I'm prototyping a PCB using the TLV75733P voltage regulator, OPA1656 Burr-Brown Op-Amp, and DRV135 Balanced Line Driver, and I would like to run a simulation of the circuit in Autodesk EAGLE using a SPICE model. Do you have EAGLE SPICE model for these ICs?
Hi Shashaank,
You are able to find OPA1656 and DRV135 PSpice compatible models below. We do not use Autodesk Eagle Spice Model, however they should be compatible, if you import PSpice model into the tools.
https://www.ti.com/product/OPA1656#design-development
https://www.ti.com/product/DRV135
TI has better and free TINA simulation tools to do the simulation, see the attached link below. We are using the tool to support our customer daily. You will find existing reference schematics in the link above.
http://www.ti.com/tool/TINA-TIT
What is RO to LP-LDO for the mto address?
TLV75733P is a linear LDO regulator, and you will be able to find its PSpice model below.
https://www.ti.com/product/TLV757P#design-development
Raymond
