CCS/TIDA-010024: Unable to upgrade original project to CC1352R (LaunchXL-CC1352R1)
Prodigy 10 points
Part Number: TIDA-010024
Dear sirs,
I followed TIDA-010024 guidelines on page 11 (below) to upgrade from CC1312R device to CC1352R device, but I could not get the App to work. CCS compilation presents some errors that I do not understand.
  1. Import CC1352R TI-15.4 sensor example from SimpleLinkTM CC13x2 and CC26x2 SDK v2.40
  2. Rename CCS project with your project
  3. Copy and paste the entire directories of 6lowpan, Application and dtls into the project directory of the CC1352R TI-15.4 sensor example
  4. Overwrite app.cfg, cc13x2lp.cmd and ccfg.c
  5. Create build configurations and update the CCS property (Predefined symbols and Include options) based on the CC1312R-based 6LoWPAN mesh example project
The compiler and SDK are identical to TIDA-010024 reference. The original project cannot be built with new versions of SDK or compilers without errors also, so I kept the original ones. I appended an "F" to target string "ti.targets.arm.elf.M4" to get "ti.targets.arm.elf.M4F" since Sensor example in the corresponding  SDK does not have it.
I exported all include paths and symbols to files and imported them in the new CC1352R project. I also erased the original symbols and include paths from the original TIDA-010024 for CC1312 project and reimported from the files exported previously to make sure that it would be the same as those in the new CC1352R project. The project for CC1312 continued to compile without any errors as in the original version.
I checked at least most of the myriad of configuration parameters of CCS  projects and could not find any difference between the projects unless the CPU selection.
I do not know what to do to solve the problem. It is not a program error since the sources and parameters are the same. Maybe there is a define detour somewhere that is causing the compilation errors.
Them I am asking some clues to help me put the App running on the CC1352R device. I have various LaunchXL and LPSTK for CC1352R and no CC1312R boards.
I also have another question: is the App/circuit compatible to exchange information with another Wi_SUN FAN 1.0 certificated device from another vendor, adjusting both to the same security certificate and mandatory 50kbps data rate? I am working in a project where the Texas devices would be much more adequate for  the leaf devices than the ones from another vendor. The routers probably would be from the other vendor for some special reasons. The TI devices are superb as leaf devices and if possible I would like to include them using Wi-SUN protocol. As a second option, some end devices would need to be used in a TI proprietary protocol. But this option should be approved by other people in the team and is more difficult to get approved.
The result of compilation of the new project with errors detected follows:
An asterisc filled line was inserted at beggining and end to delimit the compiler output log!
The result of compilation of the original project comes after.
**** Build of configuration debug_push_leaf for project WiSUN_Device ****
/Applications/ti/ccs/utils/bin/gmake -k -j 7 all -O
Building file: "../app.cfg"
Invoking: XDCtools
"/Applications/ti/xdctools_3_51_01_18_core/xs" --xdcpath="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source;/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/kernel/tirtos/packages;" xdc.tools.configuro -o configPkg -t ti.targets.arm.elf.M4F -p ti.platforms.simplelink:CC1352R1F3 -r release -c "/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS" --compileOptions "-mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path=\"/Users/maurelio/WS_CCS/WiSUN_Device\" --include_path=\"/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan\" --include_path=\"/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config\" --include_path=\"/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp\" --include_path=\"/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip\" --include_path=\"/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc\" --include_path=\"/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf\" --include_path=\"/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios\" --include_path=\"/Users/maurelio/WS_CCS/WiSUN_Device/Application\" --include_path=\"/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services\" --include_path=\"/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad\" --include_path=\"/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common\" --include_path=\"/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target\" --include_path=\"/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel\" --include_path=\"/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel\" --include_path=\"/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg\" --include_path=\"../\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs\" --include_path=\"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include\" --include_path=\"/Users/maurelio/WS_CCS/WiSUN_Device\" --include_path=\"/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan\" --include_path=\"/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config\" --include_path=\"/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp\" --include_path=\"/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip\" --include_path=\"/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc\" --include_path=\"/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf\" --include_path=\"/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios\" --include_path=\"/Users/maurelio/WS_CCS/WiSUN_Device/Application\" --include_path=\"/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services\" --include_path=\"/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad\" --include_path=\"/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common\" --include_path=\"/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target\" --include_path=\"/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel\" --include_path=\"/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel\" --include_path=\"/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv\" --include_path=\"/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs\" --include_path=\"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include\" --preinclude=\"/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h\" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off  " "../app.cfg"
making package.mak (because of package.bld) ...
generating interfaces for package configPkg (because package/package.xdc.inc is older than package.xdc) ...
configuring app.xem4f from package/cfg/app_pem4f.cfg ...
generating custom ROM library makefile ...
