I downloaded the IQmath lib (http://www.ti.com/tool/sprc542) and the C6xsim intrisics (as documented here: http://processors.wiki.ti.com/index.php/Run_Intrinsics_Code_Anywhere ) and wrote some code for the DSP that I compile for my linux host, for test/debug. The IQmath function _IQNmag performs a sqrt(a^2+b^2) per the documentation "avoiding overflow problems" however, what I see is overflowed occur well beyond the expected results. Interestingly, the problem only exists for the code compiled for the host. When I compile the code for the target and run it on the host via the commandline simulator it runs as expected. I suspect the problem is with the C6xsim, but I don't know for sure. I'd really like to be able to count on the code I compile for the host. Can anyone offer insight/resolution?
$ cat bug.c
#include <math.h>
#include <stdio.h>
#include "IQmath_inline_all.h"
int main(int argc, char **argv)
int i;
_iq a, b, c;
printf("FLOAT a = %1.15f b %1.15f c = %1.15f\n", 3.8, 3.9, sqrtf(3.8*3.8+3.9*3.9));
for (i = 31; i >= 0; i--)
a = _FtoIQN(3.8, i);
b = _FtoIQN(3.9, i);
c = _IQNmag(a, b, i);
printf("i = %2d a = %1.15f b %1.15f c = %1.15f\n", i, _IQNtoF(a, i), _IQNtoF(b, i), _IQNtoF(c, i));
return 0;
$ ./bug # compiled for host, lots of unexpected results
FLOAT a = 3.800000000000000 b 3.900000000000000 c = 5.445181369781494
<< "real" answer
i = 31 a = 0.000000000465661 b 0.000000000465661 c = 0.000000000465661
<< expected failure, input overflows accepted range
i = 30 a = 0.000000000000000 b 0.000000000000000 c = 0.000000000000000
i = 29 a = 3.799999952316284 b 3.900000095367432 c =
3.999999761581421 << expected failure, output overflows
accepted range
i = 28 a = 3.799999952316284 b 3.900000095367432 c =
0.000000000000000 << unexpected failure, only the intermediate
overflows 32 bits
i = 27 a = 3.799999952316284 b 3.900000095367432 c = 5.471137046813965
i = 26 a = 3.799999952316284 b 3.900000095367432 c = 0.000000000000000
i = 25 a = 3.799999952316284 b 3.900000095367432 c = 0.000000000000000
i = 24 a = 3.799999952316284 b 3.900000095367432 c = 5.631754875183105
i = 23 a = 3.799999952316284 b 3.900000095367432 c = 0.000000000000000
i = 22 a = 3.799999952316284 b 3.900000095367432 c = 5.451299667358398
i = 21 a = 3.799999713897705 b 3.900000095367432 c = 0.000000000000000
i = 20 a = 3.799999237060547 b 3.899999618530273 c = 5.473990440368652
i = 19 a = 3.799999237060547 b 3.899999618530273 c = 0.000000000000000
i = 18 a = 3.799999237060547 b 3.899997711181641 c = 5.451274871826172
i = 17 a = 3.799995422363281 b 3.899993896484375 c = 0.000000000000000
i = 16 a = 3.799987792968750 b 3.899993896484375 c = 0.000000000000000
i = 15 a = 3.799987792968750 b 3.899993896484375 c = 5.648529052734375
i = 14 a = 3.799987792968750 b 3.899963378906250 c = 0.000000000000000
i = 13 a = 3.799926757812500 b 3.899902343750000 c = 5.445068359375000
<< first "reliable" answer
i = 12 a = 3.799804687500000 b 3.899902343750000 c = 5.445068359375000
<< from here down, as expected... losing precision
i = 11 a = 3.799804687500000 b 3.899902343750000 c = 5.444824218750000
i = 10 a = 3.799804687500000 b 3.899414062500000 c = 5.444335937500000
