PRELIMINARY NOTE: please refer to CCS5 wrong configuration if RDK-S2E target processor change post on STELLARIS ARC CORTEX-M MICROCONTROLLER
FORUM (discussed with Lela Garofolo).
I'm using CCS version: 5.2.1.00018 and I'm working on RDK-S2E StellarisWare version 9453 compiled for a target board mounting an LM3S6918 processor.
If I build RDK-S2E using the default processor (LM3S6432) the target ethernet section works fine (ping replies are always ok).
If I build RDK-S2E using a different, bigger, processor (LM3S6918) the target ethernet section doesn't work fine (no ping replies) and don't recover.
What I'm doing to change processor is just selecting the new one under Properties -> General -> Main -> Variant: LM3S6918
In addition, I tried to change the processor definition under Properties -> Build -> ARM Compiler -> Advanced Options -> Predefined Symbols: PART_LM3S6918, without success.
Now I have generated 3 configuration files as test-case:
file .csproject_6432_OK: using this original .cproject file built for LM3S6432 my project works fine;
file .csproject_6918_KO: using this .cproject file modified for LM3S6918 my project doesn't works as explained;
file .csproject_6432_KO: using this modified-back .cproject file for LM3S6432, my project doesn't works as explained.
From my point of view, it seems that CCS builds a wrong configuration file .csproject, compared to the one (original) generated with an older version.
In effect, the differences between the original file and the new ones are several (I didn't expected that much differences).
I enclose the 3 files.
Any ideas?
Many Thanks, Giuseppe
<?xml version="1.0" encoding="UTF-8" standalone="no"?> <?fileVersion 4.0.0?> <cproject storage_type_id="org.eclipse.cdt.core.XmlProjectDescriptionStorage"> <storageModule configRelations="2" moduleId="org.eclipse.cdt.core.settings"> <cconfiguration id="com.ti.ccstudio.buildDefinitions.TMS470.Debug.27756458"> <storageModule buildSystemId="org.eclipse.cdt.managedbuilder.core.configurationDataProvider" id="com.ti.ccstudio.buildDefinitions.TMS470.Debug.27756458" moduleId="org.eclipse.cdt.core.settings" name="Debug"> <macros> <stringMacro name="ORIGINAL_PROJECT_ROOT" type="VALUE_PATH_DIR" value="C:/StellarisWare/boards/rdk-s2e/ser2enet/ccs"/> <stringMacro name="SW_ROOT" type="VALUE_PATH_DIR" value="${ORIGINAL_PROJECT_ROOT}/../../../.."/> </macros> <externalSettings/> <extensions> <extension id="com.ti.ccstudio.binaryparser.CoffParser" point="org.eclipse.cdt.core.BinaryParser"/> <extension id="com.ti.ccstudio.errorparser.CoffErrorParser" point="org.eclipse.cdt.core.ErrorParser"/> <extension id="com.ti.ccstudio.errorparser.LinkErrorParser" point="org.eclipse.cdt.core.ErrorParser"/> <extension id="com.ti.ccstudio.errorparser.AsmErrorParser" point="org.eclipse.cdt.core.ErrorParser"/> </extensions> </storageModule> <storageModule moduleId="cdtBuildSystem" version="4.0.0"> <configuration artifactExtension="out" artifactName="${ProjName}" buildProperties="" cleanCommand="${CG_CLEAN_CMD}" description="" id="com.ti.ccstudio.buildDefinitions.TMS470.Debug.27756458" name="Debug" parent="com.ti.ccstudio.buildDefinitions.TMS470.Debug" postbuildStep=""${CCE_INSTALL_ROOT}/utils/tiobj2bin/tiobj2bin" "${BuildArtifactFileName}" "${BuildArtifactFileBaseName}.bin" "${CG_TOOL_ROOT}/bin/ofd470" "${CG_TOOL_ROOT}/bin/hex470" "${CCE_INSTALL_ROOT}/utils/tiobj2bin/mkhex4bin""> <folderInfo id="com.ti.ccstudio.buildDefinitions.TMS470.Debug.27756458." name="/" resourcePath=""> <toolChain id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.DebugToolchain.413217478" name="TI Build Tools" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.DebugToolchain" targetTool="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.linkerDebug.1741251397"> <option id="com.ti.ccstudio.buildDefinitions.core.OPT_TAGS.738283637" superClass="com.ti.ccstudio.buildDefinitions.core.OPT_TAGS" valueType="stringList"> <listOptionValue builtIn="false" value="DEVICE_CONFIGURATION_ID=Cortex M.LM3S6432"/> <listOptionValue builtIn="false" value="DEVICE_ENDIANNESS=little"/> <listOptionValue builtIn="false" value="OUTPUT_FORMAT=ELF"/> <listOptionValue builtIn="false" value="CCS_MBS_VERSION=5.1.0.01"/> <listOptionValue builtIn="false" value="RUNTIME_SUPPORT_LIBRARY=libc.a"/> <listOptionValue builtIn="false" value="OUTPUT_TYPE=executable"/> </option> <option id="com.ti.ccstudio.buildDefinitions.core.OPT_CODEGEN_VERSION.252637998" superClass="com.ti.ccstudio.buildDefinitions.core.OPT_CODEGEN_VERSION" value="4.9.5" valueType="string"/> <targetPlatform id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.targetPlatformDebug.1640814727" name="Platform" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.targetPlatformDebug"/> <builder buildPath="${BuildDirectory}" id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.builderDebug.1213445875" name="GNU Make.Debug" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.builderDebug"/> <tool id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.compilerDebug.789414559" name="ARM Compiler" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.compilerDebug"> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.SILICON_VERSION.2137987878" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.SILICON_VERSION" value="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.SILICON_VERSION.7M3" valueType="enumerated"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.CODE_STATE.1439172173" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.CODE_STATE" value="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.CODE_STATE.16" valueType="enumerated"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.ABI.1391599376" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.ABI" value="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.ABI.eabi" valueType="enumerated"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DEBUGGING_MODEL.1982133534" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DEBUGGING_MODEL" value="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DEBUGGING_MODEL.SYMDEBUG__DWARF" valueType="enumerated"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DIAG_WARNING.1511116644" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DIAG_WARNING" valueType="stringList"> <listOptionValue builtIn="false" value="225"/> </option> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DISPLAY_ERROR_NUMBER.187501309" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DISPLAY_ERROR_NUMBER" value="true" valueType="boolean"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.INCLUDE_PATH.2004694409" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.INCLUDE_PATH" valueType="includePath"> <listOptionValue builtIn="false" value=""${CG_TOOL_ROOT}/include""/> <listOptionValue builtIn="false" value=""${workspace_loc:/${ProjName}}""/> <listOptionValue builtIn="false" value=""${SW_ROOT}""/> <listOptionValue builtIn="false" value=""${SW_ROOT}/third_party/lwip-1.3.2/src/include""/> <listOptionValue builtIn="false" value=""${SW_ROOT}/third_party/lwip-1.3.2/src/include/ipv4""/> <listOptionValue builtIn="false" value=""${SW_ROOT}/third_party/lwip-1.3.2/apps""/> <listOptionValue builtIn="false" value=""${SW_ROOT}/third_party/lwip-1.3.2/ports/stellaris/include""/> </option> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.LITTLE_ENDIAN.600204243" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.LITTLE_ENDIAN" value="true" valueType="boolean"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.GEN_FUNC_SUBSECTIONS.104649414" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.GEN_FUNC_SUBSECTIONS" value="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.GEN_FUNC_SUBSECTIONS.on" valueType="enumerated"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.OPT_LEVEL.179489062" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.OPT_LEVEL" value="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.OPT_LEVEL.2" valueType="enumerated"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.GCC.1767126295" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.GCC" value="true" valueType="boolean"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.UAL.726774049" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.UAL" value="true" valueType="boolean"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DEFINE.308504882" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DEFINE" valueType="definedSymbols"> <listOptionValue