Starting build of library sources ...
making /Users/maurelio/WS_CCS/WiSUN_Device/src/sysbios/rom_sysbios.aem4f ...
clem4f /Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/kernel/tirtos/packages/ti/sysbios/BIOS.c ...
asmem4f /Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/kernel/tirtos/packages/ti/sysbios/family/arm/m3/Hwi_asm.sv7M ...
asmem4f /Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/kernel/tirtos/packages/ti/sysbios/family/arm/m3/Hwi_asm_switch.sv7M ...
asmem4f /Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/kernel/tirtos/packages/ti/sysbios/family/arm/m3/IntrinsicsSupport_asm.sv7M ...
asmem4f /Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/kernel/tirtos/packages/ti/sysbios/family/arm/m3/TaskSupport_asm.sv7M ...
arem4f rom_sysbios.obj m3_Hwi_asm.obj m3_Hwi_asm_switch.obj m3_IntrinsicsSupport_asm.obj m3_TaskSupport_asm.obj ...
Build of libraries done.
clem4f package/cfg/app_pem4f.c ...
Finished building: "../app.cfg"
making ../src/sysbios/rom_sysbios.aem4f ...
gmake[1]: Nothing to be done for 'all'.
Building file: "../ccfg.c"
Invoking: ARM Compiler
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="ccfg.d_raw" --cmd_file="configPkg/compiler.opt"  "../ccfg.c"
Finished building: "../ccfg.c"
Building file: "../6lowpan/app_task_node_demo.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/app_task_node_demo.d_raw" --obj_directory="6lowpan" --cmd_file="configPkg/compiler.opt"  "../6lowpan/app_task_node_demo.c"
>> Compilation failure
6lowpan/subdir_rules.mk:7: recipe for target '6lowpan/app_task_node_demo.obj' failed
"../6lowpan/app_task_node_demo.c", line 112: error #20: identifier "SampleMsg_t" is undefined
"../6lowpan/app_task_node_demo.c", line 595: error #20: identifier "SampleMsg_t" is undefined
"../6lowpan/app_task_node_demo.c", line 598: error #167: too few arguments in function call
"../6lowpan/app_task_node_demo.c", line 618: error #20: identifier "SampleMsg_t" is undefined
"../6lowpan/app_task_node_demo.c", line 733: error #20: identifier "pudp_msg" is undefined
5 errors detected in the compilation of "../6lowpan/app_task_node_demo.c".
gmake: *** [6lowpan/app_task_node_demo.obj] Error 1
Building file: "../CC1352R1_LAUNCHXL_fxns.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="CC1352R1_LAUNCHXL_fxns.d_raw" --cmd_file="configPkg/compiler.opt"  "../CC1352R1_LAUNCHXL_fxns.c"
Finished building: "../CC1352R1_LAUNCHXL_fxns.c"
Building file: "../6lowpan/config/ulpsmacaddr.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/config/ulpsmacaddr.d_raw" --obj_directory="6lowpan/config" --cmd_file="configPkg/compiler.opt"  "../6lowpan/config/ulpsmacaddr.c"
Finished building: "../6lowpan/config/ulpsmacaddr.c"
Building file: "../6lowpan/dtls/aes/rijndael.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/dtls/aes/rijndael.d_raw" --obj_directory="6lowpan/dtls/aes" --cmd_file="configPkg/compiler.opt"  "../6lowpan/dtls/aes/rijndael.c"
Finished building: "../6lowpan/dtls/aes/rijndael.c"
Building file: "../6lowpan/config/bm_api.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/config/bm_api.d_raw" --obj_directory="6lowpan/config" --cmd_file="configPkg/compiler.opt"  "../6lowpan/config/bm_api.c"
Finished building: "../6lowpan/config/bm_api.c"
Building file: "../CC1352R1_LAUNCHXL.c"
Invoking: ARM Compiler
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="CC1352R1_LAUNCHXL.d_raw" --cmd_file="configPkg/compiler.opt"  "../CC1352R1_LAUNCHXL.c"
Finished building: "../CC1352R1_LAUNCHXL.c"
Building file: "../6lowpan/app_task_root.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/app_task_root.d_raw" --obj_directory="6lowpan" --cmd_file="configPkg/compiler.opt"  "../6lowpan/app_task_root.c"
Finished building: "../6lowpan/app_task_root.c"
Building file: "../6lowpan/app_task_node.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/app_task_node.d_raw" --obj_directory="6lowpan" --cmd_file="configPkg/compiler.opt"  "../6lowpan/app_task_node.c"
Finished building: "../6lowpan/app_task_node.c"
Building file: "../6lowpan/uip_rpl_task.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/uip_rpl_task.d_raw" --obj_directory="6lowpan" --cmd_file="configPkg/compiler.opt"  "../6lowpan/uip_rpl_task.c"
Finished building: "../6lowpan/uip_rpl_task.c"
Building file: "../6lowpan/dtls/debug.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/dtls/debug.d_raw" --obj_directory="6lowpan/dtls" --cmd_file="configPkg/compiler.opt"  "../6lowpan/dtls/debug.c"
>> Compilation failure
6lowpan/dtls/subdir_rules.mk:7: recipe for target '6lowpan/dtls/debug.obj' failed
"../6lowpan/dtls/debug.c", line 66: error #249: function "dtls_get_log_level" has already been defined
"../6lowpan/dtls/debug.c", line 67: warning #190-D: enumerated type mixed with another type
"../6lowpan/dtls/debug.c", line 71: error #249: function "dtls_set_log_level" has already been defined
"../6lowpan/dtls/debug.c", line 210: warning #112-D: statement is unreachable
"../6lowpan/dtls/debug.c", line 217: error #249: function "dsrv_log" has already been defined
"../6lowpan/dtls/debug.c", line 76: warning #179-D: variable "loglevels" was declared but never referenced
"../6lowpan/dtls/debug.c", line 114: warning #179-D: function "dtls_strnlen" was declared but never referenced
"../6lowpan/dtls/debug.c", line 126: warning #179-D: function "dsrv_print_addr" was declared but never referenced
3 errors detected in the compilation of "../6lowpan/dtls/debug.c".
