Debug with CCS ARM assembly code generated with gcc
Guru**** 151774 points
I am trying to debug with CCS some ARM code that was compiled with gcc tools. I am using mixed ARM/Thumb mode. I see some incorrect instructions in the disassembler window. This is probably because code was not generated with TI cgtools.
Is there a way to debug correctly with CCS gcc ARM generated asm code?
Cesar
  • Cesar,
    In general CCS should be able to debug gcc generated code but we have seen/heard of a few issues here and there, so as you expected, the debug experience may not be as good as what you get with compiling with TI cgtools.
    I believe this should be improved in CCS 5.4 compared with earlier versions. Are you able to give this version a try?
    The beta is currently available for download and the final release should be out by end of the month.
    http://processors.wiki.ti.com/index.php/Code_Composer_Studio_Beta_Downloads
    If 5.4 shows the same issue it would help if you could attach a simple test case to demonstrate the issue so we can check if it is something we can address/fix for the next release.
