CCS 6.1.2 graph properties
I am tired of setting graph propreties always when I start the graph. Is there any way how to save this graph settings ?
Many thanks , and sorry for my english .
Andrej.
  • I am moving this to the CCS forum, they should be able to help you out on this.
    Yes, you can export the graph properties to a file and then import it back when you need it. In the Graph Properties dialog there are buttons along the bottom called 'Import' and 'Export" for doing this.
    Below text is from the CCS Online Help:
    Graph properties can also be saved by clicking on the Export button. User will need to specify a file name with default extension .graphProp. Later the set of properties can be restored by clicking on the Import button and selecting the desired file in which the properties were saved.
