CCS/TM4C123GH6PM: CCS generator a binary file fail after windows 10 update.
Part Number: TM4C123GH6PM
Dear sir,
After execute windows update to Windows 10 Version 2004
CCS convert bin file function is fail..
Error message as below
<Linking>
Finished building target: "ABC.out"
C:/ti/ccs1011/ccs/utils/tiobj2bin/tiobj2bin "ABC.out" "ABC.bin" "C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-arm_20.2.1.LTS/bin/armofd" "C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-arm_20.2.1.LTS/bin/armhex" "C:/ti/ccs1011/ccs/utils/tiobj2bin/mkhex4bin"
C:/ti/ccs1011/ccs/utils/tiobj2bin/mkhex4bin failure occurred.  Giving up.
junk after document element at line 636, column 0, byte 13545 at XML/Parser.pm line 187.
**** Build Finished ****
Post-buld steps command setting as below:
${CCS_INSTALL_ROOT}/utils/tiobj2bin/tiobj2bin "${BuildArtifactFileName}" "${BuildArtifactFileBaseName}.bin" "${CG_TOOL_ROOT}/bin/armofd" "${CG_TOOL_ROOT}/bin/armhex" "${CCS_INSTALL_ROOT}/utils/tiobj2bin/mkhex4bin"
Reinstall the CCS was not work
Any help is appreciated.
Aska
  • Aska,
    Our expert on those utilities will be in on Monday and can take a look.
    One thing to check would be to see if this will run outside of CCS by opening a command prompt and going to your project folder
    Then running:
    John
  • My Windows 10 PC pro updated to the later build 20H2 but I can't repeat the failure using the same post build command:
    "C:/ti/ccs1011/ccs/utils/tiobj2bin/tiobj2bin" "tm4c_pwm_test.out" "tm4c_pwm_test.bin" "C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-arm_20.2.1.LTS/bin/armofd" "C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-arm_20.2.1.LTS/bin/armhex" "C:/ti/ccs1011/ccs/utils/tiobj2bin/mkhex4bin"
    While there are some other forum threads which mention an error at "XML/Parser.pm line 187", it wasn't clear what the cause was.
  • So I can reproduce this behavior ...
    ... please put the file ABC.out in a zip file, then attach that zip file to your next post.
    Thanks and regards,
    -George
  • Hi George,
    thanks for your reply, the attached file is the ABC.out.
    ABC.zip
  • Hi John,
    thanks for your information,
    I try to execute the command in windows command line :
    1.cmd.exe
    2.goto project folder
    3.execute command:
    d:\Aska_Project\CCS\Debug>C:/ti/ccs1011/ccs/utils/tiobj2bin/tiobj2bin "ABC.out" "ABC.bin" "C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-arm_20.2.1.LTS/bin/armofd" "C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-arm_20.2.1.LTS/bin/armhex" "C:/ti/ccs1011/ccs/utils/tiobj2bin/mkhex4bin"
    "C:/ti/ccs1011/ccs/utils/tiobj2bin/mkhex4bin" failure occurred.  Giving up.
    I got the same message.
    best regards,
    Aska
  • Thank you for ...
    Unfortunately, I am unable to reproduce the same behavior.  This means the the file ABC.out is not the problem.
    Instead of using tiobj2bin.bat use armobjcopy instead.  It is a recent addition to the TI ARM compiler installation.  Change the tiobj2bin.bat command to ...
    C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-arm_20.2.1.LTS/bin/armobjcopy -I elf32-little -O binary ABC.out ABC.bin
    Please let me know if this resolves the problem.
    Thanks and regards,
    -George
  • Hi George,
    Thanks for your reply.
    I Modify the Post-build command
    ${CG_TOOL_ROOT}/bin/armobjcopy -I elf32-little -O binary "${BuildArtifactFileName}" "${BuildArtifactFileBaseName}.bin" "${CG_TOOL_ROOT}/bin/armofd" "${CG_TOOL_ROOT}/bin/armhex" "${CCS_INSTALL_ROOT}/utils/tiobj2bin/mkhex4bin"
    C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-arm_20.2.1.LTS/bin/armobjcopy -I elf32-little -O binary "ABC.out" "ABC.bin" "C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-arm_20.2.1.LTS/bin/armofd" "C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-arm_20.2.1.LTS/bin/armhex" "C:/ti/ccs1011/ccs/utils/tiobj2bin/mkhex4bin"
    [0x7FFC217FE0A4] ANOMALY: use of REX.w is meaningless (default operand size is 64)
    makefile:179: recipe for target 'post-build' failed
    C:/ti/ccs1011/ccs/tools/compiler/ti-cgt-arm_20.2.1.LTS/bin\armobjcopy.exe: error: too many positional arguments
    gmake[2]: [post-build] Error 1 (ignored)
  • The arguments after naming the .bin file should not be present.  Change the post-build step to ...
    Thanks and regards,
    -George
  • Hi George,
    It is work, thank you very much.
    I modify the post-build setting as you suggested, error message is clear and got a bin file.
    [0x7FFAF9DCE0A4] ANOMALY: use of REX.w is meaningless (default operand size is 64)