gmake: *** [6lowpan/dtls/debug.obj] Error 1
Building file: "../6lowpan/dtls/ccm.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/dtls/ccm.d_raw" --obj_directory="6lowpan/dtls" --cmd_file="configPkg/compiler.opt"  "../6lowpan/dtls/ccm.c"
Finished building: "../6lowpan/dtls/ccm.c"
Building file: "../6lowpan/dtls/dtls_time.c"
Invoking: ARM Compiler
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/dtls/dtls_time.d_raw" --obj_directory="6lowpan/dtls" --cmd_file="configPkg/compiler.opt"  "../6lowpan/dtls/dtls_time.c"
Finished building: "../6lowpan/dtls/dtls_time.c"
Building file: "../6lowpan/dtls/hmac.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/dtls/hmac.d_raw" --obj_directory="6lowpan/dtls" --cmd_file="configPkg/compiler.opt"  "../6lowpan/dtls/hmac.c"
Finished building: "../6lowpan/dtls/hmac.c"
Building file: "../6lowpan/dtls/config/bsp_aes.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/dtls/config/bsp_aes.d_raw" --obj_directory="6lowpan/dtls/config" --cmd_file="configPkg/compiler.opt"  "../6lowpan/dtls/config/bsp_aes.c"
Finished building: "../6lowpan/dtls/config/bsp_aes.c"
Building file: "../6lowpan/dtls/peer.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/dtls/peer.d_raw" --obj_directory="6lowpan/dtls" --cmd_file="configPkg/compiler.opt"  "../6lowpan/dtls/peer.c"
"../6lowpan/dtls/peer.c", line 92: warning #169-D: argument of type "const session_t *" is incompatible with parameter of type "const struct __session_t *"
Finished building: "../6lowpan/dtls/peer.c"
Building file: "../6lowpan/dtls/netq.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/dtls/netq.d_raw" --obj_directory="6lowpan/dtls" --cmd_file="configPkg/compiler.opt"  "../6lowpan/dtls/netq.c"
Finished building: "../6lowpan/dtls/netq.c"
Building file: "../6lowpan/dtls/crypto.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/dtls/crypto.d_raw" --obj_directory="6lowpan/dtls" --cmd_file="configPkg/compiler.opt"  "../6lowpan/dtls/crypto.c"
Finished building: "../6lowpan/dtls/crypto.c"
Building file: "../6lowpan/uip/lib/list.c"
Invoking: ARM Compiler
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/uip/lib/list.d_raw" --obj_directory="6lowpan/uip/lib" --cmd_file="configPkg/compiler.opt"  "../6lowpan/uip/lib/list.c"
Finished building: "../6lowpan/uip/lib/list.c"
Building file: "../6lowpan/dtls/session.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/dtls/session.d_raw" --obj_directory="6lowpan/dtls" --cmd_file="configPkg/compiler.opt"  "../6lowpan/dtls/session.c"
Finished building: "../6lowpan/dtls/session.c"
Building file: "../6lowpan/uip/lib/random.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/uip/lib/random.d_raw" --obj_directory="6lowpan/uip/lib" --cmd_file="configPkg/compiler.opt"  "../6lowpan/uip/lib/random.c"
Finished building: "../6lowpan/uip/lib/random.c"
Building file: "../6lowpan/dtls/ecc/ecc.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/dtls/ecc/ecc.d_raw" --obj_directory="6lowpan/dtls/ecc" --cmd_file="configPkg/compiler.opt"  "../6lowpan/dtls/ecc/ecc.c"
Finished building: "../6lowpan/dtls/ecc/ecc.c"
Building file: "../6lowpan/dtls/sha2/sha2.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/dtls/sha2/sha2.d_raw" --obj_directory="6lowpan/dtls/sha2" --cmd_file="configPkg/compiler.opt"  "../6lowpan/dtls/sha2/sha2.c"
"../6lowpan/dtls/sha2/sha2.c", line 377: warning #179-D: variable "sha2_hex_digits" was declared but never referenced
Finished building: "../6lowpan/dtls/sha2/sha2.c"
Building file: "../6lowpan/uip/lib/memb.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/uip/lib/memb.d_raw" --obj_directory="6lowpan/uip/lib" --cmd_file="configPkg/compiler.opt"  "../6lowpan/uip/lib/memb.c"
Finished building: "../6lowpan/uip/lib/memb.c"
Building file: "../6lowpan/simple-udp/simple_udp_meters.c"
Invoking: ARM Compiler
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/simple-udp/simple_udp_meters.d_raw" --obj_directory="6lowpan/simple-udp" --cmd_file="configPkg/compiler.opt"  "../6lowpan/simple-udp/simple_udp_meters.c"
Finished building: "../6lowpan/simple-udp/simple_udp_meters.c"
