Reading image from file directory and display the same using ccs5
Other Parts Discussed in Thread: OMAPL138
I'm using ccs5. I'm doing project on image processing using tms320c6713 in C. I want to read image from file directory and display the same using code composer studio. Please give me some example code in c.  I've used fread option but I don't know exactly how to use them in ccs, please help me.
Thank You,
Raviraj
  • Dear Raviraj,
    You can refer to the attached code from OMAPL138 CCS NAND writer which will read the file from PC for flashing into board, you can take this as reference.
     * nandwriter.c
     * Copyright (C) 2012 Texas Instruments Incorporated - http://www.ti.com/
     *  Redistribution and use in source and binary forms, with or without
     *  modification, are permitted provided that the following conditions
     *  are met:
     *    Redistributions of source code must retain the above copyright
     *    Redistributions in binary form must reproduce the above copyright
     *    documentation and/or other materials provided with the
     *    distribution.
     *    Neither the name of Texas Instruments Incorporated nor the names of
     *  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
     *  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
     *  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
     *  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
     *  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
     *  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
     *  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
     *  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
     *  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
     *  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
     *  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
        FILE        : nandwriter.c
        PURPOSE     : NAND writer main program
        PROJECT     : DA8xx CCS NAND Flashing Utility (for use on DM355 EVM)
        AUTHOR      : Daniel Allred
        DESC        : CCS-based utility to flash the DM644x in preparation for
                      NAND booting
    // C standard I/O library
    #include "stdio.h"
    #include "stdlib.h"
    #include "string.h"
    // General type include
    #include "tistdtypes.h"
    // Device specific CSL
    #include "device.h"
    // Debug print header file
    #include "debug.h"
    // This module's header file
    #include "nandwriter.h"
    // NAND driver include
    #include "nand.h"
    #include "device_nand.h"
    // Misc. utility function include
    #include "util.h"
    * Explicit External Declarations                            *
    * Local Macro Declarations                                  *
    //#define NANDWIDTH_16
    #define NANDWIDTH_8
    * Local Typedef Declarations                                *
    * Local Function Declarations                               *
    static Uint32 nandwriter(void);
    static Uint32 LOCAL_writeData(NAND_InfoHandle hNandInfo, Uint8 *srcBuf, Uint32 totalPageCnt);
    * Global Variable Definitions
    extern VUint32 __FAR__ DDRStart;
    extern VUint32 __FAR__ NANDStart;
    // Global variables for page buffers
    static Uint8* gNandTx;
    static Uint8* gNandRx;
    * Global Function Definitions                               *
    void main( void )
      int status;
      // Init memory alloc pointer
      UTIL_setCurrMemPtr(0);
      // System init
      if (DEVICE_init() != E_PASS)
        exit(1);
      // Execute the NAND flashing
      status = nandwriter();
      if (status != E_PASS)
        DEBUG_printString("\n\nNAND flashing failed!\r\n");
      else
        DEBUG_printString( "\n\nNAND boot preparation was successful!\r\n" );
    * Local Function Definitions                                *
    static Uint32 nandwriter()
      Uint32 numPagesAIS;
      NAND_InfoHandle  hNandInfo;
      FILE  *fPtr;
      Uint8  *aisPtr;
      Int32  aisFileSize = 0,aisAllocSize = 0;
      Int8  fileName[256];
      Int32 i=0;
      DEBUG_printString("Starting ");
      DEBUG_printString((String)devString);
      DEBUG_printString(" NANDWriter.\r\n");
      // Initialize NAND Flash
    #if defined(NANDWIDTH_8)
      hNandInfo = NAND_open((Uint32)&NANDStart, DEVICE_BUSWIDTH_8BIT );
    #elif defined(NANDWIDTH_16)
      hNandInfo = NAND_open((Uint32)&NANDStart, DEVICE_BUSWIDTH_16BIT );
    #else
      #error "Must define one of NANDWIDTH_8 or NANDWIDTH_16"
    #endif
      if (hNandInfo == NULL)
        DEBUG_printString( "\tERROR: NAND Initialization failed.\r\n" );
        return E_FAIL;
      // Erase the nand flash
      DEBUG_printString("Do you want to global erase NAND flash?");
      DEBUG_readString(fileName);
      fflush(stdin);
      if (strcmp(fileName,"y") == 0)
        if (NAND_globalErase(hNandInfo) != E_PASS)
          DEBUG_printString("\tERROR: NAND gloabal erase failed!");
      // Read the file from host
      DEBUG_printString("Enter the binary AIS file name to flash (enter 'none' to skip) :\r\n");
      fflush(stdin);
      if (strcmp(fileName,"none") != 0)
        // Open an File from the hard drive
        fPtr = fopen(fileName, "rb");
        if(fPtr == NULL)
          DEBUG_printString("\tERROR: File ");
          DEBUG_printString(fileName);
          DEBUG_printString(" open failed.\r\n");
          return E_FAIL;
        // Read file size
        fseek(fPtr,0,SEEK_END);
        aisFileSize = ftell(fPtr);
        if(aisFileSize == 0)
          DEBUG_printString("\tERROR: File read failed.. Closing program.\r\n");
          fclose (fPtr);
          return E_FAIL;
        numPagesAIS = 0;
        while ( (numPagesAIS * hNandInfo->dataBytesPerPage)  < aisFileSize )
          numPagesAIS++;
        //We want to allocate an even number of pages.
