manipulating variable name in C66 elf format binary
we are building a C6657 based applicagtion using CGT 7.2. Is there a way that we can use  tool similar as "objcpy --prefix-symbols" to change the global variable and functions in binary obj or archive file?
thanks
Weichun
  • I don't think the TI toolset provides that functionality, but because it is ELF format, you could probably rebuild  objcpy for C6000 EABI and use that.
  • thanks for the idea.
    Could you please give me some links on where I can start? How should I include the TI C66 elf format specifics when I re-build the objcpy tool for C66x? Can I take any objcpy source from gnu? any document on the difference between C6000 EABI and standard elf in addtion to the EABI doc spab89?
    What would I miss and go wrong if I simply run objcpy on C6000 elf file? -- we do not plan to use relocation.
    thanks
    Weichun
    No.  Just in case you haven't found it already, here it is.
    Thanks and regards,
    -George
