When I try to install PSpice for TI 2020 I get the following error:
What does this mean? How do I set-up a HOME variable?
Viktor.
Viktor.
The Image didn't appear in the e2e post:
The error reads:
"Cannot proceed with the installation as the working directory set in HOME environment variable is invalid. Rerun the installation after setting a valid HOME environment variable."
Viktor.
Viktor,
Thank you for your interest in Pspice for TI.
We are sorry to hear you are having problems with your installation.
Pspice for TI does use a %HOME% variable path for placement of certain tool folders.
I am not certain how you would set that variable outside of the installation, but I will check and get back to you.
By the way, what operating system are you using?
John
Viktor,
One additional question: do you have administrator privileges on the machine you are using for the installation?
John
Hi John,
I am running Windows 10. I should have Admin access (It is a TI machine) and I also select the "Run as Administrator" option.
Viktor.
Viktor,
If you open Windows Explorer and type "%HOME%" in the path field, what is the resulting path?
For example, after installing many Cadence products, it is C:\Users\<EmpID>\AppData\Roaming\SPB_Data
where <EmpID> is my employee ID.
John
Bonjour ,
I download and install pspice but when i launch pspice i get that message " application did not succeed to start correctly ( 0xC000007B)
I tried too with administror acces , i get the same message.
Any idea ?
have a nice day .
Didier,
Thank you for your interest in Pspice for TI, and for the post.
I will check on the meaning of the error message and let you know what I find.
John
Didier,
As it turns out, the error message is from the operating system.
Pspice for TI has the following minimum system requirements:
If your system does not meet these conditions, that may be the problem.
If that is not the problem, please try rebooting your machine if you have not done so already.
Please let me know if you have any more questions or concerns.
John
Didier,
Have you been able to get Pspice for TI working?
Did rebooting the machine help?
Please let me know one way or the other, and please let me know if you have any questions.
John