Building file: "../6lowpan/uip/net/nbr_table.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/uip/net/nbr_table.d_raw" --obj_directory="6lowpan/uip/net" --cmd_file="configPkg/compiler.opt"  "../6lowpan/uip/net/nbr_table.c"
Finished building: "../6lowpan/uip/net/nbr_table.c"
Building file: "../6lowpan/uip/net/uip-fw.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/uip/net/uip-fw.d_raw" --obj_directory="6lowpan/uip/net" --cmd_file="configPkg/compiler.opt"  "../6lowpan/uip/net/uip-fw.c"
Finished building: "../6lowpan/uip/net/uip-fw.c"
Building file: "../6lowpan/uip/net/queuebuf.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/uip/net/queuebuf.d_raw" --obj_directory="6lowpan/uip/net" --cmd_file="configPkg/compiler.opt"  "../6lowpan/uip/net/queuebuf.c"
Finished building: "../6lowpan/uip/net/queuebuf.c"
Building file: "../6lowpan/uip/net/packetbuf.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/uip/net/packetbuf.d_raw" --obj_directory="6lowpan/uip/net" --cmd_file="configPkg/compiler.opt"  "../6lowpan/uip/net/packetbuf.c"
Finished building: "../6lowpan/uip/net/packetbuf.c"
Building file: "../6lowpan/uip/net/udp_simple_socket.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/uip/net/udp_simple_socket.d_raw" --obj_directory="6lowpan/uip/net" --cmd_file="configPkg/compiler.opt"  "../6lowpan/uip/net/udp_simple_socket.c"
Finished building: "../6lowpan/uip/net/udp_simple_socket.c"
Building file: "../6lowpan/uip/net/tcpip.c"
Invoking: ARM Compiler
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/uip/net/tcpip.d_raw" --obj_directory="6lowpan/uip/net" --cmd_file="configPkg/compiler.opt"  "../6lowpan/uip/net/tcpip.c"
Finished building: "../6lowpan/uip/net/tcpip.c"
Building file: "../6lowpan/uip/net/uip_debug.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/uip/net/uip_debug.d_raw" --obj_directory="6lowpan/uip/net" --cmd_file="configPkg/compiler.opt"  "../6lowpan/uip/net/uip_debug.c"
Finished building: "../6lowpan/uip/net/uip_debug.c"
Building file: "../6lowpan/uip/net/uip_ds6.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/uip/net/uip_ds6.d_raw" --obj_directory="6lowpan/uip/net" --cmd_file="configPkg/compiler.opt"  "../6lowpan/uip/net/uip_ds6.c"
Finished building: "../6lowpan/uip/net/uip_ds6.c"
Building file: "../6lowpan/dtls/dtls.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/dtls/dtls.d_raw" --obj_directory="6lowpan/dtls" --cmd_file="configPkg/compiler.opt"  "../6lowpan/dtls/dtls.c"
"../6lowpan/dtls/dtls.c", line 1810: warning #169-D: argument of type "session_t *" is incompatible with parameter of type "const struct __session_t *"
"../6lowpan/dtls/dtls.c", line 4350: warning #169-D: argument of type "session_t *" is incompatible with parameter of type "const struct __session_t *"
Finished building: "../6lowpan/dtls/dtls.c"
Building file: "../6lowpan/uip/net/uip_ds6_nbr.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/uip/net/uip_ds6_nbr.d_raw" --obj_directory="6lowpan/uip/net" --cmd_file="configPkg/compiler.opt"  "../6lowpan/uip/net/uip_ds6_nbr.c"
Finished building: "../6lowpan/uip/net/uip_ds6_nbr.c"
Building file: "../6lowpan/uip/net/uip_ds6_route.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/uip/net/uip_ds6_route.d_raw" --obj_directory="6lowpan/uip/net" --cmd_file="configPkg/compiler.opt"  "../6lowpan/uip/net/uip_ds6_route.c"
Finished building: "../6lowpan/uip/net/uip_ds6_route.c"
Building file: "../6lowpan/uip/net/sicslowpan.c"
Invoking: ARM Compiler
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/uip/net/sicslowpan.d_raw" --obj_directory="6lowpan/uip/net" --cmd_file="configPkg/compiler.opt"  "../6lowpan/uip/net/sicslowpan.c"
Finished building: "../6lowpan/uip/net/sicslowpan.c"
Building file: "../6lowpan/uip/net/uip6.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/uip/net/uip6.d_raw" --obj_directory="6lowpan/uip/net" --cmd_file="configPkg/compiler.opt"  "../6lowpan/uip/net/uip6.c"
Finished building: "../6lowpan/uip/net/uip6.c"
Building file: "../6lowpan/uip/net/uip_icmp6.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/uip/net/uip_icmp6.d_raw" --obj_directory="6lowpan/uip/net" --cmd_file="configPkg/compiler.opt"  "../6lowpan/uip/net/uip_icmp6.c"
Finished building: "../6lowpan/uip/net/uip_icmp6.c"