builtIn="false" value="ccs="ccs""/> <listOptionValue builtIn="false" value="PART_LM3S6432"/> </option> <inputType id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__C_SRCS.491603858" name="C Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__C_SRCS"/> <inputType id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__CPP_SRCS.1781051507" name="C++ Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__CPP_SRCS"/> <inputType id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__ASM_SRCS.1956501841" name="Assembly Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__ASM_SRCS"/> <inputType id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__ASM2_SRCS.2047762748" name="Assembly Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__ASM2_SRCS"/> </tool> <tool id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.linkerDebug.1741251397" name="ARM Linker" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.linkerDebug"> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.MAP_FILE.1361590713" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.MAP_FILE" value=""ser2enet_ccs.map"" valueType="string"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.STACK_SIZE.2128209016" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.STACK_SIZE" value="4096" valueType="string"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.HEAP_SIZE.732060075" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.HEAP_SIZE" value="0" valueType="string"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.OUTPUT_FILE.2093432695" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.OUTPUT_FILE" value=""${ProjName}.out"" valueType="string"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.DISPLAY_ERROR_NUMBER.1728924183" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.DISPLAY_ERROR_NUMBER" value="true" valueType="boolean"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.SEARCH_PATH.280369509" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.SEARCH_PATH" valueType="stringList"> <listOptionValue builtIn="false" value=""${CG_TOOL_ROOT}/lib""/> <listOptionValue builtIn="false" value=""${CG_TOOL_ROOT}/include""/> </option> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.LIBRARY.2115867431" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.LIBRARY" valueType="libs"> <listOptionValue builtIn="false" value=""libc.a""/> <listOptionValue builtIn="false" value=""${SW_ROOT}/driverlib/ccs-cm3/Debug/driverlib-cm3.lib""/> </option> </tool> </toolChain> </folderInfo> </configuration> </storageModule> <storageModule moduleId="org.eclipse.cdt.core.externalSettings"/> </cconfiguration> <cconfiguration id="com.ti.ccstudio.buildDefinitions.TMS470.Release.2040994429"> <storageModule buildSystemId="org.eclipse.cdt.managedbuilder.core.configurationDataProvider" id="com.ti.ccstudio.buildDefinitions.TMS470.Release.2040994429" moduleId="org.eclipse.cdt.core.settings" name="Release"> <macros> <stringMacro name="ORIGINAL_PROJECT_ROOT" type="VALUE_PATH_DIR" value="C:/StellarisWare/boards/rdk-s2e/ser2enet/ccs"/> <stringMacro name="SW_ROOT" type="VALUE_PATH_DIR" value="${ORIGINAL_PROJECT_ROOT}/../../../.."/> </macros> <externalSettings/> <extensions> <extension id="com.ti.ccstudio.binaryparser.CoffParser" point="org.eclipse.cdt.core.BinaryParser"/> <extension id="com.ti.ccstudio.errorparser.CoffErrorParser" point="org.eclipse.cdt.core.ErrorParser"/> <extension id="com.ti.ccstudio.errorparser.LinkErrorParser" point="org.eclipse.cdt.core.ErrorParser"/> <extension id="com.ti.ccstudio.errorparser.AsmErrorParser" point="org.eclipse.cdt.core.ErrorParser"/> </extensions> </storageModule> <storageModule moduleId="cdtBuildSystem" version="4.0.0"> <configuration artifactExtension="out" artifactName="${ProjName}" buildProperties="" cleanCommand="${CG_CLEAN_CMD}" description="" id="com.ti.ccstudio.buildDefinitions.TMS470.Release.2040994429" name="Release" parent="com.ti.ccstudio.buildDefinitions.TMS470.Release" postbuildStep=""${CCE_INSTALL_ROOT}/utils/tiobj2bin/tiobj2bin" "${BuildArtifactFileName}" "${BuildArtifactFileBaseName}.bin" "${CG_TOOL_ROOT}/bin/ofd470" "${CG_TOOL_ROOT}/bin/hex470" "${CCE_INSTALL_ROOT}/utils/tiobj2bin/mkhex4bin""> <folderInfo id="com.ti.ccstudio.buildDefinitions.TMS470.Release.2040994429." name="/" resourcePath=""> <toolChain id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.ReleaseToolchain.1694215346" name="TI Build Tools" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.ReleaseToolchain" targetTool="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.linkerRelease.994786213"> <option id="com.ti.ccstudio.buildDefinitions.core.OPT_TAGS.1448833738" superClass="com.ti.ccstudio.buildDefinitions.core.OPT_TAGS" valueType="stringList"> <listOptionValue builtIn="false" value="DEVICE_CONFIGURATION_ID=Cortex M.LM3S6432"/> <listOptionValue builtIn="false" value="DEVICE_ENDIANNESS=little"/> <listOptionValue builtIn="false" value="OUTPUT_FORMAT=ELF"/> <listOptionValue builtIn="false" value="CCS_MBS_VERSION=5.1.0.01"/> <listOptionValue builtIn="false" value="RUNTIME_SUPPORT_LIBRARY=libc.a"/> <listOptionValue builtIn="false" value="OUTPUT_TYPE=executable"/> </option> <option id="com.ti.ccstudio.buildDefinitions.core.OPT_CODEGEN_VERSION.2040206650" superClass="com.ti.ccstudio.buildDefinitions.core.OPT_CODEGEN_VERSION" value="4.9.5" valueType="string"/> <targetPlatform id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.targetPlatformRelease.1927517358" name="Platform" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.targetPlatformRelease"/> <builder buildPath="${BuildDirectory}" id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.builderRelease.248486123" name="GNU Make.Release" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.builderRelease"/> <tool id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.compilerRelease.141115905" name="ARM Compiler" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.compilerRelease"> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.SILICON_VERSION.2144734781" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.SILICON_VERSION" value="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.SILICON_VERSION.7M3" valueType="enumerated"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.CODE_STATE.1665379695" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.CODE_STATE" value="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.CODE_STATE.16" valueType="enumerated"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.ABI.533578491" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.ABI" value="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.ABI.eabi" valueType="enumerated"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DIAG_WARNING.1614148367" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DIAG_WARNING" valueType="stringList"> <listOptionValue builtIn="false" value="225"/> </option> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DISPLAY_ERROR_NUMBER.1243529506" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DISPLAY_ERROR_NUMBER" value="true" valueType="boolean"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.INCLUDE_PATH.1108290780" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.INCLUDE_PATH" valueType="includePath"> <listOptionValue builtIn="false" value=""${CG_TOOL_ROOT}/include""/> <listOptionValue builtIn="false" value=""${workspace_loc:/${ProjName}}""/> <listOptionValue builtIn="false" value=""${SW_ROOT}""/> <listOptionValue builtIn="false" value=""${SW_ROOT}/third_party/lwip-1.3.2/src/include""/> <listOptionValue builtIn="false" value=""${SW_ROOT}/third_party/lwip-1.3.2/src/include/ipv4""/> <listOptionValue builtIn="false" value=""${SW_ROOT}/third_party/lwip-1.3.2/apps""/> <listOptionValue