Hai,
Iam trying to implement t.38 (fax over ip) in my project using FAXLIB provided by ti.I want to detect CNG ,CED tones and V.21 Preamble and send it to my server.Can any one tell how this faxlibrary is detecting these tones?
Hai,
Madhuri,
This is a fairly old library that was create for our older C64x+ DSP architecture that we currently don`t have expertise on. Let me check the documentation and try contact some the developers who may have previously supported the offering and get back to you on the questions.
I will get back to you by the end of the week.
Rahul
Iam trying to implement t.38 in TMS320C6486 DSP .I want to detect ced tone which we recieve from terminating fax.Please suggest which algorithm i need to implement to detect this tone?
The FAXLIB has two main modules, FM and FIU.
The Facsimile Modem Unit (FM) is a software module that performs all the modulation and demodulation functions required of a fax modem: demodulation of PCM data received at the analog interface, and modulation of facsimile protocol messages received from the FIU. The FM module has the following capabilities and features:
I recall that FM module should be able to detect V21, CED and CNG. The package should have some PCM captures for a real fax call recorded. Then you ran the simulation, which reads the both signals and print out all the progress.
Regards, Eric
Attach an example print out when you run it.
Regards, Eric
input file ..//pcmIn1.pcm is opened! output file ..//pcmOut1.pcm is opened! 0000(+0000ms)GW1:FIU~ FRP successful startup 0000(+0000ms)GW1:FIU~ T.38 version 0 0000(+0000ms)GW1:FIU~ FND successful startup: T.38 UDPTL network protocol 0000(+0000ms)GW1:FIU~ FIU is opened: frame size = 10 ms 0000(+0000ms)GW1:FIU~ FRP has been activated in state: startup input file ..//pcmIn2.pcm is opened! output file ..//pcmOut2.pcm is opened! 0000(+0000ms)GW2:FIU~ FRP successful startup 0000(+0000ms)GW2:FIU~ T.38 version 0 0000(+0000ms)GW2:FIU~ FND successful startup: T.38 UDPTL network protocol 0000(+0000ms)GW2:FIU~ FIU is opened: frame size = 10 ms 0000(+0000ms)GW2:FIU~ FRP has been activated in state: startup Tone detect control is called. 0000(+0000ms)GW1:FM ~ State transition: low speed rx 0000(+0000ms)GW1:FM ~ New modulation: V.21 300bps 0000(+0000ms)GW1:FM ~ State transition: low speed rx Tone detect control is called. 0000(+0000ms)GW2:FM ~ State transition: low speed rx 0000(+0000ms)GW2:FM ~ New modulation: V.21 300bps 0000(+0000ms)GW2:FM ~ State transition: low speed rx 0000(+0000ms)GW1:FIU~ Sent T.38 packet to network: no signal ind 0000(+0000ms)GW2:FIU~ Sent T.38 packet to network: no signal ind 0000(+0000ms)GW2:FIU~ Received T.38 packet with new payload type from network: no signal ind 000A(+0010ms)GW1:FIU~ Received T.38 packet with new payload type from network: no signal ind 006E(+0100ms)GW1:FIU~ Sent T.38 packet to network: CNG ind 006E(+0000ms)GW2:FIU~ Received T.38 packet with new payload type from network: CNG ind 006E(+0000ms)GW2:FIU~ Detected tone from remote: CNG 006E(+0000ms)GW2:FIU~ Start of local tone generation: CNG 1AEA(+6780ms)GW1:FIU~ Received ignored modem event in current FRP state: FM_FP_SIGNAL_DETECT 1C8E(+0420ms)GW1:FIU~ Received ignored modem event in current FRP state: FM_FP_SIGNAL_LOSS 2896(+3080ms)GW1:FIU~ Received ignored modem event in current FRP state: FM_FP_SIGNAL_DETECT 2A3A(+0420ms)GW1:FIU~ Received ignored modem event in current FRP state: FM_FP_SIGNAL_LOSS 2BF2(+0440ms)GW2:FIU~ Received ignored modem event in current FRP state: FM_FP_SIGNAL_DETECT 3AB6(+3780ms)GW2:FIU~ Received