Building file: "../6lowpan/uip/net/uip_packetqueue.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/uip/net/uip_packetqueue.d_raw" --obj_directory="6lowpan/uip/net" --cmd_file="configPkg/compiler.opt"  "../6lowpan/uip/net/uip_packetqueue.c"
Finished building: "../6lowpan/uip/net/uip_packetqueue.c"
Building file: "../6lowpan/uip/net/uip_split.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/uip/net/uip_split.d_raw" --obj_directory="6lowpan/uip/net" --cmd_file="configPkg/compiler.opt"  "../6lowpan/uip/net/uip_split.c"
Finished building: "../6lowpan/uip/net/uip_split.c"
Building file: "../6lowpan/uip/net/uip_udp_packet.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/uip/net/uip_udp_packet.d_raw" --obj_directory="6lowpan/uip/net" --cmd_file="configPkg/compiler.opt"  "../6lowpan/uip/net/uip_udp_packet.c"
Finished building: "../6lowpan/uip/net/uip_udp_packet.c"
Building file: "../6lowpan/uip/pltfrm/sysbios/pltfrm_lib.c"
Invoking: ARM Compiler
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/uip/pltfrm/sysbios/pltfrm_lib.d_raw" --obj_directory="6lowpan/uip/pltfrm/sysbios" --cmd_file="configPkg/compiler.opt"  "../6lowpan/uip/pltfrm/sysbios/pltfrm_lib.c"
Finished building: "../6lowpan/uip/pltfrm/sysbios/pltfrm_lib.c"
Building file: "../6lowpan/uip/rime/rimeaddr.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/uip/rime/rimeaddr.d_raw" --obj_directory="6lowpan/uip/rime" --cmd_file="configPkg/compiler.opt"  "../6lowpan/uip/rime/rimeaddr.c"
Finished building: "../6lowpan/uip/rime/rimeaddr.c"
Building file: "../6lowpan/uip/net/uip_nd6.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/uip/net/uip_nd6.d_raw" --obj_directory="6lowpan/uip/net" --cmd_file="configPkg/compiler.opt"  "../6lowpan/uip/net/uip_nd6.c"
Finished building: "../6lowpan/uip/net/uip_nd6.c"
Building file: "../6lowpan/uip/rpl/rpl-plusplus.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/uip/rpl/rpl-plusplus.d_raw" --obj_directory="6lowpan/uip/rpl" --cmd_file="configPkg/compiler.opt"  "../6lowpan/uip/rpl/rpl-plusplus.c"
Finished building: "../6lowpan/uip/rpl/rpl-plusplus.c"
Building file: "../6lowpan/uip/rpl/rpl-timers.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/uip/rpl/rpl-timers.d_raw" --obj_directory="6lowpan/uip/rpl" --cmd_file="configPkg/compiler.opt"  "../6lowpan/uip/rpl/rpl-timers.c"
Finished building: "../6lowpan/uip/rpl/rpl-timers.c"
Building file: "../6lowpan/uip/rpl/rpl.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/uip/rpl/rpl.d_raw" --obj_directory="6lowpan/uip/rpl" --cmd_file="configPkg/compiler.opt"  "../6lowpan/uip/rpl/rpl.c"
Finished building: "../6lowpan/uip/rpl/rpl.c"
Building file: "../6lowpan/uip/rpl/rpl_ext_header.c"
Invoking: ARM Compiler
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/uip/rpl/rpl_ext_header.d_raw" --obj_directory="6lowpan/uip/rpl" --cmd_file="configPkg/compiler.opt"  "../6lowpan/uip/rpl/rpl_ext_header.c"
Finished building: "../6lowpan/uip/rpl/rpl_ext_header.c"
Building file: "../6lowpan/uip/rpl/rpl_mrhof.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/uip/rpl/rpl_mrhof.d_raw" --obj_directory="6lowpan/uip/rpl" --cmd_file="configPkg/compiler.opt"  "../6lowpan/uip/rpl/rpl_mrhof.c"
Finished building: "../6lowpan/uip/rpl/rpl_mrhof.c"
Building file: "../6lowpan/uip/rpl/rpl_of0.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/uip/rpl/rpl_of0.d_raw" --obj_directory="6lowpan/uip/rpl" --cmd_file="configPkg/compiler.opt"  "../6lowpan/uip/rpl/rpl_of0.c"
Finished building: "../6lowpan/uip/rpl/rpl_of0.c"
Building file: "../6lowpan/uip/rpl/rpl_routing_header.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/uip/rpl/rpl_routing_header.d_raw" --obj_directory="6lowpan/uip/rpl" --cmd_file="configPkg/compiler.opt"  "../6lowpan/uip/rpl/rpl_routing_header.c"
Finished building: "../6lowpan/uip/rpl/rpl_routing_header.c"
Building file: "../6lowpan/uip/sys/clock.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/uip/sys/clock.d_raw" --obj_directory="6lowpan/uip/sys" --cmd_file="configPkg/compiler.opt"  "../6lowpan/uip/sys/clock.c"
Finished building: "../6lowpan/uip/sys/clock.c"
