSAL\osal_memory_icall.d" "OSAL\osal_pwrmgr.d" "OSAL\osal_snv_wrapper.d" "OSAL\osal_timers.d" "ROM\common_rom_init.d" "Startup\icall_startup.d" "TOOLS\onboard.d"
No se pudo encontrar C:\Users\user1234\TI_workspace\Stack_Wrapper_ticlang\Stack_Wrapper\Stack_Wrapper_ticlang.lib
No se pudo encontrar C:\Users\user1234\TI_workspace\Stack_Wrapper_ticlang\Stack_Wrapper\HAL\Common\hal_assert.o
No se pudo encontrar C:\Users\user1234\TI_workspace\Stack_Wrapper_ticlang\Stack_Wrapper\HAL\Target\CC2650\Drivers\hal_flash_wrapper.o
No se pudo encontrar C:\Users\user1234\TI_workspace\Stack_Wrapper_ticlang\Stack_Wrapper\Host\gap.o
No se pudo encontrar C:\Users\user1234\TI_workspace\Stack_Wrapper_ticlang\Stack_Wrapper\ICallBLE\ble_dispatch_JT.o
No se pudo encontrar C:\Users\user1234\TI_workspace\Stack_Wrapper_ticlang\Stack_Wrapper\NPI\npi.o
No se pudo encontrar C:\Users\user1234\TI_workspace\Stack_Wrapper_ticlang\Stack_Wrapper\OSAL\osal.o
No se pudo encontrar C:\Users\user1234\TI_workspace\Stack_Wrapper_ticlang\Stack_Wrapper\ROM\common_rom_init.o
No se pudo encontrar C:\Users\user1234\TI_workspace\Stack_Wrapper_ticlang\Stack_Wrapper\Startup\icall_startup.o
No se pudo encontrar C:\Users\user1234\TI_workspace\Stack_Wrapper_ticlang\Stack_Wrapper\TOOLS\onboard.o
No se pudo encontrar C:\Users\user1234\TI_workspace\Stack_Wrapper_ticlang\Stack_Wrapper\HAL\Common\hal_assert.d
No se pudo encontrar C:\Users\user1234\TI_workspace\Stack_Wrapper_ticlang\Stack_Wrapper\HAL\Target\CC2650\Drivers\hal_flash_wrapper.d
No se pudo encontrar C:\Users\user1234\TI_workspace\Stack_Wrapper_ticlang\Stack_Wrapper\Host\gap.d
No se pudo encontrar C:\Users\user1234\TI_workspace\Stack_Wrapper_ticlang\Stack_Wrapper\ICallBLE\ble_dispatch_JT.d
No se pudo encontrar C:\Users\user1234\TI_workspace\Stack_Wrapper_ticlang\Stack_Wrapper\NPI\npi.d
No se pudo encontrar C:\Users\user1234\TI_workspace\Stack_Wrapper_ticlang\Stack_Wrapper\OSAL\osal.d
No se pudo encontrar C:\Users\user1234\TI_workspace\Stack_Wrapper_ticlang\Stack_Wrapper\ROM\common_rom_init.d
No se pudo encontrar C:\Users\user1234\TI_workspace\Stack_Wrapper_ticlang\Stack_Wrapper\Startup\icall_startup.d
No se pudo encontrar C:\Users\user1234\TI_workspace\Stack_Wrapper_ticlang\Stack_Wrapper\TOOLS\onboard.d
Finished clean
**** Build of configuration Stack_Wrapper for project Stack_Wrapper_ticlang ****
"C:\\ti\\ccs1230\\ccs\\utils\\bin\\gmake" -k -j 8 all -O
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/common/hal_assert.c"
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/bin/tiarmclang.exe" -c @"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang/TOOLS/Defines/Stack_Wrapper.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" @"/build_config.opt"  -mcpu=cortex-m4 -mlittle-endian -mthumb -Oz -I"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" -I"C:/ti/xdctools_3_62_00_08_core/packages" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -g -Wall -fdiagnostics-show-option -ffunction-sections -fdata-sections -march=armv7e-m -MMD -MP -MF"HAL/Common/hal_assert.d_raw" -MT"HAL/Common/hal_assert.o" -std=gnu9x  -o"HAL/Common/hal_assert.o" "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/common/hal_assert.c"
HAL/Common/subdir_rules.mk:9: recipe for target 'HAL/Common/hal_assert.o' failed
tiarmclang: error: no such file or directory: '@/build_config.opt'
gmake: *** [HAL/Common/hal_assert.o] Error 1
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common/hal_flash_wrapper.c"
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/bin/tiarmclang.exe" -c @"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang/TOOLS/Defines/Stack_Wrapper.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" @"/build_config.opt"  -mcpu=cortex-m4 -mlittle-endian -mthumb -Oz -I"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" -I"C:/ti/xdctools_3_62_00_08_core/packages" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -g -Wall -fdiagnostics-show-option -ffunction-sections -fdata-sections -march=armv7e-m -MMD -MP -MF"HAL/Target/CC2650/Drivers/hal_flash_wrapper.d_raw" -MT"HAL/Target/CC2650/Drivers/hal_flash_wrapper.o" -std=gnu9x  -o"HAL/Target/CC2650/Drivers/hal_flash_wrapper.o" "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common/hal_flash_wrapper.c"
HAL/Target/CC2650/Drivers/subdir_rules.mk:9: recipe for target 'HAL/Target/CC2650/Drivers/hal_flash_wrapper.o' failed
gmake: *** [HAL/Target/CC2650/Drivers/hal_flash_wrapper.o] Error 1