ignored modem event in current FRP state: FM_FP_SIGNAL_LOSS 3B60(+0170ms)GW2:FIU~ Received ignored modem event in current FRP state: FM_FP_SIGNAL_DETECT 3BA6(+0070ms)GW2:FM ~ Carrier detected in state: low speed rx 3BA6(+0000ms)GW2:FM ~ Preamble detected in state: low speed rx 3BA6(+0000ms)GW2:FIU~ Received ignored modem event in current FRP state: FM_FP_CARRIER_DETECT 3BA6(+0000ms)GW2:FIU~ FRP state change: local low-speed receive 3BB0(+0010ms)GW2:FIU~ Sent T.38 packet to network: V.21 preamble ind 3BBA(+0010ms)GW1:FIU~ Received T.38 packet with new payload type from network: preamble ind 3BBA(+0000ms)GW1:FIU~ FND T.38 decoder state change: transparent 3BBA(+0000ms)GW1:FIU~ Received ignored network event in current FRP state: FND_FRP_PREAMBLE_NOTIF 3CD2(+0280ms)GW1:FIU~ FRP state change: remote low-speed receive 3CDC(+0010ms)GW1:FM ~ Beginning of the delay message processing: msgData = 4b 3D2C(+0080ms)GW1:FM ~ State transition: low speed tx flag 3D2C(+0000ms)GW1:FM ~ New modulation: V.21 300bps 3D2C(+0000ms)GW1:FM ~ State transition: low speed tx flag 3D4A(+0030ms)GW1:FM ~ Beginning of the delay message processing: msgData = 352 3F66(+0540ms)GW2:FIU~ Received first byte of a low-speed data frame: 0xFF 3F7A(+0020ms)GW1:FIU~ Received T.38 packet with new payload type from network: V.21 data 3F7A(+0000ms)GW1:FIU~ FND T.38 decoder state change: low-speed data 3F98(+0030ms)GW2:FIU~ FCF of current frame: NSF (0x4) 4092(+0250ms)GW1:FIU~ Received first byte of a low-speed data frame: 0xFF 40BA(+0040ms)GW1:FM ~ Beginning of data RX or TX during transmission 40BA(+0000ms)GW1:FM ~ State transition: low speed tx data 40CE(+0020ms)GW1:FIU~ FCF of current frame: NSF (0x4) 4114(+0070ms)GW2:FIU~ Sent T.38 packet to network: V.21 data 4196(+0130ms)GW2:FIU~ Received first byte of a low-speed data frame: 0xFF 41AA(+0020ms)GW2:FIU~ Received the final frame of a low-speed transmission 41C8(+0030ms)GW2:FIU~ FCF of current frame: DIS (0x1) 4272(+0170ms)GW2:FIU~ Sent T.38 packet to network: V.21 data 429A(+0040ms)GW1:FM ~ TX or RX of a good HDLC frame: number of bytes in the frame = 0 429A(+0000ms)GW1:FM ~ State transition: low speed tx flag 429A(+0000ms)GW2:FM ~ Carrier loss detected in state: low speed rx 429A(+0000ms)GW2:FIU~ FRP state change: idle 42A4(+0010ms)GW2:FM ~ State transition: low speed rx 42A4(+0000ms)GW2:FM ~ New modulation: V.21 300bps 42A4(+0000ms)GW2:FIU~ Sent T.38 packet to network: V.21 data 42AE(+0010ms)GW1:FIU~ FND T.38 decoder state change: transparent 42AE(+0000ms)GW2:FIU~ Sent T.38 packet to network: no signal ind 42B8(+0010ms)GW1:FIU~ Received T.38 packet with new payload type from network: no signal ind 42C2(+0010ms)GW1:FIU~ Received first byte of a low-speed data frame: 0xFF 42E0(+0030ms)GW1:FIU~ Received the final frame of a low-speed transmission 42EA(+0010ms)GW1:FM ~ Beginning of data RX or TX during transmission 42EA(+0000ms)GW1:FM ~ State transition: low speed tx data 42FE(+0020ms)GW1:FIU~ FCF of current frame: DIS (0x1) 4394(+0150ms)GW1:FIU~ FRP state change: idle 43EE(+0090ms)GW1:FM ~ TX or RX of a good HDLC frame: number of bytes in the frame = 0 43EE(+0000ms)GW1:FM ~ State transition: low speed tx flag 448E(+0160ms)GW1:FM ~ State transition: offline 448E(+0000ms)GW1:FM ~ State transition: offline 4498(+0010ms)GW1:FM ~ Beginning of the delay message processing: msgData = 3c 44D4(+0060ms)GW1:FM ~ State transition: low speed rx 44D4(+0000ms)GW1:FM ~ New modulation: V.21 300bps 44D4(+0000ms)GW1:FM ~ State transition: low speed rx 4542(+0110ms)GW1:FIU~ Received ignored modem event in current FRP