builtIn="false" value=""${SW_ROOT}/third_party/lwip-1.3.2/ports/stellaris/include""/> </option> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.LITTLE_ENDIAN.1140699233" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.LITTLE_ENDIAN" value="true" valueType="boolean"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.GEN_FUNC_SUBSECTIONS.1940191057" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.GEN_FUNC_SUBSECTIONS" value="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.GEN_FUNC_SUBSECTIONS.on" valueType="enumerated"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.GCC.1656570230" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.GCC" value="true" valueType="boolean"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.UAL.557591006" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.UAL" value="true" valueType="boolean"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DEFINE.429457989" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DEFINE" valueType="definedSymbols"> <listOptionValue builtIn="false" value="ccs="ccs""/> <listOptionValue builtIn="false" value="PART_LM3S6432"/> </option> <inputType id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__C_SRCS.1689921350" name="C Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__C_SRCS"/> <inputType id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__CPP_SRCS.1596783574" name="C++ Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__CPP_SRCS"/> <inputType id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__ASM_SRCS.318651067" name="Assembly Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__ASM_SRCS"/> <inputType id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__ASM2_SRCS.1611059127" name="Assembly Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__ASM2_SRCS"/> </tool> <tool id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.linkerRelease.994786213" name="ARM Linker" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.linkerRelease"> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.MAP_FILE.149555574" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.MAP_FILE" value=""ser2enet_ccs.map"" valueType="string"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.STACK_SIZE.108000444" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.STACK_SIZE" value="4096" valueType="string"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.HEAP_SIZE.1149894067" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.HEAP_SIZE" value="0" valueType="string"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.OUTPUT_FILE.2103812880" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.OUTPUT_FILE" value=""${ProjName}.out"" valueType="string"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.DISPLAY_ERROR_NUMBER.1014175262" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.DISPLAY_ERROR_NUMBER" value="true" valueType="boolean"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.SEARCH_PATH.831717095" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.SEARCH_PATH" valueType="stringList"> <listOptionValue builtIn="false" value=""${CG_TOOL_ROOT}/lib""/> <listOptionValue builtIn="false" value=""${CG_TOOL_ROOT}/include""/> </option> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.LIBRARY.1437540585" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.LIBRARY" valueType="libs"> <listOptionValue builtIn="false" value=""libc.a""/> <listOptionValue builtIn="false" value=""${SW_ROOT}/driverlib/ccs-cm3/Debug/driverlib-cm3.lib""/> </option> </tool> </toolChain> </folderInfo> </configuration> </storageModule> <storageModule moduleId="org.eclipse.cdt.core.externalSettings"/> </cconfiguration> </storageModule> <storageModule moduleId="cdtBuildSystem" version="4.0.0"> <project id="ser2enet.com.ti.ccstudio.buildDefinitions.TMS470.ProjectType.137823329" name="ARM" projectType="com.ti.ccstudio.buildDefinitions.TMS470.ProjectType"/> </storageModule> <storageModule moduleId="org.eclipse.cdt.core.language.mapping"> <project-mappings> <content-type-mapping configuration="" content-type="org.eclipse.cdt.core.asmSource" language="com.ti.ccstudio.core.TIASMLanguage"/> <content-type-mapping configuration="" content-type="org.eclipse.cdt.core.cHeader" language="com.ti.ccstudio.core.TIGCCLanguage"/> <content-type-mapping configuration="" content-type="org.eclipse.cdt.core.cSource" language="com.ti.ccstudio.core.TIGCCLanguage"/> <content-type-mapping configuration="" content-type="org.eclipse.cdt.core.cxxHeader" language="com.ti.ccstudio.core.TIGPPLanguage"/> <content-type-mapping configuration="" content-type="org.eclipse.cdt.core.cxxSource" language="com.ti.ccstudio.core.TIGPPLanguage"/> </project-mappings> </storageModule> <storageModule moduleId="scannerConfiguration"/> </cproject>
<?xml version="1.0" encoding="UTF-8" standalone="no"?> <?fileVersion 4.0.0?> <cproject storage_type_id="org.eclipse.cdt.core.XmlProjectDescriptionStorage"> <storageModule configRelations="2" moduleId="org.eclipse.cdt.core.settings"> <cconfiguration id="com.ti.ccstudio.buildDefinitions.TMS470.Debug.27756458"> <storageModule buildSystemId="org.eclipse.cdt.managedbuilder.core.configurationDataProvider" id="com.ti.ccstudio.buildDefinitions.TMS470.Debug.27756458" moduleId="org.eclipse.cdt.core.settings" name="Debug"> <macros> <stringMacro name="ORIGINAL_PROJECT_ROOT" type="VALUE_PATH_DIR" value="C:/StellarisWare/boards/rdk-s2e/ser2enet/ccs"/> <stringMacro name="SW_ROOT" type="VALUE_PATH_DIR" value="${ORIGINAL_PROJECT_ROOT}/../../../.."/> </macros> <externalSettings/> <extensions> <extension id="com.ti.ccstudio.binaryparser.CoffParser" point="org.eclipse.cdt.core.BinaryParser"/> <extension id="com.ti.ccstudio.errorparser.CoffErrorParser" point="org.eclipse.cdt.core.ErrorParser"/> <extension id="com.ti.ccstudio.errorparser.LinkErrorParser" point="org.eclipse.cdt.core.ErrorParser"/> <extension id="com.ti.ccstudio.errorparser.AsmErrorParser" point="org.eclipse.cdt.core.ErrorParser"/> </extensions> </storageModule> <storageModule moduleId="cdtBuildSystem" version="4.0.0"> <configuration artifactExtension="out" artifactName="${ProjName}" buildProperties="" cleanCommand="${CG_CLEAN_CMD}" description="" id="com.ti.ccstudio.buildDefinitions.TMS470.Debug.27756458" name="Debug" parent="com.ti.ccstudio.buildDefinitions.TMS470.Debug" postbuildStep=""${CCE_INSTALL_ROOT}/utils/tiobj2bin/tiobj2bin" "${BuildArtifactFileName}" "${BuildArtifactFileBaseName}.bin" "${CG_TOOL_ROOT}/bin/ofd470" "${CG_TOOL_ROOT}/bin/hex470" "${CCE_INSTALL_ROOT}/utils/tiobj2bin/mkhex4bin""> <folderInfo id="com.ti.ccstudio.buildDefinitions.TMS470.Debug.27756458." name="/" resourcePath=""> <toolChain id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.DebugToolchain.8131526" name="TI Build Tools" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.DebugToolchain" targetTool="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.linkerDebug.152694596"> <option id="com.ti.ccstudio.buildDefinitions.core.OPT_TAGS.1327091039" superClass="com.ti.ccstudio.buildDefinitions.core.OPT_TAGS" valueType="stringList"> <listOptionValue builtIn="false" value="DEVICE_CONFIGURATION_ID=Cortex M.LM3S6918"/> <listOptionValue builtIn="false" value="DEVICE_ENDIANNESS=little"/> <listOptionValue builtIn="false" value="OUTPUT_FORMAT=ELF"/> <listOptionValue builtIn="false" value="CCS_MBS_VERSION=5.1.0.01"/> <listOptionValue builtIn="false" value="LINKER_COMMAND_FILE=ser2enet_ccs.cmd"/> <listOptionValue builtIn="false" value="RUNTIME_SUPPORT_LIBRARY=libc.a"/> <listOptionValue builtIn="false" value="OUTPUT_TYPE=executable"/> </option> <option id="com.ti.ccstudio.buildDefinitions.core.OPT_CODEGEN_VERSION.1457923922" name="Compiler version" superClass="com.ti.ccstudio.buildDefinitions.core.OPT_CODEGEN_VERSION" value="4.9.5" valueType="string"/> <targetPlatform id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.targetPlatformDebug.1499035019" name="Platform" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.targetPlatformDebug"/> <builder buildPath="${BuildDirectory}" id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.builderDebug.1615319655" keepEnvironmentInBuildfile="false" name="GNU Make" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.builderDebug"/> <tool id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.compilerDebug.220707149" name="ARM