Other Parts Discussed in Thread: TPS63802, , PMP30528
The PMP30693 design uses a very clever technique of charging the backup supercapacitor with TPS63802 running in reverse mode. Maximum output voltage of TPS63802 is 5.2V. If an application calls for higher output voltage, namely 12V, would it be a matter of picking any buck-boost converter able to run in reverse mode? Thanks.
Tim