state: FM_FP_SIGNAL_DETECT 457E(+0060ms)GW1:FM ~ Carrier detected in state: low speed rx 457E(+0000ms)GW1:FM ~ Preamble detected in state: low speed rx 457E(+0000ms)GW1:FIU~ Received ignored modem event in current FRP state: FM_FP_CARRIER_DETECT 457E(+0000ms)GW1:FIU~ FRP state change: local low-speed receive 4588(+0010ms)GW1:FIU~ Sent T.38 packet to network: V.21 preamble ind 4588(+0000ms)GW2:FIU~ Received T.38 packet with new payload type from network: preamble ind 4588(+0000ms)GW2:FIU~ FND T.38 decoder state change: transparent 46AA(+0290ms)GW2:FIU~ FRP state change: remote low-speed receive 46B4(+0010ms)GW2:FM ~ State transition: low speed tx flag 46B4(+0000ms)GW2:FM ~ New modulation: V.21 300bps 46B4(+0000ms)GW2:FM ~ State transition: low speed tx flag 46D2(+0030ms)GW2:FM ~ Beginning of the delay message processing: msgData = 352 48EE(+0540ms)GW1:FIU~ Received first byte of a low-speed data frame: 0xFF 48F8(+0010ms)GW2:FIU~ Received T.38 packet with new payload type from network: V.21 data 48F8(+0000ms)GW2:FIU~ FND T.38 decoder state change: low-speed data 490C(+0020ms)GW1:FIU~ Received the final frame of a low-speed transmission 4920(+0020ms)GW1:FIU~ FCF of current frame: DCS (0x41) Tone detect control is called. 4998(+0120ms)GW1:FIU~ Sent T.38 packet to network: V.21 data 49B6(+0030ms)GW1:FM ~ Carrier loss detected in state: low speed rx 49B6(+0000ms)GW1:FIU~ FRP state change: idle 49C0(+0010ms)GW1:FM ~ State transition: high speed rx 49C0(+0000ms)GW1:FM ~ New modulation: V.17 14400bps - long training 49C0(+0000ms)GW1:FM ~ State transition: high speed rx 49C0(+0000ms)GW1:FIU~ Sent T.38 packet to network: V.21 data 49C0(+0000ms)GW2:FIU~ FND T.38 decoder state change: transparent 49CA(+0010ms)GW1:FIU~ Sent T.38 packet to network: no signal ind 49CA(+0000ms)GW1:FIU~ Received ignored modem event in current FRP state: FM_FP_SIGNAL_DETECT 49CA(+0000ms)GW2:FIU~ Received T.38 packet with new payload type from network: no signal ind 4A1A(+0080ms)GW2:FIU~ Received first byte of a low-speed data frame: 0xFF 4A38(+0030ms)GW2:FIU~ Received the final frame of a low-speed transmission 4A42(+0010ms)GW2:FM ~ Beginning of data RX or TX during transmission 4A42(+0000ms)GW2:FM ~ State transition: low speed tx data 4A4C(+0010ms)GW1:FM ~ TEP detected in state: high speed rx 4A4C(+0000ms)GW1:FIU~ FRP state change: local TCF receive 4A56(+0010ms)GW1:FIU~ Sent T.38 packet to network: V.17 14400bps - long training ind 4A56(+0000ms)GW2:FIU~ Received T.38 packet with new payload type from network: V.17 14400bps - long training ind 4A56(+0000ms)GW2:FIU~ FCF of current frame: DCS (0x41) Tone detect control is called. 4ABA(+0100ms)GW2:FIU~ SLP page mode: transparent 4ABA(+0000ms)GW2:FIU~ FRP state change: idle 4ABA(+0000ms)GW2:FIU~ FRP state change: remote TCF receive 4AF6(+0060ms)GW1:FM ~ P2 detected in state: high speed rx 4B14(+0030ms)GW2:FM ~ TX or RX of a good HDLC frame: number of bytes in the frame = 0 4B14(+0000ms)GW2:FM ~ State transition: low speed tx flag 4BB4(+0160ms)GW2:FM ~ State transition: offline 4BB4(+0000ms)GW2:FM ~ State transition: offline 4BBE(+0010ms)GW2:FM ~ Beginning of the delay message processing: msgData = 3c 4BFA(+0060ms)GW2:FM ~ State transition: high speed rx 4BFA(+0000ms)GW2:FM ~ New modulation: V.17 14400bps - long training 4BFA(+0000ms)GW2:FM ~ State transition: high speed rx 4C04(+0010ms)GW2:FM ~ State transition: high speed tx training 4C04(+0000ms)GW2:FM ~ New modulation: V.17 14400bps - long training 4C04(+0000ms)GW2:FM ~ State transition: high speed tx training 5064(+1120ms)GW1:FM ~ Carrier