Other Parts Discussed in Thread: CCSTUDIO
To whom, it may concern:
I am using CCS v.5.5 more than a year. All the sudden, it stop working this morning.
Attached please find the log which included the following line:
"The proxied handler for 'com.ti.ccstudio.debug.internal.ui.modules.ShowPreferencesHandler' could not be loaded"
Any idea to resolve this issue will be highly appreciated!
Eric Ruei
!SESSION 2015-01-12 11:08:08.682 -----------------------------------------------
eclipse.buildId=M20120914-1540
java.version=1.6.0_13
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
Framework arguments: -product com.ti.ccstudio.branding.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product com.ti.ccstudio.branding.product
!ENTRY org.eclipse.ui 4 4 2015-01-12 11:08:57.620
!MESSAGE The proxied handler for 'com.ti.ccstudio.debug.internal.ui.modules.ShowPreferencesHandler' could not be loaded
!ENTRY org.eclipse.ui 4 0 2015-01-12 11:08:57.623
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in "com.ti.ccstudio.debug.ui" was unable to instantiate class "com.ti.ccstudio.debug.internal.ui.modules.ShowPreferencesHandler".
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.throwException(RegistryStrategyOSGI.java:194)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:188)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.ui.internal.handlers.HandlerProxy.loadHandler(HandlerProxy.java:347)
at org.eclipse.ui.internal.handlers.HandlerProxy.isEnabled(HandlerProxy.java:316)
at org.eclipse.core.commands.Command.isEnabled(Command.java:862)
at org.eclipse.core.commands.Command.setHandler(Command.java:1025)
at org.eclipse.ui.internal.handlers.HandlerAuthority.updateCommand(HandlerAuthority.java:459)
at org.eclipse.ui.internal.handlers.HandlerAuthority.activateHandler(HandlerAuthority.java:249)
at org.eclipse.ui.internal.handlers.HandlerService.activateHandler(HandlerService.java:120)
at org.eclipse.ui.internal.handlers.HandlerService.activateHandler(HandlerService.java:112)
at org.eclipse.ui.internal.handlers.HandlerPersistence.readHandlersFromRegistry(HandlerPersistence.java:313)
at org.eclipse.ui.internal.handlers.HandlerPersistence.reRead(HandlerPersistence.java:219)
at org.eclipse.ui.internal.handlers.HandlerPersistence.read(HandlerPersistence.java:167)
at org.eclipse.ui.internal.handlers.HandlerService.readRegistry(HandlerService.java:186)
at org.eclipse.ui.internal.handlers.HandlerServiceFactory.create(HandlerServiceFactory.java:61)
at org.eclipse.ui.internal.services.WorkbenchServiceRegistry.getService(WorkbenchServiceRegistry.java:103)
at org.eclipse.ui.internal.services.ServiceLocator.getService(ServiceLocator.java:174)
at org.eclipse.ui.internal.Workbench$49.runWithException(Workbench.java:1892)
at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run(StartupThreading.java:31)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4144)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3761)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2609)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
Caused by: java.lang.NoClassDefFoundError: com/ti/debug/engine/events/types/IObjectEventListener
at com.ti.ccstudio.debug.ui.commands.AbstractDebugHandler.<init>(AbstractDebugHandler.java:42)
at com.ti.ccstudio.debug.internal.ui.modules.ShowPreferencesHandler.<init>(ShowPreferencesHandler.java:29)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.lang.reflect.Constructor.newInstance(Unknown Source)
at java.lang.Class.newInstance0(Unknown Source)
at java.lang.Class.newInstance(Unknown Source)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:184)
... 43 more
Caused by: java.lang.ClassNotFoundException: com.ti.debug.engine.events.types.IObjectEventListener
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClass(Unknown Source)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
... 52 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2015-01-12 11:08:57.624
!MESSAGE Plug-in "com.ti.ccstudio.debug.ui" was unable to instantiate class "com.ti.ccstudio.debug.internal.ui.modules.ShowPreferencesHandler".
