CCS/TIDA-01281: TI XDS110/TMS320F28035 SC_ERR_XDS110_OVERCURRENT
Part Number: TIDA-01281
Other Parts Discussed in Thread: TMS320F28035
I get the following error message when testing the connection of the TI XDS110 debugger with TMS320F28035.
[Start: Texas Instruments XDS110 USB Debug Probe_0]
Execute the command:
%ccs_base%/common/uscif/dbgjtag -f %boarddatafile% -rv -o -S integrity
[Result]
-----[Print the board config pathname(s)]------------------------------------
C:\Users\Chris\AppData\Local\TEXASI~1\CCS\
PROGRA~1\0\0\BrdDat\testBoard.dat
-----[Print the reset-command software log-file]-----------------------------
This utility has selected a 100- or 510-class product.
This utility will load the adapter 'jioxds110.dll'.
The library build date was 'May 7 2020'.
The library build time was '21:10:18'.
The library package version is '9.2.0.00002'.
The library component version is '35.35.0.0'.
The controller does not use a programmable FPGA.
An error occurred while hard opening the controller.
-----[An error has occurred and this utility has aborted]--------------------
This error is generated by TI's USCIF driver or utilities.
The value is '-269' (0xfffffef3).
The title is 'SC_ERR_XDS110_OVERCURRENT'.
The explanation is:
An overcurrent has been detected since the last time the XDS110 was power
cycled. Please check target connection to probe and power cycle the XDS110.
[End: Texas Instruments XDS110 USB Debug Probe_0]
The physical connection from the probe to the board seems to be fine. Could this be an issue with the device/board itself?
Sandy