detected in state: high speed rx 5064(+0000ms)GW1:FIU~ Received ignored modem event in current FRP state: FM_FP_SIGNAL_LOSS 5064(+0000ms)GW1:FIU~ Received first high-speed data bytes by FRP from either modem or network 5078(+0020ms)GW2:FIU~ Received T.38 packet with new payload type from network: V.17 14400bps data 5078(+0000ms)GW2:FIU~ FND T.38 decoder state change: high-speed data 519A(+0290ms)GW2:FIU~ Received first high-speed data bytes by FRP from either modem or network 526C(+0210ms)GW2:FM ~ Beginning of data RX or TX during transmission 526C(+0000ms)GW2:FM ~ State transition: high speed tx data 5686(+1050ms)GW1:FM ~ Carrier loss detected in state: high speed rx 5686(+0000ms)GW1:FIU~ FRP state change: idle 5690(+0010ms)GW1:FM ~ State transition: high speed rx 5690(+0000ms)GW1:FM ~ New modulation: V.17 14400bps - short training 5690(+0000ms)GW1:FIU~ Sent T.38 packet to network: V.17 14400bps data 5690(+0000ms)GW2:FIU~ FND T.38 decoder state change: transparent 569A(+0010ms)GW1:FIU~ Sent T.38 packet to network: no signal ind 569A(+0000ms)GW2:FIU~ Received T.38 packet with new payload type from network: no signal ind 57BC(+0290ms)GW2:FIU~ FRP state change: idle 588E(+0210ms)GW2:FM ~ End of data RX or TX during transmission 588E(+0000ms)GW2:FM ~ State transition: high speed tx preamble off 58A2(+0020ms)GW2:FM ~ State transition: offline 58A2(+0000ms)GW2:FM ~ State transition: offline 58AC(+0010ms)GW2:FM ~ State transition: high speed rx 58AC(+0000ms)GW2:FM ~ New modulation: V.17 14400bps - short training 58AC(+0000ms)GW2:FM ~ State transition: high speed rx 5992(+0230ms)GW2:FM ~ Preamble detected in state: high speed rx 5992(+0000ms)GW2:FIU~ FRP state change: local low-speed receive 599C(+0010ms)GW2:FM ~ State transition: low speed rx 599C(+0000ms)GW2:FM ~ New modulation: V.21 300bps 599C(+0000ms)GW2:FM ~ State transition: low speed rx 599C(+0000ms)GW2:FIU~ Sent T.38 packet to network: V.21 preamble ind 59A6(+0010ms)GW1:FIU~ Received T.38 packet with new payload type from network: preamble ind 5A0A(+0100ms)GW2:FIU~ Received ignored modem event in current FRP state: FM_FP_SIGNAL_DETECT 5A50(+0070ms)GW2:FM ~ Carrier detected in state: low speed rx 5A50(+0000ms)GW2:FM ~ Preamble detected in state: low speed rx 5A50(+0000ms)GW2:FIU~ Received ignored modem event in current FRP state: FM_FP_CARRIER_DETECT 5ABE(+0110ms)GW1:FIU~ FRP state change: remote low-speed receive 5AC8(+0010ms)GW1:FM ~ State transition: low speed tx flag 5AC8(+0000ms)GW1:FM ~ New modulation: V.21 300bps 5AC8(+0000ms)GW1:FM ~ State transition: low speed tx flag 5AE6(+0030ms)GW1:FM ~ Beginning of the delay message processing: msgData = 352 5C76(+0400ms)GW2:FIU~ Received first byte of a low-speed data frame: 0xFF 5C8A(+0020ms)GW1:FIU~ Received T.38 packet with new payload type from network: V.21 data 5C8A(+0000ms)GW1:FIU~ FND T.38 decoder state change: low-speed data 5C94(+0010ms)GW2:FIU~ Received the final frame of a low-speed transmission 5CB2(+0030ms)GW2:FIU~ FCF of current frame: CFR (0x21) 5CBC(+0010ms)GW2:FIU~ Sent T.38 packet to network: V.21 data 5CDA(+0030ms)GW2:FM ~ Carrier loss detected in state: low speed rx 5CDA(+0000ms)GW2:FIU~ FRP state change: idle 5CE4(+0010ms)GW2:FM ~ State transition: high speed rx 5CE4(+0000ms)GW2:FM ~ New modulation: V.17 14400bps - short training 5CE4(+0000ms)GW2:FM ~ State transition: high speed rx 5CE4(+0000ms)GW2:FIU~ Sent T.38 packet to network: V.21 data 5CEE(+0010ms)GW1:FIU~ FND T.38 decoder state change: transparent 5CEE(+0000ms)GW2:FIU~ Sent T.38 packet to network: no signal ind 5CEE(+0000ms)GW2:FIU~ Received ignored modem event in current FRP state: FM_FP_SIGNAL_DETECT 5CF8(+0010ms)GW1:FIU~ Received T.38 packet with new payload type from network: no signal ind 5DA2(+0170ms)GW1:FIU~ Received first byte of a low-speed data frame: 0xFF 5DC0(+0030ms)GW1:FIU~ Received the final frame of a low-speed transmission 5DDE(+0030ms)GW1:FIU~ FCF of current frame: CFR (0x21) 5DDE(+0000ms)GW1:FIU~ FRP state change: idle 5E56(+0120ms)GW1:FM ~ Beginning of data RX or TX during transmission 5E56(+0000ms)GW1:FM ~ State transition: low speed tx data 5EBA(+0100ms)GW1:FM ~ TX or RX of a good HDLC frame: number of bytes in the frame = 0 5EBA(+0000ms)GW1:FM ~ State transition: low speed tx flag 5F5A(+0160ms)GW1:FM ~ State transition: offline 5F5A(+0000ms)GW1:FM ~ State transition: offline 5F64(+0010ms)GW1:FM ~ Beginning of the delay message processing: msgData = 3c 5FA0(+0060ms)GW1:FM ~ State transition: high speed rx 5FA0(+0000ms)GW1:FM ~ New modulation: V.17 14400bps - short training 5FA0(+0000ms)GW1:FM ~ State transition: high speed rx 604A(+0170ms)GW1:FM ~ TEP detected in state: high speed rx 604A(+0000ms)GW1:FIU~ FRP state change: local high-speed receive 6054(+0010ms)GW1:FIU~ Sent T.38 packet to network: V.17 14400bps - short training ind 6054(+0000ms)GW2:FIU~ Received T.38 packet with new payload type from network: V.17 14400bps - short training ind 60F4(+0160ms)GW1:FM ~ P2 detected in state: high speed rx 6176(+0130ms)GW2:FIU~ FRP state change: remote high-speed receive 6180(+0010ms)GW1:FM ~ Carrier detected in state: high speed rx 6180(+0000ms)GW2:FM ~ State transition: high speed tx training 6180(+0000ms)GW2:FM ~ New modulation: V.17 14400bps - short training 6180(+0000ms)GW2:FM ~ State transition: high speed tx training 6180(+0000ms)GW1:FIU~ Received first high-speed data bytes by FRP from either modem or network 6194(+0020ms)GW2:FIU~ Received T.38 packet with new payload type from network: V.17 14400bps data 6194(+0000ms)GW2:FIU~ FND T.38 decoder state change: high-speed data 62B6(+0290ms)GW2:FIU~ Received first high-speed data bytes by FRP from either modem or network 62FC(+0070ms)GW2:FM ~ Beginning of data RX or TX during transmission 62FC(+0000ms)GW2:FM ~ State transition: high speed tx data 0E8C(+-21616ms)GW1:FM ~ Carrier loss detected in state: high speed rx 0E8C(+0000ms)GW1:FIU~ FRP state change: idle 0E96(+0010ms)GW1:FM ~ State transition: high speed rx 0E96(+0000ms)GW1:FM ~ New modulation: V.17 14400bps - short training 0E96(+0000ms)GW1:FIU~ Sent T.38 packet to network: V.17 14400bps data 0E96(+0000ms)GW2:FIU~ FND T.38 decoder state change: transparent 0EA0(+0010ms)GW1:FIU~ Sent T.38 packet to network: no signal ind 0EA0(+0000ms)GW2:FIU~ Received T.38 packet with new payload type from network: no signal ind 0FAE(+0270ms)GW2:FIU~ FRP state change: idle 0FEA(+0060ms)GW1:FM ~ Preamble detected in state: high speed rx 0FEA(+0000ms)GW1:FIU~ FRP state change: local low-speed receive 0FF4(+0010ms)GW1:FM ~ State transition: low speed rx 0FF4(+0000ms)GW1:FM ~ New modulation: V.21 300bps 0FF4(+0000ms)GW1:FM ~ State transition: low speed rx 0FF4(+0000ms)GW1:FIU~ Sent T.38 packet to network: V.21 preamble ind 0FF4(+0000ms)GW2:FIU~ Received T.38 packet with new payload type from network: preamble ind 0FF4(+0000ms)GW2:FIU~ FRP state change: remote low-speed receive 1008(+0020ms)GW2:FM ~ End of data RX or TX during transmission 1008(+0000ms)GW2:FM ~ State transition: high speed tx preamble off 101C(+0020ms)GW2:FM ~ State transition: offline 101C(+0000ms)GW2:FM ~ State transition: offline 1026(+0010ms)GW2:FM ~ Beginning of the delay message processing: msgData = 3c 1062(+0060ms)GW2:FM ~ State transition: high speed rx 1062(+0000ms)GW2:FM ~ New modulation: V.17 14400bps - short training 1062(+0000ms)GW2:FM ~ State transition: high speed rx 1062(+0000ms)GW1:FIU~ Received ignored modem event in current FRP state: FM_FP_SIGNAL_DETECT 106C(+0010ms)GW2:FM ~ State transition: low speed tx flag 106C(+0000ms)GW2:FM ~ New modulation: V.21 300bps 106C(+0000ms)GW2:FM ~ State transition: low speed tx flag 106C(+0000ms)GW2:FIU~ Received ignored modem event in current FRP state: FM_FP_SIGNAL_DETECT 108A(+0030ms)GW2:FM ~ Beginning of the delay message processing: msgData = 352 10A8(+0030ms)GW1:FM ~ Carrier detected in state: low speed rx 10A8(+0000ms)GW1:FM ~ Preamble detected in state: low speed rx 10A8(+0000ms)GW1:FIU~ Received ignored modem event in current FRP state: FM_FP_CARRIER_DETECT 13AA(+0770ms)GW1:FIU~ Received first byte of a low-speed data frame: 0xFF 13B4(+0010ms)GW2:FIU~ Received T.38 packet with new payload type from network: V.21 data 13B4(+0000ms)GW2:FIU~ FND T.38 decoder state change: low-speed data 13C8(+0020ms)GW1:FIU~ Received the final frame of a low-speed transmission 13DC(+0020ms)GW1:FIU~ FCF of current frame: EOP (0x74) 13E6(+0010ms)GW1:FIU~ Sent T.38 packet to network: V.21 data 140E(+0040ms)GW1:FM ~ Carrier loss detected in state: low speed rx 140E(+0000ms)GW1:FIU~ FRP state change: idle 1418(+0010ms)GW1:FM ~ State transition: high speed rx 1418(+0000ms)GW1:FM ~ New modulation: V.17 14400bps - short training 1418(+0000ms)GW1:FM ~ State transition: high speed rx 1418(+0000ms)GW1:FIU~ Sent T.38 packet to network: V.21 data 1418(+0000ms)GW2:FIU~ FND T.38 decoder state change: transparent 1422(+0010ms)GW1:FIU~ Sent T.38 packet to network: no signal ind 1422(+0000ms)GW1:FIU~ Received ignored modem event in current FRP state: FM_FP_SIGNAL_DETECT 1422(+0000ms)GW2:FIU~ Received T.38 packet with new payload type from network: no signal ind 14D6(+0180ms)GW2:FIU~ Received first byte of a low-speed data frame: 0xFF 14F4(+0030ms)GW2:FIU~ Received the final frame of a low-speed transmission 14FE(+0010ms)GW2:FM ~ Beginning of data RX or TX during transmission 14FE(+0000ms)GW2:FM ~ State transition: low speed tx data 1512(+0020ms)GW2:FIU~ FCF of current frame: EOP (0x74) 1512(+0000ms)GW2:FIU~ FRP state change: idle 156C(+0090ms)GW2:FM ~ TX or RX of a good HDLC frame: number of bytes in the frame = 0 156C(+0000ms)GW2:FM ~ State transition: low speed tx flag 160C(+0160ms)GW2:FM ~ State transition: offline 160C(+0000ms)GW2:FM ~ State transition: offline 1616(+0010ms)GW2:FM ~ Beginning of the delay message processing: msgData = 3c 1652(+0060ms)GW2:FM ~ State transition: high speed rx 1652(+0000ms)GW2:FM ~ New modulation: V.17 14400bps - short training 1652(+0000ms)GW2:FM ~ State transition: high speed rx 165C(+0010ms)GW2:FIU~ Received ignored modem event in current FRP state: FM_FP_SIGNAL_DETECT 1738(+0220ms)GW2:FM ~ Preamble detected in state: high speed rx 1738(+0000ms)GW2:FIU~ FRP state change: local low-speed receive 1742(+0010ms)GW2:FM ~ State transition: low speed rx 1742(+0000ms)GW2:FM ~ New modulation: V.21 300bps 1742(+0000ms)GW2:FM ~ State transition: low speed rx 1742(+0000ms)GW2:FIU~ Sent T.38 packet to network: V.21 preamble ind 174C(+0010ms)GW1:FIU~ Received T.38 packet with new payload type from network: preamble ind 17B0(+0100ms)GW2:FIU~ Received ignored modem event in current FRP state: FM_FP_SIGNAL_DETECT 17EC(+0060ms)GW2:FM ~ Carrier detected in state: low speed rx 17EC(+0000ms)GW2:FM ~ Preamble