Other Parts Discussed in Thread: TIDA-01605, UCC21521, UCC21520, UCC21530
Hello again.
i would like to ask you some questions regarding the TIDA-01604 and TIDA-01605:
1. What control card is used in the reference design in your PDF? Is it possible the code to be different for the card used in your make up and if i use the suggested 280049C control card?
2. Is it possible to have some error in the shematic for the 01605??? For exapmle can you confirm the D5 orientation? Also The picture for U6 IC in your pfd is UCC21521, but the label bellow the picture is UCC21520. Now i have two other questions: what is correct to have on the EN pin of the chip? 1 or 0? What R configuration to use? R30, R32 R31 ??? I am using UCC21520 and as we can see on page 3 here https://www.ti.com/lit/ds/symlink/ucc21520-q1.pdf it is with disable pin (not enable as in your pdf)
3. Do you have any updated files for this design?
I have spend alot of time and money for this project, but it is still not working and i am wondering what is your oppinion regarding any software changes i have to do in order to make it work with 280049C control card.
Thanks in advance!
Dan
