in this reference design GND and EARTH is coupled with a 1M and a 4700 pF capacitor near the magnetic.
Could you please explain the reason why?
The documentation says: 'Additional capacitors are required to interconnect chassis ground and signal ground. The suggested technique is to use plane coupling capacitor values (for example, from 1000 pF to 4700 pF).
Depending on available board space, place one set of capacitors on each side of the Ethernet magnetic"
It's unclear to me why this coupling is necessary.
Best regards
Holger