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common/hal_trng_wrapper.c"
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/bin/tiarmclang.exe" -c @"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang/TOOLS/Defines/Stack_Wrapper.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" @"/build_config.opt"  -mcpu=cortex-m4 -mlittle-endian -mthumb -Oz -I"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" -I"C:/ti/xdctools_3_62_00_08_core/packages" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -g -Wall -fdiagnostics-show-option -ffunction-sections -fdata-sections -march=armv7e-m -MMD -MP -MF"HAL/Target/CC2650/Drivers/hal_trng_wrapper.d_raw" -MT"HAL/Target/CC2650/Drivers/hal_trng_wrapper.o" -std=gnu9x  -o"HAL/Target/CC2650/Drivers/hal_trng_wrapper.o" "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common/hal_trng_wrapper.c"
HAL/Target/CC2650/Drivers/subdir_rules.mk:16: recipe for target 'HAL/Target/CC2650/Drivers/hal_trng_wrapper.o' failed
gmake: *** [HAL/Target/CC2650/Drivers/hal_trng_wrapper.o] Error 1
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/host/gap.c"
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/bin/tiarmclang.exe" -c @"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang/TOOLS/Defines/Stack_Wrapper.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" @"/build_config.opt"  -mcpu=cortex-m4 -mlittle-endian -mthumb -Oz -I"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" -I"C:/ti/xdctools_3_62_00_08_core/packages" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -g -Wall -fdiagnostics-show-option -ffunction-sections -fdata-sections -march=armv7e-m -MMD -MP -MF"Host/gap.d_raw" -MT"Host/gap.o" -std=gnu9x  -o"Host/gap.o" "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/host/gap.c"
Host/subdir_rules.mk:9: recipe for target 'Host/gap.o' failed
gmake: *** [Host/gap.o] Error 1
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/host/gapbondmgr.c"
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/bin/tiarmclang.exe" -c @"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang/TOOLS/Defines/Stack_Wrapper.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" @"/build_config.opt"  -mcpu=cortex-m4 -mlittle-endian -mthumb -Oz -I"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" -I"C:/ti/xdctools_3_62_00_08_core/packages" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -g -Wall -fdiagnostics-show-option -ffunction-sections -fdata-sections -march=armv7e-m -MMD -MP -MF"Host/gapbondmgr.d_raw" -MT"Host/gapbondmgr.o" -std=gnu9x  -o"Host/gapbondmgr.o" "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/host/gapbondmgr.c"
Host/subdir_rules.mk:16: recipe for target 'Host/gapbondmgr.o' failed
gmake: *** [Host/gapbondmgr.o] Error 1
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/host/gatt_uuid.c"
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/bin/tiarmclang.exe" -c @"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang/TOOLS/Defines/Stack_Wrapper.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" @"/build_config.opt"  -mcpu=cortex-m4 -mlittle-endian -mthumb -Oz -I"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" -I"C:/ti/xdctools_3_62_00_08_core/packages" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -g -Wall -fdiagnostics-show-option -ffunction-sections -fdata-sections -march=armv7e-m -MMD -MP -MF"Host/gatt_uuid.d_raw" -MT"Host/gatt_uuid.o" -std=gnu9x  -o"Host/gatt_uuid.o" "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/host/gatt_uuid.c"
Host/subdir_rules.mk:23: recipe for target 'Host/gatt_uuid.o' failed
gmake: *** [Host/gatt_uuid.o] Error 1
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/host/gattservapp_util.c"
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/bin/tiarmclang.exe" -c @"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang/TOOLS/Defines/Stack_Wrapper.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" @"/build_config.opt"  -mcpu=cortex-m4 -mlittle-endian -mthumb -Oz -I"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" -I"C:/ti/xdctools_3_62_00_08_core/packages" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -g -Wall -fdiagnostics-show-option -ffunction-sections -fdata-sections -march=armv7e-m -MMD -MP -MF"Host/gattservapp_util.d_raw" -MT"Host/gattservapp_util.o" -std=gnu9x  -o"Host/gattservapp_util.o" "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/host/gattservapp_util.c"
