Hi ,
Currently I am using TIDA-00120 design for 12V/24V Lead acid batteries. Can i use this same design for Li-Ion / LiFePO4 batteries of same voltage? Please suggest me on this.
Thanks & Regards
Naresh
Hi ,
Thanks & Regards
Naresh
Naresh,
I'm glad to hear that this design helped you out with your application so far. In regards to charging Li-Ion, the same basic principles are used for the charging, however the software will have to be modified to do this. The primary change will be the removal of the "trickle charge" so that the cells are not overcharged.
You can find some more information on the differences at this website: https://batteryuniversity.com/learn/article/charging_lithium_ion_batteries
Bart