!STACK 0
... 52 more
!ENTRY org.eclipse.ui 4 4 2015-01-12 11:08:57.625
!MESSAGE The proxied handler for 'com.ti.ccstudio.debug.ui.commands.FindSymbol' could not be loaded
!ENTRY org.eclipse.ui 4 0 2015-01-12 11:08:57.626
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in "com.ti.ccstudio.debug.ui" was unable to instantiate class "com.ti.ccstudio.debug.ui.commands.FindSymbol".
at com.ti.ccstudio.debug.ui.commands.FindSymbol.<init>(FindSymbol.java:26)
... 43 more
... 52 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2015-01-12 11:08:57.626
!MESSAGE Plug-in "com.ti.ccstudio.debug.ui" was unable to instantiate class "com.ti.ccstudio.debug.ui.commands.FindSymbol".
!STACK 0
... 52 more
!ENTRY org.eclipse.ui 2 0 2015-01-12 11:08:57.772
!MESSAGE Warnings while parsing the viewer contributions from the 'org.eclipse.ui.popupMenus' extension point
!SUBENTRY 1 org.eclipse.ui 2 0 2015-01-12 11:08:57.772
!MESSAGE invalid keybinding: Cannot bind to an incomplete key sequence: plug-in='org.eclipse.cdt.debug.ui', id='AUTOGEN:::org.eclipse.cdt.debug.ui.CEditorRulerActions/org.eclipse.cdt.debug.internal.ui.actions.CBreakpointPropertiesRulerActionDelegate'
!MESSAGE invalid keybinding: Cannot bind to an incomplete key sequence: plug-in='org.eclipse.cdt.debug.ui', id='AUTOGEN:::org.eclipse.cdt.debug.ui.CEditorRulerActions/org.eclipse.cdt.debug.internal.ui.actions.EnableDisableBreakpointRulerActionDelegate'
!MESSAGE invalid keybinding: Cannot bind to an incomplete key sequence: plug-in='org.eclipse.cdt.debug.ui', id='AUTOGEN:::org.eclipse.cdt.debug.ui.CEditorRulerActions/org.eclipse.cdt.debug.ui.actions.RulerCreateBreakpointInteractiveAction'
!MESSAGE invalid keybinding: Cannot bind to an incomplete key sequence: plug-in='org.eclipse.cdt.debug.ui', id='AUTOGEN:::org.eclipse.cdt.debug.ui.AsmEditorRulerActions/org.eclipse.cdt.debug.internal.ui.actions.asm.CBreakpointPropertiesRulerActionDelegate'
!MESSAGE invalid keybinding: Cannot bind to an incomplete key sequence: plug-in='org.eclipse.cdt.debug.ui', id='AUTOGEN:::org.eclipse.cdt.debug.ui.AsmEditorRulerActions/org.eclipse.cdt.debug.internal.ui.actions.asm.EnableDisableBreakpointRulerActionDelegate'
!MESSAGE invalid keybinding: Cannot bind to an incomplete key sequence: plug-in='org.eclipse.cdt.debug.ui', id='AUTOGEN:::org.eclipse.cdt.debug.ui.AsmEditorRulerActions/org.eclipse.cdt.debug.ui.actions.asm.RulerCreateBreakpointInteractiveAction'
!MESSAGE invalid keybinding: Cannot bind to an incomplete key sequence: plug-in='org.eclipse.cdt.dsf.ui', id='AUTOGEN:::org.eclipse.cdt.dsf.debug.ui.disassemblyRulerActions/org.eclipse.debug.ui.actions.RulerAddBreakpointAction'
!MESSAGE invalid keybinding: Cannot bind to an incomplete key sequence: plug-in='org.eclipse.cdt.dsf.ui', id='org.eclipse.cdt.dsf.debug.ui.disassembly.commands.rulerToggleBreakpoint'
!ENTRY org.eclipse.osgi 4 0 2015-01-12 11:08:59.933
!MESSAGE Application error
!STACK 1
java.lang.NoClassDefFoundError: com/ti/xpcom/XPCOMException
at com.ti.ccstudio.debug.ui.profileClockStatus.ProfileClockStatusBar.createControl(ProfileClockStatusBar.java:36)
at org.eclipse.jface.action.ControlContribution.fill(ControlContribution.java:98)