Host/subdir_rules.mk:30: recipe for target 'Host/gattservapp_util.o' failed
gmake: *** [Host/gattservapp_util.o] Error 1
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/host/rtls_srv.c"
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/bin/tiarmclang.exe" -c @"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang/TOOLS/Defines/Stack_Wrapper.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" @"/build_config.opt"  -mcpu=cortex-m4 -mlittle-endian -mthumb -Oz -I"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" -I"C:/ti/xdctools_3_62_00_08_core/packages" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -g -Wall -fdiagnostics-show-option -ffunction-sections -fdata-sections -march=armv7e-m -MMD -MP -MF"Host/rtls_srv.d_raw" -MT"Host/rtls_srv.o" -std=gnu9x  -o"Host/rtls_srv.o" "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/host/rtls_srv.c"
Host/subdir_rules.mk:37: recipe for target 'Host/rtls_srv.o' failed
gmake: *** [Host/rtls_srv.o] Error 1
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/host/sm_ecc.c"
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/bin/tiarmclang.exe" -c @"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang/TOOLS/Defines/Stack_Wrapper.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" @"/build_config.opt"  -mcpu=cortex-m4 -mlittle-endian -mthumb -Oz -I"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" -I"C:/ti/xdctools_3_62_00_08_core/packages" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -g -Wall -fdiagnostics-show-option -ffunction-sections -fdata-sections -march=armv7e-m -MMD -MP -MF"Host/sm_ecc.d_raw" -MT"Host/sm_ecc.o" -std=gnu9x  -o"Host/sm_ecc.o" "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/host/sm_ecc.c"
Host/subdir_rules.mk:44: recipe for target 'Host/sm_ecc.o' failed
gmake: *** [Host/sm_ecc.o] Error 1
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/stack/ble_dispatch_JT.c"
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/bin/tiarmclang.exe" -c @"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang/TOOLS/Defines/Stack_Wrapper.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" @"/build_config.opt"  -mcpu=cortex-m4 -mlittle-endian -mthumb -Oz -I"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" -I"C:/ti/xdctools_3_62_00_08_core/packages" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -g -Wall -fdiagnostics-show-option -ffunction-sections -fdata-sections -march=armv7e-m -MMD -MP -MF"ICallBLE/ble_dispatch_JT.d_raw" -MT"ICallBLE/ble_dispatch_JT.o" -std=gnu9x  -o"ICallBLE/ble_dispatch_JT.o" "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/stack/ble_dispatch_JT.c"
ICallBLE/subdir_rules.mk:9: recipe for target 'ICallBLE/ble_dispatch_JT.o' failed
gmake: *** [ICallBLE/ble_dispatch_JT.o] Error 1
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/stack/ble_dispatch_lite.c"
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/bin/tiarmclang.exe" -c @"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang/TOOLS/Defines/Stack_Wrapper.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" @"/build_config.opt"  -mcpu=cortex-m4 -mlittle-endian -mthumb -Oz -I"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" -I"C:/ti/xdctools_3_62_00_08_core/packages" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -g -Wall -fdiagnostics-show-option -ffunction-sections -fdata-sections -march=armv7e-m -MMD -MP -MF"ICallBLE/ble_dispatch_lite.d_raw" -MT"ICallBLE/ble_dispatch_lite.o" -std=gnu9x  -o"ICallBLE/ble_dispatch_lite.o" "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/stack/ble_dispatch_lite.c"
ICallBLE/subdir_rules.mk:16: recipe for target 'ICallBLE/ble_dispatch_lite.o' failed
gmake: *** [ICallBLE/ble_dispatch_lite.o] Error 1
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/icall_lite_translation.c"
Invoking: Arm Compiler
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/bin/tiarmclang.exe" -c @"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang/TOOLS/Defines/Stack_Wrapper.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" @"/build_config.opt"  -mcpu=cortex-m4 -mlittle-endian -mthumb -Oz -I"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" -I"C:/ti/xdctools_3_62_00_08_core/packages" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -g -Wall -fdiagnostics-show-option -ffunction-sections -fdata-sections -march=armv7e-m -MMD -MP -MF"ICallBLE/icall_lite_translation.d_raw" -MT"ICallBLE/icall_lite_translation.o" -std=gnu9x  -o"ICallBLE/icall_lite_translation.o" "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/icall_lite_translation.c"