Compiler" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.compilerDebug"> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.SILICON_VERSION.1954130450" name="Target processor version (--silicon_version, -mv)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.SILICON_VERSION" value="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.SILICON_VERSION.7M3" valueType="enumerated"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.CODE_STATE.555369477" name="Designate code state, 16-bit (thumb) or 32-bit (--code_state)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.CODE_STATE" value="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.CODE_STATE.16" valueType="enumerated"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.ABI.2043230885" name="Application binary interface (tiabi, ti_arm9_abi, eabi) (--abi)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.ABI" value="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.ABI.eabi" valueType="enumerated"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.LITTLE_ENDIAN.2103577918" name="Little endian code (--little_endian, -me)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.LITTLE_ENDIAN" value="true" valueType="boolean"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.OPT_LEVEL.1395800779" name="Optimization level (--opt_level, -O)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.OPT_LEVEL" value="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.OPT_LEVEL.2" valueType="enumerated"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DEBUGGING_MODEL.1771217225" name="Debugging model" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DEBUGGING_MODEL" value="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DEBUGGING_MODEL.SYMDEBUG__DWARF" valueType="enumerated"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.INCLUDE_PATH.782768106" name="Add dir to #include search path (--include_path, -I)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.INCLUDE_PATH" valueType="includePath"> <listOptionValue builtIn="false" value=""${CG_TOOL_ROOT}/include""/> <listOptionValue builtIn="false" value=""${workspace_loc:/${ProjName}}""/> <listOptionValue builtIn="false" value=""${SW_ROOT}""/> <listOptionValue builtIn="false" value=""${SW_ROOT}/third_party/lwip-1.3.2/src/include""/> <listOptionValue builtIn="false" value=""${SW_ROOT}/third_party/lwip-1.3.2/src/include/ipv4""/> <listOptionValue builtIn="false" value=""${SW_ROOT}/third_party/lwip-1.3.2/apps""/> <listOptionValue builtIn="false" value=""${SW_ROOT}/third_party/lwip-1.3.2/ports/stellaris/include""/> </option> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.GCC.503288905" name="Enable support for GCC extensions (--gcc)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.GCC" value="true" valueType="boolean"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DEFINE.324159816" name="Pre-define NAME (--define, -D)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DEFINE" valueType="definedSymbols"> <listOptionValue builtIn="false" value="ccs="ccs""/> <listOptionValue builtIn="false" value="PART_LM3S6918"/> </option> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DIAG_WARNING.857568586" name="Treat diagnostic <id> as warning (--diag_warning, -pdsw)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DIAG_WARNING" valueType="stringList"> <listOptionValue builtIn="false" value="225"/> </option> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DISPLAY_ERROR_NUMBER.1308374818" name="Emit diagnostic identifier numbers (--display_error_number, -pden)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DISPLAY_ERROR_NUMBER" value="true" valueType="boolean"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.GEN_FUNC_SUBSECTIONS.2033355744" name="Place each function in a separate subsection (--gen_func_subsections, -ms)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.GEN_FUNC_SUBSECTIONS" value="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.GEN_FUNC_SUBSECTIONS.on" valueType="enumerated"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.UAL.1434782619" name="Use unified assembly language (--ual)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.UAL" value="true" valueType="boolean"/> <inputType id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__C_SRCS.115475535" name="C Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__C_SRCS"/> <inputType id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__CPP_SRCS.758045053" name="C++ Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__CPP_SRCS"/> <inputType id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__ASM_SRCS.820759776" name="Assembly Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__ASM_SRCS"/> <inputType id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__ASM2_SRCS.1814391833" name="Assembly Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__ASM2_SRCS"/> </tool> <tool id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.linkerDebug.152694596" name="ARM Linker" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.linkerDebug"> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.MAP_FILE.1601479081" name="Input and output sections listed into <file> (--map_file, -m)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.MAP_FILE" value=""app_LM3S6918_ccs.map"" valueType="string"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.STACK_SIZE.736551616" name="Set C system stack size (--stack_size, -stack)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.STACK_SIZE" value="256" valueType="string"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.HEAP_SIZE.703427097" name="Heap size for C/C++ dynamic memory allocation (--heap_size, -heap)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.HEAP_SIZE" value="0" valueType="string"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.OUTPUT_FILE.1262201580" name="Specify output file name (--output_file, -o)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.OUTPUT_FILE" value=""${ProjName}.out"" valueType="string"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.LIBRARY.1742598485" name="Include library file or command file as input (--library, -l)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.LIBRARY" valueType="libs"> <listOptionValue builtIn="false" value=""${SW_ROOT}/driverlib/ccs-cm3/Debug/driverlib-cm3.lib""/> <listOptionValue builtIn="false" value=""libc.a""/> </option> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.SEARCH_PATH.1314990224" name="Add <dir> to library search path (--search_path, -i)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.SEARCH_PATH" valueType="stringList"> <listOptionValue builtIn="false" value=""${CG_TOOL_ROOT}/lib""/> <listOptionValue builtIn="false" value=""${CG_TOOL_ROOT}/include""/> </option> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.DISPLAY_ERROR_NUMBER.13360753" name="Emit diagnostic identifier numbers (--display_error_number)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.DISPLAY_ERROR_NUMBER" value="true" valueType="boolean"/> </tool> </toolChain> </folderInfo> </configuration> </storageModule> <storageModule moduleId="org.eclipse.cdt.core.externalSettings"/> </cconfiguration> <cconfiguration id="com.ti.ccstudio.buildDefinitions.TMS470.Release.2040994429"> <storageModule buildSystemId="org.eclipse.cdt.managedbuilder.core.configurationDataProvider" id="com.ti.ccstudio.buildDefinitions.TMS470.Release.2040994429" moduleId="org.eclipse.cdt.core.settings" name="Release"> <macros> <stringMacro name="ORIGINAL_PROJECT_ROOT" type="VALUE_PATH_DIR" value="C:/StellarisWare/boards/rdk-s2e/ser2enet/ccs"/> <stringMacro name="SW_ROOT" type="VALUE_PATH_DIR" value="${ORIGINAL_PROJECT_ROOT}/../../../.."