        aisAllocSize = numPagesAIS * hNandInfo->dataBytesPerPage;
        // Setup pointer in RAM
        aisPtr = (Uint8 *) UTIL_allocMem(aisAllocSize);
        // Clear memory
        for (i=0; i<aisAllocSize; i++)
          aisPtr[i]=0xFF;
        // Go to start of file
        fseek(fPtr,0,SEEK_SET);
        // Read file data
        if (aisFileSize != fread(aisPtr, 1, aisFileSize, fPtr))
          DEBUG_printString("\tWARNING: File Size mismatch.\r\n");
        // Close file
        fclose (fPtr);
        // Write the file data to the NAND flash
        if (LOCAL_writeData(hNandInfo, aisPtr, numPagesAIS) != E_PASS)
          printf("\tERROR: Write failed.\r\n");
          return E_FAIL;
      return E_PASS;
    // Generic function to write a UBL or Application header and the associated data
      Uint32    blockNum,pageNum,pageCnt;
      Uint32    numBlks;
      Uint32    i;
      Uint8     *dataPtr;
      gNandTx = (Uint8 *) UTIL_allocMem(NAND_MAX_PAGE_SIZE);
      gNandRx = (Uint8 *) UTIL_allocMem(NAND_MAX_PAGE_SIZE);
      for (i=0; i<NAND_MAX_PAGE_SIZE; i++)
        gNandTx[i]=0xff;
        gNandRx[i]=0xff;
      // Get total number of blocks needed
      numBlks = 0;
      while ( (numBlks*hNandInfo->pagesPerBlock)  < totalPageCnt )
        numBlks++;
      DEBUG_printString("Number of blocks needed for data: ");
      DEBUG_printHexInt(numBlks);
      DEBUG_printString("\r\n");
      // Start in block 1 (leave block 0 alone)
      blockNum = 1;
      // Unprotect all blocks of the device
      if (NAND_unProtectBlocks(hNandInfo, blockNum, (hNandInfo->numBlocks-1)) != E_PASS)
        blockNum++;
        DEBUG_printString("Unprotect failed.\r\n");
        return E_FAIL;
      while (blockNum < hNandInfo->numBlocks)
        // Find first good block
        while (NAND_badBlockCheck(hNandInfo,blockNum) != E_PASS)
          blockNum++;
        // Erase the current block
        NAND_eraseBlocks(hNandInfo,blockNum,1);
        // Start writing in page 0 of current block
        pageNum = 0;
        pageCnt = 0;
        // Setup data pointer
        dataPtr = srcBuf;
        // Start page writing loop
        do
          DEBUG_printString((String)"Writing image data to block ");
          DEBUG_printHexInt(blockNum);
          DEBUG_printString((String)", page ");
          DEBUG_printHexInt(pageNum);
          DEBUG_printString((String)"\r\n");
          // Write the AIS image data to the NAND device
          if (NAND_writePage(hNandInfo, blockNum,  pageNum, dataPtr) != E_PASS)
            DEBUG_printString("Write failed. Marking block as bad...\n");
            NAND_reset(hNandInfo);
            NAND_badBlockMark(hNandInfo,blockNum);
            dataPtr -=  pageNum * hNandInfo->dataBytesPerPage;
            blockNum++;
            continue;
          UTIL_waitLoop(200);
          // Verify the page just written
          if (NAND_verifyPage(hNandInfo, blockNum, pageNum, dataPtr, gNandRx) != E_PASS)
            DEBUG_printString("Verify failed. Marking block as bad...\n");
            blockNum++;
            continue;
          pageNum++;
          pageCnt++;
          dataPtr +=  hNandInfo->dataBytesPerPage;
          if (pageNum == hNandInfo->pagesPerBlock)
            // A block transition needs to take place; go to next good block
            do
              blockNum++;
            while (NAND_badBlockCheck(hNandInfo,blockNum) != E_PASS);
            pageNum = 0;
        } while (pageCnt < totalPageCnt);
        NAND_protectBlocks(hNandInfo);
        break;
      return E_PASS;
    * End file
  • Hello Mr.Titu S.
    I am facing a similar problem.
    Will this work for tms32067x ?
    Since 67x does not have an OMAP architecture.
  • Raviraj,
    Your question is about how to display an image in CCS. This C67x Single Core DSP Forum is where the hardware team monitors for questions, and we have the Code Composer Forum for CCS-related questions. We will ask a Moderator to move this thread there.
    You can go to CCS Help menu Search and search for “view image” (no quotes).
    RandyP
  • As mentioned by RandyP, the best resource for Image Analyzer view is the CCS Online Help (menu Help->Help Contents).
    This wiki section in the CCSv5 Getting Started Guide may also help. The content is applicable for CCSv6 as well.