Building file: "../6lowpan/uip/sys/ctimer.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/uip/sys/ctimer.d_raw" --obj_directory="6lowpan/uip/sys" --cmd_file="configPkg/compiler.opt"  "../6lowpan/uip/sys/ctimer.c"
Finished building: "../6lowpan/uip/sys/ctimer.c"
Building file: "../6lowpan/uip/rpl/rpl_icmp6.c"
Invoking: ARM Compiler
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/uip/rpl/rpl_icmp6.d_raw" --obj_directory="6lowpan/uip/rpl" --cmd_file="configPkg/compiler.opt"  "../6lowpan/uip/rpl/rpl_icmp6.c"
Finished building: "../6lowpan/uip/rpl/rpl_icmp6.c"
Building file: "../Application/ICALL/icall_cc2650.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="Application/ICALL/icall_cc2650.d_raw" --obj_directory="Application/ICALL" --cmd_file="configPkg/compiler.opt"  "../Application/ICALL/icall_cc2650.c"
Finished building: "../Application/ICALL/icall_cc2650.c"
Building file: "../6lowpan/uip/sys/etimer.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/uip/sys/etimer.d_raw" --obj_directory="6lowpan/uip/sys" --cmd_file="configPkg/compiler.opt"  "../6lowpan/uip/sys/etimer.c"
Finished building: "../6lowpan/uip/sys/etimer.c"
Building file: "../6lowpan/uip/sys/net_timer.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/uip/sys/net_timer.d_raw" --obj_directory="6lowpan/uip/sys" --cmd_file="configPkg/compiler.opt"  "../6lowpan/uip/sys/net_timer.c"
Finished building: "../6lowpan/uip/sys/net_timer.c"
Building file: "../6lowpan/uip/sys/stimer.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/uip/sys/stimer.d_raw" --obj_directory="6lowpan/uip/sys" --cmd_file="configPkg/compiler.opt"  "../6lowpan/uip/sys/stimer.c"
Finished building: "../6lowpan/uip/sys/stimer.c"
Building file: "../Application/ICALL/icall_lite_translation.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="Application/ICALL/icall_lite_translation.d_raw" --obj_directory="Application/ICALL" --cmd_file="configPkg/compiler.opt"  "../Application/ICALL/icall_lite_translation.c"
Finished building: "../Application/ICALL/icall_lite_translation.c"
Building file: "../6lowpan/uip/rpl/rpl_dag.c"
Invoking: ARM Compiler
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/uip/rpl/rpl_dag.d_raw" --obj_directory="6lowpan/uip/rpl" --cmd_file="configPkg/compiler.opt"  "../6lowpan/uip/rpl/rpl_dag.c"
Finished building: "../6lowpan/uip/rpl/rpl_dag.c"
Building file: "../Application/MAC/HAL/common/hal_appasrt.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="Application/MAC/HAL/common/hal_appasrt.d_raw" --obj_directory="Application/MAC/HAL/common" --cmd_file="configPkg/compiler.opt"  "../Application/MAC/HAL/common/hal_appasrt.c"
Finished building: "../Application/MAC/HAL/common/hal_appasrt.c"
Building file: "../6lowpan/uip/uip_rpl_impl/uip_rpl_attributes.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="6lowpan/uip/uip_rpl_impl/uip_rpl_attributes.d_raw" --obj_directory="6lowpan/uip/uip_rpl_impl" --cmd_file="configPkg/compiler.opt"  "../6lowpan/uip/uip_rpl_impl/uip_rpl_attributes.c"
Finished building: "../6lowpan/uip/uip_rpl_impl/uip_rpl_attributes.c"
Building file: "../Application/LaunchPad/board_lcd.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="Application/LaunchPad/board_lcd.d_raw" --obj_directory="Application/LaunchPad" --cmd_file="configPkg/compiler.opt"  "../Application/LaunchPad/board_lcd.c"
Finished building: "../Application/LaunchPad/board_lcd.c"
Building file: "../Application/LaunchPad/board_key.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="Application/LaunchPad/board_key.d_raw" --obj_directory="Application/LaunchPad" --cmd_file="configPkg/compiler.opt"  "../Application/LaunchPad/board_key.c"
Finished building: "../Application/LaunchPad/board_key.c"
Building file: "../Application/LaunchPad/board_gpio.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="Application/LaunchPad/board_gpio.d_raw" --obj_directory="Application/LaunchPad" --cmd_file="configPkg/compiler.opt"  "../Application/LaunchPad/board_gpio.c"
Finished building: "../Application/LaunchPad/board_gpio.c"
Building file: "../Application/MAC/HAL/target/hal_aes.c"
Invoking: ARM Compiler