/> </macros> <externalSettings/> <extensions> <extension id="com.ti.ccstudio.binaryparser.CoffParser" point="org.eclipse.cdt.core.BinaryParser"/> <extension id="com.ti.ccstudio.errorparser.CoffErrorParser" point="org.eclipse.cdt.core.ErrorParser"/> <extension id="com.ti.ccstudio.errorparser.LinkErrorParser" point="org.eclipse.cdt.core.ErrorParser"/> <extension id="com.ti.ccstudio.errorparser.AsmErrorParser" point="org.eclipse.cdt.core.ErrorParser"/> </extensions> </storageModule> <storageModule moduleId="cdtBuildSystem" version="4.0.0"> <configuration artifactExtension="out" artifactName="${ProjName}" buildProperties="" cleanCommand="${CG_CLEAN_CMD}" description="" id="com.ti.ccstudio.buildDefinitions.TMS470.Release.2040994429" name="Release" parent="com.ti.ccstudio.buildDefinitions.TMS470.Release" postbuildStep=""${CCE_INSTALL_ROOT}/utils/tiobj2bin/tiobj2bin" "${BuildArtifactFileName}" "${BuildArtifactFileBaseName}.bin" "${CG_TOOL_ROOT}/bin/ofd470" "${CG_TOOL_ROOT}/bin/hex470" "${CCE_INSTALL_ROOT}/utils/tiobj2bin/mkhex4bin""> <folderInfo id="com.ti.ccstudio.buildDefinitions.TMS470.Release.2040994429." name="/" resourcePath=""> <toolChain id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.ReleaseToolchain.1605340816" name="TI Build Tools" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.ReleaseToolchain" targetTool="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.linkerRelease.1643658281"> <option id="com.ti.ccstudio.buildDefinitions.core.OPT_TAGS.281955609" superClass="com.ti.ccstudio.buildDefinitions.core.OPT_TAGS" valueType="stringList"> <listOptionValue builtIn="false" value="DEVICE_CONFIGURATION_ID=Cortex M.LM3S6918"/> <listOptionValue builtIn="false" value="DEVICE_ENDIANNESS=little"/> <listOptionValue builtIn="false" value="OUTPUT_FORMAT=ELF"/> <listOptionValue builtIn="false" value="CCS_MBS_VERSION=5.1.0.01"/> <listOptionValue builtIn="false" value="LINKER_COMMAND_FILE=ser2enet_ccs.cmd"/> <listOptionValue builtIn="false" value="RUNTIME_SUPPORT_LIBRARY=libc.a"/> <listOptionValue builtIn="false" value="OUTPUT_TYPE=executable"/> </option> <option id="com.ti.ccstudio.buildDefinitions.core.OPT_CODEGEN_VERSION.1892031851" name="Compiler version" superClass="com.ti.ccstudio.buildDefinitions.core.OPT_CODEGEN_VERSION" value="4.9.5" valueType="string"/> <targetPlatform id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.targetPlatformRelease.1080378308" name="Platform" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.targetPlatformRelease"/> <builder buildPath="${BuildDirectory}" id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.builderRelease.970003874" keepEnvironmentInBuildfile="false" name="GNU Make" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.builderRelease"/> <tool id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.compilerRelease.824182229" name="ARM Compiler" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.compilerRelease"> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.SILICON_VERSION.640123428" name="Target processor version (--silicon_version, -mv)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.SILICON_VERSION" value="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.SILICON_VERSION.7M3" valueType="enumerated"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.CODE_STATE.16164406" name="Designate code state, 16-bit (thumb) or 32-bit (--code_state)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.CODE_STATE" value="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.CODE_STATE.16" valueType="enumerated"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.ABI.1198308498" name="Application binary interface (tiabi, ti_arm9_abi, eabi) (--abi)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.ABI" value="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.ABI.eabi" valueType="enumerated"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.LITTLE_ENDIAN.1030010912" name="Little endian code (--little_endian, -me)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.LITTLE_ENDIAN" value="true" valueType="boolean"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.INCLUDE_PATH.741124051" name="Add dir to #include search path (--include_path, -I)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.INCLUDE_PATH" valueType="includePath"> <listOptionValue builtIn="false" value=""${CG_TOOL_ROOT}/include""/> <listOptionValue builtIn="false" value=""${workspace_loc:/${ProjName}}""/> <listOptionValue builtIn="false" value=""${SW_ROOT}""/> <listOptionValue builtIn="false" value=""${SW_ROOT}/third_party/lwip-1.3.2/src/include""/> <listOptionValue builtIn="false" value=""${SW_ROOT}/third_party/lwip-1.3.2/src/include/ipv4""/> <listOptionValue builtIn="false" value=""${SW_ROOT}/third_party/lwip-1.3.2/apps""/> <listOptionValue builtIn="false" value=""${SW_ROOT}/third_party/lwip-1.3.2/ports/stellaris/include""/> </option> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.GCC.927279229" name="Enable support for GCC extensions (--gcc)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.GCC" value="true" valueType="boolean"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DEFINE.1779817793" name="Pre-define NAME (--define, -D)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DEFINE" valueType="definedSymbols"> <listOptionValue builtIn="false" value="ccs="ccs""/> <listOptionValue builtIn="false" value="PART_LM3S6918"/> </option> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DIAG_WARNING.82116380" name="Treat diagnostic <id> as warning (--diag_warning, -pdsw)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DIAG_WARNING" valueType="stringList"> <listOptionValue builtIn="false" value="225"/> </option> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DISPLAY_ERROR_NUMBER.2101487513" name="Emit diagnostic identifier numbers (--display_error_number, -pden)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DISPLAY_ERROR_NUMBER" value="true" valueType="boolean"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.GEN_FUNC_SUBSECTIONS.514559315" name="Place each function in a separate subsection (--gen_func_subsections, -ms)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.GEN_FUNC_SUBSECTIONS" value="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.GEN_FUNC_SUBSECTIONS.on" valueType="enumerated"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.UAL.1135810808" name="Use unified assembly language (--ual)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.UAL" value="true" valueType="boolean"/> <inputType id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__C_SRCS.972057314" name="C Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__C_SRCS"/> <inputType id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__CPP_SRCS.2080036813" name="C++ Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__CPP_SRCS"/> <inputType id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__ASM_SRCS.1339202090" name="Assembly Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__ASM_SRCS"/> <inputType id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__ASM2_SRCS.1338346571" name="Assembly Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__ASM2_SRCS"/> </tool> <tool id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.linkerRelease.1643658281" name="ARM Linker" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.linkerRelease"> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.MAP_FILE.479824876" name="Input and output sections listed into <file> (--map_file, -m)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.MAP_FILE" value=""app_LM3S6918_ccs.map"" valueType="string"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.STACK_SIZE.141776792" name="Set C system stack size (--stack_size, -stack)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.STACK_SIZE" value="256" valueType="string"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.HEAP_SIZE.2053214064" name="Heap size for C/C++ dynamic memory allocation (--heap_size, -heap)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.HEAP_SIZE" value="0" valueType="string"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.OUTPUT_FILE.1768508687" name="Specify output file name (--output_file, -o)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.OUTPUT_FILE" value=""${ProjName}.out"" valueType="string"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.LIBRARY.729322185" name="Include library file or command file as input (--library, -l)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.LIBRARY" valueType="libs"> <listOptionValue