ICallBLE/subdir_rules.mk:23: recipe for target 'ICallBLE/icall_lite_translation.o' failed
gmake: *** [ICallBLE/icall_lite_translation.o] Error 1
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack/npi.c"
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/bin/tiarmclang.exe" -c @"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang/TOOLS/Defines/Stack_Wrapper.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" @"/build_config.opt"  -mcpu=cortex-m4 -mlittle-endian -mthumb -Oz -I"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" -I"C:/ti/xdctools_3_62_00_08_core/packages" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -g -Wall -fdiagnostics-show-option -ffunction-sections -fdata-sections -march=armv7e-m -MMD -MP -MF"NPI/npi.d_raw" -MT"NPI/npi.o" -std=gnu9x  -o"NPI/npi.o" "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack/npi.c"
NPI/subdir_rules.mk:9: recipe for target 'NPI/npi.o' failed
gmake: *** [NPI/npi.o] Error 1
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/bin/tiarmclang.exe" -c @"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang/TOOLS/Defines/Stack_Wrapper.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" @"/build_config.opt"  -mcpu=cortex-m4 -mlittle-endian -mthumb -Oz -I"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" -I"C:/ti/xdctools_3_62_00_08_core/packages" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -g -Wall -fdiagnostics-show-option -ffunction-sections -fdata-sections -march=armv7e-m -MMD -MP -MF"OSAL/osal.d_raw" -MT"OSAL/osal.o" -std=gnu9x  -o"OSAL/osal.o" "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/common/osal.c"
OSAL/subdir_rules.mk:9: recipe for target 'OSAL/osal.o' failed
gmake: *** [OSAL/osal.o] Error 1
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/common/osal_bufmgr.c"
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/bin/tiarmclang.exe" -c @"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang/TOOLS/Defines/Stack_Wrapper.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" @"/build_config.opt"  -mcpu=cortex-m4 -mlittle-endian -mthumb -Oz -I"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" -I"C:/ti/xdctools_3_62_00_08_core/packages" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -g -Wall -fdiagnostics-show-option -ffunction-sections -fdata-sections -march=armv7e-m -MMD -MP -MF"OSAL/osal_bufmgr.d_raw" -MT"OSAL/osal_bufmgr.o" -std=gnu9x  -o"OSAL/osal_bufmgr.o" "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/common/osal_bufmgr.c"
OSAL/subdir_rules.mk:16: recipe for target 'OSAL/osal_bufmgr.o' failed
gmake: *** [OSAL/osal_bufmgr.o] Error 1
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/common/osal_cbtimer.c"
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/bin/tiarmclang.exe" -c @"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang/TOOLS/Defines/Stack_Wrapper.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" @"/build_config.opt"  -mcpu=cortex-m4 -mlittle-endian -mthumb -Oz -I"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" -I"C:/ti/xdctools_3_62_00_08_core/packages" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -g -Wall -fdiagnostics-show-option -ffunction-sections -fdata-sections -march=armv7e-m -MMD -MP -MF"OSAL/osal_cbtimer.d_raw" -MT"OSAL/osal_cbtimer.o" -std=gnu9x  -o"OSAL/osal_cbtimer.o" "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/common/osal_cbtimer.c"
OSAL/subdir_rules.mk:23: recipe for target 'OSAL/osal_cbtimer.o' failed
gmake: *** [OSAL/osal_cbtimer.o] Error 1
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/common/osal_clock.c"
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/bin/tiarmclang.exe" -c @"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang/TOOLS/Defines/Stack_Wrapper.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" @"/build_config.opt"  -mcpu=cortex-m4 -mlittle-endian -mthumb -Oz -I"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" -I"C:/ti/xdctools_3_62_00_08_core/packages" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -g -Wall -fdiagnostics-show-option -ffunction-sections -fdata-sections -march=armv7e-m -MMD -MP -MF"OSAL/osal_clock.d_raw" -MT"OSAL/osal_clock.o" -std=gnu9x  -o"OSAL/osal_clock.o" "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/common/osal_clock.c"
OSAL/subdir_rules.mk:30: recipe for target 'OSAL/osal_clock.o' failed
