Part Number: TIDA-00951
As the signals IBAT_HS+ & IBAT_HS- enter the Current Sense Board (TIDA-01141) they are effectively swapped at the INA240. This will change the polarity od the CS signal. There is an offset applied, so there will be some usable range. Is this inverted level what the software is expecting to see, or should the two signals be transposed for correct operation?