builtIn="false" value=""${SW_ROOT}/driverlib/ccs-cm3/Debug/driverlib-cm3.lib""/> <listOptionValue builtIn="false" value=""libc.a""/> </option> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.SEARCH_PATH.1481196292" name="Add <dir> to library search path (--search_path, -i)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.SEARCH_PATH" valueType="stringList"> <listOptionValue builtIn="false" value=""${CG_TOOL_ROOT}/lib""/> <listOptionValue builtIn="false" value=""${CG_TOOL_ROOT}/include""/> </option> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.DISPLAY_ERROR_NUMBER.1774396337" name="Emit diagnostic identifier numbers (--display_error_number)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.DISPLAY_ERROR_NUMBER" value="true" valueType="boolean"/> </tool> </toolChain> </folderInfo> </configuration> </storageModule> <storageModule moduleId="org.eclipse.cdt.core.externalSettings"/> </cconfiguration> </storageModule> <storageModule moduleId="cdtBuildSystem" version="4.0.0"> <project id="ser2enet.com.ti.ccstudio.buildDefinitions.TMS470.ProjectType.137823329" name="ARM" projectType="com.ti.ccstudio.buildDefinitions.TMS470.ProjectType"/> </storageModule> <storageModule moduleId="org.eclipse.cdt.core.language.mapping"> <project-mappings> <content-type-mapping configuration="" content-type="org.eclipse.cdt.core.asmSource" language="com.ti.ccstudio.core.TIASMLanguage"/> <content-type-mapping configuration="" content-type="org.eclipse.cdt.core.cHeader" language="com.ti.ccstudio.core.TIGCCLanguage"/> <content-type-mapping configuration="" content-type="org.eclipse.cdt.core.cSource" language="com.ti.ccstudio.core.TIGCCLanguage"/> <content-type-mapping configuration="" content-type="org.eclipse.cdt.core.cxxHeader" language="com.ti.ccstudio.core.TIGPPLanguage"/> <content-type-mapping configuration="" content-type="org.eclipse.cdt.core.cxxSource" language="com.ti.ccstudio.core.TIGPPLanguage"/> </project-mappings> </storageModule> <storageModule moduleId="scannerConfiguration"/> <storageModule moduleId="refreshScope"/> </cproject>
<?xml version="1.0" encoding="UTF-8" standalone="no"?> <?fileVersion 4.0.0?> <cproject storage_type_id="org.eclipse.cdt.core.XmlProjectDescriptionStorage"> <storageModule configRelations="2" moduleId="org.eclipse.cdt.core.settings"> <cconfiguration id="com.ti.ccstudio.buildDefinitions.TMS470.Debug.27756458"> <storageModule buildSystemId="org.eclipse.cdt.managedbuilder.core.configurationDataProvider" id="com.ti.ccstudio.buildDefinitions.TMS470.Debug.27756458" moduleId="org.eclipse.cdt.core.settings" name="Debug"> <macros> <stringMacro name="ORIGINAL_PROJECT_ROOT" type="VALUE_PATH_DIR" value="C:/StellarisWare/boards/rdk-s2e/ser2enet/ccs"/> <stringMacro name="SW_ROOT" type="VALUE_PATH_DIR" value="${ORIGINAL_PROJECT_ROOT}/../../../.."/> </macros> <externalSettings/> <extensions> <extension id="com.ti.ccstudio.binaryparser.CoffParser" point="org.eclipse.cdt.core.BinaryParser"/> <extension id="com.ti.ccstudio.errorparser.CoffErrorParser" point="org.eclipse.cdt.core.ErrorParser"/> <extension id="com.ti.ccstudio.errorparser.LinkErrorParser" point="org.eclipse.cdt.core.ErrorParser"/> <extension id="com.ti.ccstudio.errorparser.AsmErrorParser" point="org.eclipse.cdt.core.ErrorParser"/> </extensions> </storageModule> <storageModule moduleId="cdtBuildSystem" version="4.0.0"> <configuration artifactExtension="out" artifactName="${ProjName}" buildProperties="" cleanCommand="${CG_CLEAN_CMD}" description="" id="com.ti.ccstudio.buildDefinitions.TMS470.Debug.27756458" name="Debug" parent="com.ti.ccstudio.buildDefinitions.TMS470.Debug" postbuildStep=""${CCE_INSTALL_ROOT}/utils/tiobj2bin/tiobj2bin" "${BuildArtifactFileName}" "${BuildArtifactFileBaseName}.bin" "${CG_TOOL_ROOT}/bin/ofd470" "${CG_TOOL_ROOT}/bin/hex470" "${CCE_INSTALL_ROOT}/utils/tiobj2bin/mkhex4bin""> <folderInfo id="com.ti.ccstudio.buildDefinitions.TMS470.Debug.27756458." name="/" resourcePath=""> <toolChain id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.DebugToolchain.1202933434" name="TI Build Tools" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.DebugToolchain" targetTool="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.linkerDebug.437757161"> <option id="com.ti.ccstudio.buildDefinitions.core.OPT_TAGS.2000975519" superClass="com.ti.ccstudio.buildDefinitions.core.OPT_TAGS" valueType="stringList"> <listOptionValue builtIn="false" value="DEVICE_CONFIGURATION_ID=Cortex M.LM3S6432"/> <listOptionValue builtIn="false" value="DEVICE_ENDIANNESS=little"/> <listOptionValue builtIn="false" value="OUTPUT_FORMAT=ELF"/> <listOptionValue builtIn="false" value="CCS_MBS_VERSION=5.1.0.01"/> <listOptionValue builtIn="false" value="LINKER_COMMAND_FILE=ser2enet_ccs.cmd"/> <listOptionValue builtIn="false" value="RUNTIME_SUPPORT_LIBRARY=libc.a"/> <listOptionValue builtIn="false" value="OUTPUT_TYPE=executable"/> </option> <option id="com.ti.ccstudio.buildDefinitions.core.OPT_CODEGEN_VERSION.1324269021" name="Compiler version" superClass="com.ti.ccstudio.buildDefinitions.core.OPT_CODEGEN_VERSION" value="4.9.5" valueType="string"/> <targetPlatform id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.targetPlatformDebug.1887312771" name="Platform" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.targetPlatformDebug"/> <builder buildPath="${BuildDirectory}" id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.builderDebug.1473704467" keepEnvironmentInBuildfile="false" name="GNU Make" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.builderDebug"/> <tool id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.compilerDebug.12934986" name="ARM Compiler" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.compilerDebug"> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.LITTLE_ENDIAN.1079043776" name="Little endian code (--little_endian, -me)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.LITTLE_ENDIAN" value="true" valueType="boolean"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.OPT_LEVEL.1963581468" name="Optimization level (--opt_level, -O)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.OPT_LEVEL" value="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.OPT_LEVEL.2" valueType="enumerated"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DEBUGGING_MODEL.371522718" name="Debugging model" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DEBUGGING_MODEL" value="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DEBUGGING_MODEL.SYMDEBUG__DWARF" valueType="enumerated"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.INCLUDE_PATH.1940953534" name="Add dir to #include search path (--include_path, -I)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.INCLUDE_PATH" valueType="includePath"> <listOptionValue builtIn="false" value=""${CG_TOOL_ROOT}/include""/> <listOptionValue builtIn="false" value=""${workspace_loc:/${ProjName}}""/> <listOptionValue builtIn="false" value=""${SW_ROOT}""/> <listOptionValue builtIn="false" value=""${SW_ROOT}/third_party/lwip-1.3.2/src/include""/> <listOptionValue builtIn="false" value=""${SW_ROOT}/third_party/lwip-1.3.2/src/include/ipv4""/> <listOptionValue builtIn="false" value=""${SW_ROOT}/third_party/lwip-1.3.2/apps""/> <listOptionValue builtIn="false" value=""${SW_ROOT}/third_party/lwip-1.3.2/ports/stellaris/include""/> </option> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.GCC.880124970" name="Enable support for GCC extensions (--gcc)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.GCC" value="true" valueType="boolean"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DEFINE.1750503706" name="Pre-define NAME (--define, -D)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DEFINE" valueType="definedSymbols"> <listOptionValue builtIn="false" value="ccs="ccs""/> <listOptionValue builtIn="false" value="PART_LM3S6432"/> </option> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DIAG_WARNING.792100647" name="Treat diagnostic <id> as warning (--diag_warning, -pdsw)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DIAG_WARNING" valueType="stringList"> <listOptionValue builtIn="false" value="225"/> </option> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DISPLAY_ERROR_NUMBER.1170105794" name="Emit