gmake: *** [OSAL/osal_clock.o] Error 1
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/common/osal_list.c"
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/bin/tiarmclang.exe" -c @"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang/TOOLS/Defines/Stack_Wrapper.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" @"/build_config.opt"  -mcpu=cortex-m4 -mlittle-endian -mthumb -Oz -I"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" -I"C:/ti/xdctools_3_62_00_08_core/packages" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -g -Wall -fdiagnostics-show-option -ffunction-sections -fdata-sections -march=armv7e-m -MMD -MP -MF"OSAL/osal_list.d_raw" -MT"OSAL/osal_list.o" -std=gnu9x  -o"OSAL/osal_list.o" "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/common/osal_list.c"
OSAL/subdir_rules.mk:37: recipe for target 'OSAL/osal_list.o' failed
gmake: *** [OSAL/osal_list.o] Error 1
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/common/osal_memory_icall.c"
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/bin/tiarmclang.exe" -c @"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang/TOOLS/Defines/Stack_Wrapper.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" @"/build_config.opt"  -mcpu=cortex-m4 -mlittle-endian -mthumb -Oz -I"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" -I"C:/ti/xdctools_3_62_00_08_core/packages" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -g -Wall -fdiagnostics-show-option -ffunction-sections -fdata-sections -march=armv7e-m -MMD -MP -MF"OSAL/osal_memory_icall.d_raw" -MT"OSAL/osal_memory_icall.o" -std=gnu9x  -o"OSAL/osal_memory_icall.o" "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/common/osal_memory_icall.c"
OSAL/subdir_rules.mk:44: recipe for target 'OSAL/osal_memory_icall.o' failed
gmake: *** [OSAL/osal_memory_icall.o] Error 1
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/common/osal_pwrmgr.c"
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/bin/tiarmclang.exe" -c @"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang/TOOLS/Defines/Stack_Wrapper.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" @"/build_config.opt"  -mcpu=cortex-m4 -mlittle-endian -mthumb -Oz -I"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" -I"C:/ti/xdctools_3_62_00_08_core/packages" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -g -Wall -fdiagnostics-show-option -ffunction-sections -fdata-sections -march=armv7e-m -MMD -MP -MF"OSAL/osal_pwrmgr.d_raw" -MT"OSAL/osal_pwrmgr.o" -std=gnu9x  -o"OSAL/osal_pwrmgr.o" "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/common/osal_pwrmgr.c"
OSAL/subdir_rules.mk:51: recipe for target 'OSAL/osal_pwrmgr.o' failed
gmake: *** [OSAL/osal_pwrmgr.o] Error 1
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/mcu/cc26xx/osal_snv_wrapper.c"
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/bin/tiarmclang.exe" -c @"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang/TOOLS/Defines/Stack_Wrapper.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" @"/build_config.opt"  -mcpu=cortex-m4 -mlittle-endian -mthumb -Oz -I"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" -I"C:/ti/xdctools_3_62_00_08_core/packages" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -g -Wall -fdiagnostics-show-option -ffunction-sections -fdata-sections -march=armv7e-m -MMD -MP -MF"OSAL/osal_snv_wrapper.d_raw" -MT"OSAL/osal_snv_wrapper.o" -std=gnu9x  -o"OSAL/osal_snv_wrapper.o" "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/mcu/cc26xx/osal_snv_wrapper.c"
OSAL/subdir_rules.mk:58: recipe for target 'OSAL/osal_snv_wrapper.o' failed
tiarmclang: error: no such file or directory: '@/build_config.opt'
gmake: *** [OSAL/osal_snv_wrapper.o] Error 1
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/common/osal_timers.c"
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/bin/tiarmclang.exe" -c @"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang/TOOLS/Defines/Stack_Wrapper.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" @"/build_config.opt"  -mcpu=cortex-m4 -mlittle-endian -mthumb -Oz -I"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" -I"C:/ti/xdctools_3_62_00_08_core/packages" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -g -Wall -fdiagnostics-show-option -ffunction-sections -fdata-sections -march=armv7e-m -MMD -MP -MF"OSAL/osal_timers.d_raw" -MT"OSAL/osal_timers.o" -std=gnu9x  -o"OSAL/osal_timers.o" "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/common/osal_timers.c"