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="Application/MAC/HAL/target/hal_aes.d_raw" --obj_directory="Application/MAC/HAL/target" --cmd_file="configPkg/compiler.opt"  "../Application/MAC/HAL/target/hal_aes.c"
Finished building: "../Application/MAC/HAL/target/hal_aes.c"
Building file: "../Application/LaunchPad/board_led.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="Application/LaunchPad/board_led.d_raw" --obj_directory="Application/LaunchPad" --cmd_file="configPkg/compiler.opt"  "../Application/LaunchPad/board_led.c"
Finished building: "../Application/LaunchPad/board_led.c"
Building file: "../Application/MAC/HAL/target/hal_trng_wrapper.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="Application/MAC/HAL/target/hal_trng_wrapper.d_raw" --obj_directory="Application/MAC/HAL/target" --cmd_file="configPkg/compiler.opt"  "../Application/MAC/HAL/target/hal_trng_wrapper.c"
Finished building: "../Application/MAC/HAL/target/hal_trng_wrapper.c"
Building file: "../Application/MAC/HAL/target/hal_ccm.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="Application/MAC/HAL/target/hal_ccm.d_raw" --obj_directory="Application/MAC/HAL/target" --cmd_file="configPkg/compiler.opt"  "../Application/MAC/HAL/target/hal_ccm.c"
Finished building: "../Application/MAC/HAL/target/hal_ccm.c"
Building file: "../Application/MAC/HAL/target/hal_flash_wrapper.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="Application/MAC/HAL/target/hal_flash_wrapper.d_raw" --obj_directory="Application/MAC/HAL/target" --cmd_file="configPkg/compiler.opt"  "../Application/MAC/HAL/target/hal_flash_wrapper.c"
Finished building: "../Application/MAC/HAL/target/hal_flash_wrapper.c"
Building file: "../Application/MAC/HAL/target/pwrmon.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="Application/MAC/HAL/target/pwrmon.d_raw" --obj_directory="Application/MAC/HAL/target" --cmd_file="configPkg/compiler.opt"  "../Application/MAC/HAL/target/pwrmon.c"
Finished building: "../Application/MAC/HAL/target/pwrmon.c"
Building file: "../Application/MAC/HAL/target/dbg.c"
Invoking: ARM Compiler
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="Application/MAC/HAL/target/dbg.d_raw" --obj_directory="Application/MAC/HAL/target" --cmd_file="configPkg/compiler.opt"  "../Application/MAC/HAL/target/dbg.c"
Finished building: "../Application/MAC/HAL/target/dbg.c"
Building file: "../Application/MAC/LowLevel/mac_settings.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="Application/MAC/LowLevel/mac_settings.d_raw" --obj_directory="Application/MAC/LowLevel" --cmd_file="configPkg/compiler.opt"  "../Application/MAC/LowLevel/mac_settings.c"
Finished building: "../Application/MAC/LowLevel/mac_settings.c"
Building file: "../Application/MAC/OSAL/osal_bufmgr.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="Application/MAC/OSAL/osal_bufmgr.d_raw" --obj_directory="Application/MAC/OSAL" --cmd_file="configPkg/compiler.opt"  "../Application/MAC/OSAL/osal_bufmgr.c"
Finished building: "../Application/MAC/OSAL/osal_bufmgr.c"
Building file: "../Application/MAC/OSAL/osal_memory_icall.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="Application/MAC/OSAL/osal_memory_icall.d_raw" --obj_directory="Application/MAC/OSAL" --cmd_file="configPkg/compiler.opt"  "../Application/MAC/OSAL/osal_memory_icall.c"
Finished building: "../Application/MAC/OSAL/osal_memory_icall.c"
Building file: "../Application/MAC/HighLevel/mac_cfg.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="Application/MAC/HighLevel/mac_cfg.d_raw" --obj_directory="Application/MAC/HighLevel" --cmd_file="configPkg/compiler.opt"  "../Application/MAC/HighLevel/mac_cfg.c"
Finished building: "../Application/MAC/HighLevel/mac_cfg.c"
Building file: "../Application/Services/crc.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="Application/Services/crc.d_raw" --obj_directory="Application/Services" --cmd_file="configPkg/compiler.opt"  "../Application/Services/crc.c"
Finished building: "../Application/Services/crc.c"
Building file: "../Application/MAC/HAL/target/hal_rtc_wrapper.c"
Invoking: ARM Compiler
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="Application/MAC/HAL/target/hal_rtc_wrapper.d_raw" --obj_directory="Application/MAC/HAL/target" --cmd_file="configPkg/compiler.opt"  "../Application/MAC/HAL/target/hal_rtc_wrapper.c"
