Other Parts Discussed in Thread: SFRA
Manish Bhardwaj:
Hello!
When you replied to my question last month, you mentioned that the software of TIDA-01606 will be updated once, and I want to confirm the update time. Thank you!
Manish Bhardwaj:
Hello!
The SDK release is planned for 2Q 2020 and will be in end of June.
We will update the MSS package of TIDA-01606 in March, with code tested on a HIL framework.
Can you remind me in what capacity do you plan on using the code ? To understand ? TO run on a TIDA-01606 board you have constructed?
Manish Bhardwaj:
Hello!
Thank you for your reply!
I made the TIDA-01606 PCB board according to the relevant technical documents provided by Ti.
Currently, the software package TIDA-01606 provided by Ti is being used for debugging.
However, due to some macro definition errors in tida-01606 package(#define TINV_ADC_PU_SCALE_FACTOR ((float32_t)(3.3 / (2^12))))
I made some modifications according to my own understanding, but the overall architecture of the program was almost unchanged.
But there are some problems, which were mentioned in the forum before.
At present, the main problem is that the output sine wave is normal when no-load, but the output sine wave is distorted after loading.
I try to adjust the parameters of PI control loop - ki, KP, but the output sine wave distortion shows little improvement.
Originally, I wanted to get the control parameters of PCB board suitable for me through SFRA, but I didn't know how to proceed.
Thank you again for your attention!
Best regards!