OSAL/subdir_rules.mk:65: recipe for target 'OSAL/osal_timers.o' failed
gmake: *** [OSAL/osal_timers.o] Error 1
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom/agama_r1/common_rom_init.c"
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/bin/tiarmclang.exe" -c @"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang/TOOLS/Defines/Stack_Wrapper.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" @"/build_config.opt"  -mcpu=cortex-m4 -mlittle-endian -mthumb -Oz -I"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" -I"C:/ti/xdctools_3_62_00_08_core/packages" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -g -Wall -fdiagnostics-show-option -ffunction-sections -fdata-sections -march=armv7e-m -MMD -MP -MF"ROM/common_rom_init.d_raw" -MT"ROM/common_rom_init.o" -std=gnu9x  -o"ROM/common_rom_init.o" "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom/agama_r1/common_rom_init.c"
ROM/subdir_rules.mk:9: recipe for target 'ROM/common_rom_init.o' failed
gmake: *** [ROM/common_rom_init.o] Error 1
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/icall_startup.c"
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/bin/tiarmclang.exe" -c @"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang/TOOLS/Defines/Stack_Wrapper.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" @"/build_config.opt"  -mcpu=cortex-m4 -mlittle-endian -mthumb -Oz -I"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" -I"C:/ti/xdctools_3_62_00_08_core/packages" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -g -Wall -fdiagnostics-show-option -ffunction-sections -fdata-sections -march=armv7e-m -MMD -MP -MF"Startup/icall_startup.d_raw" -MT"Startup/icall_startup.o" -std=gnu9x  -o"Startup/icall_startup.o" "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/icall_startup.c"
Startup/subdir_rules.mk:9: recipe for target 'Startup/icall_startup.o' failed
gmake: *** [Startup/icall_startup.o] Error 1
Building file: "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/onboard.c"
"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/bin/tiarmclang.exe" -c @"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang/TOOLS/Defines/Stack_Wrapper.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/build_components.opt" @"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/config/factory_config.opt" @"/build_config.opt"  -mcpu=cortex-m4 -mlittle-endian -mthumb -Oz -I"C:/Users/user1234/TI_workspace/Stack_Wrapper_ticlang" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/controller/cc26xx/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/rom" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/npi/stack" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/_common" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target/cc2650tirtos" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/target" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/hal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/icall/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/npi/src" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/osal/src/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/common/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/aes/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv/cc26xx" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/nv" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/services/src/saddr" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/rf_patches" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/devices/cc13x2_cc26x2/inc" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source" -I"C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/kernel/tirtos7/packages" -I"C:/ti/xdctools_3_62_00_08_core/packages" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -I"C:/ti/ccs1230/ccs/tools/compiler/ti-cgt-armllvm_2.1.3.LTS/include" -g -Wall -fdiagnostics-show-option -ffunction-sections -fdata-sections -march=armv7e-m -MMD -MP -MF"TOOLS/onboard.d_raw" -MT"TOOLS/onboard.o" -std=gnu9x  -o"TOOLS/onboard.o" "C:/ti/simplelink_cc13xx_cc26xx_sdk_7_10_00_98/source/ti/ble5stack/common/cc26xx/onboard.c"
TOOLS/subdir_rules.mk:9: recipe for target 'TOOLS/onboard.o' failed
gmake: *** [TOOLS/onboard.o] Error 1
gmake: Target 'all' not remade because of errors.
**** Build Finished ****
Any help would be greatly appreciated,
Thanks in advance
