Compiler/CCSTUDIO-C2000: Split a large file into sections
Part Number: CCSTUDIO-C2000
While linking a large file of size 0x12fe to my project, I get the following error:
program will not fit into available memory. placement with alignment/blocking fails for section ".text" size 0x12fe page 0.
In the linker command file I have .text mapped to multiple RAM sections:
.text : >> RAMD0 | RAMD1 | RAMLS0 | RAMLS1 | RAMLS2 | RAMLS3 | RAMLS4 | RAMLS5
where each section is of size 0x800. The combined size is definitely bigger than the actual size of .text section.
That's when I realized, even if we OR multiple memory sections, linker tries to fit in the complete c file into one of the memories. Please correct me if I am wrong.
One workaround I am doing currently is to combine the memories and define a bigger memory block
.text : >> RAMD0 | RAMD1 | RAMLS0123
where RAMLS0123 is defined as memory of size 0x2000
I would prefer to retain separate memory blocks in the linker command file. Is there a way I can tell the linker to split the file into smaller chunks and place it across the memories?
Veena