detected in state: low speed rx 17EC(+0000ms)GW2:FIU~ Received ignored modem event in current FRP state: FM_FP_CARRIER_DETECT 1864(+0120ms)GW1:FIU~ FRP state change: remote low-speed receive 186E(+0010ms)GW1:FM ~ State transition: low speed tx flag 186E(+0000ms)GW1:FM ~ New modulation: V.21 300bps 186E(+0000ms)GW1:FM ~ State transition: low speed tx flag 188C(+0030ms)GW1:FM ~ Beginning of the delay message processing: msgData = 352 1A4E(+0450ms)GW2:FIU~ Received first byte of a low-speed data frame: 0xFF 1A62(+0020ms)GW1:FIU~ Received T.38 packet with new payload type from network: V.21 data 1A62(+0000ms)GW1:FIU~ FND T.38 decoder state change: low-speed data 1A6C(+0010ms)GW2:FIU~ Received the final frame of a low-speed transmission 1A8A(+0030ms)GW2:FIU~ FCF of current frame: MCF (0x31) 1A94(+0010ms)GW2:FIU~ Sent T.38 packet to network: V.21 data 1AB2(+0030ms)GW2:FM ~ Carrier loss detected in state: low speed rx 1AB2(+0000ms)GW2:FIU~ FRP state change: idle 1ABC(+0010ms)GW2:FM ~ State transition: high speed rx 1ABC(+0000ms)GW2:FM ~ New modulation: V.17 14400bps - short training 1ABC(+0000ms)GW2:FM ~ State transition: high speed rx 1ABC(+0000ms)GW2:FIU~ Sent T.38 packet to network: V.21 data 1AC6(+0010ms)GW1:FIU~ FND T.38 decoder state change: transparent 1AC6(+0000ms)GW2:FIU~ Sent T.38 packet to network: no signal ind 1AC6(+0000ms)GW2:FIU~ Received ignored modem event in current FRP state: FM_FP_SIGNAL_DETECT 1AD0(+0010ms)GW1:FIU~ Received T.38 packet with new payload type from network: no signal ind 1B7A(+0170ms)GW1:FIU~ Received first byte of a low-speed data frame: 0xFF 1B98(+0030ms)GW1:FIU~ Received the final frame of a low-speed transmission 1BB6(+0030ms)GW1:FIU~ FCF of current frame: MCF (0x31) 1BB6(+0000ms)GW1:FIU~ FRP state change: idle 1BFC(+0070ms)GW1:FM ~ Beginning of data RX or TX during transmission 1BFC(+0000ms)GW1:FM ~ State transition: low speed tx data 1C60(+0100ms)GW1:FM ~ TX or RX of a good HDLC frame: number of bytes in the frame = 0 1C60(+0000ms)GW1:FM ~ State transition: low speed tx flag 1D00(+0160ms)GW1:FM ~ State transition: offline 1D00(+0000ms)GW1:FM ~ State transition: offline 1D0A(+0010ms)GW1:FM ~ Beginning of the delay message processing: msgData = 3c 1D46(+0060ms)GW1:FM ~ State transition: high speed rx 1D46(+0000ms)GW1:FM ~ New modulation: V.17 14400bps - short training 1D46(+0000ms)GW1:FM ~ State transition: high speed rx 1D50(+0010ms)GW1:FIU~ Received ignored modem event in current FRP state: FM_FP_SIGNAL_DETECT 1E40(+0240ms)GW1:FM ~ Preamble detected in state: high speed rx 1E40(+0000ms)GW1:FIU~ FRP state change: local low-speed receive 1E4A(+0010ms)GW1:FM ~ State transition: low speed rx 1E4A(+0000ms)GW1:FM ~ New modulation: V.21 300bps 1E4A(+0000ms)GW1:FM ~ State transition: low speed rx 1E4A(+0000ms)GW1:FIU~ Sent T.38 packet to network: V.21 preamble ind 1E4A(+0000ms)GW2:FIU~ Received T.38 packet with new payload type from network: preamble ind 1EB8(+0110ms)GW1:FIU~ Received ignored modem event in current FRP state: FM_FP_SIGNAL_DETECT 1EFE(+0070ms)GW1:FM ~ Carrier detected in state: low speed rx 1EFE(+0000ms)GW1:FM ~ Preamble detected in state: low speed rx 1EFE(+0000ms)GW1:FIU~ Received ignored modem event in current FRP state: FM_FP_CARRIER_DETECT 1F6C(+0110ms)GW2:FIU~ FRP state change: remote low-speed receive 1F76(+0010ms)GW2:FM ~ State transition: low speed tx flag 1F76(+0000ms)GW2:FM ~ New modulation: V.21 300bps 1F76(+0000ms)GW2:FM ~ State transition: low speed tx flag 1F94(+0030ms)GW2:FM ~ Beginning of the delay message processing: msgData = 352 20C0(+0300ms)GW1:FIU~ Received first byte of a low-speed data frame: 0xFF 20CA(+0010ms)GW2:FIU~ Received T.38 packet with new payload type from network: V.21 data 20CA(+0000ms)GW2:FIU~ FND T.38 decoder state change: low-speed data 20DE(+0020ms)GW1:FIU~ Received the final frame of a low-speed transmission 20F2(+0020ms)GW1:FIU~ FCF of current frame: DCN (0x5F) 20FC(+0010ms)GW1:FIU~ Sent T.38 packet to network: V.21 data 2124(+0040ms)GW1:FM ~ Carrier loss detected in state: low speed rx 2124(+0000ms)GW1:FIU~ FRP state change: switch out pending 2124(+0000ms)GW1:FIU~ Expiration of protocol timer: cleardown timer 2124(+0000ms)GW1:FIU~ Fax cleardown: DCN message received from local 212E(+0010ms)GW1:FM ~ State transition: offline 212E(+0000ms)GW1:FM ~ State transition: offline 212E(+0000ms)GW1:FIU~ Sent T.38 packet to network: V.21 data 212E(+0000ms)GW2:FIU~ FND T.38 decoder state change: transparent 2138(+0010ms)GW1:FIU~ Sent T.38 packet to network: no signal ind 2138(+0000ms)GW2:FIU~ Received T.38 packet with new payload type from network: no signal ind 21EC(+0180ms)GW2:FIU~ Received first byte of a low-speed data frame: 0xFF 220A(+0030ms)GW2:FIU~ Received the final frame of a low-speed transmission 2228(+0030ms)GW2:FIU~ FCF of current frame: DCN (0x5F) 2304(+0220ms)GW2:FM ~ Beginning of data RX or TX during transmission 2304(+0000ms)GW2:FM ~ State transition: low speed tx data 2368(+0100ms)GW2:FM ~ TX or RX of a good HDLC frame: number of bytes in the frame = 0 2368(+0000ms)GW2:FM ~ State transition: low speed tx flag 2408(+0160ms)GW2:FM ~ State transition: offline 2408(+0000ms)GW2:FM ~ State transition: offline 2412(+0010ms)GW2:FM ~ Beginning of the delay message processing: msgData = 3c 244E(+0060ms)GW2:FM ~ Processed sync message 244E(+0000ms)GW2:FIU~ FRP state change: switch out pending 244E(+0000ms)GW2:FIU~ Fax cleardown: DCN message received from remote 2458(+0010ms)GW2:FM ~ State transition: offline 27BE(+0870ms)GW1:FIU~ FIU is closed 27BE(+0000ms)GW2:FIU~ FIU is closed
Regards, Eric
Hai Eric,
Thank you so much for replying.I have found the following 3 functions in code regarding tone detection in which Ist 2 functions does nothing(He gave them as empty) and last function is doing something .
void siuToneOnFax (void *TargetInst, tgnParams_t *toneParams)
}//Routine called by FM to initialize generation of single frequency tone cadence (i.e. CNG/CED) by an external tone generator utility. The parameter 'params' is a pointer to a data structure defining the frequency, amplitude, and on/off cadence of the tone.
void siuToneOffFax (void *TargetInst)
} //Routine called by FM to terminate generation of a tone cadence by an external tone generator utility.
fmToneDetect (siuInst[0].fmInst, iffax_TONE_CNG, NULL, NULL); //This function notifies FM that a tone detection indication has been received from an external tone detection module.
Following is the output
why to generate tone locally and which function is doing the tone detection here?
I used FAXLIB many years ago and currently we don't have expertise on the FAXLIB.
From I recall, the CNG, CED signal is not passing through the network. But it is detected on remote side, then sending the T.38 packets over the network for an indication that a certain tone is detected. Then on the local side, tone generation can be implemented by TI TGU (tone generation unit).
TI has another module called TDU (tone detection unit), that is used to detect various tones.
TGU and TDU are parts of TI VOLIB. http://software-dl.ti.com/sdoemb/sdoemb_public_sw/volib/latest/index_FDS.html
Regards, Eric
