I'm working on ARM7 based devices, i'm using "rts32tiabi.lib" as a library file. So I'm looking for New or Updates Library file for the same.
Please suggest me where do i get the same.
Rahul
Rahul,
If you have CCSv5 you will be able to update your version of the ARM compiler tools through the menu Help --> Check for updates - all versions support ARM7 cores and they will provide arm7 libraries. However, the library names will be different: for example the TIABI big endian version for ARM7 is named <rtsv4_A_be_tiarm7.lib> and EABI big endian version for ARM7 is named <rtsv4_A_be_eabi.lib>.
Hope this helps,
Rafael