diagnostic identifier numbers (--display_error_number, -pden)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DISPLAY_ERROR_NUMBER" value="true" valueType="boolean"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.GEN_FUNC_SUBSECTIONS.1569502843" name="Place each function in a separate subsection (--gen_func_subsections, -ms)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.GEN_FUNC_SUBSECTIONS" value="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.GEN_FUNC_SUBSECTIONS.on" valueType="enumerated"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.UAL.553614440" name="Use unified assembly language (--ual)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.UAL" value="true" valueType="boolean"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.SILICON_VERSION.1411826910" name="Target processor version (--silicon_version, -mv)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.SILICON_VERSION" value="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.SILICON_VERSION.7M3" valueType="enumerated"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.CODE_STATE.657696150" name="Designate code state, 16-bit (thumb) or 32-bit (--code_state)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.CODE_STATE" value="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.CODE_STATE.16" valueType="enumerated"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.ABI.680548005" name="Application binary interface (tiabi, ti_arm9_abi, eabi) (--abi)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.ABI" value="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.ABI.eabi" valueType="enumerated"/> <inputType id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__C_SRCS.282340037" name="C Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__C_SRCS"/> <inputType id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__CPP_SRCS.769372962" name="C++ Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__CPP_SRCS"/> <inputType id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__ASM_SRCS.36029429" name="Assembly Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__ASM_SRCS"/> <inputType id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__ASM2_SRCS.2016251400" name="Assembly Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__ASM2_SRCS"/> </tool> <tool id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.linkerDebug.437757161" name="ARM Linker" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.linkerDebug"> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.OUTPUT_FILE.819092120" name="Specify output file name (--output_file, -o)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.OUTPUT_FILE" value=""${ProjName}.out"" valueType="string"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.LIBRARY.1471344242" name="Include library file or command file as input (--library, -l)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.LIBRARY" valueType="libs"> <listOptionValue builtIn="false" value=""${SW_ROOT}/driverlib/ccs-cm3/Debug/driverlib-cm3.lib""/> <listOptionValue builtIn="false" value=""libc.a""/> </option> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.SEARCH_PATH.101238132" name="Add <dir> to library search path (--search_path, -i)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.SEARCH_PATH" valueType="stringList"> <listOptionValue builtIn="false" value=""${CG_TOOL_ROOT}/lib""/> <listOptionValue builtIn="false" value=""${CG_TOOL_ROOT}/include""/> </option> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.DISPLAY_ERROR_NUMBER.288924653" name="Emit diagnostic identifier numbers (--display_error_number)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.DISPLAY_ERROR_NUMBER" value="true" valueType="boolean"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.MAP_FILE.811365881" name="Input and output sections listed into <file> (--map_file, -m)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.MAP_FILE" value=""app_LM3S6432_ccs.map"" valueType="string"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.STACK_SIZE.1839206352" name="Set C system stack size (--stack_size, -stack)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.STACK_SIZE" value="256" valueType="string"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.HEAP_SIZE.1567079770" name="Heap size for C/C++ dynamic memory allocation (--heap_size, -heap)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.HEAP_SIZE" value="0" valueType="string"/> </tool> </toolChain> </folderInfo> </configuration> </storageModule> <storageModule moduleId="org.eclipse.cdt.core.externalSettings"/> </cconfiguration> <cconfiguration id="com.ti.ccstudio.buildDefinitions.TMS470.Release.2040994429"> <storageModule buildSystemId="org.eclipse.cdt.managedbuilder.core.configurationDataProvider" id="com.ti.ccstudio.buildDefinitions.TMS470.Release.2040994429" moduleId="org.eclipse.cdt.core.settings" name="Release"> <macros> <stringMacro name="ORIGINAL_PROJECT_ROOT" type="VALUE_PATH_DIR" value="C:/StellarisWare/boards/rdk-s2e/ser2enet/ccs"/> <stringMacro name="SW_ROOT" type="VALUE_PATH_DIR" value="${ORIGINAL_PROJECT_ROOT}/../../../.."/> </macros> <externalSettings/> <extensions> <extension id="com.ti.ccstudio.binaryparser.CoffParser" point="org.eclipse.cdt.core.BinaryParser"/> <extension id="com.ti.ccstudio.errorparser.CoffErrorParser" point="org.eclipse.cdt.core.ErrorParser"/> <extension id="com.ti.ccstudio.errorparser.LinkErrorParser" point="org.eclipse.cdt.core.ErrorParser"/> <extension id="com.ti.ccstudio.errorparser.AsmErrorParser" point="org.eclipse.cdt.core.ErrorParser"/> </extensions> </storageModule> <storageModule moduleId="cdtBuildSystem" version="4.0.0"> <configuration artifactExtension="out" artifactName="${ProjName}" buildProperties="" cleanCommand="${CG_CLEAN_CMD}" description="" id="com.ti.ccstudio.buildDefinitions.TMS470.Release.2040994429" name="Release" parent="com.ti.ccstudio.buildDefinitions.TMS470.Release" postbuildStep=""${CCE_INSTALL_ROOT}/utils/tiobj2bin/tiobj2bin" "${BuildArtifactFileName}" "${BuildArtifactFileBaseName}.bin" "${CG_TOOL_ROOT}/bin/ofd470" "${CG_TOOL_ROOT}/bin/hex470" "${CCE_INSTALL_ROOT}/utils/tiobj2bin/mkhex4bin""> <folderInfo id="com.ti.ccstudio.buildDefinitions.TMS470.Release.2040994429." name="/" resourcePath=""> <toolChain id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.ReleaseToolchain.1694215346" name="TI Build Tools" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.ReleaseToolchain" targetTool="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.linkerRelease.994786213"> <option id="com.ti.ccstudio.buildDefinitions.core.OPT_TAGS.1448833738" superClass="com.ti.ccstudio.buildDefinitions.core.OPT_TAGS" valueType="stringList"> <listOptionValue builtIn="false" value="DEVICE_CONFIGURATION_ID=Cortex M.LM3S6432"/> <listOptionValue builtIn="false" value="DEVICE_ENDIANNESS=little"/> <listOptionValue builtIn="false" value="OUTPUT_FORMAT=ELF"/> <listOptionValue builtIn="false" value="CCS_MBS_VERSION=5.1.0.01"/> <listOptionValue builtIn="false" value="RUNTIME_SUPPORT_LIBRARY=libc.a"/> <listOptionValue builtIn="false" value="OUTPUT_TYPE=executable"/> </option> <option id="com.ti.ccstudio.buildDefinitions.core.OPT_CODEGEN_VERSION.2040206650" name="Compiler version" superClass="com.ti.ccstudio.buildDefinitions.core.OPT_CODEGEN_VERSION" value="4.9.5" valueType="string"/> <targetPlatform id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.targetPlatformRelease.1927517358" name="Platform" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.targetPlatformRelease"/> <builder buildPath="${BuildDirectory}" id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.builderRelease.248486123" keepEnvironmentInBuildfile="false" name="GNU Make" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.builderRelease"/> <tool id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.compilerRelease.141115905" name="ARM Compiler" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.compilerRelease"> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.SILICON_VERSION.2144734781" name="Target processor version (--silicon_version, -mv)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.SILICON_VERSION" value="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.SILICON_VERSION.7M3" valueType="enumerated"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.CODE_STATE.1665379695" name="Designate code state, 16-bit (thumb) or 32-bit (--code_state)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.CODE_STATE" value="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.CODE_STATE.16" valueType="enumerated"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.ABI.533578491" name="Application binary interface (tiabi, ti_arm9_abi, eabi) (--abi)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.ABI" value="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.ABI.eabi" valueType="enumerated"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DIAG_WARNING.1614148367" name="Treat diagnostic <id> as warning (--diag_warning, -pdsw)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DIAG_WARNING" valueType="stringList"> <listOptionValue builtIn="false" value="225"/> </option> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DISPLAY_ERROR_NUMBER.1243529506" name="Emit diagnostic identifier numbers (--display_error_number, -pden)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DISPLAY_ERROR_NUMBER" value="true" valueType="boolean"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.INCLUDE_PATH.1108290780" name="Add dir to #include search path (--include_path, -I)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.INCLUDE_PATH" valueType="includePath"> <listOptionValue builtIn="false" value=""${CG_TOOL_ROOT}/include""/> <listOptionValue builtIn="false" value=""${workspace_loc:/${ProjName}}""/> <listOptionValue builtIn="false" value=""${SW_ROOT}""/> <listOptionValue builtIn="false" value=""${SW_ROOT}/third_party/lwip-1.3.2/src/include""/> <listOptionValue builtIn="false" value=""${SW_ROOT}/third_party/lwip-1.3.2/src/include/ipv4""/> <listOptionValue builtIn="false" value=""${SW_ROOT}/third_party/lwip-1.3.2/apps""/> <listOptionValue builtIn="false" value=""${SW_ROOT}/third_party/lwip-1.3.2/ports/stellaris/include""/> </option> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.LITTLE_ENDIAN.1140699233" name="Little endian code (--little_endian, -me)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.LITTLE_ENDIAN" value="true" valueType="boolean"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.GEN_FUNC_SUBSECTIONS.1940191057" name="Place each function in a separate subsection (--gen_func_subsections, -ms)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.GEN_FUNC_SUBSECTIONS" value="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.GEN_FUNC_SUBSECTIONS.on" valueType="enumerated"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.GCC.1656570230" name="Enable support for GCC extensions (--gcc)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.GCC" value="true" valueType="boolean"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.UAL.557591006" name="Use unified assembly language (--ual)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.UAL" value="true" valueType="boolean"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DEFINE.429457989" name="Pre-define NAME (--define, -D)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compilerID.DEFINE" valueType="definedSymbols"> <listOptionValue builtIn="false" value="ccs="ccs""/> <listOptionValue builtIn="false" value="PART_LM3S6432"/> </option> <inputType id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__C_SRCS.1689921350" name="C Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__C_SRCS"/> <inputType id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__CPP_SRCS.1596783574" name="C++ Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__CPP_SRCS"/> <inputType id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__ASM_SRCS.318651067" name="Assembly Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__ASM_SRCS"/> <inputType id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__ASM2_SRCS.1611059127" name="Assembly Sources" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.compiler.inputType__ASM2_SRCS"/> </tool> <tool id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.linkerRelease.994786213" name="ARM Linker" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.linkerRelease"> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.MAP_FILE.149555574" name="Input and output sections listed into <file> (--map_file, -m)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.MAP_FILE" value=""ser2enet_ccs.map"" valueType="string"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.STACK_SIZE.108000444" name="Set C system stack size (--stack_size, -stack)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.STACK_SIZE" value="4096" valueType="string"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.HEAP_SIZE.1149894067" name="Heap size for C/C++ dynamic memory allocation (--heap_size, -heap)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.HEAP_SIZE" value="0" valueType="string"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.OUTPUT_FILE.2103812880" name="Specify output file name (--output_file, -o)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.OUTPUT_FILE" value=""${ProjName}.out"" valueType="string"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.DISPLAY_ERROR_NUMBER.1014175262" name="Emit diagnostic identifier numbers (--display_error_number)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.DISPLAY_ERROR_NUMBER" value="true" valueType="boolean"/> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.SEARCH_PATH.831717095" name="Add <dir> to library search path (--search_path, -i)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.SEARCH_PATH" valueType="stringList"> <listOptionValue builtIn="false" value=""${CG_TOOL_ROOT}/lib""/> <listOptionValue builtIn="false" value=""${CG_TOOL_ROOT}/include""/> </option> <option id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.LIBRARY.1437540585" name="Include library file or command file as input (--library, -l)" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.linkerID.LIBRARY" valueType="libs"> <listOptionValue builtIn="false" value=""libc.a""/> <listOptionValue builtIn="false" value=""${SW_ROOT}/driverlib/ccs-cm3/Debug/driverlib-cm3.lib""/> </option> </tool> </toolChain> </folderInfo> <fileInfo id="com.ti.ccstudio.buildDefinitions.TMS470.Release.2040994429.ser2enet_ccs.cmd" name="ser2enet_ccs.cmd" rcbsApplicability="disable" resourcePath="ser2enet_ccs.cmd" toolsToInvoke="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.linkerRelease.994786213.159764140"> <tool id="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.linkerRelease.994786213.159764140" name="ARM Linker" superClass="com.ti.ccstudio.buildDefinitions.TMS470_4.9.exe.linkerRelease.994786213"/> </fileInfo> <sourceEntries> <entry excluding="ser2enet_ccs.cmd" flags="VALUE_WORKSPACE_PATH|RESOLVED" kind="sourcePath" name=""/> </sourceEntries> </configuration> </storageModule> <storageModule moduleId="org.eclipse.cdt.core.externalSettings"/> </cconfiguration> </storageModule> <storageModule moduleId="cdtBuildSystem" version="4.0.0"> <project id="ser2enet.com.ti.ccstudio.buildDefinitions.TMS470.ProjectType.137823329" name="ARM" projectType="com.ti.ccstudio.buildDefinitions.TMS470.ProjectType"/> </storageModule> <storageModule moduleId="org.eclipse.cdt.core.language.mapping"> <project-mappings> <content-type-mapping configuration="" content-type="org.eclipse.cdt.core.asmSource" language="com.ti.ccstudio.core.TIASMLanguage"/> <content-type-mapping configuration="" content-type="org.eclipse.cdt.core.cHeader" language="com.ti.ccstudio.core.TIGCCLanguage"/> <content-type-mapping configuration="" content-type="org.eclipse.cdt.core.cSource" language="com.ti.ccstudio.core.TIGCCLanguage"/> <content-type-mapping configuration="" content-type="org.eclipse.cdt.core.cxxHeader" language="com.ti.ccstudio.core.TIGPPLanguage"/> <content-type-mapping configuration="" content-type="org.eclipse.cdt.core.cxxSource" language="com.ti.ccstudio.core.TIGPPLanguage"/> </project-mappings> </storageModule> <storageModule moduleId="scannerConfiguration"/> </cproject>