at org.eclipse.ui.internal.menus.DynamicMenuContributionItem.fill(DynamicMenuContributionItem.java:210)
at org.eclipse.jface.action.ToolBarManager.update(ToolBarManager.java:353)
at org.eclipse.jface.action.ToolBarManager.createControl(ToolBarManager.java:111)
at org.eclipse.ui.internal.menus.TrimContributionManager$ToolBarTrimProxy.dock(TrimContributionManager.java:88)
at org.eclipse.ui.internal.menus.TrimContributionManager.update(TrimContributionManager.java:265)
at org.eclipse.ui.internal.WorkbenchWindow.updateLayoutDataForContents(WorkbenchWindow.java:3874)
at org.eclipse.ui.internal.WorkbenchWindow.setLayoutDataForContents(WorkbenchWindow.java:3885)
at org.eclipse.ui.internal.WorkbenchWindow.createDefaultContents(WorkbenchWindow.java:1157)
at org.eclipse.ui.internal.WorkbenchWindowConfigurer.createDefaultContents(WorkbenchWindowConfigurer.java:623)
at org.eclipse.ui.application.WorkbenchWindowAdvisor.createWindowContents(WorkbenchWindowAdvisor.java:300)
at org.eclipse.ui.internal.WorkbenchWindow.createContents(WorkbenchWindow.java:1043)
at org.eclipse.jface.window.Window.create(Window.java:431)
at org.eclipse.ui.internal.Workbench$22.runWithException(Workbench.java:1216)
at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(WorkbenchAdvisor.java:803)
at org.eclipse.ui.internal.Workbench$33.runWithException(Workbench.java:1600)
Caused by: java.lang.ClassNotFoundException: com.ti.xpcom.XPCOMException
... 46 more
!ENTRY org.eclipse.core.jobs 2 2 2015-01-12 11:09:00.321
!MESSAGE Job found still running after platform shutdown. Jobs should be canceled by the plugin that scheduled them during shutdown: org.eclipse.ui.internal.AbstractWorkingSetManager$10
!ENTRY org.eclipse.core.jobs 2 2 2015-01-12 11:09:00.322
!ENTRY org.eclipse.core.jobs 2 2 2015-01-12 11:09:00.323
!ENTRY org.eclipse.core.jobs 2 2 2015-01-12 11:09:00.324
!ENTRY org.eclipse.core.jobs 2 2 2015-01-12 11:09:00.325
!ENTRY org.eclipse.core.jobs 2 2 2015-01-12 11:09:00.326
!ENTRY org.eclipse.core.jobs 2 2 2015-01-12 11:09:00.327
!SESSION 2015-01-12 11:09:07.674 -----------------------------------------------
!ENTRY org.eclipse.ui 4 4 2015-01-12 11:09:25.212
!ENTRY org.eclipse.ui 4 0 2015-01-12 11:09:25.216
!STACK 1
... 43 more
... 52 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2015-01-12 11:09:25.217
!STACK 0
... 52 more
!ENTRY org.eclipse.ui 4 4 2015-01-12 11:09:25.219
!ENTRY org.eclipse.ui 4 0 2015-01-12 11:09:25.220
!STACK 1
... 43 more
... 52 more
!SUBENTRY 1 org.eclipse.equinox.registry 4 1 2015-01-12 11:09:25.220
!STACK 0
... 52 more
!ENTRY org.eclipse.ui 2 0 2015-01-12 11:09:25.370
!SUBENTRY 1 org.eclipse.ui 2 0 2015-01-12 11:09:25.370
!ENTRY org.eclipse.osgi 4 0 2015-01-12 11:09:25.820
!STACK 1
... 46 more
!ENTRY org.eclipse.core.jobs 2 2 2015-01-12 11:09:26.200
!ENTRY org.eclipse.core.jobs 2 2 2015-01-12 11:09:26.201
!ENTRY org.eclipse.core.jobs 2 2 2015-01-12 11:09:26.202
!ENTRY org.eclipse.core.jobs 2 2 2015-01-12 11:09:26.203
!ENTRY org.eclipse.core.jobs 2 2 2015-01-12 11:09:26.204
!ENTRY org.eclipse.core.jobs 2 2 2015-01-12 11:09:26.205
!ENTRY org.eclipse.core.jobs 2 2 2015-01-12 11:09:26.206