i = 9 a = 3.798828125000000 b 3.898437500000000 c = 5.443359375000000
i = 8 a = 3.796875000000000 b 3.898437500000000 c = 5.441406250000000
i = 7 a = 3.796875000000000 b 3.898437500000000 c = 5.445312500000000
i = 6 a = 3.796875000000000 b 3.890625000000000 c = 5.437500000000000
i = 5 a = 3.781250000000000 b 3.875000000000000 c = 5.406250000000000
i = 4 a = 3.750000000000000 b 3.875000000000000 c = 5.375000000000000
i = 3 a = 3.750000000000000 b 3.875000000000000 c = 5.375000000000000
i = 2 a = 3.750000000000000 b 3.750000000000000 c = 5.250000000000000
i = 1 a = 3.500000000000000 b 3.500000000000000 c = 5.000000000000000
i = 0 a = 3.000000000000000 b 3.000000000000000 c = 4.000000000000000
$ loadti.sh -q -c c64xp_le_sim.ccxml bug.out # compiled for c64x+, all results as expected
testEnv.outFiles: bug.out
FLOAT a = 3.800000000000000 b = 3.900000000000000 c = 5.445181369781494
i = 31 a = 0.000000000000000 b = 0.000000000000000 c = 0.000000000000000
i = 30 a = 0.000000000000000 b = 0.000000000000000 c = 0.000000000000000
i = 29 a = 3.799999952316284 b = 3.900000095367432 c = 3.999999761581421
i = 28 a = 3.799999952316284 b = 3.900000095367432 c = 5.445181369781494
i = 27 a = 3.799999952316284 b = 3.900000095367432 c = 5.445181369781494
i = 26 a = 3.799999952316284 b = 3.900000095367432 c = 5.445181369781494
i = 25 a = 3.799999952316284 b = 3.900000095367432 c = 5.445181369781494
i = 24 a = 3.799999952316284 b = 3.900000095367432 c = 5.445181369781494
i = 23 a = 3.799999952316284 b = 3.900000095367432 c = 5.445181369781494
i = 22 a = 3.799999952316284 b = 3.900000095367432 c = 5.445181369781494
i = 21 a = 3.799999713897705 b = 3.900000095367432 c = 5.445181369781494
i = 20 a = 3.799999237060547 b = 3.899999618530273 c = 5.445180892944336
i = 19 a = 3.799999237060547 b = 3.899999618530273 c = 5.445180892944336
i = 18 a = 3.799999237060547 b = 3.899997711181641 c = 5.445178985595703
i = 17 a = 3.799995422363281 b = 3.899993896484375 c = 5.445175170898438
i = 16 a = 3.799987792968750 b = 3.899993896484375 c = 5.445175170898438
i = 15 a = 3.799987792968750 b = 3.899993896484375 c = 5.445159912109375
i = 14 a = 3.799987792968750 b = 3.899963378906250 c = 5.445129394531250
i = 13 a = 3.799926757812500 b = 3.899902343750000 c = 5.445068359375000
i = 12 a = 3.799804687500000 b = 3.899902343750000 c = 5.445068359375000
i = 11 a = 3.799804687500000 b = 3.899902343750000 c = 5.444824218750000
i = 10 a = 3.799804687500000 b = 3.899414062500000 c = 5.444335937500000
i = 9 a = 3.798828125000000 b = 3.898437500000000 c = 5.443359375000000
i = 8 a = 3.796875000000000 b = 3.898437500000000 c = 5.441406250000000
i = 7 a = 3.796875000000000 b = 3.898437500000000 c = 5.445312500000000
i = 6 a = 3.796875000000000 b = 3.890625000000000 c = 5.437500000000000
i = 5 a = 3.781250000000000 b = 3.875000000000000 c = 5.406250000000000
i = 4 a = 3.750000000000000 b = 3.875000000000000 c = 5.375000000000000
i = 3 a = 3.750000000000000 b = 3.875000000000000 c = 5.375000000000000
i = 2 a = 3.750000000000000 b = 3.750000000000000 c = 5.250000000000000
i = 1 a = 3.500000000000000 b = 3.500000000000000 c = 5.000000000000000
i = 0 a = 3.000000000000000 b = 3.000000000000000 c = 4.000000000000000