Finished building: "../Application/MAC/HAL/target/hal_rtc_wrapper.c"
Building file: "../Application/MAC/OSAL/osal_clock.c"
"/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/bin/armcl" --cmd_file="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Defines/sensor.opts"  -mv7M4 --code_state=16 --float_support=FPv4SPD16 -me -O4 --opt_for_speed=0 --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="../" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/config" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/simple-udp" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/inc" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/conf" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/6lowpan/uip/pltfrm/sysbios" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/Services" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/LaunchPad" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/common" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HAL/target" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/HighLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/MAC/LowLevel" --include_path="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/api/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/icall/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src/icall" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/tirtos/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/stack/src" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/heapmgr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/boards/subg" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/util" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/common/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/hal/src/target/_common/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/osal/src/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/aes" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/appasrt" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/saddr" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/services/src/sdata" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/fh" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/high_level" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/rom" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/inc/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/tracer" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/low_level/cc13xx/combo" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/apps/sensor" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/inc" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/devices/cc13x2_cc26x2/driverlib" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/ti154stack/source/common/nv" --include_path="/Applications/ti/simplelink_cc13x2_26x2_sdk_2_40_00_81/source/ti/posix/ccs" --include_path="/Applications/ti/ccs/tools/compiler/ti-cgt-arm_18.1.1.LTS/include" --preinclude="/Users/maurelio/WS_CCS/WiSUN_Device/Application/subg/features.h" --define=Board_EXCLUDE_NVS_EXTERNAL_FLASH --define=DeviceFamily_CC13X2 --define=SET_CCFG_BL_CONFIG_BL_LEVEL=0x00 --define=SET_CCFG_BL_CONFIG_BL_ENABLE=0xC5 --define=SET_CCFG_BL_CONFIG_BL_PIN_NUMBER=0x0F --define=SET_CCFG_BL_CONFIG_BOOTLOADER_ENABLE=0xC5 --define=UIP_SMARTNET --define=FEATURE_DTLS=0 --define=xDTLS_WITH_TIRTOS --define=xWITH_SHA256 --define=POLL_APP=0 --define=IS_ROOT=0 --define=IS_INTERMEDIATE=0 --define=UIP_CONF_TCP=0 --define=TI_MAC_USE_MAC64 --define=xFH_KEEP_ALIVE --define=MW_DEBUG --define=TCPIP_FULL_DEBUG -g --c99 --plain_char=unsigned --diag_warning=225 --diag_warning=255 --diag_wrap=off --display_error_number --gen_func_subsections=on --embedded_constants=on --unaligned_access=on --enum_type=packed --wchar_t=16 --common=on --fp_reassoc=off --sat_reassoc=off --preproc_with_compile --preproc_dependency="Application/MAC/OSAL/osal_clock.d_raw" --obj_directory="Application/MAC/OSAL" --cmd_file="configPkg/compiler.opt"  "../Application/MAC/OSAL/osal_clock.c"
Finished building: "../Application/MAC/OSAL/osal_clock.c"
Building file: "../Application/MAC/OSAL/osal_pwrmgr.c"
