Other Parts Discussed in Thread: LM2904B, , LM2904
HI
TIDA-010074
HI
TIDA-010074
Hi Daniel
Thanks for your reply.
Hi Star,
I've taken a further look at the problem and think I now understand your question.
If you go to the page for the TID and scroll down a bit, you will get to a place where you can download the schematic. Here is the relevant portion of the design.
So the V- supply of the op amp is not directly connected to ground. However, I do not know exactly what the operating voltage of the node will be. It will depend on the operating conditions which will determine the voltage across the drain-source. I'm not sure what is going on across Q20 either. It almost looks like they tried to diode connect the transistor.
Unfortunately, there are no TINA sim files already built. If you look in the bottom right of the schematic, you can see the name of the engineer that designed, or at least put into Altium, this project. I recommend you email him directly to confirm. I do think that you are right, however, that the supply voltage will be too high if the supplies are Vbat and GND.
Please let me know if you need any further help.
Daniel
