When I try to download and install MSP430 GCC and MSPware
I get the following error
Any idea how get pass this error. The proxy setting looks ok. Also attach is error log too
!ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2015-06-25 12:13:38.713 !MESSAGE HTTP Proxy Authentication Required: software-dl.ti.com/.../artifacts.xml !STACK 1 org.eclipse.ecf.filetransfer.BrowseFileTransferException: Proxy Authentication Required at org.eclipse.ecf.provider.filetransfer.httpclient4.HttpClientFileSystemBrowser.runRequest(HttpClientFileSystemBrowser.java:287) at org.eclipse.ecf.provider.filetransfer.browse.AbstractFileSystemBrowser$DirectoryJob.run(AbstractFileSystemBrowser.java:69) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54) !SUBENTRY 1 org.eclipse.ecf.identity 4 0 2015-06-25 12:13:38.713 !MESSAGE Proxy Authentication Required !ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2015-06-25 12:13:38.758 !MESSAGE HTTP Proxy Authentication Required: software-dl.ti.com/.../content.xml !STACK 1 org.eclipse.ecf.filetransfer.BrowseFileTransferException: Proxy Authentication Required at org.eclipse.ecf.provider.filetransfer.httpclient4.HttpClientFileSystemBrowser.runRequest(HttpClientFileSystemBrowser.java:287) at org.eclipse.ecf.provider.filetransfer.browse.AbstractFileSystemBrowser$DirectoryJob.run(AbstractFileSystemBrowser.java:69) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54) !SUBENTRY 1 org.eclipse.ecf.identity 4 0 2015-06-25 12:13:38.758 !MESSAGE Proxy Authentication Required !ENTRY org.eclipse.equinox.p2.transport.ecf 4 1002 2015-06-25 12:13:38.805 !MESSAGE HTTP Proxy Authentication Required: software-dl.ti.com/.../content.xml !STACK 1 org.eclipse.ecf.filetransfer.BrowseFileTransferException: Proxy Authentication Required at org.eclipse.ecf.provider.filetransfer.httpclient4.HttpClientFileSystemBrowser.runRequest(HttpClientFileSystemBrowser.java:287) at org.eclipse.ecf.provider.filetransfer.browse.AbstractFileSystemBrowser$DirectoryJob.run(AbstractFileSystemBrowser.java:69) at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54) !SUBENTRY 1 org.eclipse.ecf.identity 4 0 2015-06-25 12:13:38.805 !MESSAGE Proxy Authentication Required !ENTRY org.eclipse.equinox.p2.core 4 0 2015-06-25 12:13:38.806 !MESSAGE Unable to load repositories.
